My customer is considering ADA 4627-1.
So I got a question.
What is the input voltage range and output voltage range
when ADA4627-1 is used with V + = + 5V and V- = -5V?
Yuya
Yuya
You need to stay 3V away from each rail, so -2V to +2V for Vout,
and 4.5V for the input, so +/-0.5V Vin.
Harry
Thank you for your answer.
As an additional question, is the headroom voltage and footroom voltage (3V away & 4.5V away from each rail) constant with the ADA4627-1 as the power supply voltage?
Best Regards,
Yuya
Pretty much.
