My Adalm Pluto won't go below 323 Mhz
I reset my device with factory settings
I also expanded the range with the Pluto Hack
https://www.youtube.com/watch?v=g1jIAh6fG_A&ab_channel=TechMinds
with no luck.
any suggestions?
Thanks
Fernando
hack instead of hach
[edited by: fbc at 6:16 PM (GMT -5) on 9 Feb 2022]
Parents
  • Please see this page for instructions: https://wiki.analog.com/university/tools/pluto/users/customizing#revision_ball_firmware_versions
    When you log into Pluto, what does running
    fw_printenv attr_name
    and
    fw_printenv attr_val
    return?
    - Srikanth
  • device-fw v0.34
    hdl hdl_2019_r2-32-g43cdc
    buildroot 2019.08-4910-g35af59
    linux adi-xilinx-2020.1-535-g9c04de
    u-boot-xlnx v0.20-PlutoSDR-24-ga2c20
    NAME=Buildroot
    VERSION=2019.08-4910-g35af596319
    ID=buildroot
    VERSION_ID=2020.02.8
    PRETTY_NAME="Buildroot 2020.02.8"
    Jan 1 00:00:02 (none) syslog.info syslogd started: BusyBox v1.31.1
    Jan 1 00:00:02 (none) user.notice kernel: klogd started: BusyBox v1.31.1 (2021-08-20 14:00:32 CEST)
    Jan 1 00:00:02 (none) user.info kernel: Booting Linux on physical CPU 0x0
    Jan 1 00:00:02 (none) user.notice kernel: Linux version 5.4.0-00535-g9c04de11ae53 (michael@mhenneri-D06) (gcc version 8.2.0 (GCC)) #1 SMP PREEMPT Fri Aug 20 13:01:03 CEST 2021
    Jan 1 00:00:02 (none) user.info kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
    Jan 1 00:00:02 (none) user.info kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    Jan 1 00:00:02 (none) user.info kernel: OF: fdt: Machine model: Analog Devices PlutoSDR Rev.B (Z7010/AD9363)
    Jan 1 00:00:02 (none) user.info kernel: Memory policy: Data cache writealloc
    Jan 1 00:00:02 (none) user.info kernel: cma: Reserved 256 MiB at 0x0e400000
    Jan 1 00:00:02 (none) user.debug kernel: On node 0 totalpages: 131072
    Jan 1 00:00:02 (none) user.debug kernel: Normal zone: 1024 pages used for memmap
    Jan 1 00:00:02 (none) user.debug kernel: Normal zone: 0 pages reserved
    Jan 1 00:00:02 (none) user.debug kernel: Normal zone: 131072 pages, LIFO batch:31
    Jan 1 00:00:02 (none) user.info kernel: percpu: Embedded 15 pages/cpu s29196 r8192 d24052 u61440
    Jan 1 00:00:02 (none) user.debug kernel: pcpu-alloc: s29196 r8192 d24052 u61440 alloc=15*4096
    Jan 1 00:00:02 (none) user.debug kernel: pcpu-alloc: [0] 0 [0] 1
    Jan 1 00:00:02 (none) user.info kernel: Built 1 zonelists, mobility grouping on. Total pages: 130048
    Jan 1 00:00:02 (none) user.notice kernel: Kernel command line: console=ttyPS0,115200 maxcpus=1 rootfstype=ramfs root=/dev/ram0 rw quiet loglevel=4 uboot=U-Boot PlutoSDR v0.20-PlutoSDR-00053-g89d0754 (Jan 14 2019 - 13:15:56 +0100)
    Jan 1 00:00:02 (none) user.info kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    Jan 1 00:00:02 (none) user.info kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
    Jan 1 00:00:02 (none) user.info kernel: mem auto-init: stack:off, heap alloc:off, heap free:off
    Jan 1 00:00:02 (none) user.info kernel: Memory: 241008K/524288K available (6144K kernel code, 613K rwdata, 1616K rodata, 1024K init, 138K bss, 21136K reserved, 262144K cma-reserved, 0K highmem)
    Jan 1 00:00:02 (none) user.info kernel: rcu: Preemptible hierarchical RCU implementation.
    Jan 1 00:00:02 (none) user.info kernel: rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
    Jan 1 00:00:02 (none) user.info kernel: Tasks RCU enabled.
    Jan 1 00:00:02 (none) user.info kernel: rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    Jan 1 00:00:02 (none) user.info kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    Jan 1 00:00:02 (none) user.info kernel: NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    Jan 1 00:00:02 (none) user.info kernel: efuse mapped to (ptrval)
    Jan 1 00:00:02 (none) user.info kernel: slcr mapped to (ptrval)
    Jan 1 00:00:02 (none) user.warn kernel: L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
    Jan 1 00:00:02 (none) user.warn kernel: L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
    Jan 1 00:00:02 (none) user.info kernel: L2C-310 erratum 769419 enabled
    Jan 1 00:00:02 (none) user.info kernel: L2C-310 enabling early BRESP for Cortex-A9
    Jan 1 00:00:02 (none) user.info kernel: L2C-310 full line of zeros enabled for Cortex-A9
    Jan 1 00:00:02 (none) user.info kernel: L2C-310 ID prefetch enabled, offset 1 lines
    Jan 1 00:00:02 (none) user.info kernel: L2C-310 dynamic clock gating enabled, standby mode enabled
    Jan 1 00:00:02 (none) user.info kernel: L2C-310 cache controller enabled, 8 ways, 512 kB
    Jan 1 00:00:02 (none) user.info kernel: L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
    Jan 1 00:00:02 (none) user.notice kernel: random: get_random_bytes called from start_kernel+0x270/0x450 with crng_init=0
    Jan 1 00:00:02 (none) user.info kernel: zynq_clock_init: clkc starts at (ptrval)
    Jan 1 00:00:02 (none) user.info kernel: Zynq clock init
    Jan 1 00:00:02 (none) user.info kernel: sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
    Jan 1 00:00:02 (none) user.info kernel: clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
    Jan 1 00:00:02 (none) user.info kernel: Switching to timer-based delay loop, resolution 3ns
    Jan 1 00:00:02 (none) user.info kernel: clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
    Jan 1 00:00:02 (none) user.info kernel: timer #0 at (ptrval), irq=17
    Jan 1 00:00:02 (none) user.info kernel: Console: colour dummy device 80x30
    Jan 1 00:00:02 (none) user.info kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 666.66 BogoMIPS (lpj=3333333)
    Jan 1 00:00:02 (none) user.info kernel: pid_max: default: 32768 minimum: 301
    Jan 1 00:00:02 (none) user.info kernel: Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
    Jan 1 00:00:02 (none) user.info kernel: Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
    Jan 1 00:00:02 (none) user.info kernel: CPU: Testing write buffer coherency: ok
    Jan 1 00:00:02 (none) user.info kernel: CPU0: Spectre v2: using BPIALL workaround
    Jan 1 00:00:02 (none) user.info kernel: CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    Jan 1 00:00:02 (none) user.info kernel: Setting up static identity map for 0x100000 - 0x100060
    Jan 1 00:00:02 (none) user.info kernel: rcu: Hierarchical SRCU implementation.
    Jan 1 00:00:02 (none) user.info kernel: smp: Bringing up secondary CPUs ...
    Jan 1 00:00:02 (none) user.info kernel: smp: Brought up 1 node, 1 CPU
    Jan 1 00:00:02 (none) user.info kernel: SMP: Total of 1 processors activated (666.66 BogoMIPS).
    Jan 1 00:00:02 (none) user.info kernel: CPU: All CPU(s) started in SVC mode.
    Jan 1 00:00:02 (none) user.info kernel: devtmpfs: initialized
    Jan 1 00:00:02 (none) user.info kernel: VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
    Jan 1 00:00:02 (none) user.info kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    Jan 1 00:00:02 (none) user.info kernel: futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    Jan 1 00:00:02 (none) user.info kernel: pinctrl core: initialized pinctrl subsystem
    Jan 1 00:00:02 (none) user.info kernel: NET: Registered protocol family 16
    Jan 1 00:00:02 (none) user.info kernel: DMA: preallocated 256 KiB pool for atomic coherent allocations
    Jan 1 00:00:02 (none) user.info kernel: cpuidle: using governor ladder
    Jan 1 00:00:02 (none) user.info kernel: hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
    Jan 1 00:00:02 (none) user.info kernel: hw-breakpoint: maximum watchpoint size is 4 bytes.
    Jan 1 00:00:02 (none) user.info kernel: zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0x(ptrval)
    Jan 1 00:00:02 (none) user.info kernel: e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 25, base_baud = 6249999) is a xuartps
    Jan 1 00:00:02 (none) user.info kernel: printk: console [ttyPS0] enabled
    Jan 1 00:00:02 (none) user.notice kernel: SCSI subsystem initialized
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver usbfs
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver hub
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new device driver usb
    Jan 1 00:00:02 (none) user.info kernel: FPGA manager framework
    Jan 1 00:00:02 (none) user.info kernel: clocksource: Switched to clocksource arm_global_timer
    Jan 1 00:00:02 (none) user.info kernel: thermal_sys: Registered thermal governor 'step_wise'
    Jan 1 00:00:02 (none) user.info kernel: NET: Registered protocol family 2
    Jan 1 00:00:02 (none) user.info kernel: tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    Jan 1 00:00:02 (none) user.info kernel: TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
    Jan 1 00:00:02 (none) user.info kernel: TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
    Jan 1 00:00:02 (none) user.info kernel: TCP: Hash tables configured (established 4096 bind 4096)
    Jan 1 00:00:02 (none) user.info kernel: UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
    Jan 1 00:00:02 (none) user.info kernel: UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
    Jan 1 00:00:02 (none) user.info kernel: Trying to unpack rootfs image as initramfs...
    Jan 1 00:00:02 (none) user.info kernel: Freeing initrd memory: 5436K
    Jan 1 00:00:02 (none) user.warn kernel: hw perfevents: no interrupt-affinity property for /pmu@f8891000, guessing.
    Jan 1 00:00:02 (none) user.info kernel: hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
    Jan 1 00:00:02 (none) user.notice kernel: Initialise system trusted keyrings
    Jan 1 00:00:02 (none) user.info kernel: workingset: timestamp_bits=30 max_order=17 bucket_order=0
    Jan 1 00:00:02 (none) user.info kernel: jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
    Jan 1 00:00:02 (none) user.notice kernel: Key type asymmetric registered
    Jan 1 00:00:02 (none) user.notice kernel: Asymmetric key parser 'x509' registered
    Jan 1 00:00:02 (none) user.info kernel: io scheduler mq-deadline registered
    Jan 1 00:00:02 (none) user.info kernel: io scheduler kyber registered
    Jan 1 00:00:02 (none) user.info kernel: zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
    Jan 1 00:00:02 (none) user.info kernel: brd: module loaded
    Jan 1 00:00:02 (none) user.info kernel: loop: module loaded
    Jan 1 00:00:02 (none) user.info kernel: spi-nor spi1.0: SPI-NOR-UniqueID 1044739659930004180010009d1128f096
    Jan 1 00:00:02 (none) user.warn kernel: spi-nor spi1.0: found n25q256ax1, expected n25q256a
    Jan 1 00:00:02 (none) user.info kernel: spi-nor spi1.0: n25q256ax1 (32768 Kbytes)
    Jan 1 00:00:02 (none) user.notice kernel: 4 fixed-partitions partitions found on MTD device spi1.0
    Jan 1 00:00:02 (none) user.notice kernel: Creating 4 MTD partitions on "spi1.0":
    Jan 1 00:00:02 (none) user.notice kernel: 0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
    Jan 1 00:00:02 (none) user.notice kernel: 0x000000100000-0x000000120000 : "qspi-uboot-env"
    Jan 1 00:00:02 (none) user.notice kernel: 0x000000120000-0x000000200000 : "qspi-nvmfs"
    Jan 1 00:00:02 (none) user.notice kernel: 0x000000200000-0x000002000000 : "qspi-linux"
    Jan 1 00:00:02 (none) user.info kernel: libphy: Fixed MDIO Bus: probed
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver rt2500usb
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver rt73usb
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver rt2800usb
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver rtl8187
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver rtl8192cu
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver rtl8xxxu
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver r8152
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver lan78xx
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver asix
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver ax88179_178a
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver cdc_ether
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver dm9601
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver smsc75xx
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver smsc95xx
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver rndis_host
    Jan 1 00:00:02 (none) user.info kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver usb-storage
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver usbserial_generic
    Jan 1 00:00:02 (none) user.info kernel: usbserial: USB Serial support registered for generic
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver ftdi_sio
    Jan 1 00:00:02 (none) user.info kernel: usbserial: USB Serial support registered for FTDI USB Serial Device
    Jan 1 00:00:02 (none) user.warn kernel: chipidea-usb2 e0002000.usb: e0002000.usb supply vbus not found, using dummy regulator
    Jan 1 00:00:02 (none) user.info kernel: ULPI transceiver vendor/product ID 0x0424/0x0007
    Jan 1 00:00:02 (none) user.info kernel: Found SMSC USB3320 ULPI transceiver.
