Software for EVAL-CN0566-RPIZ is not operational.
Product Number: CN0566
To whom it may concern,
I purchased an Analog Devices EVAL-CN0566-RPIZ on November 25, 2024 (Web Reference No. 2002571687; Order #1001171453), and the order was received on December 4, 2024.  I finally had time to open the package on December 28, 2024 to begin setup and evaluation of the received hardware.
I was disappointed that the 6-inch USB-to-Mini USB cable was not sent with the unit to connect the ADALM-Pluto to the Raspberry Pi, so a replacement cable was purchased from Amazon Prime.  Next, the DFRobot HB100 Gravity: Digital 10.525GHz Microwave Sensor (Motion Detection) was Dead on Arrival and had to be replaced with a new unit ordered from Digikey.  The replacement HB100 worked perfectly when connected to a power source.
The September 6, 2024 edition of the EVAL-CN0566-RPIZ Quick Start Guide (https://wiki.analog.com/resources/eval/user-guides/circuits-from-the-lab/cn0566/quickstart) was followed to begin the setup and evaluation of the hardware.  This document was approved for release on Sept 6, 2024 by ADI Engineer Mark Thoren.  It appears as though Mr. Thoren did not work through the document to validate its contents before releasing the document.    The instructions in the document have problems that I need assistance resolving, which is the reason for this post.
Regardless, the first step after the hardware is assembled is to load Kuiper Linux 2021_R2 onto the SD Card.  However, the security certificates for Kuiper Linux 2021_R2 have expired, so the required software cannot be downloaded from Github.  Therefore, Kuiper Linux 2023_r2 had to be used for the system software.
The following script documents the updates to Kuiper Linux 2023_r2:
 login as: analog
analog@analog.local's password:
Linux analog 6.1.54-v7l+ #1 SMP Tue Nov  5 15:29:09 UTC 2024 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Nov  8 15:05:19 2024
Wi-Fi is currently blocked by rfkill.
Use raspi-config to set the country before use.
analog@analog:~ $ wget github.com/.../phaser_sdcard_setup.sh
--2025-01-04 13:14:14--  github.com/.../phaser_sdcard_setup.sh
Resolving github.com (github.com)... 140.82.112.4
Connecting to github.com (github.com)|140.82.112.4|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: raw.githubusercontent.com/.../phaser_sdcard_setup.sh [following]
--2025-01-04 13:14:15--  raw.githubusercontent.com/.../phaser_sdcard_setup.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.108.133, 185.199.110.133, 185.199.111.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.108.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 2781 (2.7K) [text/plain]
Saving to: ‘phaser_sdcard_setup.sh’
phaser_sdcard_setup 100%[===================>]   2.72K  --.-KB/s    in 0.004s
2025-01-04 13:14:15 (641 KB/s) - ‘phaser_sdcard_setup.sh’ saved [2781/2781]
analog@analog:~ $ sudo chmod +x phaser_sdcard_setup.sh
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
    #1) Respect the privacy of others.
    #2) Think before you type.
    #3) With great power comes great responsibility.
[sudo] password for analog:
analog@analog:~ $ ./phaser_sdcard_setup.sh
Sat 04 Jan 2025 01:14:59 PM GMT
Get:1 archive.raspberrypi.org/debian bullseye InRelease [39.0 kB]
Get:2 raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
Get:3 raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13.2 MB]
Get:4 archive.raspberrypi.org/debian bullseye/main armhf Packages [329 kB]
Get:5 raspbian.raspberrypi.org/raspbian bullseye/non-free armhf Packages [107 kB]
Fetched 13.7 MB in 6s (2,203 kB/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
53 packages can be upgraded. Run 'apt list --upgradable' to see them.
--2025-01-04 13:15:10--  github.com/.../config_phaser.txt
Resolving github.com (github.com)... 140.82.114.4
Connecting to github.com (github.com)|140.82.114.4|:443... connected.
Location: raw.githubusercontent.com/.../config_phaser.txt [following]
--2025-01-04 13:15:10--  raw.githubusercontent.com/.../config_phaser.txt
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.109.133, 185.199.111.133, 185.199.110.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.109.133|:443... connected.
