Hi Everyone,
I bricked pluto SDR rev. D. Could you please help me out?
Main errors: Unsupported flash IDs: manuf 00, jedec 0000, ext_jedec 0000
Failed to create SPI flash at 0:0:40000000:0.
Environment: Ubuntu 24.04.01 LTS, Vivado 2024.2.
Description:
1. I changed the vivado project file (below link) to have my own system_top.xsa file.
github.com/.../pluto
2. Then I changed the makefile (below link) to make it suitable for my environment. Other than changing Vivado version, I also changed the way the system_top.xsa generated also as below. Basically I only let it copy .xsa from the one generated in Step 1.
https://github.com/analogdevicesinc/plutosdr-fw/blob/master/Makefile
build/system_top.xsa: | build
cp system_top.xsa build/system_top.xsa
3. I put the generated .zip to pluto massive storage device folder, eject it. And wait for Pluto USB storage showing up. However it was bricked from then.
I followed unbricking PlutoSDR from below link but got no luck. Instead of using xmd commands, I used xsct in plutosdr-jtag-bootstrap-v0.39 folder terminal.
https://wiki.analog.com/university/tools/pluto/devs/fpga
I only did some change on run.tcl as below link.
https://drive.google.com/file/d/1xUFtYO7vLalACkQV8CV56cOJrkMeuUzY/view?usp=drive_link
Then I plugged in the USB-UART cable into host PC, this is lsusb and the u-boot menu. The errors say SF: Unsupported flash IDs: manuf 00, jedec 0000, ext_jedec 0000
I cannot solve this, could anyone please help?
From start to end, only the left LED is on and dim.