    Jan 1 00:00:02 (none) user.info kernel: ULPI integrity check: passed.
    Jan 1 00:00:02 (none) user.info kernel: i2c /dev entries driver
    Jan 1 00:00:02 (none) user.info kernel: cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer with timeout 10s
    Jan 1 00:00:02 (none) user.info kernel: Xilinx Zynq CpuIdle Driver started
    Jan 1 00:00:02 (none) user.info kernel: ledtrig-cpu: registered to indicate activity on CPUs
    Jan 1 00:00:02 (none) user.info kernel: hidraw: raw HID events driver (C) Jiri Kosina
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver usbhid
    Jan 1 00:00:02 (none) user.info kernel: usbhid: USB HID core driver
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver r8712u
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver r8188eu
    Jan 1 00:00:02 (none) user.info kernel: ad9361 spi0.0: ad9361_probe : enter (ad9363a)
    Jan 1 00:00:02 (none) user.notice kernel: random: fast init done
    Jan 1 00:00:02 (none) user.info kernel: ad9361 spi0.0: ad9361_probe : AD936x Rev 2 successfully initialized
    Jan 1 00:00:02 (none) user.info kernel: cf_axi_dds 79024000.cf-ad9361-dds-core-lpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x79024000 mapped to 0x(ptrval), probed DDS AD9364
    Jan 1 00:00:02 (none) user.info kernel: fpga_manager fpga0: Xilinx Zynq FPGA Manager registered
    Jan 1 00:00:02 (none) user.info kernel: NET: Registered protocol family 17
    Jan 1 00:00:02 (none) user.info kernel: lib80211: common routines for IEEE802.11 drivers
    Jan 1 00:00:02 (none) user.debug kernel: lib80211_crypt: registered algorithm 'NULL'
    Jan 1 00:00:02 (none) user.debug kernel: lib80211_crypt: registered algorithm 'WEP'
    Jan 1 00:00:02 (none) user.debug kernel: lib80211_crypt: registered algorithm 'CCMP'
    Jan 1 00:00:02 (none) user.notice kernel: Registering SWP/SWPB emulation handler
    Jan 1 00:00:02 (none) user.notice kernel: Loading compiled-in X.509 certificates
    Jan 1 00:00:02 (none) user.info kernel: cf_axi_adc 79020000.cf-ad9361-lpc: ADI AIM (10.01.b) at 0x79020000 mapped to 0x(ptrval), probed ADC AD9364 as MASTER
    Jan 1 00:00:02 (none) user.info kernel: input: gpio_keys as /devices/soc0/gpio_keys/input/input0
    Jan 1 00:00:02 (none) user.notice kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
    Jan 1 00:00:02 (none) user.notice kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    Jan 1 00:00:02 (none) user.warn kernel: platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    Jan 1 00:00:02 (none) user.info kernel: cfg80211: failed to load regulatory.db
    Jan 1 00:00:02 (none) user.info kernel: Freeing unused kernel memory: 1024K
    Jan 1 00:00:02 (none) user.info kernel: Run /init as init process
    Jan 1 00:00:03 (none) user.info kernel: file system registered
    Jan 1 00:00:03 (none) user.warn kernel: using random self ethernet address
    Jan 1 00:00:03 (none) user.warn kernel: using random host ethernet address
    Jan 1 00:00:03 (none) user.info kernel: Mass Storage Function, version: 2009/09/11
    Jan 1 00:00:03 (none) user.info kernel: LUN: removable file: (no medium)
    Jan 1 00:00:03 (none) user.info kernel: read descriptors
    Jan 1 00:00:03 (none) user.info kernel: read strings
    Jan 1 00:00:03 (none) user.info kernel: usb0: HOST MAC 00:e0:22:a0:6b:0c
    Jan 1 00:00:03 (none) user.info kernel: usb0: MAC 00:05:f7:8b:6c:aa
    Jan 1 00:00:03 (none) user.notice kernel: random: dbus-uuidgen: uninitialized urandom read (12 bytes read)
    Jan 1 00:00:03 (none) user.notice kernel: random: dbus-uuidgen: uninitialized urandom read (8 bytes read)
    Jan 1 00:00:03 (none) user.notice kernel: random: dbus-daemon: uninitialized urandom read (12 bytes read)
    Jan 1 00:00:03 (none) user.notice kernel: random: crng init done
    Jan 1 00:00:03 (none) user.notice kernel: random: 1 urandom warning(s) missed due to ratelimiting
    Jan 1 00:00:03 (none) user.info kernel: configfs-gadget gadget: high-speed config #1: c
    Jan 1 00:00:04 (none) user.notice root: ip: SIOCGIFFLAGS: No such device
    Jan 1 00:00:04 (none) daemon.info avahi-daemon[324]: Found user 'avahi' (UID 1000) and group 'avahi' (GID 1000).
    Jan 1 00:00:04 (none) daemon.info avahi-daemon[324]: Successfully dropped root privileges.
    Jan 1 00:00:04 (none) daemon.info avahi-daemon[324]: avahi-daemon 0.7 starting up.
    Jan 1 00:00:04 (none) daemon.warn avahi-daemon[324]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
    Jan 1 00:00:04 (none) daemon.warn avahi-daemon[324]: Failed to open /etc/resolv.conf: No such file or directory
    Jan 1 00:00:04 (none) daemon.info avahi-daemon[324]: Loading service file /etc/avahi/services/sftp-ssh.service.
    Jan 1 00:00:04 (none) daemon.info avahi-daemon[324]: Loading service file /etc/avahi/services/ssh.service.
    Jan 1 00:00:04 (none) daemon.warn avahi-daemon[324]: socket() failed: Address family not supported by protocol
    Jan 1 00:00:04 (none) daemon.notice avahi-daemon[324]: Failed to create IPv6 socket, proceeding in IPv4 only mode
    Jan 1 00:00:04 (none) daemon.info avahi-daemon[324]: Joining mDNS multicast group on interface usb0.IPv4 with address 192.168.2.1.
    Jan 1 00:00:04 (none) daemon.info avahi-daemon[324]: New relevant interface usb0.IPv4 for mDNS.
    Jan 1 00:00:04 (none) daemon.info avahi-daemon[324]: Network interface enumeration completed.
    Jan 1 00:00:04 (none) daemon.info avahi-daemon[324]: Registering new address record for 192.168.2.1 on usb0.IPv4.
    Jan 1 00:00:04 (none) authpriv.info dropbear[332]: Running in background
    Jan 1 00:00:04 (none) daemon.info : starting pid 336, tty '/dev/ttyPS0': '/sbin/getty -L ttyPS0 0 vt100 '
    Jan 1 00:00:04 (none) daemon.info : starting pid 337, tty '/dev/ttyGS0': '/sbin/getty -L ttyGS0 0 vt100 '
    Jan 1 00:00:05 (none) daemon.info avahi-daemon[324]: Server startup complete. Host name is pluto.local. Local service cookie is 610619128.
    Jan 1 00:00:06 (none) daemon.info avahi-daemon[324]: Service "pluto" (/etc/avahi/services/ssh.service) successfully established.
    Jan 1 00:00:06 (none) daemon.info avahi-daemon[324]: Service "pluto" (/etc/avahi/services/sftp-ssh.service) successfully established.
    Jan 1 00:03:16 (none) auth.info login[337]: root login on 'ttyGS0'
    processor : 0
    model name : ARMv7 Processor rev 0 (v7l)
    BogoMIPS : 666.66
    Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpd32
    CPU implementer : 0x41
    CPU architecture: 7
    CPU variant : 0x3
    CPU part : 0xc09
    CPU revision : 0
    Hardware : Xilinx Zynq Platform
    Revision : 0003
    Serial : 0000000000000000
    CPU0
    16: 0 GIC-0 27 Edge gt
    17: 0 GIC-0 43 Level ttc_clockevent
    18: 59444 GIC-0 29 Edge twd
    19: 0 GIC-0 37 Level arm-pmu
    20: 0 GIC-0 38 Level arm-pmu
    21: 54 GIC-0 39 Level f8007100.adc
    24: 0 GIC-0 35 Level f800c000.ocmc
    25: 30 GIC-0 82 Level xuartps
    26: 4133 GIC-0 58 Level e0006000.spi
    27: 43739 GIC-0 51 Level e000d000.spi
    38: 0 GIC-0 40 Level f8007000.devcfg
    44: 3829 GIC-0 53 Level e0002000.usb
    46: 6 GIC-0 91 Level 41600000.i2c
    47: 0 GIC-0 89 Level 7c400000.dma
    48: 0 GIC-0 88 Level 7c420000.dma
    49: 0 zynq-gpio 14 Edge Button
    IPI1: 0 0 Timer broadcast interrupts
    IPI2: 0 0 Rescheduling interrupts
    IPI3: 0 0 Function call interrupts
    IPI4: 0 0 CPU stop interrupts
    IPI5: 0 0 IRQ work interrupts
    IPI6: 0 0 completion interrupts
    Err: 0
    00000000-1fffffff : System RAM
    00008000-008fffff : Kernel code
    00a00000-00abc15f : Kernel data
    41600000-4160ffff : 41600000.i2c
    79020000-79025fff : 79020000.cf-ad9361-lpc
    7c400000-7c40ffff : 7c400000.dma
    7c420000-7c42ffff : 7c420000.dma
    e0001000-e0001fff : xuartps
    e0002000-e0002fff : usb@e0002000
    e0002000-e0002fff : ci_hdrc.0
    e0006000-e0006fff : e0006000.spi
    e000a000-e000afff : e000a000.gpio
    e000d000-e000dfff : e000d000.spi
    f8003000-f8003fff : dmac@f8003000
    f8005000-f8005fff : f8005000.watchdog
    f8007000-f80070ff : f8007000.devcfg
    f8007100-f800711f : f8007100.adc
    f800c000-f800cfff : f800c000.ocmc
    f8801000-f8801fff : etb@f8801000
    f8803000-f8803fff : tpiu@f8803000
    f8804000-f8804fff : funnel@f8804000
    f889c000-f889cfff : ptm@f889c000
    f889d000-f889dfff : ptm@f889d000
    fffc0000-ffffffff : f800c000.ocmc
    MemTotal: 509612 kB
    MemFree: 454312 kB
    MemAvailable: 452756 kB
    Buffers: 28 kB
    Cached: 44680 kB
    SwapCached: 0 kB
    Active: 1628 kB
    Inactive: 44 kB
    Active(anon): 1600 kB
    Inactive(anon): 44 kB
    Active(file): 28 kB
    Inactive(file): 0 kB
    Unevictable: 44580 kB
    Mlocked: 0 kB
    HighTotal: 0 kB
    HighFree: 0 kB
    LowTotal: 509612 kB
    LowFree: 454312 kB
    SwapTotal: 0 kB
    SwapFree: 0 kB
    Dirty: 24 kB
    Writeback: 0 kB
    AnonPages: 1588 kB
    Mapped: 4040 kB
    Shmem: 72 kB
    KReclaimable: 2728 kB
    Slab: 5808 kB
    SReclaimable: 2728 kB
    SUnreclaim: 3080 kB
    KernelStack: 416 kB
    PageTables: 240 kB
    NFS_Unstable: 0 kB
    Bounce: 0 kB
    WritebackTmp: 0 kB
    CommitLimit: 254804 kB
    Committed_AS: 30560 kB
    VmallocTotal: 507904 kB
    VmallocUsed: 340 kB
    VmallocChunk: 0 kB
    Percpu: 208 kB
    CmaTotal: 262144 kB
    CmaFree: 261884 kB
    enable prepare protect duty
    clock count count count rate accuracy phase cycle nshot
    spi0.0-tx_lo_dummy 0 0 0 1225000000 0 0 50000 0
    spi0.0-rx_lo_dummy 0 0 0 1200000000 0 0 50000 0
    ad9364_ext_refclk 4 4 0 39999778 200000 0 50000 0
    spi0.0-bb_refclk 1 1 0 39999778 200000 0 50000 0
    spi0.0-bbpll_clk 1 1 0 983040002 200000 0 50000 0
    spi0.0-adc_clk 1 1 0 245760000 200000 0 50000 0
    spi0.0-dac_clk 1 1 0 122880000 200000 0 50000 0
    spi0.0-t2_clk 1 1 0 122880000 200000 0 50000 0
    spi0.0-t1_clk 1 1 0 61440000 200000 0 50000 0
    spi0.0-clktf_clk 1 1 0 30720000 200000 0 50000 0
    spi0.0-tx_sampl_clk 1 1 0 30720000 200000 0 50000 0
    spi0.0-r2_clk 0 0 0 122880000 200000 0 50000 0
    spi0.0-r1_clk 0 0 0 61440000 200000 0 50000 0
    spi0.0-clkrf_clk 0 0 0 30720000 200000 0 50000 0
    spi0.0-rx_sampl_clk 0 0 0 30720000 200000 0 50000 0
    spi0.0-rx_refclk 1 1 0 79999556 200000 0 50000 0
    spi0.0-rx_rfpll_int 1 1 0 1200000000 200000 0 50000 0
    spi0.0-rx_rfpll 1 1 0 1200000000 200000 0 50000 0
    spi0.0-tx_refclk 1 1 0 79999556 200000 0 50000 0
    spi0.0-tx_rfpll_int 1 1 0 1225000000 200000 0 50000 0
    spi0.0-tx_rfpll 1 1 0 1225000000 200000 0 50000 0
    ps_clk 3 3 0 33333333 0 0 50000 0
    iopll_int 1 1 0 999999990 0 0 50000 0
    iopll 9 9 0 999999990 0 0 50000 0
    dbg_mux 1 1 0 999999990 0 0 50000 0
    dbg_div 1 1 0 66666666 0 0 50000 0
    dbg_emio_mux 1 1 0 66666666 0 0 50000 0
    dbg_trc 1 1 0 66666666 0 0 50000 0
    can_mux 0 0 0 999999990 0 0 50000 0
    can_div0 0 0 0 40000000 0 0 50000 0
    can_div1 0 0 0 8000000 0 0 50000 0
    can1_gate 0 0 0 8000000 0 0 50000 0
    can1 0 0 0 8000000 0 0 50000 0
    can0_gate 0 0 0 8000000 0 0 50000 0
    can0 0 0 0 8000000 0 0 50000 0
    gem1_mux 0 0 0 999999990 0 0 50000 0
    gem1_div0 0 0 0 16666667 0 0 50000 0
    gem1_div1 0 0 0 16666667 0 0 50000 0
    gem1_emio_mux 0 0 0 16666667 0 0 50000 0
    gem1 0 0 0 16666667 0 0 50000 0
    gem0_mux 0 0 0 999999990 0 0 50000 0
    gem0_div0 0 0 0 16666667 0 0 50000 0
    gem0_div1 0 0 0 16666667 0 0 50000 0
    gem0_emio_mux 0 0 0 16666667 0 0 50000 0
    gem0 0 0 0 16666667 0 0 50000 0
    spi0_mux 1 1 0 999999990 0 0 50000 0
    spi0_div 1 1 0 166666665 0 0 50000 0
    spi1 0 0 0 166666665 0 0 50000 0
    spi0 1 1 0 166666665 0 0 50000 0
    uart0_mux 1 1 0 999999990 0 0 50000 0
    uart0_div 1 1 0 99999999 0 0 50000 0
    uart1 1 1 0 99999999 0 0 50000 0
    uart0 0 0 0 99999999 0 0 50000 0
    sdio0_mux 0 0 0 999999990 0 0 50000 0
    sdio0_div 0 0 0 33333333 0 0 50000 0
    sdio1 0 0 0 33333333 0 0 50000 0
    sdio0 0 0 0 33333333 0 0 50000 0
    pcap_mux 1 1 0 999999990 0 0 50000 0
    pcap_div 1 1 0 199999998 0 0 50000 0
    pcap 1 2 0 199999998 0 0 50000 0
    lqspi_mux 1 1 0 999999990 0 0 50000 0
    lqspi_div 1 1 0 199999998 0 0 50000 0
    lqspi 1 1 0 199999998 0 0 50000 0
    fclk3_mux 1 1 0 999999990 0 0 50000 0
    fclk3_div0 1 1 0 41666667 0 0 50000 0
    fclk3_div1 1 1 0 41666667 0 0 50000 0
    fclk3 1 1 0 41666667 0 0 50000 0
    fclk2_mux 1 1 0 999999990 0 0 50000 0
    fclk2_div0 1 1 0 41666667 0 0 50000 0
    fclk2_div1 1 1 0 41666667 0 0 50000 0
    fclk2 1 1 0 41666667 0 0 50000 0
    fclk1_mux 1 1 0 999999990 0 0 50000 0
    fclk1_div0 1 1 0 199999998 0 0 50000 0
    fclk1_div1 1 1 0 199999998 0 0 50000 0
    fclk1 3 3 0 199999998 0 0 50000 0
    fclk0_mux 1 1 0 999999990 0 0 50000 0
    fclk0_div0 1 1 0 199999998 0 0 50000 0
    fclk0_div1 1 1 0 99999999 0 0 50000 0
    fclk0 1 2 0 99999999 0 0 50000 0
    ddrpll_int 1 1 0 1066666656 0 0 50000 0
    ddrpll 3 3 0 1066666656 0 0 50000 0
    dci_div0 1 1 0 71111111 0 0 50000 0
    dci_div1 1 1 0 10158731 0 0 50000 0
    dci 1 1 0 10158731 0 0 50000 0
    ddr3x_div 1 1 0 533333328 0 0 50000 0
    ddr3x 1 1 0 533333328 0 0 50000 0
    ddr2x_div 1 1 0 355555552 0 0 50000 0
    ddr2x 1 1 0 355555552 0 0 50000 0
    armpll_int 1 1 0 1333333320 0 0 50000 0
    armpll 1 1 0 1333333320 0 0 50000 0
    smc_mux 0 0 0 1333333320 0 0 50000 0
    smc_div 0 0 0 22222222 0 0 50000 0
    smc 0 0 0 22222222 0 0 50000 0
    cpu_mux 1 1 0 1333333320 0 0 50000 0
    cpu_div 3 3 0 666666660 0 0 50000 0
    cpu_1x_div 1 1 0 111111110 0 0 50000 0
    cpu_1x 9 9 0 111111110 0 0 50000 0
    smc_aper 0 0 0 111111110 0 0 50000 0
    lqspi_aper 1 1 0 111111110 0 0 50000 0
    gpio_aper 1 1 0 111111110 0 0 50000 0
    uart1_aper 1 1 0 111111110 0 0 50000 0
    uart0_aper 0 0 0 111111110 0 0 50000 0
    i2c1_aper 0 0 0 111111110 0 0 50000 0
    i2c0_aper 0 0 0 111111110 0 0 50000 0
    can1_aper 0 0 0 111111110 0 0 50000 0
    can0_aper 0 0 0 111111110 0 0 50000 0
    spi1_aper 0 0 0 111111110 0 0 50000 0
    spi0_aper 1 1 0 111111110 0 0 50000 0
    sdio1_aper 0 0 0 111111110 0 0 50000 0
    sdio0_aper 0 0 0 111111110 0 0 50000 0
    gem1_aper 0 0 0 111111110 0 0 50000 0
    gem0_aper 0 0 0 111111110 0 0 50000 0
    usb1_aper 0 0 0 111111110 0 0 50000 0
    usb0_aper 1 1 0 111111110 0 0 50000 0
    dbg_apb 1 1 0 111111110 0 0 50000 0
    swdt 1 1 0 111111110 0 0 50000 0
    cpu_2x_div 1 1 0 222222220 0 0 50000 0
    cpu_2x 1 1 0 222222220 0 0 50000 0
    dma 0 0 0 222222220 0 0 50000 0
    cpu_3or2x_div 1 1 0 333333330 0 0 50000 0
    cpu_3or2x 2 2 0 333333330 0 0 50000 0
    cpu_6or4x 0 0 0 666666660 0 0 50000 0
    can1_mio_mux 0 0 0 0 0 0 50000 0
    can0_mio_mux 0 0 0 0 0 0 50000 0
    /sys/kernel/debug/regmap/7c420000.dma/access:080: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:084: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:088: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:400: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:404: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:408: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:40c: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:410: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:414: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:418: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:41c: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:420: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:424: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:428: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:42c: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:430: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:434: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:438: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:43c: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:440: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:444: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:44c: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:450: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/registers:080: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:084: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:088: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:400: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:404: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:408: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:40c: 00000001
    /sys/kernel/debug/regmap/7c420000.dma/registers:410: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:414: 1ffffff8
    /sys/kernel/debug/regmap/7c420000.dma/registers:418: 00000007
    /sys/kernel/debug/regmap/7c420000.dma/registers:41c: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:420: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:424: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:428: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:42c: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:430: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:434: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:438: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:43c: 00000701
    /sys/kernel/debug/regmap/7c420000.dma/registers:440: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:444: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:44c: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:450: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/range:80-88
    /sys/kernel/debug/regmap/7c420000.dma/range:400-444
    /sys/kernel/debug/regmap/7c420000.dma/range:44c-450
    /sys/kernel/debug/regmap/7c420000.dma/name:dma-axi-dmac
    /sys/kernel/debug/regmap/7c400000.dma/access:080: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:084: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:088: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:400: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:404: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:408: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:40c: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:410: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:414: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:418: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:41c: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:420: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:424: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:428: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:42c: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:430: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:434: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:438: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:43c: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:440: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:444: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:44c: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:450: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/registers:080: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:084: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:088: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:400: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:404: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:408: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:40c: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:410: 1ffffff8
    /sys/kernel/debug/regmap/7c400000.dma/registers:414: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:418: 00000007
    /sys/kernel/debug/regmap/7c400000.dma/registers:41c: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:420: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:424: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:428: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:42c: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:430: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:434: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:438: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:43c: 00000701
    /sys/kernel/debug/regmap/7c400000.dma/registers:440: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:444: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:44c: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:450: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/range:80-88
    /sys/kernel/debug/regmap/7c400000.dma/range:400-444
    /sys/kernel/debug/regmap/7c400000.dma/range:44c-450
    /sys/kernel/debug/regmap/7c400000.dma/name:dma-axi-dmac
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:000: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:004: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:008: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:00c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:010: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:014: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:018: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:01c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:020: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:024: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:028: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:02c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:030: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:034: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:038: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:03c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:040: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:044: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:048: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:04c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:050: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:054: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:058: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:05c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:060: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:064: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:068: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:06c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:070: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:074: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:078: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:07c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:080: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:084: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:088: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:08c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:090: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:094: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:098: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:09c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0a0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0a4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0a8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0ac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0b0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0b4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0b8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0bc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0c0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0c4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0c8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0cc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0d0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0d4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0d8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0dc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0e0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0e4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0e8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0ec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0f0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0f4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0f8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0fc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:100: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:104: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:108: