I would like to use the AD8436 to capture the output of the SCT-013 sensor and convert the rms to dc.
I took a look at the datasheet and saw that the input range is 100uV to 3V, on the other hand, the sensor output SCT-013 sensor is from 0V to 1V.
When I performed the simulation *, the rms output value did not correspond to the theoretical value. Especially the value differs in the input operation range from 0 to 1V.
I have consulted the datasheet and the EZ, but I still do not understand why this happens and if there is an error in the simulation or if the macro file could be wrong.
In any case, I would like to know if I can use the AD8436 with a single source for an input range of 0-1V at 50Hz.
* AD8436 SPICE Macro-model * Description: rms-DC Converter * Generic Desc: Low Coat Low Power True RMS-dc Converter * Developed by: MDC PRB IAP ADI * Revision History: 10/11/12, - Rev. C - Updated to new header style * 3.0 (09/2009) * Copyright 2012 by Analog Devices. * * Refer to http://www.analog.com/Analog_Root/static/techSupport/designTools/spiceModels/license/spice_general.html for License Statement. Use of this model * indicates your acceptance with the terms and provisions in the License Statement. * * BEGIN Notes: * * Not Modeled: Temperature effects * * Parameters modeled include: * * END Notes * * Node assignments * No Connect * | AC input to RMS core * | | Input Buffer Output * | | | Input Buffer Minus input * | | | | Input Buffer Positive Input * | | | | | Input Buffer Gain resistor * | | | | | | No Connect * | | | | | | | OGND * | | | | | | | | OUTPUT of RMS core * | | | | | | | | | Negative Supply * | | | | | | | | | | Half Supply Node * | | | | | | | | | | | Output Buffer Positive Input * | | | | | | | | | | | | Output Buffer Minus Input * | | | | | | | | | | | | | Output Buffer Output * | | | | | | | | | | | | | | Output Buffer Power Supply * | | | | | | | | | | | | | | | Input Buffer Power Supply * | | | | | | | | | | | | | | | | Positive Supply Rail * | | | | | | | | | | | | | | | | | Crest Factor Averaging * | | | | | | | | | | | | | | | | | | Averaging Capacitor * | | | | | | | | | | | | | | | | | | | Summing amplifier input node * | | | | | | | | | | | | | | | | | | | | .subckt AD8436 DNC RMS IBUFOUT IBUFINM IBUFINP IBUFGN DNC OGND OUT VEE IGND OBUFINP OBUFINM OBUFOUT OBUFVP IBUFVP VCC CCF CAVG SUM B2 0 OUT I=I(V16) R4 CCF 567 1k V16 567 0 0 R6 CCF CAVG 4k R1 IGND VEE 100k R2 VCC IGND 100k R7 OUT OGND 16k G1 0 N013 N015 IBUFINM 1 R5 N013 0 1e6 V6 N015 IBUFINP 0.5m I4 IBUFINP 0 25p I3 IBUFINM 0 25p R8 IBUFOUT IBUFINM 10k R16 IBUFINM IBUFGN 10k C2 IBUFOUT IBUFINM 10p G2 0 N008 N011 N010 1 R10 N008 0 1e6 C3 N013 0 10.1e-8 C4 N008 0 4.3e-7 R11 OBUFINM N010 16k I6 OBUFINP 0 1.5n I5 OBUFINM 0 1.5n V9 N011 OBUFINP 100u V8 VCCX N009 1.9 B3 IBUFVP VEE I=IF( (V(IBUFVP)-V(VEE) ) > 4.8, 160u, 0) B4 OBUFVP VEE I=IF( (V(OBUFVP)-V(VEE) ) > 4.8, 40u, 0) B5 VCC VEE I=IF( (V(VCC) - V(VEE) ) > 4.8, 325u, 0) E2 VCCX 0 VCC 0 1 E3 VEEX 0 VEE 0 1 G3 0 OBUFOUT N008 0 1 R12 OBUFOUT 0 1 C5 OBUFOUT 0 3.6e-7 G4 0 IBUFOUT N013 0 1 R13 IBUFOUT 0 1 C6 IBUFOUT 0 8.3e-8 R14 0 DNC 1e6 D1 N013 N014 D D2 N012 N013 D V5 VCCX N014 .875 V3 N012 VEEX .875 R9 IBUFINM 0 10e12 R15 IBUFINP 0 10e12 D3 N008 N009 D D4 N007 N008 D V7 N007 VEEX 0.88 G5 IGND N004 IGND SUM 1 R17 N004 IGND 1e6 *F1 0 N005 V12 1.00025 F1 0 N005 V12 .500125 C8 N004 IGND 2.62e-8 E4 N002 IGND N004 IGND 1 V12 SUM N001 0 D5 N001 N002 D D6 N002 N006 D V13 N006 SUM 0 *F2 0 N005 V13 .99975 F2 0 N005 V13 .499875 V11 N005 0 0 B1 0 CAVG I=I(V11)**2/ABS(I(V16)) R3 N003 RMS 8k V10 SUM N003 0 .model D D .IC V(CAVG)=.1n .end
