LT6200 Shutdown pin
Can i left floating the shutdown pin? If i don't use a pull up resistor, will I have a problem about EMI?
Thank you.
tagged
[edited by: JValeriani at 2:09 PM (GMT 0) on 14 Oct 2019]
    A small amount of scarce information can be extracted directly from the datasheet:
    If this mode is used in testing, it is quite acceptable, in my opinion. To not have problems with EMI without pull up resistor just try adding a capacitor between ground and this pin.
    I hope that this help you.
    Kirill