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:10c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:110: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:114: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:118: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:11c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:120: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:124: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:128: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:12c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:130: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:134: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:138: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:13c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:140: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:144: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:148: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:14c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:150: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:154: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:158: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:15c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:160: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:164: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:168: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:16c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:170: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:174: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:178: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:17c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:180: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:184: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:188: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:18c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:190: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:194: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:198: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:19c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1a0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1a4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1a8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1ac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1b0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1b4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1b8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1bc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1c0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1c4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1c8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1cc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1d0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1d4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1d8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1dc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1e0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1e4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1e8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1ec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1f0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1f4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1f8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1fc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:200: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:204: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:208: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:20c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:210: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:214: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:218: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:21c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:220: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:224: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:228: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:22c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:230: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:234: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:238: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:23c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:240: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:244: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:248: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:24c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:250: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:254: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:258: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:25c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:260: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:264: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:268: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:26c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:270: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:274: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:278: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:27c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:280: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:284: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:288: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:28c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:290: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:294: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:298: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:29c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2a0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2a4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2a8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2ac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2b0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2b4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2b8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2bc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2c0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2c4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2c8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2cc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2d0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2d4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2d8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2dc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2e0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2e4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2e8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2ec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2f0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2f4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2f8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2fc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:300: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:304: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:308: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:30c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:310: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:314: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:318: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:31c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:320: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:324: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:328: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:32c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:330: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:334: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:338: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:33c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:340: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:344: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:348: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:34c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:350: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:354: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:358: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:35c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:360: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:364: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:368: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:36c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:370: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:374: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:378: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:37c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:380: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:384: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:388: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:38c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:390: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:394: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:398: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:39c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3a0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3a4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3a8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3ac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3b0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3b4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3b8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3bc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3c0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3c4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3c8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3cc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3d0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3d4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3d8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3dc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3e0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3e4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3e8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3ec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3f0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3f4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3f8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3fc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:400: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:404: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:408: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:40c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:410: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:414: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:418: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:41c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:420: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:424: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:428: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:42c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:430: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:434: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:438: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:43c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:440: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:444: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:448: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:44c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:450: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:454: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:458: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:45c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:460: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:464: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:468: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:46c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:470: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:474: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:478: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:47c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:480: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:484: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:488: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:48c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:490: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:494: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:498: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:49c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4a0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4a4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4a8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4ac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4b0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4b4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4b8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4bc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4c0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4c4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4c8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4cc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4d0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4d4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4d8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4dc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4e0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4e4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4e8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4ec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4f0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4f4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4f8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4fc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:500: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:504: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:508: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:50c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:510: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:514: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:518: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:51c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:520: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:524: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:528: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:52c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:530: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:534: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:538: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:53c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:540: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:544: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:548: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:54c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:550: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:554: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:558: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:55c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:560: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:564: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:568: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:56c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:570: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:574: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:578: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:57c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:580: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:584: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:588: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:58c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:590: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:594: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:598: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:59c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5a0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5a4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5a8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5ac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5b0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5b4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5b8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5bc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5c0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5c4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5c8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5cc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5d0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5d4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5d8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5dc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5e0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5e4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5e8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5ec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5f0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5f4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5f8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5fc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:600: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:604: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:608: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:60c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:610: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:614: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:618: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:61c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:620: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:624: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:628: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:62c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:630: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:634: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:638: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:63c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:640: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:644: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:648: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:64c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:650: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:654: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:658: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:65c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:660: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:664: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:668: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:66c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:670: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:674: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:678: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:67c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:680: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:684: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:688: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:68c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:690: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:694: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:698: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:69c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6a0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6a4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6a8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6ac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6b0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6b4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6b8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6bc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6c0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6c4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6c8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6cc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6d0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6d4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6d8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6dc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6e0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6e4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6e8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6ec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6f0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6f4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6f8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6fc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:700: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:704: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:708: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:70c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:710: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:714: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:718: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:71c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:720: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:724: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:728: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:72c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:730: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:734: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:738: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:73c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:740: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:744: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:748: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:74c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:750: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:754: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:758: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:75c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:760: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:764: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:768: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:76c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:770: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:774: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:778: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:77c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:780: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:784: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:788: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:78c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:790: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:794: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:798: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:79c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7a0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7a4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7a8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7ac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7b0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7b4