Introduction:
Hello everyone ,
At the moment I am having trouble with my ADALM-PLUTO in terms of transmission. Using https://github.com/osqzss/gps-sdr-sim , I wanted to simulate a GPS-Simulator, however whenever I give the SDR the nmea stream, it doesn't seem to transmit anything. At the moment I am currently trying to figure out if the issue is related to hardware, or if it has something to do with my configuration. The plutoplayer.c file doesn't spit out any error messages regarding the preperation for transmittion.
So far I have checked a couple of things:
I have already tried resetting the ADALM PLUTO (setting reset to 1 and unmounting)
Firmware update for ADALM PLUTO
Changing the host maschine (albiet same OS, Linux debian)
Changing usb ports on the host maschine
Changing the transmit file gpssim.bin to a different output
Sadly I am not an expert in terms of SDR and would greatly appreciate the help
Plutoplayer output when giving the SDR input:
player/plutoplayer -t gpssim.bin -a 1575.42
* Transmit file size: 16.746 GB
* Acquiring IIO context
* Found 192.168.2.1 (Analog Devices PlutoSDR Rev.C (Z7010-AD9363A)), serial=10447376de0b0013f6ff0c0023119a895c
* Acquiring devices
* Context has 4 device(s).
* Acquiring TX device
* Initializing streaming channels
* Enabling IIO streaming channels
* Creating TX buffer
* Transmit starts...
iio_info -s output:
iio_info -s
Library version: 0.24 (git tag: a08ad5f)
Compiled with backends: local xml ip usb
Unable to create Local IIO context : No such file or directory (2)
Available contexts:
0: 192.168.2.1 (Analog Devices PlutoSDR Rev.C (Z7010-AD9363A)), serial=10447376de0b0013f6ff0c0023119a895c [ip:pluto.local]
1: 0456:b673 (Analog Devices Inc. PlutoSDR (ADALM-PLUTO)), serial=10447376de0b0013f6ff0c0023119a895c [usb:3.2.5]
iio_info -u ip:192.168.2.1
iio_info -s
Available contexts:
root@debian:~/gps-sdr-sim-master# iio_info -u ip:192.168.2.1
IIO context created with network backend.
Backend version: 0.24 (git tag: v0.24)
Backend description string: 192.168.2.1 Linux (none) 5.10.0-98231-g9dfba10b795d #54 SMP PREEMPT Mon Jul 11 14:38:48 CEST 2022 armv7l
IIO context has 9 attributes:
hw_model: Analog Devices PlutoSDR Rev.C (Z7010-AD9363A)
hw_model_variant: 1
hw_serial: 10447376de0b0013f6ff0c0023119a895c
fw_version: v0.35
ad9361-phy,xo_correction: 39999977
ad9361-phy,model: ad9363a
local,kernel: 5.10.0-98231-g9dfba10b795d
uri: ip:192.168.2.1
ip,ip-addr: 192.168.2.1
IIO context has 4 devices:
iio:device0: ad9361-phy
9 channels found:
altvoltage1: TX_LO (output)
8 channel-specific attributes found:
attr 0: external value: 0
attr 1: fastlock_load value: 0
attr 2: fastlock_recall ERROR: Invalid argument (22)
attr 3: fastlock_save value: 0 27,27,27,27,27,27,27,27,27,27,27,27,27,27,27,27
attr 4: fastlock_store value: 0
attr 5: frequency value: 1575419998
attr 6: frequency_available value: [325000000 1 3800000000]
attr 7: powerdown value: 1
voltage0: (input)
15 channel-specific attributes found:
attr 0: bb_dc_offset_tracking_en value: 1
attr 1: filter_fir_en value: 1
