I am trying to connect an ADALM-Pluto SDR to a Raspberry Pi Zero WH to access the SDR remotely. However, when I connect to the Raspberry Pi via SSH (using PuTTY), it does not detect the device or assign it an IP address.
dmesg:
[ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 6.6.51+rpt-rpi-v6 (serge@raspberrypi.com) (gcc-12 ( Raspbian 12.2.0-14+rpi1) 12.2.0, GNU ld (GNU Binutils for Raspbian) 2.40) #1 Ras pbian 1:6.6.51-1+rpt3 (2024-10-08) [ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr =00c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruc tion cache [ 0.000000] OF: fdt: Machine model: Raspberry Pi Zero W Rev 1.1 [ 0.000000] random: crng init done [ 0.000000] Memory policy: Data cache writeback [ 0.000000] Reserved memory: created CMA memory pool at 0x0b000000, size 256 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id share d-dma-pool [ 0.000000] OF: reserved mem: 0x0b000000..0x1affffff (262144 KiB) map reusabl e linux,cma [ 0.000000] Zone ranges: [ 0.000000] Normal [mem 0x0000000000000000-0x000000001bffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000000000-0x000000001bffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000001bffffff] [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835 .enable_headphones=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95 xx.macaddr=B8:27:EB:1F:29:F1 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x200000 00 console=ttyS0,115200 console=tty1 root=PARTUUID=40c3ac51-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.i eee80211_regdom=GB [ 0.000000] Unknown kernel command line parameters "splash", will be passed t o user space. [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, l inear) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, li near) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 113680 [ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off [ 0.000000] Memory: 159924K/458752K available (10025K kernel code, 1478K rwda ta, 3120K rodata, 456K init, 581K bss, 36684K reserved, 262144K cma-reserved) [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] ftrace: allocating 35010 entries in 103 pages [ 0.000000] ftrace: allocated 103 pages with 5 groups [ 0.000000] trace event string verifier disabled [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2 147483647500ns [ 0.000068] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_ idle_ns: 1911260446275 ns [ 0.000170] bcm2835: system timer (irq = 27) [ 0.001029] Console: colour dummy device 80x30 [ 0.001072] printk: console [tty1] enabled [ 0.001207] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792) [ 0.060288] CPU: Testing write buffer coherency: ok [ 0.060378] pid_max: default: 32768 minimum: 301 [ 0.060544] LSM: initializing lsm=capability,integrity [ 0.060858] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linea r) [ 0.060901] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear) [ 0.062319] cgroup: Disabling memory control group subsystem [ 0.064737] RCU Tasks Rude: Setting shift to 0 and lim to 1 rcu_task_cb_adjus t=1. [ 0.064998] RCU Tasks Trace: Setting shift to 0 and lim to 1 rcu_task_cb_adju st=1. [ 0.065286] Setting up static identity map for 0x8220 - 0x8258 [ 0.066726] devtmpfs: initialized [ 0.079797] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5 [ 0.080200] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 19112604462750000 ns [ 0.080256] futex hash table entries: 256 (order: -1, 3072 bytes, linear) [ 0.118954] pinctrl core: initialized pinctrl subsystem [ 0.121678] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.124305] DMA: preallocated 1024 KiB pool for atomic coherent allocations [ 0.130918] audit: initializing netlink subsys (disabled) [ 0.131479] audit: type=2000 audit(0.130:1): state=initialized audit_enabled= 0 res=1 [ 0.132602] thermal_sys: Registered thermal governor 'step_wise' [ 0.133058] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers. [ 0.133091] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.133614] Serial: AMBA PL011 UART driver [ 0.143086] bcm2835-mbox 2000b880.mailbox: mailbox enabled [ 0.160803] raspberrypi-firmware soc:firmware: Attached to firmware from 2024 -08-30T19:19:11, variant start [ 0.170833] raspberrypi-firmware soc:firmware: Firmware hash is 2808975b80149 bbfe86844655fe45c7de66fc078 [ 0.187416] kprobes: kprobe jump-optimization is enabled. All kprobes are opt imized if possible. [ 