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7b8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7bc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7c0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7c4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7c8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7cc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7d0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7d4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7d8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7dc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7e0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7e4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7e8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7ec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7f0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7f4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7f8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7fc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:800: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:804: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:808: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:80c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:810: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:814: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:818: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:81c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:820: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:824: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:828: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:82c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:830: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:834: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:838: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:83c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:840: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:844: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:848: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:84c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:850: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:854: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:858: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:85c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:860: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:864: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:868: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:86c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:870: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:874: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:878: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:87c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:880: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:884: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:888: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:88c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:890: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:894: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:898: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:89c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8a0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8a4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8a8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8ac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8b0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8b4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8b8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8bc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8c0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8c4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8c8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8cc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8d0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8d4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8d8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8dc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8e0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8e4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8e8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8ec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8f0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8f4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8f8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8fc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:900: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:904: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:908: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:90c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:910: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:914: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:918: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:91c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:920: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:924: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:928: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:92c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:930: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:934: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:938: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:93c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:940: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:944: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:948: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:94c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:950: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:954: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:958: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:95c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:960: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:964: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:968: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:96c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:970: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:974: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:978: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:97c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:980: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:984: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:988: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:98c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:990: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:994: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:998: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:99c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9a0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9a4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9a8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9ac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9b0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9b4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9b8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9bc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9c0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9c4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9c8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9cc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9d0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9d4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9d8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9dc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9e0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9e4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9e8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9ec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9f0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9f4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9f8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9fc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a00: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a04: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a08: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a0c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a10: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a14: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a18: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a1c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a20: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a24: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a28: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a2c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a30: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a34: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a38: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a3c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a40: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a44: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a48: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a4c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a50: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a54: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a58: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a5c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a60: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a64: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a68: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a6c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a70: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a74: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a78: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a7c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a80: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a84: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a88: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a8c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a90: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a94: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a98: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a9c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:aa0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:aa4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:aa8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:aac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ab0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ab4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ab8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:abc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ac0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ac4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ac8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:acc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ad0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ad4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ad8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:adc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ae0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ae4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ae8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:aec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:af0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:af4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:af8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:afc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b00: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b04: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b08: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b0c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b10: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b14: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b18: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b1c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b20: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b24: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b28: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b2c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b30: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b34: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b38: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b3c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b40: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b44: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b48: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b4c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b50: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b54: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b58: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b5c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b60: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b64: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b68: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b6c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b70: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b74: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b78: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b7c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b80: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b84: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b88: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b8c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b90: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b94: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b98: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b9c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ba0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ba4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ba8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bb0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bb4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bb8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bbc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bc0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bc4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bc8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bcc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bd0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bd4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bd8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bdc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:be0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:be4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:be8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bf0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bf4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bf8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bfc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c00: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c04: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c08: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c0c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c10: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c14: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c18: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c1c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c20: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c24: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c28: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c2c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c30: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c34: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c38: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c3c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c40: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c44: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c48: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c4c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c50: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c54: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c58: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c5c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c60: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c64: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c68: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c6c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c70: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c74: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c78: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c7c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c80: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c84: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c88: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c8c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c90: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c94: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c98: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c9c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ca0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ca4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ca8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cb0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cb4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cb8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cbc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cc0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cc4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cc8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ccc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cd0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cd4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cd8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cdc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ce0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ce4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ce8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cf0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cf4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cf8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cfc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d00: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d04: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d08: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d0c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d10: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d14: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d18: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d1c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d20: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d24: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d28: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d2c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d30: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d34: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d38: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d3c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d40: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d44: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d48: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d4c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d50: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d54: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d58: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d5c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d60: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d64: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d68: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d6c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d70: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d74: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d78: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d7c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d80: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d84: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d88: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d8c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d90: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d94: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d98: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d9c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:da0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:da4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:da8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:db0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:db4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:db8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dbc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dc0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dc4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dc8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dcc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dd0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dd4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dd8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ddc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:de0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:de4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:de8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:df0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:df4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:df8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dfc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e00: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e04: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e08: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e0c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e10: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e14: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e18: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e1c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e20: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e24: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e28: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e2c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e30: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e34: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e38: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e3c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e40: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e44: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e48: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e4c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e50: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e54: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e58: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e5c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e60: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e64: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e68: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e6c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e70: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e74: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e78: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e7c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e80: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e84: