OP97 / OP07 spice models
I have a bunch of OP97 op amps that I'm trying to simulate in LTSPICE-  so I have a few questions:
1) Why is this not found in the LT SPICE library?  Or anywhere else ?
2) Can I use the OP07 as a simulation model instead?
3)  When using an existing spice model such as OP07,  I can't see anything inside the model,  like what parameters it is simulating with.  Is that intended?  I know for example, I can look at parameters like beta, etc, for a transistor and even change it, sweep it, whatever.
Thank you in advance
