September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
AD8128
Production
The AD8128 is a high speed, differential receiver/equalizer that
compensates for the transmission losses of unshielded twisted pair
(UTP) CAT-5 cables...
Datasheet
AD8128 on Analog.com
I would like to use AD8128 in my CVBT receiver over CAT5.
My quesions are.
1. How properly connect isolation transformer with AD8128 Inputs?
2. May I use single supply +10V?
3. How to provide bias AD8128 for single supply operation? Using half of VS+ applied to transformer central tap? Any other options?
4. Any reference design available?
5. LTspice model availability?
-- Best Regards
Victor
PoornimaSubramani - Moved from Video to Differential Amplifiers and ADC Drivers. Post date updated from Friday, February 14, 2025 11:36 AM UTC to Friday, February 14, 2025 1:18 PM UTC to reflect the move.
It seems that AD8128 is not well documented and supported...
Any alternative solution with cable equalisation available?
I need receive CVBS video over CAT5 cable with length 100+ meters.
Transformer isolation is mandatory. Single supply ~10V highly desirable.
Are there any ADI FAE`s here? Or all fired?
Apologies for the lack of a response. (Here from LTspice team/forum). I don't see an LTspice model for this. To reach someone to answer your tech questions, you might be able to reach someone at the numbers listed here:
https://www.analog.com/en/support.html
mike