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e88: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e8c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e90: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e94: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e98: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e9c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ea0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ea4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ea8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:eac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:eb0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:eb4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:eb8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ebc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ec0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ec4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ec8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ecc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ed0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ed4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ed8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:edc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ee0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ee4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ee8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:eec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ef0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ef4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ef8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:efc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f00: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f04: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f08: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f0c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f10: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f14: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f18: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f1c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f20: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f24: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f28: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f2c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f30: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f34: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f38: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f3c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f40: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f44: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f48: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f4c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f50: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f54: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f58: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f5c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f60: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f64: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f68: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f6c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f70: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f74: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f78: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f7c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f80: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f84: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f88: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f8c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f90: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f94: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f98: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f9c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fa0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fa4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fa8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fb0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fb4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fb8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fbc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fc0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fc4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fc8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fcc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fd0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fd4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fd8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fdc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fe0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fe4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fe8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ff0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ff4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ff8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ffc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:000: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:004: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:008: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:00c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:010: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:014: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:018: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:01c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:020: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:024: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:028: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:02c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:030: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:034: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:038: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:03c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:040: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:044: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:048: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:04c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:050: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:054: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:058: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:05c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:060: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:064: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:068: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:06c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:070: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:074: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:078: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:07c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:080: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:084: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:088: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:08c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:090: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:094: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:098: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:09c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0a0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0a4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0a8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0ac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0b0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0b4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0b8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0bc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0c0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0c4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0c8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0cc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0d0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0d4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0d8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0dc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0e0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0e4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0e8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0ec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0f0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0f4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0f8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0fc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:100: 00028000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:104: 00020000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:108: 0001e000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:10c: 0000003f
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:110: 000fa220
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:114: 0012c220
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:118: 001452c0
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:11c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:120: 1f000200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:124: 0c200003
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:128: 00700f01
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:12c: 00e04004
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:130: 00101941
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:134: 00101941
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:138: 00000001
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:13c: 00000001
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:140: 00003c00
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:144: 00003c00
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:148: 00003c20
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:14c: 00000501
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:150: 00001e00
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:154: 00000a02
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:158: 00000601
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:15c: 00501900
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:160: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:164: 00000f03
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:168: 00000501
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:16c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:170: 00200500
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:174: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:178: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:17c: 00010000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:180: 00100500
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:184: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:188: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:18c: 00010000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:190: 00101800
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:194: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:198: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:19c: 00010000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1a0: 00101800
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1a4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1a8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1ac: 00010000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1b0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1b4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1b8: 0000001f
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1bc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1c0: 00000001
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1c4: 00000001
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1c8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1cc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1d0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1d4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1d8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1dc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1e0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1e4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1e8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1ec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1f0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1f4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1f8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1fc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:200: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:204: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:208: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:20c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:210: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:214: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:218: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:21c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:220: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:224: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:228: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:22c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:230: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:234: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:238: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:23c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:240: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:244: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:248: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:24c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:250: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:254: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:258: 00400000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:25c: 00000001
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:260: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:264: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:268: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:26c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:270: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:274: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:278: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:27c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:280: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:284: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:288: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:28c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:290: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:294: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:298: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:29c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2a0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2a4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2a8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2ac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2b0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2b4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2b8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2bc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2c0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2c4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2c8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2cc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2d0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2d4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2d8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2dc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2e0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2e4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2e8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2ec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2f0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2f4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2f8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2fc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:300: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:304: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:308: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:30c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:310: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:314: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:318: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:31c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:320: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:324: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:328: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:32c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:330: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:334: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:338: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:33c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:340: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:344: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:348: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:34c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:350: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:354: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:358: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:35c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:360: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:364: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:368: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:36c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:370: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:374: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:378: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:37c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:380: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:384: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:388: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:38c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:390: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:394: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:398: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:39c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3a0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3a4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3a8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3ac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3b0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3b4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3b8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3bc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3c0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3c4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3c8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3cc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3d0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3d4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3d8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3dc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3e0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3e4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3e8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3ec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3f0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3f4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3f8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3fc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:400: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:404: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:408: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:40c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:410: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:414: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:418: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:41c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:420: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:424: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:428: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:42c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:430: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:434: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:438: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:43c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:440: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:444: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:448: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:44c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:450: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:454: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:458: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:45c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:460: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:464: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:468: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:46c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:470: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:474: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:478: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:47c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:480: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:484: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:488: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:48c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:490: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:494: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:498: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:49c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4a0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4a4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4a8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4ac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4b0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4b4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4b8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4bc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4c0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4c4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4c8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4cc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4d0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4d4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4d8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4dc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4e0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4e4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4e8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4ec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4f0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4f4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4f8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4fc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:500: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:504: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:508: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:50c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:510: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:514: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:518: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:51c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:520: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:524: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:528: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:52c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:530: 13722093