0.204088] bcm2835-dma 20007000.dma-controller: DMA legacy API manager, dmac hans=0x1 [ 0.206991] SCSI subsystem initialized [ 0.207472] usbcore: registered new interface driver usbfs [ 0.207576] usbcore: registered new interface driver hub [ 0.207691] usbcore: registered new device driver usb [ 0.208559] pps_core: LinuxPPS API ver. 1 registered [ 0.208590] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it> [ 0.208639] PTP clock support registered [ 0.222449] clocksource: Switched to clocksource timer [ 0.223337] VFS: Disk quotas dquot_6.6.0 [ 0.223449] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.223690] FS-Cache: Loaded [ 0.224464] CacheFiles: Loaded [ 0.269142] NET: Registered PF_INET protocol family [ 0.269467] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear ) [ 0.271859] tcp_listen_portaddr_hash hash table entries: 1024 (order: 0, 4096 bytes, linear) [ 0.271936] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.271976] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear) [ 0.272059] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.272213] TCP: Hash tables configured (established 4096 bind 4096) [ 0.272366] UDP hash table entries: 256 (order: 0, 4096 bytes, linear) [ 0.272422] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear) [ 0.272998] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.274114] RPC: Registered named UNIX socket transport module. [ 0.274154] RPC: Registered udp transport module. [ 0.274167] RPC: Registered tcp transport module. [ 0.274177] RPC: Registered tcp-with-tls transport module. [ 0.274188] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.275187] armv6-pmu arm-pmu: hw perfevents: no irqs for PMU, sampling event s not supported [ 0.275269] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters ava ilable [ 0.279628] Trying to unpack rootfs image as initramfs... [ 4.429028] Initialise system trusted keyrings [ 4.429518] workingset: timestamp_bits=14 max_order=17 bucket_order=3 [ 4.429692] zbud: loaded [ 4.431263] NFS: Registering the id_resolver key type [ 4.431344] Key type id_resolver registered [ 4.431361] Key type id_legacy registered [ 4.431447] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 4.431472] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering ... [ 4.433088] Key type asymmetric registered [ 4.433134] Asymmetric key parser 'x509' registered [ 4.433328] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 47) [ 4.433359] io scheduler mq-deadline registered [ 4.433376] io scheduler kyber registered [ 4.433518] io scheduler bfq registered [ 4.452250] pinctrl-bcm2835 20200000.gpio: GPIO_OUT persistence: yes [ 4.453935] simple-framebuffer 1eaa9000.framebuffer: framebuffer at 0x1eaa900 0, 0x151800 bytes [ 4.453988] simple-framebuffer 1eaa9000.framebuffer: format=a8r8g8b8, mode=72 0x480x32, linelength=2880 [ 4.455042] Console: switching to colour frame buffer device 90x30 [ 4.460265] simple-framebuffer 1eaa9000.framebuffer: fb0: simplefb registered ! [ 4.468321] bcm2835-rng 20104000.rng: hwrng registered [ 4.468957] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000 000(512 MiB) [ 4.521335] brd: module loaded [ 4.543243] loop: module loaded [ 4.560889] Loading iSCSI transport class v2.0-870. [ 4.563504] usbcore: registered new interface driver smsc95xx [ 4.563549] dwc_otg: version 3.00a 10-AUG-2012 (platform bus) [ 5.493260] Core Release: 2.80a [ 5.493316] Setting default values for core params [ 5.493351] Finished setting default values for core params [ 5.693513] Using Buffer DMA mode [ 5.693541] Periodic Transfer Interrupt Enhancement - disabled [ 5.693556] Multiprocessor Interrupt Enhancement - disabled [ 5.693568] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 5.891305] Dedicated Tx FIFOs mode [ 5.892330] WARN::dwc_otg_hcd_init:1070: FIQ DMA bounce buffers: virt = cb104 000 dma = 0x8b104000 len=9024 [ 5.892389] FIQ FSM acceleration enabled for : Non-periodic Split Transactions Periodic Split Transactions High-Speed Isochronous Endpoints Interrupt/Control Split Transaction hack enabled [ 5.892415] dwc_otg: Microframe scheduler enabled [ 5.892765] WARN::hcd_init_fiq:457: FIQ on core 0 [ 5.892801] WARN::hcd_init_fiq:458: FIQ ASM at c07367bc length 36 [ 5.892844] WARN::hcd_init_fiq:496: MPHI regs_base at dc810000 [ 5.892890] dwc_otg 20980000.usb: DWC OTG Controller [ 5.892970] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1 [ 