To make a simple signal generator based on ad9850, the op-amp used is lm224, but the limiting frequency is too low and the output frequency is low. If you want to change to a high-speed op amp, the requirement is the same as the lm224 pin, so that the software can be used directly. What are the replacements? The scheme?
