Question with regards to ADA4530-1
Hi ,
I have a number of questions with regard to ADA4350-1.
We are planning to get EVAL-CN0407 evaluation board to evaluate ADA4350-1.
I cannot see EVAL-CN0407-1-SDPZ board in buy list, is it possible to order only EVAL-CN0407-1-SDPZ for replacement.
Is the Shield included with EVAL-CN0407-SDPZ evalaution .
What is the test condition to replicate CN-0407 Figure 10 .
Thanking you
With best regards and wishes
    on Nov 27, 2019 2:58 AM over 1 year ago
    HI Kabekami,
    As of now, the EVAL-CN0407-1-SDPZ and EVAL-CN0407-2-SDPZ can only be purchased as a kit through
    EVAL-CN0407-SDPZ.
    To replicate the system noise shown on figure 10, you will be needing the EVAL-CN0407-1-SDPZ, EVAL-CN0407-2-SDPZ and EVAL-SDP-CS1Z.
    and for the setup please see the default setting for TIA described on Table 1 in the Circuit note document, the 10G glass resistor is installed in this setup. The software settings may also be found on page 7 of the document.
    The RF shields are included in the EVAL-CN0407-SDPZ package but the metal box described on the circuit note for further optimization of the system is not included.
    Hope this helps Kabekami.
    Best Regards,
    Dann