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:534: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:538: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:53c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:540: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:544: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:548: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:54c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:550: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:554: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:558: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:55c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:560: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:564: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:568: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:56c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:570: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:574: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:578: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:57c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:580: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:584: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:588: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:58c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:590: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:594: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:598: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:59c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5a0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5a4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5a8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5ac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5b0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5b4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5b8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5bc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5c0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5c4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5c8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5cc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5d0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5d4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5d8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5dc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5e0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5e4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5e8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5ec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5f0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5f4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5f8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5fc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:600: 0000000c
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:604: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:608: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:60c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:610: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:614: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:618: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:61c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:620: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:624: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:628: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:62c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:630: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:634: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:638: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:63c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:640: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:644: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:648: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:64c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:650: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:654: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:658: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:65c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:660: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:664: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:668: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:66c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:670: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:674: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:678: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:67c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:680: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:684: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:688: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:68c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:690: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:694: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:698: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:69c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6a0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6a4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6a8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6ac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6b0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6b4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6b8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6bc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6c0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6c4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6c8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6cc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6d0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6d4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6d8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6dc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6e0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6e4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6e8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6ec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6f0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6f4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6f8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6fc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:700: 00001200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:704: 00001202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:708: 00000202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:70c: 00000202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:710: 00000202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:714: 00000202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:718: 00000202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:71c: 00000200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:720: 00000200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:724: 00001200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:728: 00001200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:72c: 00001200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:730: 000012e0
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:734: 000012e1
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:738: 00001200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:73c: 00001200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:740: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:744: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:748: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:74c: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:750: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:754: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:758: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:75c: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:760: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:764: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:768: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:76c: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:770: 00001204
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:774: 00001205
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:778: 00001204
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:77c: 00001205
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:780: 00001204
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:784: 00001204
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:788: 00001204
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:78c: 00001204
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:790: 00001205
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:794: 00001204
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:798: 00001204
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:79c: 00001204
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7a0: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7a4: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7a8: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7ac: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7b0: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7b4: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7b8: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7bc: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7c0: 00001200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7c4: 00001200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7c8: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7cc: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7d0: 00001200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7d4: 00001200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7d8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7dc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7e0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7e4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7e8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7ec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7f0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7f4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7f8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7fc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:800: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:804: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:808: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:80c: afff2000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:810: 000cff10
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:814: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:818: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:81c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:820: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:824: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:828: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:82c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:830: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:834: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:838: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:83c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:840: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:844: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:848: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:84c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:850: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:854: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:858: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:85c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:860: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:864: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:868: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:86c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:870: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:874: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:878: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:87c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:880: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:884: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:888: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:88c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:890: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:894: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:898: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:89c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8a0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8a4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8a8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8ac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8b0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8b4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8b8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8bc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8c0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8c4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8c8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8cc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8d0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8d4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8d8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8dc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8e0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8e4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8e8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8ec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8f0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8f4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8f8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8fc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:900: 0000000f
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:904: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:908: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:90c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:910: 0000001f
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:914: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:918: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:91c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:920: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:924: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:928: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:92c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:930: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:934: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:938: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:93c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:940: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:944: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:948: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:94c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:950: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:954: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:958: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:95c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:960: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:964: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:968: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:96c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:970: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:974: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:978: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:97c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:980: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:984: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:988: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:98c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:990: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:994: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:998: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:99c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9a0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9a4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9a8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9ac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9b0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9b4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9b8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9bc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9c0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9c4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9c8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9cc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9d0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9d4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9d8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9dc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9e0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9e4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9e8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9ec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9f0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9f4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9f8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9fc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a00: 00020202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a04: 00020202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a08: 02020202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a0c: 00020202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a10: 00020202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a14: 02020202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a18: 00000002
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a1c: 00020202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a20: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a24: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a28: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a2c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a30: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a34: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a38: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a3c: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a40: 00090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a44: 00090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a48: 00000909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a4c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a50: 00000009
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a54: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a58: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a5c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a60: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a64: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a68: 00000909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a6c: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a70: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a74: 00000909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a78: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a7c: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a80: 00000909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a84: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a88: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a8c: 00000909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a90: 01010101
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a94: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a98: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a9c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:aa0: 00000909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:aa4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:aa8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:aac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ab0: 00000001
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ab4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ab8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:abc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ac0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ac4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ac8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:acc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ad0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ad4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ad8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:adc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ae0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ae4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ae8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:aec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:af0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:af4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:af8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:afc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b00: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b04: 0c301166
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b08: 0c301100
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b0c: 0c301166
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b10: 0c301166
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b14: 0c750077
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b18: 80008000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b1c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b20: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b24: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b28: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b2c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b30: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b34: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b38: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b3c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b40: 00000600
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b44: 00000600
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b48: 000007f2
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b4c: 00000800
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b50: 000007f4
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b54: 00000800
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b58: 00000600
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b5c: 0018c61c
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b60: 00f9861c
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b64: 00f9861c
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b68: 00f9861c
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b6c: 00000220
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b70: 00000823
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b74: 00003417