Length: 2402 (2.3K) [text/plain]
Saving to: ‘config_phaser.txt’
config_phaser.txt   100%[===================>]   2.35K  --.-KB/s    in 0s
2025-01-04 13:15:13 (6.34 MB/s) - ‘config_phaser.txt’ saved [2402/2402]
--2025-01-04 13:15:13--  github.com/.../iiod-usb@.service
Location: raw.githubusercontent.com/.../iiod-usb@.service [following]
--2025-01-04 13:15:13--  raw.githubusercontent.com/.../iiod-usb@.service
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.108.133, 185.199.109.133, 185.199.111.133, ...
Length: 253 [text/plain]
Saving to: ‘iiod-usb@.service’
iiod-usb@.service   100%[===================>]     253  --.-KB/s    in 0s
2025-01-04 13:15:13 (3.03 MB/s) - ‘iiod-usb@.service’ saved [253/253]
--2025-01-04 13:15:13--  github.com/.../89-pluto.rules
Location: raw.githubusercontent.com/.../89-pluto.rules [following]
--2025-01-04 13:15:14--  raw.githubusercontent.com/.../89-pluto.rules
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.110.133, 185.199.108.133, 185.199.109.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.110.133|:443... connected.
Length: 325 [text/plain]
Saving to: ‘89-pluto.rules’
89-pluto.rules      100%[===================>]     325  --.-KB/s    in 0s
2025-01-04 13:15:14 (2.85 MB/s) - ‘89-pluto.rules’ saved [325/325]
--2025-01-04 13:15:18--  github.com/.../hosts_phaser
Resolving github.com (github.com)... 140.82.112.3
Connecting to github.com (github.com)|140.82.112.3|:443... connected.
Location: raw.githubusercontent.com/.../hosts_phaser [following]
--2025-01-04 13:15:18--  raw.githubusercontent.com/.../hosts_phaser
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.111.133, 185.199.110.133, 185.199.108.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.111.133|:443... connected.
Length: 126 [text/plain]
Saving to: ‘hosts_phaser’
hosts_phaser        100%[===================>]     126  --.-KB/s    in 0s
2025-01-04 13:15:18 (3.26 MB/s) - ‘hosts_phaser’ saved [126/126]
--2025-01-04 13:15:18--  github.com/.../hostname_phaser
Location: raw.githubusercontent.com/.../hostname_phaser [following]
--2025-01-04 13:15:19--  raw.githubusercontent.com/.../hostname_phaser
Length: 7 [text/plain]
Saving to: ‘hostname_phaser’
hostname_phaser     100%[===================>]       7  --.-KB/s    in 0s
2025-01-04 13:15:19 (76.8 KB/s) - ‘hostname_phaser’ saved [7/7]
--2025-01-04 13:15:20--  github.com/.../pluto_update_ad9361.sh
Location: raw.githubusercontent.com/.../pluto_update_ad9361.sh [following]
--2025-01-04 13:15:20--  raw.githubusercontent.com/.../pluto_update_ad9361.sh
Length: 671 [text/plain]
Saving to: ‘pluto_update_ad9361.sh’
pluto_update_ad9361 100%[===================>]     671  --.-KB/s    in 0s
2025-01-04 13:15:20 (11.7 MB/s) - ‘pluto_update_ad9361.sh’ saved [671/671]
Found existing installation: pyadi-iio 0.0.18
Uninstalling pyadi-iio-0.0.18:
  Successfully uninstalled pyadi-iio-0.0.18
Cloning into 'pyadi-iio'...
remote: Enumerating objects: 33883, done.
remote: Counting objects: 100% (276/276), done.
remote: Compressing objects: 100% (133/133), done.
remote: Total 33883 (delta 196), reused 147 (delta 143), pack-reused 33607 (from 3)
Receiving objects: 100% (33883/33883), 78.65 MiB | 16.06 MiB/s, done.
Resolving deltas: 100% (28159/28159), done.
Already on 'main'
Your branch is up to date with 'origin/main'.