attr 2: gain_control_mode value: slow_attack
attr 3: gain_control_mode_available value: manual fast_attack slow_attack hybrid
attr 4: hardwaregain value: 71.000000 dB
attr 5: hardwaregain_available value: [-3 1 71]
attr 6: quadrature_tracking_en value: 1
attr 7: rf_bandwidth value: 18000000
attr 8: rf_bandwidth_available value: [200000 1 56000000]
attr 9: rf_dc_offset_tracking_en value: 1
attr 10: rf_port_select value: A_BALANCED
attr 11: rf_port_select_available value: A_BALANCED B_BALANCED C_BALANCED A_N A_P B_N B_P C_N C_P TX_MONITOR1 TX_MONITOR2 TX_MONITOR1_2
attr 12: rssi value: 126.00 dB
attr 13: sampling_frequency value: 2600000
attr 14: sampling_frequency_available value: [520833 1 30720000]
voltage3: (output)
attr 0: filter_fir_en value: 1
attr 1: raw value: 306
attr 2: rf_bandwidth value: 3000000
attr 3: rf_bandwidth_available value: [200000 1 40000000]
attr 4: rf_port_select_available value: A B
attr 5: sampling_frequency value: 2600000
attr 6: sampling_frequency_available value: [520833 1 30720000]
attr 7: scale value: 1.000000
altvoltage0: RX_LO (output)
attr 3: fastlock_save value: 0 195,195,195,195,195,195,195,195,195,195,195,195,195,195,195,195
attr 5: frequency value: 2400000000
voltage2: (output)
temp0: (input)
1 channel-specific attributes found:
attr 0: input value: 33333
voltage0: (output)
10 channel-specific attributes found:
attr 1: hardwaregain value: 0.000000 dB
attr 2: hardwaregain_available value: [-89.750000 0.250000 0.000000]
attr 3: rf_bandwidth value: 3000000
attr 4: rf_bandwidth_available value: [200000 1 40000000]
attr 5: rf_port_select value: A
attr 6: rf_port_select_available value: A B
attr 7: rssi value: 0.00 dB
attr 8: sampling_frequency value: 2600000
attr 9: sampling_frequency_available value: [520833 1 30720000]
voltage2: (input)
13 channel-specific attributes found:
attr 2: gain_control_mode_available value: manual fast_attack slow_attack hybrid
attr 3: offset value: 57
attr 4: quadrature_tracking_en value: 1
attr 5: raw value: 1114
attr 6: rf_bandwidth value: 18000000
attr 7: rf_bandwidth_available value: [200000 1 56000000]
attr 8: rf_dc_offset_tracking_en value: 1
attr 9: rf_port_select_available value: A_BALANCED B_BALANCED C_BALANCED A_N A_P B_N B_P C_N C_P TX_MONITOR1 TX_MONITOR2 TX_MONITOR1_2
attr 10: sampling_frequency value: 2600000
attr 11: sampling_frequency_available value: [520833 1 30720000]
attr 12: scale value: 0.305250
out: (input, WARN:iio_channel_get_type()=UNKNOWN)
attr 0: voltage_filter_fir_en value: 1
18 device-specific attributes found:
attr 0: calib_mode value: auto
attr 1: calib_mode_available value: auto manual manual_tx_quad tx_quad rf_dc_offs rssi_gain_step
attr 2: dcxo_tune_coarse ERROR: No such device (19)
attr 3: dcxo_tune_coarse_available value: [0 0 0]
attr 4: dcxo_tune_fine ERROR: No such device (19)
attr 5: dcxo_tune_fine_available value: [0 0 0]
attr 6: ensm_mode value: fdd
attr 7: ensm_mode_available value: sleep wait alert fdd pinctrl pinctrl_fdd_indep
attr 8: filter_fir_config value: FIR Rx: 128,4 Tx: 128,4
