Inconsistent Input Current Noise Density of AD8627 LTSpice Model
I am trying to use the Spice model for the AD8627, that I found on the AD website here:
https://www.analog.com/en/products/ad8627.html#product-overview
The specification on the datasheet for this op amp is 0.5 fA/√Hz at 1 kHz, but this is not what I measure from the model. I am measuring the input current nosie following the method suggested here:
https://e2e.ti.com/blogs_/b/analogwire/archive/2017/12/04/trust-but-verify-spice-model-accuracy-part-6-voltage-noise-and-current-noise
The method consists of placing a current-controlled voltage source in series with the input of the op amp, to be able to convert the op amp's current noise into a voltage noise that can be measured. When doing this, I measure 7.2 fA/√Hz at 1 kHz, instead of 0.5. I have attached a screenshot, because I could not upload the asc file for some reason.
Where does this inconsitency come from?
