Good day,
Can the AD8215 handle a negative sense current, i.e. what is the maximum negative differential voltage the AD8215 can handle between the IN+ & IN- pins? I could not find a clear answer in the datasheet.
Application:
I'm using the AD8215 to sense charge current of Li-Ion battery, however when not charging, there will be a small reverse current to keep the MCU alive. I don't need to measure this current, I just need to know that the AD8215 is OK with it, i.e. what the electrical limits are.
Rean Bootsma
