Hello Analog Devices Team,
I am using the ADA4930-1 fully differential amplifier (FDA) to drive the AD9257-65 ADC. I would appreciate your guidance on selecting the appropriate circuit configuration and verifying its performance through simulation and hardware measurements.
Application details:
FDA: ADA4930-1.
ADC: AD9257-65, operating with a 1.8 V analog supply.
FDA supply: 5 V (Single supply)
Input signal: Single-ended, varying between 0.2 V and 2.8 V, with signal content in the 7.5–10 MHz range. The input consists of changing voltage levels rather than a continuous sinusoidal waveform.
Target differential output: 2 Vpp.
Intended gain: 0.7 V/V. However, I am unable to achieve the expected gain in hardware.
- 0.9V Vocm
Rf=1.4k,Rg=2k and isolation resistance at output of amplifier is 33ohm each side.
What load I can assume to simulate AD9257-65 in simulation and in hardware to separately test this Amplifier
Could you please advise on the following?
1. Circuit configuration and gain selection
What is the recommended ADA4930-1 configuration for converting my single-ended input into a differential signal for the AD9257-65?
Should I initially validate the circuit at unity gain before configuring it for a gain of 0.7 V/V?
How should I select the feedback resistors (Rf) and gain-setting resistors (Rg)? Should their values be equal, or should their ratio be adjusted to obtain the required gain?
What could cause the measured hardware gain to differ from the theoretical value?
How should I configure VOCM to meet the ADC input common-mode requirements?
2. Low-pass filter selection
What filter topology and cutoff frequency would you recommend between the ADA4930-1 and AD9257-65?
Since my signal content is in the 7.5–10 MHz range, how should I select the cutoff frequency to preserve the desired signal while attenuating unwanted high-frequency noise?
Should I use a differential RC filter at the ADC inputs? If so, how should I select the resistor and capacitor values?
How should I account for the filter's effects on signal attenuation, settling time, noise, and ADC input performance?
3. DC performance and gain accuracy
How can I measure gain accuracy, gain linearity, output offset, and offset variation using simulation and hardware measurements?
4. AC performance and bandwidth
How can I measure the −3 dB bandwidth, gain flatness, noise density, and distortion?
How should I perform AC analysis and interpret the Bode plot?
How can I determine whether the amplifier and filter provide sufficient bandwidth for my application?
5. Stability analysis and feedback capacitor
How can I evaluate loop stability, gain margin, phase margin, and frequency-response peaking?
Would adding a 1 pF feedback capacitor across Rf provide any benefit, or could it adversely affect bandwidth and transient response?
What is the recommended method for determining whether a feedback capacitor is required and selecting its value?
6. Transient and large-signal analysis
Since my input consists of changing voltage levels rather than a continuous sinusoidal waveform, how should I evaluate:
Step response, overshoot, ringing, and settling time.
Slew rate and large-signal bandwidth.
Distortion and output clipping.
Recovery following changes in input amplitude.
Response to input voltage changes across the 0.2–2.8 V range.
7. Output swing and ADC interface
How can I verify that the ADA4930-1 produces the required 2 Vpp differential output without clipping or excessive distortion? What measurements should I perform at the FDA outputs and ADC inputs to verify correct common-mode voltage, differential amplitude, and signal integrity?
8. Simulation and hardware validation
Could you please recommend a step-by-step procedure for analysing this complete interface using an appropriate Analog Devices simulation tool and validating the results on hardware?
I would particularly appreciate guidance on selecting the gain-setting resistors, filter cutoff frequency, and test conditions for verifying DC accuracy, AC performance, stability, and transient response.
Thank you for your support.