5.893059] dwc_otg 20980000.usb: irq 56, io mem 0x00000000 [ 5.893129] Init: Port Power? op_state=1 [ 5.893144] Init: Power Port (0) [ 5.909016] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc dDevice= 6.06 [ 5.909070] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 5.909096] usb usb1: Product: DWC OTG Controller [ 5.909117] usb usb1: Manufacturer: Linux 6.6.51+rpt-rpi-v6 dwc_otg_hcd [ 5.909137] usb usb1: SerialNumber: 20980000.usb [ 5.910483] hub 1-0:1.0: USB hub found [ 5.910605] hub 1-0:1.0: 1 port detected [ 5.911730] dwc_otg: FIQ enabled [ 5.911761] dwc_otg: NAK holdoff enabled [ 5.911773] dwc_otg: FIQ split-transaction FSM enabled [ 5.911804] Module dwc_common_port init [ 5.912425] usbcore: registered new interface driver usb-storage [ 5.913102] mousedev: PS/2 mouse device common for all mice [ 5.916325] sdhci: Secure Digital Host Controller Interface driver [ 5.916361] sdhci: Copyright(c) Pierre Ossman [ 5.916745] sdhci-pltfm: SDHCI platform and OF driver helper [ 5.933908] ledtrig-cpu: registered to indicate activity on CPUs [ 5.934511] hid: raw HID events driver (C) Jiri Kosina [ 5.934768] usbcore: registered new interface driver usbhid [ 5.934792] usbhid: USB HID core driver [ 5.935035] bcm2835_vchiq 2000b840.mailbox: there is not valid maps for state default [ 5.956436] Initializing XFRM netlink socket [ 5.956536] NET: Registered PF_PACKET protocol family [ 5.956691] Key type dns_resolver registered [ 6.029373] registered taskstats version 1 [ 6.029569] Loading compiled-in X.509 certificates [ 6.084255] uart-pl011 20201000.serial: cts_event_workaround enabled [ 6.085123] 20201000.serial: ttyAMA1 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2 [ 6.085720] serial serial0: tty port ttyAMA1 registered [ 6.101726] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer [ 6.102310] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains drive r [ 6.104795] mmc-bcm2835 20300000.mmcnr: mmc_debug:0 mmc_debug2:0 [ 6.104848] mmc-bcm2835 20300000.mmcnr: DMA channel allocated [ 6.147195] sdhost: log_buf @ 9149608e (8b103000) [ 6.238110] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1) [ 6.241062] of_cfs_init [ 6.241286] of_cfs_init: OK [ 6.243651] clk: Disabling unused clocks [ 6.394025] mmc0: host does not support reading read-only switch, assuming wr ite-enable [ 6.410194] mmc0: Host Software Queue enabled [ 6.410272] mmc0: new high speed SDHC card at address aaaa [ 6.411800] mmcblk0: mmc0:aaaa SK32G 29.7 GiB [ 6.425107] mmcblk0: p1 p2 [ 6.426674] mmcblk0: mmc0:aaaa SK32G 29.7 GiB (quirks 0x00004000) [ 6.868067] mmc1: new high speed SDIO card at address 0001 [ 7.124715] Freeing initrd memory: 15640K [ 7.130072] Freeing unused kernel image (initmem) memory: 456K [ 7.130122] Kernel memory protection not selected by kernel config. [ 7.130175] Run /init as init process [ 7.130189] with arguments: [ 7.130198] /init [ 7.130207] splash [ 7.130216] with environment: [ 7.130224] HOME=/ [ 7.130233] TERM=linux [ 10.627965] Console: switching to colour dummy device 80x30 [ 10.631819] vc4-drm soc:gpu: bound 20400000.hvs (ops vc4_hvs_ops [vc4]) [ 10.645547] Registered IR keymap rc-cec [ 10.645938] rc rc0: vc4-hdmi as /devices/platform/soc/20902000.hdmi/rc/rc0 [ 10.646418] input: vc4-hdmi as /devices/platform/soc/20902000.hdmi/rc/rc0/inp ut0 [ 10.657869] input: vc4-hdmi HDMI Jack as /devices/platform/soc/20902000.hdmi/ sound/card0/input1 [ 10.672674] vc4-drm soc:gpu: bound 20902000.hdmi (ops vc4_hdmi_ops [vc4]) [ 10.673784] vc4-drm soc:gpu: bound 20004000.txp (ops vc4_txp_ops [vc4]) [ 10.674700] vc4-drm soc:gpu: bound 20206000.pixelvalve (ops vc4_crtc_ops [vc4 ]) [ 10.675593] vc4-drm soc:gpu: bound 20207000.pixelvalve (ops vc4_crtc_ops [vc4 ]) [ 10.676489] vc4-drm soc:gpu: bound 20807000.pixelvalve (ops vc4_crtc_ops [vc4 ]) [ 10.677192] vc4-drm soc:gpu: bound 20c00000.v3d (ops vc4_v3d_ops [vc4]) [ 10.734091] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 0 [ 10.765146] vc4-drm soc:gpu: [drm] Cannot find any crtc or sizes [ 10.766169] vc4-drm soc:gpu: [drm] Cannot find any crtc or sizes [ 14.126916] EXT4-fs (mmcblk0p2): mounted filesystem dcae8a9b-3730-4135-9ca4-6 7efe6e9a54f ro with ordered data mode. Quota mode: none. [ 15.330675] systemd[1]: System time before build time, advancing clock. [ 15.683659] NET: Registered PF_INET6 protocol family [ 15.686159] Segment Routing with IPv6 [ 15.686256] In-situ OAM (IOAM) with IPv6 [ 