How to decode Temperature and humidity value from Bunch sensor board that is seen at AnodeCP GUI?
for eg: Temp data(4 bytes) : B3 87 BB 41 . How does it correspond to a temperature in C or F?
            Humidity data(4 bytes) : A8 C2 90 42 . How does it correspond to a %RH?
 Similarily for XL362 , how to decode bytes into meaningful x,y,z co-ordinates?
  • Hi Samanwaya, These float values formatted in IEEE754 format and are stored in little endian.
    So, the Temp data is actually 41 BB 87 B3 in hex. This is equivalent to 23.44 deg.C
    Use this calculator for reference.
    We have provided an API convertieee754() in file ADSensors/src/convert.c file. You can use this to convert this hex value to actual sensor data.
    Hope this helps.