Looking in indexes: https://pypi.org/simple, www.piwheels.org/simple
Processing /home/analog/pyadi-iio
  Installing build dependencies ... done
  Getting requirements to build wheel ... done
    Preparing wheel metadata ... done
Requirement already satisfied: numpy>=1.20 in /usr/local/lib/python3.9/dist-packages (from pyadi-iio==0.0.19) (2.0.2)
Requirement already satisfied: pylibiio>=0.25 in /usr/local/lib/python3.9/dist-packages (from pyadi-iio==0.0.19) (0.25)
Building wheels for collected packages: pyadi-iio
  Building wheel for pyadi-iio (PEP 517) ... done
  Created wheel for pyadi-iio: filename=pyadi_iio-0.0.19-py3-none-any.whl size=186003 sha256=818129eec03e5fa62d0a96d35a886664d0eb5fb6fb92ce6dcd9556569c42beb4
  Stored in directory: /root/.cache/pip/wheels/7a/03/46/64e26b0c298ae5f42d027305c05e7893509eb3acc0f58c7ba8
Successfully built pyadi-iio
Installing collected packages: pyadi-iio
Successfully installed pyadi-iio-0.0.19
Requirement already satisfied: pyqtgraph in /usr/lib/python3/dist-packages (0.11.1)
Collecting pyqtgraph
  Downloading www.piwheels.org/.../pyqtgraph-0.13.7-py3-none-any.whl (1.9 MB)
     |████████████████████████████████| 1.9 MB 261 kB/s
Requirement already satisfied: numpy>=1.22.0 in /usr/local/lib/python3.9/dist-packages (from pyqtgraph) (2.0.2)
Installing collected packages: pyqtgraph
  Attempting uninstall: pyqtgraph
    Found existing installation: pyqtgraph 0.11.1
    Not uninstalling pyqtgraph at /usr/lib/python3/dist-packages, outside environment /usr
    Can't uninstall 'pyqtgraph'. No files were found to uninstall.
Successfully installed pyqtgraph-0.13.7
The following NEW packages will be installed:
  sshpass
0 upgraded, 1 newly installed, 0 to remove and 53 not upgraded.
Need to get 11.9 kB of archives.
After this operation, 32.8 kB of additional disk space will be used.
Get:1 raspbian.mirror.axinja.net/raspbian bullseye/main armhf sshpass armhf 1.09-1 [11.9 kB]
Fetched 11.9 kB in 1s (15.2 kB/s)
Selecting previously unselected package sshpass.
(Reading database ... 184150 files and directories currently installed.)
Preparing to unpack .../sshpass_1.09-1_armhf.deb ...
Unpacking sshpass (1.09-1) ...
Setting up sshpass (1.09-1) ...
Processing triggers for man-db (2.9.4-2) ...
--2025-01-04 13:16:45--  github.com/.../plutosdr-fw-v0.38.zip
Resolving github.com (github.com)... 140.82.113.4
Connecting to github.com (github.com)|140.82.113.4|:443... connected.
Location: objects.githubusercontent.com/.../64fca00a-c4f5-4e0b-9699-4d9fa5de236a [following]
--2025-01-04 13:16:46--  objects.githubusercontent.com/.../64fca00a-c4f5-4e0b-9699-4d9fa5de236a
Resolving objects.githubusercontent.com (objects.githubusercontent.com)... 185.199.108.133, 185.199.109.133, 185.199.111.133, ...
Connecting to objects.githubusercontent.com (objects.githubusercontent.com)|185.199.108.133|:443... connected.
Length: 23276876 (22M) [application/octet-stream]
Saving to: ‘plutosdr-fw-v0.38.zip’
plutosdr-fw-v0.38.z 100%[===================>]  22.20M  27.5MB/s    in 0.8s
2025-01-04 13:16:47 (27.5 MB/s) - ‘plutosdr-fw-v0.38.zip’ saved [23276876/23276876]
Done setting up SD card! A reboot is probably in order, sor run 'sudo reboot'
IF you are very sure you're only going to be operating headless or by command line and want to speed the boot / shutdown process, run:
sudo systemctl disable x11vnc.service
And then set the Pi to boot to CLI in either the GUI or CLI Raspi-config tool.
analog@analog:~ $ sudo reboot
analog@phaser:~ $ cd ~/pyadi-iio/examples/phaser
analog@phaser:~/pyadi-iio/examples/phaser $ python phaser_find_hb100.py
A module that was compiled using NumPy 1.x cannot be run in
NumPy 2.0.2 as it may crash. To support both 1.x and 2.x
versions of NumPy, modules must be compiled with NumPy 2.0.