15.829932] systemd[1]: systemd 252.31-1~deb12u1+rpi1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +A CL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAM EWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 15.830062] systemd[1]: Detected architecture arm. [ 15.856451] systemd[1]: Hostname set to <raspberrypi>. [ 19.703003] systemd[1]: Queued start job for default target graphical.target. [ 19.725058] systemd[1]: Created slice system-getty.slice - Slice /system/gett y. [ 19.731511] systemd[1]: Created slice system-modprobe.slice - Slice /system/m odprobe. [ 19.737639] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /s ystem/systemd-fsck. [ 19.740980] systemd[1]: Created slice user.slice - User and Session Slice. [ 19.742883] systemd[1]: Started systemd-ask-password-wall.path - Forward Pass word Requests to Wall Directory Watch. [ 19.746135] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point. [ 19.746871] systemd[1]: Expecting device dev-disk-by\x2dpartuuid-40c3ac51\x2d 01.device - /dev/disk/by-partuuid/40c3ac51-01... [ 19.747319] systemd[1]: Expecting device dev-dri-card0.device - /dev/dri/card 0... [ 19.747688] systemd[1]: Expecting device dev-dri-renderD128.device - /dev/dri /renderD128... [ 19.748765] systemd[1]: Reached target integritysetup.target - Local Integrit y Protected Volumes. [ 19.750185] systemd[1]: Reached target nss-user-lookup.target - User and Grou p Name Lookups. [ 19.751361] systemd[1]: Reached target slices.target - Slice Units. [ 19.752270] systemd[1]: Reached target swap.target - Swaps. [ 19.753501] systemd[1]: Reached target veritysetup.target - Local Verity Prot ected Volumes. [ 19.757136] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd com munication Socket. [ 19.758742] systemd[1]: Listening on systemd-initctl.socket - initctl Compati bility Named Pipe. [ 19.763129] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket. [ 19.765773] systemd[1]: Listening on systemd-journald-dev-log.socket - Journa l Socket (/dev/log). [ 19.768617] systemd[1]: Listening on systemd-journald.socket - Journal Socket . [ 19.773187] systemd[1]: Listening on systemd-udevd-control.socket - udev Cont rol Socket. [ 19.775558] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kerne l Socket. [ 19.778652] systemd[1]: dev-hugepages.mount - Huge Pages File System was skip ped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/huge pages). [ 19.794067] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System... [ 19.823328] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File S ystem... [ 19.862043] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System... [ 19.871287] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists =/etc/krb5.keytab). [ 19.917171] systemd[1]: Starting fake-hwclock.service - Restore / save the cu rrent clock... [ 19.959046] systemd[1]: Starting keyboard-setup.service - Set the console key board layout... [ 20.001794] systemd[1]: Starting kmod-static-nodes.service - Create List of S tatic Device Nodes... [ 20.077904] systemd[1]: Starting modprobe@configfs.service - Load Kernel Modu le configfs... [ 20.164229] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod... [ 20.242082] systemd[1]: Starting modprobe@drm.service - Load Kernel Module dr m... [ 20.328122] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Mo dule efi_pstore... [ 20.404198] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module f use... [ 20.513835] systemd[1]: Starting modprobe@loop.service - Load Kernel Module l oop... [ 20.518156] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/r un/initramfs/fsck-root). [ 20.674238] systemd[1]: Starting systemd-journald.service - Journal Service.. . [ 20.764037] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-d evel@redhat.com [ 20.804273] systemd[1]: Starting systemd-modules-load.service - Load Kernel M odules... [ 20.886085] systemd[1]: Starting systemd-remount-fs.service - Remount Root an d Kernel File Systems... [ 20.990777] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices... [ 21.010124] fuse: init (API version 7.39) [ 21.199559] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File S ystem. [ 21.232652] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File Sy stem. [ 21.254298] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System. [ 21.292818] systemd[1]: Finished fake-hwclock.service - Restore / save the cu rrent clock. [ 