attr 9: gain_table_config value: <gaintable AD9361 type=FULL dest=3 start=1300000000 end=4000000000>
-3, 0x00, 0x00, 0x20
-3, 0x00, 0x00, 0x00
-2, 0x00, 0x01, 0x00
-1, 0x00, 0x02, 0x00
0, 0x00, 0x03, 0x00
1, 0x00, 0x04, 0x00
2, 0x00, 0x05, 0x00
3, 0x01, 0x03, 0x20
4, 0x01, 0x04, 0x00
5, 0x01, 0x05, 0x00
6, 0x01, 0x06, 0x00
7, 0x01, 0x07, 0x00
8, 0x01, 0x08, 0x00
9, 0x01, 0x09, 0x00
10, 0x01, 0x0A, 0x00
11, 0x01, 0x0B, 0x00
12, 0x01, 0x0C, 0x00
13, 0x01, 0x0D, 0x00
14, 0x01, 0x0E, 0x00
15, 0x02, 0x09, 0x20
16, 0x02, 0x0A, 0x00
17, 0x02, 0x0B, 0x00
18, 0x02, 0x0C, 0x00
19, 0x02, 0x0D, 0x00
20, 0x02, 0x0E, 0x00
21, 0x02, 0x0F, 0x00
22, 0x02, 0x10, 0x00
23, 0x02, 0x2B, 0x20
24, 0x02, 0x2C, 0x00
25, 0x04, 0x27, 0x20
26, 0x04, 0x28, 0x00
27, 0x04, 0x29, 0x00
28, 0x04, 0x2A, 0x00
29, 0x04, 0x2B, 0x00
30, 0x24, 0x21, 0x20
31, 0x24, 0x22, 0x00
32, 0x44, 0x20, 0x20
33, 0x44, 0x21, 0x00
34, 0x44, 0x22, 0x00
35, 0x44, 0x23, 0x00
36, 0x44, 0x24, 0x00
37, 0x44, 0x25, 0x00
38, 0x44, 0x26, 0x00
39, 0x44, 0x27, 0x00
40, 0x44, 0x28, 0x00
41, 0x44, 0x29, 0x00
42, 0x44, 0x2A, 0x00
43, 0x44, 0x2B, 0x00
44, 0x44, 0x2C, 0x00
45, 0x44, 0x2D, 0x00
46, 0x44, 0x2E, 0x00
47, 0x44, 0x2F, 0x00
48, 0x44, 0x30, 0x00
49, 0x44, 0x31, 0x00
50, 0x64, 0x2E, 0x20
51, 0x64, 0x2F, 0x00
52, 0x64, 0x30, 0x00
53, 0x64, 0x31, 0x00
54, 0x64, 0x32, 0x00
55, 0x64, 0x33, 0x00
56, 0x64, 0x34, 0x00
57, 0x64, 0x35, 0x00
58, 0x64, 0x36, 0x00
59, 0x64, 0x37, 0x00
60, 0x64, 0x38, 0x00
61, 0x65, 0x38, 0x20
62, 0x66, 0x38, 0x20
63, 0x67, 0x38, 0x20
64, 0x68, 0x38, 0x20
65, 0x69, 0x38, 0x20
66, 0x6A, 0x38, 0x20
67, 0x6B, 0x38, 0x20
68, 0x6C, 0x38, 0x20
69, 0x6D, 0x38, 0x20
70, 0x6E, 0x38, 0x20
71, 0x6F, 0x38, 0x20
</gaintable>
attr 10: multichip_sync ERROR: Permission denied (13)
attr 11: rssi_gain_step_error value: lna_error: 0 0 0 0
mixer_error: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
gain_step_calib_reg_val: 0 0 0 0 0
attr 12: rx_path_rates value: BBPLL:1331200004 ADC:83200000 R2:41600000 R1:20800000 RF:10400000 RXSAMP:2600000
attr 13: trx_rate_governor value: nominal
attr 14: trx_rate_governor_available value: nominal highest_osr
attr 15: tx_path_rates value: BBPLL:1331200004 DAC:83200000 T2:41600000 T1:20800000 TF:10400000 TXSAMP:2600000
attr 16: xo_correction value: 39999977
attr 17: xo_correction_available value: [39991978 1 40007976]
179 debug attributes found:
debug attr 0: digital_tune value: 0
debug attr 1: calibration_switch_control value: 0
debug attr 2: multichip_sync value: 0
debug attr 3: gaininfo_rx2 ERROR: Resource temporarily unavailable (11)
debug attr 4: gaininfo_rx1 value: 71 76 0 0 0 0 0 0
debug attr 5: bist_timing_analysis value: 0
debug attr 6: gpo_set value: 0
debug attr 7: bist_tone value: 0
debug attr 8: bist_prbs value: 0
debug attr 9: loopback value: 0
debug attr 10: initialize value: 0
debug attr 11: adi,bb-clk-change-dig-tune-enable value: 0
debug attr 12: adi,axi-half-dac-rate-enable value: 0
debug attr 13: adi,txmon-2-lo-cm value: 48
debug attr 14: adi,txmon-1-lo-cm value: 48
debug attr 15: adi,txmon-2-front-end-gain value: 2
