Simulation problem- LTspice model of ADA4930-1
Product Number: ADA4930-1
I need single to differential Amp, low noise and abut 1MHz to 200MHz, G=1.
I found this amplifier, I performed a simulation in the Diff-Amp Calculator software and it looks good, but the LTspice simulation I don't see that the model works for me accordingly.
 Diff-Amp Calculator:
LTspice: The G is not 1, the amplifier fails me for some reason.
Thanks
Barak
fix
[edited by: Barak at 4:23 PM (GMT -4) on 12 Mar 2023]
Parents
  • Hi Barak,
    The ADA4930-1 is only operational up to 5V supply.
    The Diff Amp calculator software also gives this warning on your configuration (you configured it to +/-5V or 10V single-supply equivalent).
    I attached a sample circuit with a gain of 1 based on your configuration. I set the Vocm to 2.5V though.
    please see and let us know if you have more questions.
    ADA4930-1_test.asc
    Hope this helps.
    Best Regards,
    Dann
Reply
  • Hi Barak,
    ADA4930-1_test.asc
    Hope this helps.
    Best Regards,
    Dann
Children
No Data