Some module may need to rebuild instead e.g. with 'pybind11>=2.12'.
If you are a user of the module, the easiest solution will be to
downgrade to 'numpy<2' or try to upgrade the affected module.
We expect that some modules will need time to support NumPy 2.
Traceback (most recent call last):  File "/home/analog/pyadi-iio/examples/phaser/phaser_find_hb100.py", line 50, in <module>
    import matplotlib.pyplot as plt
  File "/usr/lib/python3/dist-packages/matplotlib/__init__.py", line 174, in <module>
    _check_versions()
  File "/usr/lib/python3/dist-packages/matplotlib/__init__.py", line 159, in _check_versions
    from . import ft2font
AttributeError: _ARRAY_API not found
    _check_versions()
ImportError: numpy.core.multiarray failed to import
As you can see, the code downloaded from Github (https://github.com/thorenscientific/rpi_setup_stuff/raw/main/phaser/phaser_sdcard_setup.sh) is not compatible with Kuiper Linux 2023_r2, so the code must be updated or modified to work with Kuiper Linux 2023_r2.  Where on Github can I download the correct revision of the code to work with Kuiper Linux 2023_r2, or can anyone provide me with step-by-step instructions to make the necessary changes to the code?
I am looking forward to your timely reply.
Respectfully,
Scott
Dr. Scott Best
Chief Technology Officer
SiberSci, LLC
https://sibersci.com
  • Hi Scott, in the future you can just post the error that you're seeing.  And oftentimes a search for that error on ez.analog.com will uncover the solution.  Mark does an outstanding job helping us use Phaser and its software.  Sometimes libraries change and some engineering debug is necessary.  Mark has addressed the numpy issue found with the new version of Kuiper here:
     ADALM-PHASER Example Python Code Not Working
  • Dear Jon,
    Thanks for the reply, but I did not find a solution to my problem in this post ( ADALM-PHASER Example Python Code Not Working).  Is the solution to my problem for Kuiper Linux 2023_r2 located in another post?
    Scott
  • Hi Scott,
    I just updated the wiki page, adding a link to the 2021_r2 Kuiper release:
    https://wiki.analog.com/resources/eval/user-guides/circuits-from-the-lab/cn0566/quickstart?rev=1736188126#sd_cardsoftware_setup
    What happened was newer versions of Kuiper also have a newer version of Matplotlib.
    Did you try this, noted toward the end of the  ADALM-PHASER Example Python Code Not Working thread?:
    sudo pip install --force-reinstall numpy==1.22
    This should get your 2023_r2 card working.
    Also could you clarify "However, the security certificates for Kuiper Linux 2021_R2 have expired, so the required software cannot be downloaded from Github"? Is this a problem downloading the image, or running the setup script?
    -Mark
  • Dear Kevin,
    I downloaded and installed Kuiper Linux 2023_r2 from https://swdownloads.analog.com/cse/kuiper/image_2024-11-08-ADI-Kuiper-full.zip, which was used for demonstrating that it is not compatible with the Python codes, so an update is needed.
    Kuiper Linux 2021_r2 can be obtained from https://swdownloads.analog.com/cse/kuiper/image_2023-04-02-ADI-Kuiper-full.zip, and cannot be updated with the Gihub link because the security certificates have expired.
    Every available version of Kuiper Linux can be obtained online at https://wiki.analog.com/resources/tools-software/linux-software/adi-kuiper_images/release_notes.
    The URL you provided, https://swdownloads.analog.com/cse/kuiper/image_2023-04-02-ADI-Kuiper-full.zip, cannot be used since the security certificates have expired, so downloads from Github are refused for this reason.  This is why I used Kuiper Linux 2023_r2.  What do I need to do to make Kuiper Linux 2023_r2 compatible with the Python codes for using the system?
    Respectfully,
    Scott
  • Hi Scott,
    Try running this command:
    This will downgrade the numpy version and should fix the compatibility issue.
    -Mark
  • Also I just downloaded 2021_r2, burned a fresh SD card, and ran the setup script. It went cleanly, with no errors.