debug attr 16: adi,txmon-1-front-end-gain value: 2
debug attr 17: adi,txmon-duration value: 8192
debug attr 18: adi,txmon-delay value: 511
debug attr 19: adi,txmon-one-shot-mode-enable value: 0
debug attr 20: adi,txmon-dc-tracking-enable value: 0
debug attr 21: adi,txmon-high-gain value: 24
debug attr 22: adi,txmon-low-gain value: 0
debug attr 23: adi,txmon-low-high-thresh value: 37000
debug attr 24: adi,gpo3-tx-delay-us value: 0
debug attr 25: adi,gpo3-rx-delay-us value: 0
debug attr 26: adi,gpo2-tx-delay-us value: 0
debug attr 27: adi,gpo2-rx-delay-us value: 0
debug attr 28: adi,gpo1-tx-delay-us value: 0
debug attr 29: adi,gpo1-rx-delay-us value: 0
debug attr 30: adi,gpo0-tx-delay-us value: 0
debug attr 31: adi,gpo0-rx-delay-us value: 0
debug attr 32: adi,gpo3-slave-tx-enable value: 0
debug attr 33: adi,gpo3-slave-rx-enable value: 0
debug attr 34: adi,gpo2-slave-tx-enable value: 0
debug attr 35: adi,gpo2-slave-rx-enable value: 0
debug attr 36: adi,gpo1-slave-tx-enable value: 0
debug attr 37: adi,gpo1-slave-rx-enable value: 0
debug attr 38: adi,gpo0-slave-tx-enable value: 0
debug attr 39: adi,gpo0-slave-rx-enable value: 0
debug attr 40: adi,gpo3-inactive-state-high-enable value: 0
debug attr 41: adi,gpo2-inactive-state-high-enable value: 0
debug attr 42: adi,gpo1-inactive-state-high-enable value: 0
debug attr 43: adi,gpo0-inactive-state-high-enable value: 0
debug attr 44: adi,gpo-manual-mode-enable-mask value: 0
debug attr 45: adi,gpo-manual-mode-enable value: 0
debug attr 46: adi,aux-dac2-tx-delay-us value: 0
debug attr 47: adi,aux-dac2-rx-delay-us value: 0
debug attr 48: adi,aux-dac2-active-in-alert-enable value: 0
debug attr 49: adi,aux-dac2-active-in-tx-enable value: 0
debug attr 50: adi,aux-dac2-active-in-rx-enable value: 0
debug attr 51: adi,aux-dac2-default-value-mV value: 0
debug attr 52: adi,aux-dac1-tx-delay-us value: 0
debug attr 53: adi,aux-dac1-rx-delay-us value: 0
debug attr 54: adi,aux-dac1-active-in-alert-enable value: 0
debug attr 55: adi,aux-dac1-active-in-tx-enable value: 0
debug attr 56: adi,aux-dac1-active-in-rx-enable value: 0
debug attr 57: adi,aux-dac1-default-value-mV value: 0
debug attr 58: adi,aux-dac-manual-mode-enable value: 1
debug attr 59: adi,aux-adc-decimation value: 256
debug attr 60: adi,aux-adc-rate value: 40000000
debug attr 61: adi,temp-sense-decimation value: 256
debug attr 62: adi,temp-sense-periodic-measurement-enable value: 1
debug attr 63: adi,temp-sense-offset-signed value: 206
debug attr 64: adi,temp-sense-measurement-interval-ms value: 1000
debug attr 65: adi,elna-gaintable-all-index-enable value: 0
debug attr 66: adi,elna-rx2-gpo1-control-enable value: 0
debug attr 67: adi,elna-rx1-gpo0-control-enable value: 0
debug attr 68: adi,elna-bypass-loss-mdB value: 0
debug attr 69: adi,elna-gain-mdB value: 0
debug attr 70: adi,elna-settling-delay-ns value: 0
debug attr 71: adi,ctrl-outs-enable-mask value: 255
debug attr 72: adi,ctrl-outs-index value: 0
debug attr 73: adi,rssi-duration value: 1000
debug attr 74: adi,rssi-wait value: 1
