AD8606 About Amplifier and Fiter
AD8086 same as the figure,why use a 120pF capacitance and resistance in series parallel?Fiter or Offset?
and can you tell me  the reason why  not use a resistance in -INA pin?? how it going on??
add figure
[edited by: Dangfei at 2:41 AM (GMT -4) on 30 Aug 2018]
  • Hi Dangfei,
    May I know where did you get this circuit?
    Absolute maximum supply voltage of this part is 6V and therefore I recommend to limit the supply voltage to probably around 5.5V to avoid damaging this parts in case there is a transient happening on the supply lines.
    R56 is your feedback resistor (RF) and R57 is the gain resistor(RG). These two resistors dictate your gain. For inverting amplifier G = -RF/RG
    The C66 and R56 forms a lowpass filter which decreases the system gain at higher frequency due to the connections of the C66 which is parallel on the R56.
    Emman
