I would like to implement AAF (as a LPF) at the output of ADC driver, the MPN is ADA4930. The filter characteristic is depended on its input impedance. There are output resistors 22R at Out+ and Out-, but to get proper simulation results I need to know internal output resistance of ADA4930. Can you estimate the output resistance? Or is it significantly lower than 22Ohm?
