Hi
The ADALM1000 documentation states that the device is able to measure a maximum of 200mA of current.
What is the minimum detectable current the ADALM1000 can measure?
Thanks in advance!
Hi
Thanks in advance!
Hi:
The same 16 bit ADC is used for the current measurements. Given the +/- 200 mA range ( 400 mA total ) the ADC LSB would be 400mA/65536 or 6 uA. However there is much more noise in the current sensor amplifier than this and you will not see down to the ADC LSB level. With a little averaging what I generally see is the value flickering about 100uA. Or about 12 bit resolution.
Doug