debug attr 75: adi,rssi-delay value: 1
debug attr 76: adi,rssi-unit-is-rx-samples-enable value: 0
debug attr 77: adi,rssi-restart-mode value: 3
debug attr 78: adi,fagc-adc-large-overload-inc-steps value: 2
debug attr 79: adi,fagc-power-measurement-duration-in-state5 value: 64
debug attr 80: adi,fagc-rst-gla-if-en-agc-pulled-high-mode value: 0
debug attr 81: adi,fagc-rst-gla-en-agc-pulled-high-enable value: 0
debug attr 82: adi,fagc-rst-gla-large-lmt-overload-enable value: 1
debug attr 83: adi,fagc-rst-gla-large-adc-overload-enable value: 1
ERROR: READ LINE: -32
debug attr 84: adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt ERROR: Broken pipe (32)
debug attr 85: adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll ERROR: Broken pipe (32)
debug attr 86: adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable value: 8
debug attr 87: adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable value: 10
debug attr 88: adi,fagc-rst-gla-stronger-sig-thresh-above-ll value: 1
debug attr 89: adi,fagc-optimized-gain-offset value: 1
debug attr 90: adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable value: 10
debug attr 91: adi,fagc-use-last-lock-level-for-set-gain-enable value: 5
debug attr 92: adi,fagc-gain-index-type-after-exit-rx-mode value: 1
debug attr 93: adi,fagc-gain-increase-after-gain-lock-enable value: 1
debug attr 94: adi,fagc-final-overrange-count value: 0
debug attr 95: adi,fagc-lmt-final-settling-steps value: 0
debug attr 96: adi,fagc-lpf-final-settling-steps value: 3
debug attr 97: adi,fagc-lock-level-gain-increase-upper-limit value: 1
debug attr 98: adi,fagc-lock-level-lmt-gain-increase-enable value: 1
debug attr 99: adi,fagc-lp-thresh-increment-steps value: 5
debug attr 100: adi,fagc-lp-thresh-increment-time value: 1
debug attr 101: adi,fagc-allow-agc-gain-increase-enable value: 1
debug attr 102: adi,fagc-state-wait-time-ns value: 5
debug attr 103: adi,fagc-dec-pow-measurement-duration value: 0
debug attr 104: adi,agc-immed-gain-change-if-large-lmt-overload-enable value: 260
debug attr 105: adi,agc-immed-gain-change-if-large-adc-overload-enable value: 64
debug attr 106: adi,agc-gain-update-interval-us value: 0
debug attr 107: adi,agc-sync-for-gain-counter-enable value: 0
debug attr 108: adi,agc-dig-gain-step-size value: 1000
debug attr 109: adi,agc-dig-saturation-exceed-counter value: 0
debug attr 110: adi,agc-lmt-overload-large-inc-steps value: 4
debug attr 111: adi,agc-lmt-overload-small-exceed-counter value: 3
debug attr 112: adi,agc-lmt-overload-large-exceed-counter value: 2
debug attr 113: adi,agc-adc-lmt-small-overload-prevent-gain-inc-enable value: 10
debug attr 114: adi,agc-adc-large-overload-inc-steps value: 10
debug attr 115: adi,agc-adc-large-overload-exceed-counter value: 0
debug attr 116: adi,agc-adc-small-overload-exceed-counter value: 2
debug attr 117: adi,agc-outer-thresh-low-inc-steps value: 10
debug attr 118: adi,agc-outer-thresh-low value: 10
debug attr 119: adi,agc-inner-thresh-low-inc-steps value: 2
debug attr 120: adi,agc-inner-thresh-low value: 18