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b78: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b7c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b80: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b84: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b88: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b8c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b90: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b94: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b98: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b9c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ba0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ba4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ba8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bb0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bb4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bb8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bbc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bc0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bc4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bc8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bcc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bd0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bd4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bd8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bdc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:be0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:be4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:be8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bf0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bf4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bf8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bfc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c00: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c04: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c08: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c0c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c10: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c14: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c18: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c1c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c20: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c24: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c28: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c2c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c30: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c34: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c38: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c3c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c40: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c44: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c48: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c4c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c50: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c54: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c58: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c5c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c60: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c64: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c68: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c6c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c70: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c74: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c78: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c7c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c80: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c84: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c88: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c8c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c90: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c94: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c98: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c9c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ca0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ca4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ca8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cb0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cb4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cb8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cbc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cc0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cc4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cc8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ccc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cd0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cd4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cd8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cdc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ce0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ce4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ce8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cf0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cf4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cf8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cfc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d00: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d04: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d08: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d0c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d10: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d14: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d18: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d1c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d20: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d24: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d28: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d2c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d30: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d34: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d38: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d3c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d40: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d44: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d48: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d4c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d50: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d54: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d58: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d5c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d60: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d64: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d68: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d6c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d70: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d74: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d78: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d7c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d80: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d84: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d88: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d8c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d90: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d94: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d98: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d9c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:da0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:da4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:da8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:db0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:db4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:db8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dbc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dc0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dc4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dc8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dcc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dd0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dd4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dd8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ddc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:de0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:de4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:de8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:df0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:df4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:df8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dfc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e00: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e04: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e08: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e0c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e10: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e14: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e18: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e1c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e20: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e24: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e28: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e2c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e30: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e34: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e38: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e3c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e40: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e44: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e48: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e4c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e50: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e54: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e58: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e5c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e60: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e64: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e68: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e6c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e70: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e74: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e78: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e7c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e80: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e84: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e88: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e8c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e90: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e94: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e98: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e9c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ea0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ea4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ea8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:eac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:eb0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:eb4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:eb8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ebc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ec0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ec4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ec8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ecc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ed0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ed4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ed8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:edc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ee0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ee4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ee8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:eec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ef0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ef4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ef8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:efc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f00: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f04: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f08: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f0c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f10: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f14: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f18: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f1c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f20: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f24: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f28: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f2c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f30: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f34: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f38: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f3c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f40: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f44: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f48: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f4c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f50: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f54: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f58: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f5c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f60: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f64: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f68: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f6c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f70: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f74: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f78: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f7c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f80: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f84: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f88: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f8c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f90: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f94: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f98: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f9c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fa0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fa4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fa8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fb0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fb4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fb8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fbc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fc0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fc4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fc8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fcc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fd0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fd4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fd8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fdc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fe0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fe4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fe8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ff0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ff4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ff8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ffc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/range:0-ffc
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/name:nodev
    Library version: 0.23 (git tag: v0.23)
    Compiled with backends: local xml ip usb serial
    IIO context created with local backend.
    Backend version: 0.23 (git tag: v0.23)
    Backend description string: Linux pluto 5.4.0-00535-g9c04de11ae53 #1 SMP PREEMPT Fri Aug 20 13:01:03 CEST 2021 armv7l
    IIO context has 8 attributes:
    hw_model: Analog Devices PlutoSDR Rev.B (Z7010-AD9363A)
    hw_model_variant: 1
    hw_serial: 1044739659930004180010009d1128f096
    fw_version: v0.34
    ad9361-phy,xo_correction: 39999778
    ad9361-phy,model: ad9363a
    local,kernel: 5.4.0-00535-g9c04de11ae53
    uri: local:
    IIO context has 5 devices:
    iio:device0: adm1177-iio
    2 channels found:
    voltage0: (input)
    2 channel-specific attributes found:
    attr 0: raw value: 771
    attr 1: scale value: 6.433105468
    current0: (input)
    attr 0: raw value: 826
    attr 1: scale value: 0.516601562
    No trigger on this device
    iio:device1: ad9361-phy
    9 channels found:
    altvoltage1: TX_LO (output)
    8 channel-specific attributes found:
    attr 0: external value: 0
    attr 1: fastlock_load value: 0
    attr 2: fastlock_recall ERROR: Invalid argument (22)
    attr 3: fastlock_save value: 0 247,250,64,147,27,210,130,145,217,255,145,217,217,240,153,230
    attr 4: fastlock_store value: 0
    attr 5: frequency value: 2450000000
    attr 6: frequency_available value: [325000000 1 3800000000]
    attr 7: powerdown value: 0
    voltage0: (input)
    15 channel-specific attributes found:
    attr 0: bb_dc_offset_tracking_en value: 1
    attr 1: filter_fir_en value: 0
    attr 2: gain_control_mode value: slow_attack
    attr 3: gain_control_mode_available value: manual fast_attack slow_attack hybrid
    attr 4: hardwaregain value: 71.000000 dB
    attr 5: hardwaregain_available value: [-3 1 71]
    attr 6: quadrature_tracking_en value: 1
    attr 7: rf_bandwidth value: 18000000
    attr 8: rf_bandwidth_available value: [200000 1 56000000]
    attr 9: rf_dc_offset_tracking_en value: 1
    attr 10: rf_port_select value: A_BALANCED
    attr 11: rf_port_select_available value: A_BALANCED B_BALANCED C_BALANCED A_N A_P B_N B_P C_N C_P TX_MONITOR1 TX_MONITOR2 TX_MONITOR1_2
    attr 12: rssi value: 111.75 dB
    attr 13: sampling_frequency value: 30720000
    attr 14: sampling_frequency_available value: [2083333 1 61440000]
    voltage3: (output)
    attr 0: filter_fir_en value: 0
    attr 1: raw value: 306
    attr 2: rf_bandwidth value: 18000000
    attr 3: rf_bandwidth_available value: [200000 1 40000000]
    attr 4: rf_port_select_available value: A B
    attr 5: sampling_frequency value: 30720000
    attr 6: sampling_frequency_available value: [2083333 1 61440000]
    attr 7: scale value: 1.000000
    altvoltage0: RX_LO (output)
    attr 3: fastlock_save value: 0 152,145,126,148,153,145,145,213,145,145,145,145,210,145,145,149
    attr 5: frequency value: 2400000000
    voltage2: (output)
    temp0: (input)
    1 channel-specific attributes found:
    attr 0: input value: 28070
    voltage0: (output)
    10 channel-specific attributes found:
    attr 1: hardwaregain value: -10.000000 dB
    attr 2: hardwaregain_available value: [-89.750000 0.250000 0.000000]
    attr 3: rf_bandwidth value: 18000000
    attr 4: rf_bandwidth_available value: [200000 1 40000000]
    attr 5: rf_port_select value: A
    attr 6: rf_port_select_available value: A B
    attr 7: rssi value: 0.00 dB
    attr 8: sampling_frequency value: 30720000
    attr 9: sampling_frequency_available value: [2083333 1 61440000]
    voltage2: (input)
    13 channel-specific attributes found:
    attr 2: gain_control_mode_available value: manual fast_attack slow_attack hybrid
    attr 3: offset value: 57
    attr 4: quadrature_tracking_en value: 1
    attr 5: raw value: 1189
    attr 6: rf_bandwidth value: 18000000
    attr 7: rf_bandwidth_available value: [200000 1 56000000]
    attr 8: rf_dc_offset_tracking_en value: 1
    attr 9: rf_port_select_available value: A_BALANCED B_BALANCED C_BALANCED A_N A_P B_N B_P C_N C_P TX_MONITOR1 TX_MONITOR2 TX_MONITOR1_2
    attr 10: sampling_frequency value: 30720000
    attr 11: sampling_frequency_available value: [2083333 1 61440000]
    attr 12: scale value: 0.305250
    out: (input, WARN:iio_channel_get_type()=UNKNOWN)
    attr 0: voltage_filter_fir_en value: 0
    18 device-specific attributes found:
    attr 0: calib_mode value: auto
    attr 1: calib_mode_available value: auto manual manual_tx_quad tx_quad rf_dc_offs rssi_gain_step
    attr 2: dcxo_tune_coarse ERROR: No such device (19)
    attr 3: dcxo_tune_coarse_available value: [0 0 0]
    attr 4: dcxo_tune_fine ERROR: No such device (19)
    attr 5: dcxo_tune_fine_available value: [0 0 0]
    attr 6: ensm_mode value: fdd
    attr 7: ensm_mode_available value: sleep wait alert fdd pinctrl pinctrl_fdd_indep
    attr 8: filter_fir_config value: FIR Rx: 0,0 Tx: 0,0
    attr 9: gain_table_config value: <gaintable AD9361 type=FULL dest=3 start=1300000000 end=4000000000>
    -3, 0x00, 0x00, 0x20
    -3, 0x00, 0x00, 0x00
    -2, 0x00, 0x01, 0x00
    -1, 0x00, 0x02, 0x00
    0, 0x00, 0x03, 0x00
    1, 0x00, 0x04, 0x00
    2, 0x00, 0x05, 0x00
    3, 0x01, 0x03, 0x20
    4, 0x01, 0x04, 0x00
    5, 0x01, 0x05, 0x00
    6, 0x01, 0x06, 0x00
    7, 0x01, 0x07, 0x00
    8, 0x01, 0x08, 0x00
    9, 0x01, 0x09, 0x00
    10, 0x01, 0x0A, 0x00
    11, 0x01, 0x0B, 0x00
    12, 0x01, 0x0C, 0x00
    13, 0x01, 0x0D, 0x00
    14, 0x01, 0x0E, 0x00
    15, 0x02, 0x09, 0x20
    16, 0x02, 0x0A, 0x00
    17, 0x02, 0x0B, 0x00
    18, 0x02, 0x0C, 0x00
    19, 0x02, 0x0D, 0x00
    20, 0x02, 0x0E, 0x00
    21, 0x02, 0x0F, 0x00
    22, 0x02, 0x10, 0x00
    23, 0x02, 0x2B, 0x20
    24, 0x02, 0x2C, 0x00
    25, 0x04, 0x27, 0x20
    26, 0x04, 0x28, 0x00
    27, 0x04, 0x29, 0x00
    28, 0x04, 0x2A, 0x00
    29, 0x04, 0x2B, 0x00
    30, 0x24, 0x21, 0x20
    31, 0x24, 0x22, 0x00
    32, 0x44, 0x20, 0x20
    33, 0x44, 0x21, 0x00
    34, 0x44, 0x22, 0x00
    35, 0x44, 0x23, 0x00
    36, 0x44, 0x24, 0x00
    37, 0x44, 0x25, 0x00
    38, 0x44, 0x26, 0x00
    39, 0x44, 0x27, 0x00
    40, 0x44, 0x28, 0x00
    41, 0x44, 0x29, 0x00
    42, 0x44, 0x2A, 0x00
    43, 0x44, 0x2B, 0x00
    44, 0x44, 0x2C, 0x00
    45, 0x44, 0x2D, 0x00
    46, 0x44, 0x2E, 0x00
    47, 0x44, 0x2F, 0x00
    48, 0x44, 0x30, 0x00
    49, 0x44, 0x31, 0x00
    50, 0x64, 0x2E, 0x20
    51, 0x64, 0x2F, 0x00
    52, 0x64, 0x30, 0x00
    53, 0x64, 0x31, 0x00
    54, 0x64, 0x32, 0x00
    55, 0x64, 0x33, 0x00
    56, 0x64, 0x34, 0x00
    57, 0x64, 0x35, 0x00
    58, 0x64, 0x36, 0x00
    59, 0x64, 0x37, 0x00
    60, 0x64, 0x38, 0x00
    61, 0x65, 0x38, 0x20
    62, 0x66, 0x38, 0x20
    63, 0x67, 0x38, 0x20
    64, 0x68, 0x38, 0x20
    65, 0x69, 0x38, 0x20
    66, 0x6A, 0x38, 0x20
    67, 0x6B, 0x38, 0x20
    68, 0x6C, 0x38, 0x20
    69, 0x6D, 0x38, 0x20
    70, 0x6E, 0x38, 0x20
    71, 0x6F, 0x38, 0x20
    </gaintable>
    attr 10: multichip_sync ERROR: Permission denied (13)
    attr 11: rssi_gain_step_error value: lna_error: 0 0 0 0
    mixer_error: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
    gain_step_calib_reg_val: 0 0 0 0 0
    attr 12: rx_path_rates value: BBPLL:983040002 ADC:245760000 R2:122880000 R1:61440000 RF:30720000 RXSAMP:30720000
    attr 13: trx_rate_governor value: nominal
    attr 14: trx_rate_governor_available value: nominal highest_osr
    attr 15: tx_path_rates value: BBPLL:983040002 DAC:122880000 T2:122880000 T1:61440000 TF:30720000 TXSAMP:30720000
    attr 16: xo_correction value: 39999778
    attr 17: xo_correction_available value: [39991779 1 40007777]
    179 debug attributes found:
    debug attr 0: digital_tune value: 0
    debug attr 1: calibration_switch_control value: 0
    debug attr 2: multichip_sync value: 0
    debug attr 3: gaininfo_rx2 ERROR: Resource temporarily unavailable (11)
    debug attr 4: gaininfo_rx1 value: 71 76 0 0 0 0 0 0
    debug attr 5: bist_timing_analysis value: 0
    debug attr 6: gpo_set value: 0
    debug attr 7: bist_tone value: 0
    debug attr 8: bist_prbs value: 0
    debug attr 9: loopback value: 0
    debug attr 10: initialize value: 0
    debug attr 11: adi,bb-clk-change-dig-tune-enable value: 0
    debug attr 12: adi,axi-half-dac-rate-enable value: 0
    debug attr 13: adi,txmon-2-lo-cm value: 48
    debug attr 14: adi,txmon-1-lo-cm value: 48
    debug attr 15: adi,txmon-2-front-end-gain value: 2
    debug attr 16: adi,txmon-1-front-end-gain value: 2
    debug attr 17: adi,txmon-duration value: 8192
    debug attr 18: adi,txmon-delay value: 511
    debug attr 19: adi,txmon-one-shot-mode-enable value: 0
    debug attr 20: adi,txmon-dc-tracking-enable value: 0
    debug attr 21: adi,txmon-high-gain value: 24
    debug attr 22: adi,txmon-low-gain value: 0
    debug attr 23: adi,txmon-low-high-thresh value: 37000
    debug attr 24: adi,gpo3-tx-delay-us value: 0
