ADA4350 SPI
Can several ADA4350 devices be daisy chained together, with  SDO of one device connected to the SDI of the next one?
    on Oct 21, 2019 9:46 AM
    Yes, kindly refer to page 13 and 14 for the timing diagram. See t11 for the daisy chain timing. May I know how many ADA4350 you would daisy chain? And also what your application might be.
    Goz
  • I will be putting up to 16  devices in the chain.  This is for interfacing to a photodiode array.
    My plan for writing to the ADA4350 chain would be:
    - connect CS/, LATCH/, and SCLK to all devices in parallel.
    - set LATCH/ high,  send 16 groups of 24 bits to the SDI of the first device,  framing  each group by toggling CS/ as per Fig. 2.
    -toggle LATCH/ to load all devices.
    For reading :  Not sure how this will work
    - set LATCH/ high, send 16 groups of 24 bits with only the Read/Write bit set to 1, framing  each group with CS/.
    - toggle LATCH/ to put all devices in Read mode.
    - set LATCH/ low and send 16 groups of 24 bits,  (NOP command = all 0 ?) framing each group with CS/,  and capturing thedata clocked out of SDO from the last device in the chain.
    Thank you for your help with this.