21.317800] systemd[1]: Finished kmod-static-nodes.service - Create List of S tatic Device Nodes. [ 21.346742] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 21.382916] systemd[1]: Finished modprobe@configfs.service - Load Kernel Modu le configfs. [ 21.402390] systemd[1]: modprobe@dm_mod.service: Deactivated successfully. [ 21.413606] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod. [ 21.418835] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 21.472942] systemd[1]: Finished modprobe@drm.service - Load Kernel Module dr m. [ 21.477902] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully . [ 21.512937] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Mo dule efi_pstore. [ 21.517938] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 21.544228] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module f use. [ 21.561783] systemd[1]: modprobe@loop.service: Deactivated successfully. [ 21.601026] systemd[1]: Finished modprobe@loop.service - Load Kernel Module l oop. [ 21.685674] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System... [ 21.691689] i2c_dev: i2c /dev entries driver [ 21.776844] EXT4-fs (mmcblk0p2): re-mounted dcae8a9b-3730-4135-9ca4-67efe6e9a 54f r/w. Quota mode: none. [ 21.844130] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configurati on File System... [ 21.845587] systemd[1]: systemd-repart.service - Repartition Root Disk was sk ipped because no trigger condition checks were met. [ 22.163772] systemd[1]: Finished systemd-modules-load.service - Load Kernel M odules. [ 22.192795] systemd[1]: Finished systemd-remount-fs.service - Remount Root an d Kernel File Systems. [ 22.204400] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System. [ 22.207698] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuratio n File System. [ 22.212141] systemd[1]: systemd-firstboot.service - First Boot Wizard was ski pped because of an unmet condition check (ConditionFirstBoot=yes). [ 22.243566] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotE mpty=/sys/fs/pstore). [ 22.307869] systemd[1]: Starting systemd-random-seed.service - Load/Save Rand om Seed... [ 22.387536] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variab les... [ 22.485874] systemd[1]: Starting systemd-sysusers.service - Create System Use rs... [ 23.123184] systemd[1]: Finished systemd-random-seed.service - Load/Save Rand om Seed. [ 23.143748] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes). [ 23.229277] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variab les. [ 23.512893] systemd[1]: Started systemd-journald.service - Journal Service. [ 24.131666] systemd-journald[201]: Received client request to flush runtime j ournal. [ 24.193049] systemd-journald[201]: File /var/log/journal/4c883233e0f645a4b2f6 e239a06c8519/system.journal corrupted or uncleanly shut down, renaming and repla cing. [ 40.237384] rpi-gpiomem 20200000.gpiomem: window base 0x20200000 size 0x00001 000 [ 40.316651] rpi-gpiomem 20200000.gpiomem: initialised 1 regions as /dev/gpiom em [ 40.421585] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned. [ 40.479862] vc_sm_cma: module is from the staging directory, the quality is u nknown, you have been warned. [ 40.481771] bcm2835_vc_sm_cma_probe: Videocore shared memory driver [ 40.481819] [vc_sm_connected_init]: start [ 40.571666] [vc_sm_connected_init]: installed successfully [ 40.619043] mc: Linux media interface: v0.10 [ 41.641378] videodev: Linux video capture interface: v2.00 [ 41.820637] bcm2835_mmal_vchiq: module is from the staging directory, the qua lity is unknown, you have been warned. [ 41.902850] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned. [ 41.921745] bcm2835_v4l2: module is from the staging directory, the quality i s unknown, you have been warned. [ 41.927580] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev /video13 [ 41.933203] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /de v/video14 [ 41.945339] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /de v/video15 [ 41.946144] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/ video16 [ 41.946214] bcm2835-isp bcm2835-isp: Register output node 0 with media contro ller [ 41.946256] bcm2835-isp bcm2835-isp: Register capture node 1 with media contr oller [ 41.946288] bcm2835-isp bcm2835-isp: Register capture node 2 with media contr oller [ 41.946323] bcm2835-isp bcm2835-isp: Register capture node 3 with media