I'm using this opamp , only one of the four available for now in order to develop an inverting integrator. I'm using this configuration
The problem is that if I use a 50 Hz sinusoidal input with a vrms amplitude which ranges from 100mv to 2v I see a gain wich varies of 2%.
In my project I can't have this. May you help me? I have made the circuit on breadboard and pcb but the problem is there. May you send me the best layout in order to avoid this problem?
Thanks in advance.
Best regards