debug attr 121: adi,agc-inner-thresh-high-dec-steps value: 1
debug attr 122: adi,agc-inner-thresh-high value: 12
debug attr 123: adi,agc-outer-thresh-high-dec-steps value: 1
debug attr 124: adi,agc-outer-thresh-high value: 10
debug attr 125: adi,agc-attack-delay-extra-margin-us value: 2
debug attr 126: adi,mgc-split-table-ctrl-inp-gain-mode value: 5
debug attr 127: adi,mgc-dec-gain-step value: 1
debug attr 128: adi,mgc-inc-gain-step value: 0
debug attr 129: adi,mgc-rx2-ctrl-inp-enable value: 2
debug attr 130: adi,mgc-rx1-ctrl-inp-enable value: 2
debug attr 131: adi,gc-use-rx-fir-out-for-dec-pwr-meas-enable value: 0
debug attr 132: adi,gc-max-dig-gain value: 0
debug attr 133: adi,gc-dig-gain-enable value: 0
debug attr 134: adi,gc-low-power-thresh value: 15
debug attr 135: adi,gc-dec-pow-measurement-duration value: 0
debug attr 136: adi,gc-lmt-overload-low-thresh value: 24
debug attr 137: adi,gc-lmt-overload-high-thresh value: 8192
debug attr 138: adi,gc-adc-large-overload-thresh value: 704
debug attr 139: adi,gc-adc-small-overload-thresh value: 800
debug attr 140: adi,gc-adc-ovr-sample-size value: 58
debug attr 141: adi,gc-rx2-mode value: 47
debug attr 142: adi,gc-rx1-mode value: 4
debug attr 143: adi,update-tx-gain-in-alert-enable value: 2
debug attr 144: adi,tx-attenuation-mdB value: 2
debug attr 145: adi,rf-tx-bandwidth-hz value: 0
debug attr 146: adi,rf-rx-bandwidth-hz value: 10000
debug attr 147: adi,qec-tracking-slow-mode-enable value: 18000000
debug attr 148: adi,dc-offset-count-low-range value: 18000000
debug attr 149: adi,dc-offset-count-high-range value: 0
debug attr 150: adi,dc-offset-attenuation-low-range value: 50
debug attr 151: adi,dc-offset-attenuation-high-range value: 40
debug attr 152: adi,dc-offset-tracking-update-event-mask value: 5
debug attr 153: adi,clk-output-mode-select value: 6
debug attr 154: adi,tx-lo-powerdown-managed-enable value: 5
debug attr 155: adi,trx-synthesizer-target-fref-overwrite-hz value: 0
debug attr 156: adi,rx1-rx2-phase-inversion-enable value: 1
debug attr 157: adi,tx-rf-port-input-select-lock-enable value: 80008000
debug attr 158: adi,rx-rf-port-input-select-lock-enable value: 0
debug attr 159: adi,tx-rf-port-input-select value: 1
debug attr 160: adi,rx-rf-port-input-select value: 1
debug attr 161: adi,split-gain-table-mode-enable value: 0
debug attr 162: adi,1rx-1tx-mode-use-tx-num value: 0
debug attr 163: adi,1rx-1tx-mode-use-rx-num value: 0
debug attr 164: adi,2rx-2tx-mode-enable value: 1
debug attr 165: adi,digital-interface-tune-fir-disable value: 1
debug attr 166: adi,digital-interface-tune-skip-mode value: 0
debug attr 167: adi,tx-fastlock-pincontrol-enable value: 1
debug attr 168: adi,rx-fastlock-pincontrol-enable value: 0
debug attr 169: adi,rx-fastlock-delay-ns value: 0
debug attr 170: adi,tx-fastlock-delay-ns value: 0
debug attr 171: adi,tdd-skip-vco-cal-enable value: 0
debug attr 172: adi,tdd-use-dual-synth-mode-enable value: 0
debug attr 173: adi,debug-mode-enable value: 0
debug attr 174: adi,ensm-enable-txnrx-control-enable value: 0