    Can you paste the exact errors you're seeing that are related to expired security certificates?
    -Mark
  • Dear Kevin, Mark, and Jon,
    Please accept my apology for the late reply, but the snow and ice storm in Western Kentucky have impeded work on several projects.  Arctic air arrives today, so the next few days will be a lot colder than normal, so hopefully, we do not lose power or Internet access.
    Let’s start by benchmarking the system before the change you suggested on Monday, January 6, is implemented.  Here is how the original system behaves for the following two commands:
        _check_versions()
        _check_versions()
    The following can now be made to the system per your e-mail on Monday, January 6, 2025:
    analog@phaser:~/pyadi-iio/examples/phaser $ sudo pip install --force-reinstall numpy==1.22
    Collecting numpy==1.22
      Downloading www.piwheels.org/.../numpy-1.22.0-cp39-cp39-linux_armv7l.whl (12.9 MB)
         |████████████████████████████████| 12.9 MB 11 kB/s
    Installing collected packages: numpy
      Attempting uninstall: numpy
        Found existing installation: numpy 2.0.2
        Uninstalling numpy-2.0.2:
          Successfully uninstalled numpy-2.0.2
    Successfully installed numpy-1.22.0
    Attempting to connect to CN0566 via ip:localhost...
    Found CN0566. Connecting to PlutoSDR via default IP address...
    PlutoSDR connected.
    Peak frequency found at  10.415078125  GHz.
    You may need to close plot to continue...
    Save cal file? (y or n)y
    -bash: analog@phaser:~/pyadi-iio/examples/phaser: No such file or directory
    -bash: [sudo]: command not found
    -bash: Looking: command not found
    -bash: Collecting: command not found
    -bash: syntax error near unexpected token `('
    -bash: syntax error near unexpected token `|'
    -bash: Installing: command not found
    -bash: Attempting: command not found
    -bash: Found: command not found
    -bash: Uninstalling: command not found
    -bash: Successfully: command not found
    If I run the VNC Viewer app, I am able to see the following spectral graph:
    The Calibration routine can also be successfully completed:
    python phaser_examples.py cal
    Can you provide any information for how to use the Python codes with the default Kuiper Linux 2023_r2?  Do you have step-by-step instructions for compiling the Python codes to work with the default Kuiper Linux 2023_r2 configuration?
    Scott
  • Dear Mark,
    I downloaded a copy of Kuiper Linux 2021_r2 from https://swdownloads.analog.com/cse/kuiper/image_2023-04-02-ADI-Kuiper-full.zip, and uploaded the image to a SD Card using rufus_4-6 (https://rufus.ie/downloads/#google_vignette).
    Here are the startup screenshots and dialogue for Kuiper Linux 2021_r2:
    Running the first command creates the expired security certificate problem:
    Wget https://github.com/thorenscientific/rpi_setup_stuff/raw/main/phaser/phaser_sdcard_setup.sh
    --2023-04-02 21:46:40--  github.com/.../phaser_sdcard_setup.sh
    ERROR: The certificate of ‘github.com’ is not trusted.
    ERROR: The certificate of ‘github.com’ is not yet activated.
    The certificate has not yet been activated
    Does this help with resolving the problem with attempting to use Kuiper Linux 2021_r2?  If not, what additional information do you need from me?
    Scott
  • A little googling led me to two non-EZ forum discussions with potential solutions to the Github certificate issue:
    DeandrePetersen at https://github.com/orgs/community/discussions/112148 suggested:
    Ensure that the system date and time on your machine are correctly set. If the system clock is incorrect, SSL certificates may appear as not yet valid or expired. Correcting the date/time settings should resolve the issue in many cases. If the system date/time is correct, check the expiration date of the SSL certificate associated with the server you're trying to connect to. If the certificate has expired, it will need to be renewed or replaced. Ensure that the SSL certificate presented by the server is properly signed by a trusted Certificate Authority (CA) and that the entire certificate chain is valid. Sometimes, an incomplete or misconfigured certificate chain can cause validation errors.
    Another option I read over at https://forums.fogproject.org/topic/11343/certificate-of-github-com-is-not-trusted is you can add "--no-check-certificate" to the end of your wget command.
