MFB Antialiasing Filter Problem AD8137/ADA4932
Hi all,
I created a lowpass 3-pole Antialiasing Filter in MFB fully differential Topology to drive a differential ADC. The cutoff frequency is 30kHz and the Gain is 11.
When I use the AD8137 for the filter the output of the AD8137 is oscillating at 180MHz when I switch on the supply voltage.
The feedback capacitor is 1nF, is the feedback capacitance to huge for the AD8137? I reduced the Gain to 1, but the output ist still oscillating.
When I add a resistor in series to the capacitor  to prevent oscillation it works fine.
When I use the ADA4932 for the filter the output doesn't oscillate and I don't need a series resistor. When do I need a resistor to prevent oscillation?
Why is the output oscillating with the AD8137 and why not with the ADA4932?
When I simulate both filters in Spice they work fine.
What must I consider in designing of active fully differential filters / choosing the right differential amplifier for my application?
Thanks
Michael
MFB_Spice.pdf
Parents Reply Children
No Data
