HI,
I have been trying to simulate the noise of the LTC6362 and I would like to compare the results with the datasheet of the component.
from the datasheet I can see that the common mode noise is 14.3nV/rtHz.
HOwever, if I measure the noise from one of the output of the FDA in buffer configuration I do not get this value at 100kHz. HEre below my simulation :
Simulation results show that the common mode noise at 100kHz is 55nV/rtHz, am I right? or am i interpreting the results in a wrong way?
Unfortunately the LTC6362 spice model is built in in LTSPICE and the sub file is encripted, so i cannot check the implementation.
Any tips?