contr oller [ 41.960283] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev /video20 [ 41.961221] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /de v/video21 [ 41.962224] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /de v/video22 [ 41.973222] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/ video23 [ 41.973298] bcm2835-isp bcm2835-isp: Register output node 0 with media contro ller [ 41.973340] bcm2835-isp bcm2835-isp: Register capture node 1 with media contr oller [ 41.973372] bcm2835-isp bcm2835-isp: Register capture node 2 with media contr oller [ 41.973403] bcm2835-isp bcm2835-isp: Register capture node 3 with media contr oller [ 41.981156] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp [ 42.021860] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned. [ 42.056611] bcm2835-codec bcm2835-codec: Device registered as /dev/video10 [ 42.056705] bcm2835-codec bcm2835-codec: Loaded V4L2 decode [ 42.060481] bcm2835-codec bcm2835-codec: Device registered as /dev/video11 [ 42.060584] bcm2835-codec bcm2835-codec: Loaded V4L2 encode [ 42.073242] bcm2835-codec bcm2835-codec: Device registered as /dev/video12 [ 42.073334] bcm2835-codec bcm2835-codec: Loaded V4L2 isp [ 42.084798] bcm2835-codec bcm2835-codec: Device registered as /dev/video18 [ 42.084888] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx [ 42.088699] bcm2835-codec bcm2835-codec: Device registered as /dev/video31 [ 42.088807] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image [ 42.284175] Bluetooth: Core ver 2.22 [ 42.284380] NET: Registered PF_BLUETOOTH protocol family [ 42.284404] Bluetooth: HCI device and connection manager initialized [ 42.284445] Bluetooth: HCI socket layer initialized [ 42.284472] Bluetooth: L2CAP socket layer initialized [ 42.284525] Bluetooth: SCO socket layer initialized [ 42.349194] Bluetooth: HCI UART driver ver 2.3 [ 42.349247] Bluetooth: HCI UART protocol H4 registered [ 42.349429] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 42.350136] hci_uart_bcm serial0-0: supply vbat not found, using dummy regula tor [ 42.350558] hci_uart_bcm serial0-0: supply vddio not found, using dummy regul ator [ 42.372723] Bluetooth: HCI UART protocol Broadcom registered [ 42.462909] uart-pl011 20201000.serial: no DMA platform data [ 42.713668] Bluetooth: hci0: BCM: chip id 94 [ 42.714220] Bluetooth: hci0: BCM: features 0x2e [ 42.715650] Bluetooth: hci0: BCM43430A1 [ 42.715696] Bluetooth: hci0: BCM43430A1 (001.002.009) build 0000 [ 42.738224] Bluetooth: hci0: BCM43430A1 'brcm/BCM43430A1.raspberrypi,model-ze ro-w.hcd' Patch [ 43.373771] Bluetooth: hci0: BCM: features 0x2e [ 43.379054] Bluetooth: hci0: BCM43438A1 37.4MHz Raspberry Pi 3-0141 [ 43.379110] Bluetooth: hci0: BCM43430A1 (001.002.009) build 0508 [ 45.207639] alsactl[390]: memfd_create() called without MFD_EXEC or MFD_NOEXE C_SEAL set [ 46.365897] cfg80211: Loading compiled-in X.509 certificates for regulatory d atabase [ 46.518446] Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4 961b8b4fadf' [ 46.522245] Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016 ab9d6cf71dd233f0328' [ 46.552025] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 46.575978] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600 ' [ 47.622809] brcmfmac: F1 signature read @0x18000000=0x1541a9a6 [ 47.665906] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio f or chip BCM43430/1 [ 47.667143] usbcore: registered new interface driver brcmfmac [ 48.091820] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (er r=-2) [ 48.094495] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Jul 19 2021 03:24:18 version 7.45.98 (TOB) (56df937 CY) FWID 01-8e14b897 [ 71.204864] Adding 204796k swap on /var/swap. Priority:-2 extents:5 across:1 6474108k SS [ 74.939209] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 74.939249] Bluetooth: BNEP filters: protocol multicast [ 74.939277] Bluetooth: BNEP socket layer initialized [ 75.123947] Bluetooth: MGMT ver 1.22 [ 75.393051] NET: Registered PF_ALG protocol family [ 82.594961] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled [ 87.932961] systemd-journald[201]: File /var/log/journal/4c883233e0f645a4b2f6 e239a06c8519/user-1000.journal corrupted or uncleanly shut down, renaming and re placing. [ 99.942597] Bluetooth: RFCOMM TTY layer initialized [ 99.942658] Bluetooth: RFCOMM socket layer initialized [ 99.942710] Bluetooth: RFCOMM ver 1.11
