About AD8599
1. We are using the AD8599 at ± 15V.  When the room temperature is 25 ° C, device temperature  is 80 ° C. Are these normal?
    Can you attach your schematic to verify whether this is in normal operation. Assuming the part is operated at ± 15V supply, ambient temperature and buffer configuration. The products junction temperature should only be around 66degC using the formula:
    Tj = Pd x thetaJA + Ta
    where:
     Tj = Junction temp
    Pd = power dissipation
    thethaJA = junction to ambient thermal resistance
    Ta = ambient temp
    You can learn more about this with this article.
    Goz
