8th order bandpass with LTC1562 and Total Q value
I want to design 8th bandpass filter with LTC1562. I can calculate Q1..Q4 values from datasheet but I don't find total Q and bandwidth.
There is some quick design formulas for bandwidth=-3dB  & Q=10 on page 16 in datasheet but I need different Q ve BW values.
Please can you show me how I can calculate?
thanks
  • hello again,
    Are the following calculations correct approximately ?
    if gain and Q  of four stages are same,   for example, if gain is 1 and Q is 4
    total gain =1 (G1*G2*G3*G4)
    get center Frq=100khz, stage1: BW= 100Khz / 4 = 25Khz ( fH=125Khz,fL=75Khz but amplitude decreases -3dB)
    end of stage4 : -3dB*4=- 12dB so
    ( at fH=125Khz, at fL=75Khz but amplitude decreases -12dB) ,
    for  new BW at -3dB
    I found BW=25Khz at -3dB,
     for new BW, can I say  25Khz/4=6-7Khz? (-12dB/-3dB=4, Assuming linear )
    BW=93Khz--107Khz (-3dB)
    on May 10, 2021 8:25 AM
    Hi Kutay,
    Apologies for missing thing item. We will look into this, I'll contact the product owner and get back to you. Thank you!