debug attr 175: adi,ensm-enable-pin-pulse-mode-enable value: 0
debug attr 176: adi,frequency-division-duplex-independent-mode-enable value: 0
debug attr 177: adi,frequency-division-duplex-mode-enable value: 0
debug attr 178: direct_reg_access value: 0
ERROR: checking for trigger : No such device or address (6)
iio:device1: xadc
10 channels found:
voltage5: vccoddr (input)
2 channel-specific attributes found:
attr 0: raw value: 0x0
attr 1: scale ERROR: No such file or directory (2)
voltage0: vccint (input)
attr 0: raw value: 1826
attr 1: scale value: 0.732421875
voltage4: vccpaux (input)
attr 0: raw value: 1373
temp0: (input)
attr 0: offset value: 2440
attr 1: raw value: 0.732421875
attr 2: scale value: -2219
voltage7: vrefn (input)
attr 0: raw value: 2631
attr 1: scale value: 123.040771484
voltage1: vccaux (input)
attr 0: raw value: -1
voltage2: vccbram (input)
attr 0: raw value: 2442
voltage3: vccpint (input)
attr 0: raw value: 1374
voltage8: (input)
voltage6: vrefp (input)
attr 0: raw value: 3282
attr 1: scale value: 0.244140625
1 device-specific attributes found:
attr 0: sampling_frequency value: 1700
iio:device2: cf-ad9361-dds-core-lpc (buffer capable)
6 channels found:
voltage0: (output, index: 0, format: le:S16/16>>0)
4 channel-specific attributes found:
attr 0: calibphase value: 961538
attr 1: calibscale ERROR: No such file or directory (2)
attr 2: sampling_frequency value: 0.000000
attr 3: sampling_frequency_available value: 1.000000
voltage1: (output, index: 1, format: le:S16/16>>0)
attr 0: calibphase value: 2600000
attr 1: calibscale value: 2600000 325000
altvoltage3: TX1_Q_F2 (output)
attr 0: frequency value: 2600000
attr 1: phase value: 2600000 325000
attr 2: raw value: 999414
attr 3: sampling_frequency value: 0
attr 4: scale value: 1
altvoltage1: TX1_I_F2 (output)
attr 1: phase value: 0.000000
attr 3: sampling_frequency value: 90000
altvoltage0: TX1_I_F1 (output)
altvoltage2: TX1_Q_F1 (output)
2 device-specific attributes found:
attr 0: sync_start_enable value: 2600000
attr 1: sync_start_enable_available value: 0.000000
2 buffer-specific attributes found:
attr 0: data_available value: arm
attr 1: length_align_bytes value: arm
1 debug attributes found:
debug attr 0: direct_reg_access value: 0
iio:device3: cf-ad9361-lpc (buffer capable)
2 channels found:
voltage0: (input, index: 0, format: le:S12/16>>0)
7 channel-specific attributes found:
attr 0: calibbias value: 0x90162
attr 1: calibphase ERROR: No such file or directory (2)
attr 2: calibscale value: 0
attr 3: label value: 0.000000
attr 4: samples_pps value: 1.000000
attr 5: sampling_frequency ERROR: Function not implemented (38)
attr 6: sampling_frequency_available ERROR: No such device (19)
voltage1: (input, index: 1, format: le:S12/16>>0)
attr 0: calibbias value: 2600000
attr 1: calibphase value: 2600000 325000
attr 1: sync_start_enable_available value: 2600000 325000
attr 0: data_available value: disarm
2 debug attributes found:
debug attr 0: pseudorandom_err_check value: 0
debug attr 1: direct_reg_access value: 8
