I want to use the AD629 with a 24V single supply and a 2.5V reference voltage.
My common mode voltage is positive only with a maximum of 60V.
Is this possible?
September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
AD629
Production
The AD629 is a difference amplifier with a very high input, common-mode voltage range. It is a precision device that allows the user to accurately measure...
Datasheet
AD629 on Analog.com
Is this possible?
HI mkhw
The common mode voltage range with a maximum of 60V is possible.
The new VCM can be calculated based on the formula:
VCM (±) = 20 VX/VY(±) − 19 VREF
This single supply operation is explained on p.11 of the datasheet
Hope that helps.
JE
