Driving AD9629 from ADA4940 for programmable input
I am using ADA4940-1 as differential ended unity gain amplifier for driving AD9629
 Now, as AD9629's Input differential voltage is 2Vp-p, I need to give programmable I/p (negative Sine wave) to the ADA4940's Inverting terminal.
For Ex:  If Non inverting terminal of ADA4940 (pin no :2) has input Voltage of 1Vp-p than there must be a negative 1Vp-p Sine wave  on inverting terminal (pin no :3)
    So,  If Non inverting terminal of ADA4940 (pin no :2) has input Voltage of 0.5Vp-p than there must be a negative 1.5 Vp-p Sine wave  on inverting terminal (pin no :3) to generate 2Vp-p for AD9629.
Is it so? And if it is then what must be good design approach for the same?
    You are correct on both of your examples. To know further about how your signal behaves on a differential amplifier you may want to use Diff-Amp Calculator that can be downloaded on this link. There is also an application note on it's features and how to use it. Diff-Amp Calc is an interactive design and parametric simulation tool that automates calculations critical for your design such as power dissipation, noise, input common-mode voltage and termination resistors.
    Goz
    Apologies, I was in the assumption of the signal being before on the gain resitsor(Rg). Your question is for the pins 2 and 3, it should be in phase and not complementary.
    Goz
  • Hello Gauzz,
    Thanks for your concern.
    I have already simulated in Diff-Amp. I want to know the best approach to deal with it when your Input is not known. In my design, I want to make it for general use. So at inverting input I want to put programmable Input which can balance my requirement of getting Output from ADA4940 as 2Vp-p so that it can be given to AD9629.
    That is when my I/p is 0.8Vp-p (at non-inverting terminal) ; I want to generate 1.2Vp-p at inverting terminal for getting differential output as 2 Vp-p.
    For more reference, i am attaching my ADA4940-1's schematic part:
    As shown below at non-inverting terminal Input is sine wave from 0.1Vp-p to 2Vp-p. so, what is good design approach to make inverting terminal's input sine wave programmable as per need?
  • Hi ,
    May be I am not making my query correctly.
    So, if 0.5Vp-p sine wave is at input pin 2 (non-inverting input) then for generating 2Vp-p differential output it must be 1.5Vp-p Complementary Sine wave at input pin 3 (inverting input) as per simulation in Diff-Amp Calc.
    So my question is how can I make inverting input programmable? May be I can use some DAC with FPGA for generating desired value's Sine wave or some other approach?
    Thanks.
