LTC6404 - Exposed Pad
I am wondering where to connect the Exposed Pad to? The datasheet says connect to V- and do not connect to ground if split power supplies are used. (But Ground and V- are the same in my design)
My design has the same power source connected to all of the V+ and V- Pins.
Is there any use to the Exposed pad beside transferring heat away from the chip?
Is there a problem if it is floating and not connected?
Hope you can help me.
Best regards
