I am currently working with the ADALM-Pluto SDR in its 2R2T configuration and facing an issue regarding phase consistency between two transmitted signals. My test involves transmitting two sinusoidal signals with a predefined phase difference using the PlutoSDR. During it, each transmit channel (TX1 and TX2) is connected to its corresponding receive channel (RX1 and RX2).
Each time I get random phase offset, for example, two consecutive tests (expected phase shift 30 degrees):
With loopback enabled ("sdr.loopback = 1") I get the expected result:
I understand that RX and TX have separate LOs, but this should not affect the phase difference between the TX signals.
What am I doing wrong? Does such a task require some specific calibration?
Code I am using for the test:
SDR setup:
# Configuration parameters sample_rate = 20e6 # must be <=30.72 MHz if both channels are enabled rf_bandwidth = 1e6 # RF bandwidth carrier_freq = 400e6 # Frequency of the tone tx_gain0 = -30 # TX gain in dB tx_gain1 = -30 # TX gain in dB num_samples = 2**18 # Number of samples in the buffer rx_mode = "manual" # can be "manual" or "slow_attack" rx_gain0 = 0 rx_gain1 = 0 def initSDR(): # Connect to Pluto SDR sdr = adi.ad9361(uri=PLUTO_IP) # Configure SDR properties sdr.gain_control_mode = rx_mode sdr.rx_rf_bandwidth = int(rf_bandwidth) # RX bandwidth sdr.sample_rate = int(sample_rate) # RX sample rate sdr.rx_lo = int(carrier_freq) # RX local oscillator frequency sdr.rx_hardwaregain_chan0 = int(rx_gain0) # RX gain for channel 0 sdr.rx_hardwaregain_chan1 = int(rx_gain1) # RX gain for channel 1 sdr.rx_buffer_size = int(num_samples) # Set RX buffer size sdr.rx_enabled_channels = [0, 1] # Enable both channels # Configure TX properties sdr.tx_rf_bandwidth = int(rf_bandwidth) # TX bandwidth sdr.tx_lo = int(carrier_freq) # TX local oscillator frequency sdr.tx_hardwaregain_chan0 = tx_gain0 # TX gain for channel 0 sdr.tx_hardwaregain_chan1 = tx_gain1 # TX gain for channel 1 sdr.tx_cyclic_buffer = True # Enable cyclic buffer sdr.tx_buffer_size = int(num_samples) # Set TX buffer size sdr.tx_enabled_channels = [0, 1] # Enable both channels sdr.loopback = 0 # Enable loopback mode return sdr
Signal creation:
def create_signal(phase_shift=0): fs = int(sdr.sample_rate) # Sampling rate # int(fc / (fs / N)) * (fs / N) # is used to ensure that fc is a multiple of the frequency resolution fc0 = int(frequency_of_signal) # Frequency of the first signal fc1 = int(frequency_of_signal) # Frequency of the second signal N = 2**16 # Number of samples ts = 1 / float(fs) # Time step t = np.arange(0, N * ts, ts) # Time vector i0 = np.cos(2 * np.pi * t * fc0) * 2 ** 14 # In-phase component of the first signal q0 = np.sin(2 * np.pi * t * fc0) * 2 ** 14 # Quadrature component of the first signal i1 = np.cos(2 * np.pi * t * fc1 + phase_shift*(np.pi/180)) * 2 ** 14 q1 = np.sin(2 * np.pi * t * fc1 + phase_shift*(np.pi/180)) * 2 ** 14 iq0 = i0 + 1j * q0 iq1 = i1 + 1j * q1 return [iq0, iq1]
Visualization part:
# Collect data from the receiver data = sdr.rx() Rx_0 = data[0] # Data from the first RX channel Rx_1 = data[1] # Data from the second RX channel fs = int(sdr.sample_rate) # Sampling rate t = np.arange(len(Rx_0)) / fs # Time vector # Define the frequency for time range calculation frequency_of_waveform = frequency_of_signal # Frequency of the transmitted signal period_of_waveform = 1 / frequency_of_waveform number_of_periods_to_display = 5 # Displaying 5 periods # Find the time range that covers the specified number of periods time_range_to_display = period_of_waveform * number_of_periods_to_display indices_to_display = t < time_range_to_display # Correcting the range # Compute phases of both signals phase_0 = np.angle(Rx_0) phase_1 = np.angle(Rx_1) # Calculate phase difference, wrap it and convert to degrees phase_diff = np.unwrap(phase_1 - phase_0) * (180 / np.pi) phase_diff = np.mod(phase_diff, 360) # Ensure phase difference is within 0-360 degrees mean_phase_diff = np.mean(phase_diff[indices_to_display]) # Plotting both received signals within the correct range plt.figure(figsize=(10, 6)) plt.subplot(2, 1, 1) plt.plot(t[indices_to_display], np.real(Rx_0)[indices_to_display], label='Channel 0 - TX 0 RX') plt.plot(t[indices_to_display], np.real(Rx_1)[indices_to_display], label='Channel 1 - TX 1 RX', linestyle='--') plt.title('Received Signals to Compare Phase Shift') plt.xlabel('Time (s)') plt.ylabel('Amplitude') plt.legend() plt.grid(True) # Plotting phase difference in degrees plt.subplot(2, 1, 2) plt.plot(t[indices_to_display], phase_diff[indices_to_display], label='Phase Difference', color='green') plt.axhline(y=mean_phase_diff, color='r', linestyle='-', label=f'Mean Phase Difference: {mean_phase_diff:.2f}°') plt.title('Phase Difference Over Time (Degrees)') plt.xlabel('Time (s)') plt.ylabel('Phase Difference (Degrees)') plt.legend() plt.grid(True)
