Hi everyone,
I have a problem with receiving signals from Adalm Pluto. The problem is when I configure the
If you are generating a real tone (not complex), Pluto’s QEC will assume you have an image which it will try to remove adaptively. This has the effect of modulating your data. Try disabling quadrature correction.
-Travis
Hi Travid,
Can you tell me how to disable quadrature by using matlab?
Thank you so much
Hi Travid,
Thank you so much for your reply.
I have another problem: I would like to implement BPSK with Adalm Pluto. I used the comm.BPSKModulator function from Matlab to modulate data and the comm.CoarseFrequencyCompensator function for synchronization before demodulating. My problem is that even if I put the transmitter and receiver very near, the bit error rate is still very high. Do you have a program for BPSK and Adam Pluto that you can share with me?
Sorry no. Most MATLAB examples are provided by MathWorks. If might be worth reaching out to them.
-Travis
