LT1677-AMPLIFIER O/P LOOKS WEIRED
Dear Team,
I am developing a circuit which will convert a DC value of 2.8V to a square wave of value 2.8V and 3.3V. This is done by using an opamp as an amplifier and a transistor is used to as a switch to do this.But I can see output is not proper and it changes the duty cycle of output wave form.My input is 50Khz 0 to 3.3V squre wave.
Please find the attached circuit diagram and output waveform  .Could you please help me how to solve this issue.
tagged
[edited by: JValeriani at 2:32 PM (GMT 0) on 14 Oct 2019]
  • Hi harianalog,
    Firstly, set the rise time and the fail time to 1 picosecond value. Secondly, increase value of capacitor. Please, look at my results:
    It meets your requirements?
    Kirill
  • Hi Kirill,
    Thank you very much.I need few clarifications.
    Please find the attached image.Green is output wave form and blue is input waveform
    Regards
    Hari
  • Hi Hari,
    Deceleration of pulse fronts is caused by time constants of RC networks. The overshoots is caused by the recharging of capacity between gate and drain. To test these hypotheses, I use a simple amplifier model with no frequency correction.
    Step 1: capacitance between gate and drain 5 pF
    If control pulse increases recharge current flows through resistive feedback network from V2 to op-amp output and causes negative overshoot. If control pulse decreases recharge current flows from op-amp output to V2 and causes positive overshoot.
    Step 2: capacitance between source and drain 5 pF
    This capacitance causes increasing of pulse fail time.
    Step 3: capacitance of correction causes increasing of rise and fail time at once
    Combination all capacitances:
    Note that this is only a qualitative illustration but not quantitative.
    Probably an analog switch can replace the transistor here. Consider this option.
    I hope that this help you.
    Kirill
  • Hi Krill,
    When I am simulating my complete system,I am getting an error.
    Could you please  tell me why. Please find the schematic and error log
    Regards
    Hari
  • Hi Hari,
    How did you add TLV7011 model to LTSpice library? Note that first three lines in log refer to U4 component, try to find error there.
    Update: I have tried add this model in LTSpice. Unfortunately, syntax of TLV model is not compatible with LTSpice software. Try to find the nearest analogue in ADI portfolio.
    Kirill
  • Hi Kirill,
    Yes that is the issue with the model.
    The circuit which we discussed is converting a 0V to 3.3V digital signal to 2.8V to 3.6V digital signal.
    Do You have any other method to accomplish the same.
    Regards
    Hari
