Using AD8450, when the PGIA is tested and set to 0 drift or 20mv, why is the output of PGIA always negative
Hi.
How negative was the output?
Are you using the evaluation board for this IC?
If possible please send us your schematic so we can evaluate further.
For the meantime, I recommend that you check the setting of the MODE pin first.
Shine
Thank you .However,I have a other question.When the charging and discharging current of lithium battery is higher than 10A, why does the output voltage fluctuate and the SS pin of ADP1972 also change?
Hi.
Thank you for your question. Unfortunately, we can only provide support to amplifier-related questions in this particular community.
Kindly address your question to the "Power by Linear" community in this link: https://ez.analog.com/power
Thank you very much,
Shine
Hi.
I'm sorry but can you still send us your schematic so we can evaluate your question better? I would like to know how AD8540 and ADP1972 are connected in your circuit.
Shine
你好,AD8450补偿设计工具怎么找,链接打开没有找到,能更加具体点吗?
Thank you.Why AD8450 compensation design tools, when using the software does not reflect?And Iknow
this PDF is used for calculation
