I want to design that uses the AD8336.
The "NC" pin in the figure of the datasheet is grounded. But the note below the figure is "DO NOT CONNECT TO THIS PIN". What should I do?
AD8336
Production
The AD8336 is a low noise, single-ended, linear in dB, general-purpose variable gain amplifier, usable over a large range of supply voltages. It features...
Datasheet
AD8336 on Analog.com
Hello LiXq ,
I would suggest to follow the schematic on the datasheet and connect NC pins to ground plane. Those pins have no internal connections and we usually ground it for additional thermal dissipation unless stated on the datasheet.
Best Regards,
Kenneth
