ad8130 always seems to be out of stock, is there an alternate to this IC ?
Strong EMC design
AD8130
Production
The AD8129/AD8130 are designed as receivers for the transmission of high speed signals over twisted-pair cables to work with the AD8131 or AD8132 drivers...
Datasheet
AD8130 on Analog.com
Hi MGK,
AD8130 is a differential receiver amplifier, so the best alternative depends on how it is being used in your design. AD8129 is the closest related device within the same product family, while newer differential amplifier families such as AD8139 or ADA4945-1 may also be suitable depending on the required bandwidth, gain, supply voltage, and input/output signal configuration. Could you provide the application schematic or key operating requirements so a more appropriate replacement can be recommended?
Best Regards,
Ian
Hello Ian, Thanks for the update.
AD8130 is used for doing differential to single ended conversion. unity gain. operating RF frequency 3.5Mhz. attaching schematic snippet. which is the closest and best alternate ? can you give the part and LTspice schematic.
Hi MGK,
Thank you for providing the schematic and additional details.
I believe AD830 can be potential alternative for differential to single ended conversion. Could you also provide the expected differential input amplitude and common-mode voltage at sense_p_buff and sense_n_buff? This will help verify whether the AD830 input range is suitable for your application.
Best Regards,
Ian