    debug attr 25: adi,gpo3-rx-delay-us value: 0
    debug attr 26: adi,gpo2-tx-delay-us value: 0
    debug attr 27: adi,gpo2-rx-delay-us value: 0
    debug attr 28: adi,gpo1-tx-delay-us value: 0
    debug attr 29: adi,gpo1-rx-delay-us value: 0
    debug attr 30: adi,gpo0-tx-delay-us value: 0
    debug attr 31: adi,gpo0-rx-delay-us value: 0
    debug attr 32: adi,gpo3-slave-tx-enable value: 0
    debug attr 33: adi,gpo3-slave-rx-enable value: 0
    debug attr 34: adi,gpo2-slave-tx-enable value: 0
    debug attr 35: adi,gpo2-slave-rx-enable value: 0
    debug attr 36: adi,gpo1-slave-tx-enable value: 0
    debug attr 37: adi,gpo1-slave-rx-enable value: 0
    debug attr 38: adi,gpo0-slave-tx-enable value: 0
    debug attr 39: adi,gpo0-slave-rx-enable value: 0
    debug attr 40: adi,gpo3-inactive-state-high-enable value: 0
    debug attr 41: adi,gpo2-inactive-state-high-enable value: 0
    debug attr 42: adi,gpo1-inactive-state-high-enable value: 0
    debug attr 43: adi,gpo0-inactive-state-high-enable value: 0
    debug attr 44: adi,gpo-manual-mode-enable-mask value: 0
    debug attr 45: adi,gpo-manual-mode-enable value: 0
    debug attr 46: adi,aux-dac2-tx-delay-us value: 0
    debug attr 47: adi,aux-dac2-rx-delay-us value: 0
    debug attr 48: adi,aux-dac2-active-in-alert-enable value: 0
    debug attr 49: adi,aux-dac2-active-in-tx-enable value: 0
    debug attr 50: adi,aux-dac2-active-in-rx-enable value: 0
    debug attr 51: adi,aux-dac2-default-value-mV value: 0
    debug attr 52: adi,aux-dac1-tx-delay-us value: 0
    debug attr 53: adi,aux-dac1-rx-delay-us value: 0
    debug attr 54: adi,aux-dac1-active-in-alert-enable value: 0
    debug attr 55: adi,aux-dac1-active-in-tx-enable value: 0
    debug attr 56: adi,aux-dac1-active-in-rx-enable value: 0
    debug attr 57: adi,aux-dac1-default-value-mV value: 0
    debug attr 58: adi,aux-dac-manual-mode-enable value: 1
    debug attr 59: adi,aux-adc-decimation value: 256
    debug attr 60: adi,aux-adc-rate value: 40000000
    debug attr 61: adi,temp-sense-decimation value: 256
    debug attr 62: adi,temp-sense-periodic-measurement-enable value: 1
    debug attr 63: adi,temp-sense-offset-signed value: 206
    debug attr 64: adi,temp-sense-measurement-interval-ms value: 1000
    debug attr 65: adi,elna-gaintable-all-index-enable value: 0
    debug attr 66: adi,elna-rx2-gpo1-control-enable value: 0
    debug attr 67: adi,elna-rx1-gpo0-control-enable value: 0
    debug attr 68: adi,elna-bypass-loss-mdB value: 0
    debug attr 69: adi,elna-gain-mdB value: 0
    debug attr 70: adi,elna-settling-delay-ns value: 0
    debug attr 71: adi,ctrl-outs-enable-mask value: 255
    debug attr 72: adi,ctrl-outs-index value: 0
    debug attr 73: adi,rssi-duration value: 1000
    debug attr 74: adi,rssi-wait value: 1
    debug attr 75: adi,rssi-delay value: 1
    debug attr 76: adi,rssi-unit-is-rx-samples-enable value: 0
    debug attr 77: adi,rssi-restart-mode value: 3
    debug attr 78: adi,fagc-adc-large-overload-inc-steps value: 2
    debug attr 79: adi,fagc-power-measurement-duration-in-state5 value: 64
    debug attr 80: adi,fagc-rst-gla-if-en-agc-pulled-high-mode value: 0
    debug attr 81: adi,fagc-rst-gla-en-agc-pulled-high-enable value: 0
    debug attr 82: adi,fagc-rst-gla-large-lmt-overload-enable value: 1
    debug attr 83: adi,fagc-rst-gla-large-adc-overload-enable value: 1
    debug attr 84: adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt value: 8
    debug attr 85: adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll value: 10
    debug attr 86: adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable value: 1
    debug attr 87: adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable value: 1
    debug attr 88: adi,fagc-rst-gla-stronger-sig-thresh-above-ll value: 10
    debug attr 89: adi,fagc-optimized-gain-offset value: 5
    debug attr 90: adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable value: 1
    debug attr 91: adi,fagc-use-last-lock-level-for-set-gain-enable value: 1
    debug attr 92: adi,fagc-gain-index-type-after-exit-rx-mode value: 0
    debug attr 93: adi,fagc-gain-increase-after-gain-lock-enable value: 0
    debug attr 94: adi,fagc-final-overrange-count value: 3
    debug attr 95: adi,fagc-lmt-final-settling-steps value: 1
    debug attr 96: adi,fagc-lpf-final-settling-steps value: 1
    debug attr 97: adi,fagc-lock-level-gain-increase-upper-limit value: 5
    debug attr 98: adi,fagc-lock-level-lmt-gain-increase-enable value: 1
    debug attr 99: adi,fagc-lp-thresh-increment-steps value: 1
    debug attr 100: adi,fagc-lp-thresh-increment-time value: 5
    debug attr 101: adi,fagc-allow-agc-gain-increase-enable value: 0
    debug attr 102: adi,fagc-state-wait-time-ns value: 260
    debug attr 103: adi,fagc-dec-pow-measurement-duration value: 64
    debug attr 104: adi,agc-immed-gain-change-if-large-lmt-overload-enable value: 0
    debug attr 105: adi,agc-immed-gain-change-if-large-adc-overload-enable value: 0
    debug attr 106: adi,agc-gain-update-interval-us value: 1000
    debug attr 107: adi,agc-sync-for-gain-counter-enable value: 0
    debug attr 108: adi,agc-dig-gain-step-size value: 4
    debug attr 109: adi,agc-dig-saturation-exceed-counter value: 3
    debug attr 110: adi,agc-lmt-overload-large-inc-steps value: 2
    debug attr 111: adi,agc-lmt-overload-small-exceed-counter value: 10
    debug attr 112: adi,agc-lmt-overload-large-exceed-counter value: 10
    debug attr 113: adi,agc-adc-lmt-small-overload-prevent-gain-inc-enable value: 0
    debug attr 114: adi,agc-adc-large-overload-inc-steps value: 2
    debug attr 115: adi,agc-adc-large-overload-exceed-counter value: 10
    debug attr 116: adi,agc-adc-small-overload-exceed-counter value: 10
    debug attr 117: adi,agc-outer-thresh-low-inc-steps value: 2
    debug attr 118: adi,agc-outer-thresh-low value: 18
    debug attr 119: adi,agc-inner-thresh-low-inc-steps value: 1
    debug attr 120: adi,agc-inner-thresh-low value: 12
    debug attr 121: adi,agc-inner-thresh-high-dec-steps value: 1
    debug attr 122: adi,agc-inner-thresh-high value: 10
    debug attr 123: adi,agc-outer-thresh-high-dec-steps value: 2
    debug attr 124: adi,agc-outer-thresh-high value: 5
    debug attr 125: adi,agc-attack-delay-extra-margin-us value: 1
    debug attr 126: adi,mgc-split-table-ctrl-inp-gain-mode value: 0
    debug attr 127: adi,mgc-dec-gain-step value: 2
    debug attr 128: adi,mgc-inc-gain-step value: 2
    debug attr 129: adi,mgc-rx2-ctrl-inp-enable value: 0
    debug attr 130: adi,mgc-rx1-ctrl-inp-enable value: 0
    debug attr 131: adi,gc-use-rx-fir-out-for-dec-pwr-meas-enable value: 0
    debug attr 132: adi,gc-max-dig-gain value: 15
    debug attr 133: adi,gc-dig-gain-enable value: 0
    debug attr 134: adi,gc-low-power-thresh value: 24
    debug attr 135: adi,gc-dec-pow-measurement-duration value: 8192
    debug attr 136: adi,gc-lmt-overload-low-thresh value: 704
    debug attr 137: adi,gc-lmt-overload-high-thresh value: 800
    debug attr 138: adi,gc-adc-large-overload-thresh value: 58
    debug attr 139: adi,gc-adc-small-overload-thresh value: 47
    debug attr 140: adi,gc-adc-ovr-sample-size value: 4
    debug attr 141: adi,gc-rx2-mode value: 2
    debug attr 142: adi,gc-rx1-mode value: 2
    debug attr 143: adi,update-tx-gain-in-alert-enable value: 0
    debug attr 144: adi,tx-attenuation-mdB value: 10000
    debug attr 145: adi,rf-tx-bandwidth-hz value: 18000000
    debug attr 146: adi,rf-rx-bandwidth-hz value: 18000000
    debug attr 147: adi,qec-tracking-slow-mode-enable value: 0
    debug attr 148: adi,dc-offset-count-low-range value: 50
    debug attr 149: adi,dc-offset-count-high-range value: 40
    debug attr 150: adi,dc-offset-attenuation-low-range value: 5
    debug attr 151: adi,dc-offset-attenuation-high-range value: 6
    debug attr 152: adi,dc-offset-tracking-update-event-mask value: 5
    debug attr 153: adi,clk-output-mode-select value: 0
    debug attr 154: adi,tx-lo-powerdown-managed-enable value: 1
    debug attr 155: adi,trx-synthesizer-target-fref-overwrite-hz value: 80008000
    debug attr 156: adi,rx1-rx2-phase-inversion-enable value: 0
    debug attr 157: adi,tx-rf-port-input-select-lock-enable value: 1
    debug attr 158: adi,rx-rf-port-input-select-lock-enable value: 1
    debug attr 159: adi,tx-rf-port-input-select value: 0
    debug attr 160: adi,rx-rf-port-input-select value: 0
    debug attr 161: adi,split-gain-table-mode-enable value: 0
    debug attr 162: adi,1rx-1tx-mode-use-tx-num value: 1
    debug attr 163: adi,1rx-1tx-mode-use-rx-num value: 1
    debug attr 164: adi,2rx-2tx-mode-enable value: 0
    debug attr 165: adi,digital-interface-tune-fir-disable value: 1
    debug attr 166: adi,digital-interface-tune-skip-mode value: 0
    debug attr 167: adi,tx-fastlock-pincontrol-enable value: 0
    debug attr 168: adi,rx-fastlock-pincontrol-enable value: 0
    debug attr 169: adi,rx-fastlock-delay-ns value: 0
    debug attr 170: adi,tx-fastlock-delay-ns value: 0
    debug attr 171: adi,tdd-skip-vco-cal-enable value: 0
    debug attr 172: adi,tdd-use-dual-synth-mode-enable value: 0
    debug attr 173: adi,debug-mode-enable value: 0
    debug attr 174: adi,ensm-enable-txnrx-control-enable value: 0
    debug attr 175: adi,ensm-enable-pin-pulse-mode-enable value: 0
    debug attr 176: adi,frequency-division-duplex-independent-mode-enable value: 0
    debug attr 177: adi,frequency-division-duplex-mode-enable value: 1
    debug attr 178: direct_reg_access value: 0x0
    iio:device2: xadc
    10 channels found:
    voltage5: vccoddr (input)
    attr 0: raw value: 1848
    attr 1: scale value: 0.732421875
    voltage0: vccint (input)
    attr 0: raw value: 1385
    voltage4: vccpaux (input)
    attr 0: raw value: 2457
    temp0: (input)
    attr 0: offset value: -2219
    attr 1: raw value: 2611
    attr 2: scale value: 123.040771484
    voltage7: vrefn (input)
    attr 0: raw value: 6
    voltage1: vccaux (input)
    attr 0: raw value: 2462
    voltage2: vccbram (input)
    attr 0: raw value: 1391
    voltage3: vccpint (input)
    attr 0: raw value: 1386
    voltage8: (input)
    attr 0: raw value: 3688
    attr 1: scale value: 0.244140625
    voltage6: vrefp (input)
    attr 0: raw value: 1705
    1 device-specific attributes found:
    attr 0: sampling_frequency value: 961538
    iio:device3: cf-ad9361-dds-core-lpc (buffer capable)
    6 channels found:
    voltage0: (output, index: 0, format: le:S16/16>>0)
    4 channel-specific attributes found:
    attr 0: calibphase value: 0.000000
    attr 1: calibscale value: 1.000000
    attr 2: sampling_frequency value: 30720000
    attr 3: sampling_frequency_available value: 30720000 3840000
    voltage1: (output, index: 1, format: le:S16/16>>0)
    altvoltage3: TX1_Q_F2 (output)
    attr 0: frequency value: 9279985
    attr 1: phase value: 0
    attr 2: raw value: 1
    attr 3: sampling_frequency value: 30720000
    attr 4: scale value: 0.000000
    altvoltage1: TX1_I_F2 (output)
    attr 1: phase value: 90000
    altvoltage0: TX1_I_F1 (output)
    altvoltage2: TX1_Q_F1 (output)
    3 buffer-specific attributes found:
    attr 0: data_available value: 0
    attr 1: length_align_bytes value: 8
    attr 2: watermark value: 2048
    1 debug attributes found:
    debug attr 0: direct_reg_access value: 0x90162
    iio:device4: cf-ad9361-lpc (buffer capable)
    2 channels found:
    voltage0: (input, index: 0, format: le:S12/16>>0)
    6 channel-specific attributes found:
    attr 0: calibbias value: 0
    attr 1: calibphase value: 0.000000
    attr 2: calibscale value: 1.000000
    attr 3: samples_pps ERROR: No such device (19)
    attr 4: sampling_frequency value: 30720000
    attr 5: sampling_frequency_available value: 30720000 3840000
    voltage1: (input, index: 1, format: le:S12/16>>0)
    2 debug attributes found:
    debug attr 0: pseudorandom_err_check value: CH0 : PN9 : Out of Sync : PN Error
    CH1 : PN9 : Out of Sync : PN Error
    debug attr 1: direct_reg_access value: 0x0
    lo Link encap:Local Loopback
    inet addr:127.0.0.1 Mask:255.0.0.0
    UP LOOPBACK RUNNING MTU:65536 Metric:1
    RX packets:0 errors:0 dropped:0 overruns:0 frame:0
    TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
    collisions:0 txqueuelen:1000
    RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
    usb0 Link encap:Ethernet HWaddr 00:05:F7:8B:6C:AA
    inet addr:192.168.2.1 Bcast:0.0.0.0 Mask:255.255.255.0
    UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
    RX packets:131 errors:0 dropped:49 overruns:0 frame:0
    TX packets:21 errors:0 dropped:0 overruns:0 carrier:0
    RX bytes:17536 (17.1 KiB) TX bytes:4850 (4.7 KiB)
    none on / type rootfs (rw)
    devtmpfs on /dev type devtmpfs (rw,relatime,size=120504k,nr_inodes=30126,mode=755)
    proc on /proc type proc (rw,relatime)
    devpts on /dev/pts type devpts (rw,relatime,gid=5,mode=620,ptmxmode=000)
    tmpfs on /dev/shm type tmpfs (rw,relatime,mode=777)
    tmpfs on /tmp type tmpfs (rw,relatime)
    tmpfs on /run type tmpfs (rw,nosuid,nodev,relatime,mode=755)
    sysfs on /sys type sysfs (rw,relatime)
    mtd2 on /mnt/jffs2 type jffs2 (rw,noatime)
    none on /sys/kernel/debug type debugfs (rw,relatime)
    configfs on /sys/kernel/config type configfs (rw,relatime)
    iio_ffs on /dev/iio_ffs type functionfs (rw,relatime)
    /dev/loop7 on /mnt/msd type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
    Mem: 55480K used, 454132K free, 72K shrd, 28K buff, 44848K cached
    CPU: 0% usr 9% sys 0% nic 90% idle 0% io 0% irq 0% sirq
    Load average: 0.00 0.00 0.00 1/47 1527
    PID PPID USER STAT VSZ %VSZ %CPU COMMAND
    185 1 root S 30468 6% 0% /usr/sbin/iiod -D -n 3 -F /dev/iio_ffs
    324 1 avahi S 3252 1% 0% avahi-daemon: running [pluto.local]
    208 1 dbus S 2804 1% 0% dbus-daemon --system
    337 1 root S 2736 1% 0% -sh
    1 0 root S 2608 1% 0% init
    317 1 root S 2608 1% 0% /bin/sh /sbin/update.sh
    96 1 root S 2608 1% 0% /sbin/klogd -n
    1527 317 root R 2608 1% 0% top -b -n1
    92 1 root S 2608 1% 0% /sbin/syslogd -n
    266 1 root S 2608 1% 0% /usr/sbin/udhcpd /etc/udhcpd.conf
    269 1 root S 2608 1% 0% httpd -h /www
    336 1 root S 2608 1% 0% /sbin/getty -L ttyPS0 0 vt100
    113 1 root S 2476 0% 0% watchdog -t 5 -T 10 /dev/watchdog
    332 1 root S 2252 0% 0% /usr/sbin/dropbear -R
    335 1 root S 1732 0% 0% input-event-daemon
    15 2 root IW 0 0% 0% [kworker/0:1-mm_]
    65 2 root SW 0 0% 0% [spi1]
    10 2 root IW 0 0% 0% [rcu_preempt]
    9 2 root SW 0 0% 0% [ksoftirqd/0]
    190 2 root SW 0 0% 0% [file-storage]
    64 2 root SW 0 0% 0% [spi0]
    2 0 root SW 0 0% 0% [kthreadd]
    3 2 root IW< 0 0% 0% [rcu_gp]
    4 2 root IW< 0 0% 0% [rcu_par_gp]
    6 2 root IW< 0 0% 0% [kworker/0:0H-kb]
    7 2 root IW 0 0% 0% [kworker/u4:0-ev]
    8 2 root IW< 0 0% 0% [mm_percpu_wq]
    11 2 root SW 0 0% 0% [migration/0]
    12 2 root SW 0 0% 0% [cpuhp/0]
    13 2 root SW 0 0% 0% [kdevtmpfs]
    14 2 root SW 0 0% 0% [rcu_tasks_kthre]
    16 2 root SW 0 0% 0% [khungtaskd]
    17 2 root SW 0 0% 0% [oom_reaper]
    18 2 root IW< 0 0% 0% [writeback]
    20 2 root IW 0 0% 0% [kworker/u4:1-ev]
    58 2 root IW< 0 0% 0% [kblockd]
    59 2 root SW 0 0% 0% [watchdogd]
    60 2 root IW< 0 0% 0% [cfg80211]
    61 2 root SW 0 0% 0% [kswapd0]
    67 2 root IW< 0 0% 0% [ci_otg]
    68 2 root SW 0 0% 0% [irq/46-41600000]
    69 2 root IW 0 0% 0% [kworker/0:2-pm]
    81 2 root SWN 0 0% 0% [jffs2_gcd_mtd2]
    305 2 root SW< 0 0% 0% [loop7]
    309 2 root IW< 0 0% 0% [kworker/0:1H-kb]
    ad936x_ext_refclk=<39999778>
    adi_loadvals=fdt addr ${fit_load_address} && fdt get value fdt_choosen /configurations/${fit_config}/ fdt && fdt get addr fdtaddr /images/${fdt_choosen} data && fdt addr ${fdtaddr}; if test -n ${ad936x_ext_refclk} && test ! -n ${ad936x_skip_ext_refclk}; then fdt set /clocks/clock@0 clock-frequency ${ad936x_ext_refclk}; fi; fdt get value model / model; if test -n ${ad936x_ext_refclk_override} && test "${model}" = "Analog Devices PlutoSDR Rev.C (Z7010/AD9363)"; then fdt set /clocks/clock@0 clock-frequency ${ad936x_ext_refclk_override}; fi; if test ${refclk_source} = internal || test ! "${model}" = "Analog Devices PlutoSDR Rev.C (Z7010/AD9363)" ; then fdt rm /amba/gpio@e000a000/clock_extern_en; fi; if test -n ${attr_name} && test -n ${attr_val}; then fdt set /amba/spi@e0006000/ad9361-phy@0 ${attr_name} ${attr_val}; fi; if test ${refclk_source} = external || test ! "${model}" = "Analog Devices PlutoSDR Rev.C (Z7010/AD9363)" ; then fdt rm /amba/gpio@e000a000/clock_internal_en; fi; if test -n ${compatible} && test ! ${compatible} = ad9361 && test ! ${compatible} = ad9363a && test ! ${compatible} = ad9364; then setenv compatible ad9363a; saveenv; fi; if test -n ${mode} && test ! ${mode} = 1r1t && test ! ${mode} = 2r2t; then setenv mode 1r1t; saveenv; fi; if test -n ${refclk_source} && test ! ${refclk_source} = internal && test ! ${refclk_source} = external; then setenv refclk_source internal; saveenv; fi; if test -n ${compatible}; then fdt set /amba/spi@e0006000/ad9361-phy@0 compatible ${compatible}; fi; if test ${compatible} = ad9361 && test ! "${model}" = "Analog Devices PlutoSDR Rev.C (Z7010/AD9363)" ; then fdt set /amba/spi@e0006000/ad9361-phy@0 compatible ad9363a; compatible=ad9363a; fi; if test ${mode} = 1r1t || test ! "${model}" = "Analog Devices PlutoSDR Rev.C (Z7010/AD9363)"; then fdt rm /amba/spi@e0006000/ad9361-phy@0 adi,2rx-2tx-mode-enable; fi; if test -n ${cs_gpio}; then fdt set /amba/axi_quad_spi@7C430000/ cs-gpios "<0x06 ${cs_gpio} 0>"; fi; if test ${compatible} = ad9364 || test -n ${attr_val} = ad9364; then fdt rm /amba/spi@e0006000/ad9361-phy@0 adi,2rx-2tx-mode-enable; fdt set /fpga-axi/cf-ad9361-dds-core-lpc@79024000 compatible adi,axi-ad9364-dds-6.00.a; setenv mode 1r1t; saveenv; fi;
    baudrate=115200
    bitstream_image=system.bit.bin
    bitstream_size=0x400000
    boot_image=BOOT.bin
    boot_size=0xF00000
    bootcmd=run $modeboot
    bootdelay=0
    bootenv=uEnv.txt
    clear_reset_cause=mw f8000008 df0d && mw f8000258 00400000 && mw f8000004 767b
    devicetree_image=devicetree.dtb
    devicetree_load_address=0x2000000
    devicetree_size=0x20000
    dfu_ram=echo Entering DFU RAM mode ... && run dfu_ram_info && dfu 0 ram 0
    dfu_ram_info=set dfu_alt_info dummy.dfu ram 0 0\\;firmware.dfu ram ${fit_load_address} 0x1E00000
    dfu_sf=gpio set 15;set stdout serial@e0001000;echo Entering DFU SF mode ... && run dfu_sf_info && dfu 0 sf 0:0:40000000:0 && if test -n ${dfu_alt_num} && test ${dfu_alt_num} = 1; then set fit_size ${filesize} && set dfu_alt_num && env save; fi;gpio clear 15;
    dfu_sf_info=set dfu_alt_info boot.dfu raw 0x0 0x100000\\;firmware.dfu raw 0x200000 0x1E00000\\;uboot-extra-env.dfu raw 0xFF000 0x1000\\;uboot-env.dfu raw 0x100000 0x20000\\;spare.dfu raw 0x120000 0xE0000
    ethaddr=00:0a:35:00:01:22
    extraenv_load_address=0x207E000
    fdt_choosen=fdt@2
    fdt_high=0x20000000
    fdtaddr=2084a50
    fdtcontroladdr=1ff99f50
    fit_config=config@9
    fit_load_address=0x2080000
    fit_size=A17363
    importbootenv=echo Importing environment from SD ...; env import -t ${loadbootenv_addr} $filesize
    initrd_high=0x20000000
    ipaddr=192.168.2.1
    ipaddr_host=192.168.2.10
    jtagboot=env default -a;sf probe && sf protect unlock 0 100000 && run dfu_sf;
    kernel_image=uImage
    loadbit_addr=0x100000
    loadbootenv=load mmc 0 ${loadbootenv_addr} ${bootenv}
    loadbootenv_addr=0x2000000
    mode=1r1t
    modeboot=qspiboot
    model=Analog Devices PlutoSDR Rev.B (Z7010/AD9363)
    netmask=255.255.255.0
    preboot=if test $modeboot = sdboot && env run sd_uEnvtxt_existence_test; then if env run loadbootenv; then env run importbootenv; fi; fi;
    productkey=1a6591d2fae29ed19e60e9ea5ef6c14cb6266d22
    qspiboot=set stdout nulldev;adi_hwref;test -n $PlutoRevA || gpio input 14 && set stdout serial@e0001000 && sf probe && sf protect lock 0 100000 && run dfu_sf; set stdout serial@e0001000;itest *f8000258 == 480003 && run clear_reset_cause && run dfu_sf; itest *f8000258 == 480007 && run clear_reset_cause && run ramboot_verbose; itest *f8000258 == 480006 && run clear_reset_cause && run qspiboot_verbose; itest *f8000258 == 480002 && run clear_reset_cause && exit; echo Booting silently && set stdout nulldev; run read_sf && run adi_loadvals; envversion;setenv bootargs console=ttyPS0,115200 maxcpus=${maxcpus} rootfstype=ramfs root=/dev/ram0 rw quiet loglevel=4 uboot="${uboot-version}" && bootm ${fit_load_address}#${fit_config} || set stdout serial@e0001000;echo BOOT failed entering DFU mode ... && sf protect lock 0 100000 && run dfu_sf
    qspiboot_extraenv=sf read ${extraenv_load_address} 0xFF000 0x1000 && env import -c ${extraenv_load_address} 0x1000 || true
    qspiboot_verbose=adi_hwref;echo Copying Linux from QSPI flash to RAM... && run read_sf && if run adi_loadvals; then echo Loaded AD936x refclk frequency and model into devicetree; fi; envversion;setenv bootargs console=ttyPS0,115200 maxcpus=${maxcpus} rootfstype=ramfs root=/dev/ram0 rw earlyprintk uboot="${uboot-version}" && bootm ${fit_load_address}#${fit_config} || echo BOOT failed entering DFU mode ... && run dfu_sf
    ramboot_verbose=adi_hwref;echo Copying Linux from DFU to RAM... && run dfu_ram;if run adi_loadvals; then echo Loaded AD936x refclk frequency and model into devicetree; fi; envversion;setenv bootargs console=ttyPS0,115200 maxcpus=${maxcpus} rootfstype=ramfs root=/dev/ram0 rw earlyprintk uboot="${uboot-version}" && bootm ${fit_load_address}#${fit_config}
    ramdisk_image=uramdisk.image.gz
    ramdisk_load_address=0x4000000
    ramdisk_size=0x400000
    read_sf=sf probe 0:0 50000000 0 && run qspiboot_extraenv &&sf read ${fit_load_address} 0x200000 ${fit_size} && iminfo ${fit_load_address} || sf read ${fit_load_address} 0x200000 0x1E00000;
    refclk_source=internal
    sd_uEnvtxt_existence_test=test -e mmc 0 /uEnv.txt
    serial=1044739659930004180010009d1128f096
    stderr=serial@e0001000
    stdin=serial@e0001000
    stdout=nulldev
    thor_ram=run dfu_ram_info && thordown 0 ram 0
    uenvboot=if run loadbootenv; then echo Loaded environment from ${bootenv}; run importbootenv; fi; if test -n $uenvcmd; then echo Running uenvcmd ...; run uenvcmd; fi
    usbboot=if usb start; then run uenvboot; echo Copying Linux from USB to RAM... && load usb 0 ${fit_load_address} ${kernel_image} && load usb 0 ${devicetree_load_address} ${devicetree_image} && load usb 0 ${ramdisk_load_address} ${ramdisk_image} && bootm ${fit_load_address} ${ramdisk_load_address} ${devicetree_load_address}; fi
    maxcpus=1
    hostname=pluto
    udc_handle_suspend=0
    usb_ethernet_mode=0
    netmask_eth=255.255.255.0
Reply
  • device-fw v0.34
    hdl hdl_2019_r2-32-g43cdc
    buildroot 2019.08-4910-g35af59
    linux adi-xilinx-2020.1-535-g9c04de
    u-boot-xlnx v0.20-PlutoSDR-24-ga2c20
    NAME=Buildroot
    VERSION=2019.08-4910-g35af596319
    ID=buildroot
    VERSION_ID=2020.02.8
    PRETTY_NAME="Buildroot 2020.02.8"
    Jan 1 00:00:02 (none) syslog.info syslogd started: BusyBox v1.31.1
    Jan 1 00:00:02 (none) user.notice kernel: klogd started: BusyBox v1.31.1 (2021-08-20 14:00:32 CEST)
    Jan 1 00:00:02 (none) user.info kernel: Booting Linux on physical CPU 0x0
    Jan 1 00:00:02 (none) user.notice kernel: Linux version 5.4.0-00535-g9c04de11ae53 (michael@mhenneri-D06) (gcc version 8.2.0 (GCC)) #1 SMP PREEMPT Fri Aug 20 13:01:03 CEST 2021
    Jan 1 00:00:02 (none) user.info kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
    Jan 1 00:00:02 (none) user.info kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    Jan 1 00:00:02 (none) user.info kernel: OF: fdt: Machine model: Analog Devices PlutoSDR Rev.B (Z7010/AD9363)
    Jan 1 00:00:02 (none) user.info kernel: Memory policy: Data cache writealloc
    Jan 1 00:00:02 (none) user.info kernel: cma: Reserved 256 MiB at 0x0e400000
    Jan 1 00:00:02 (none) user.debug kernel: On node 0 totalpages: 131072
    Jan 1 00:00:02 (none) user.debug kernel: Normal zone: 1024 pages used for memmap
    Jan 1 00:00:02 (none) user.debug kernel: Normal zone: 0 pages reserved
    Jan 1 00:00:02 (none) user.debug kernel: Normal zone: 131072 pages, LIFO batch:31
    Jan 1 00:00:02 (none) user.info kernel: percpu: Embedded 15 pages/cpu s29196 r8192 d24052 u61440
    Jan 1 00:00:02 (none) user.debug kernel: pcpu-alloc: s29196 r8192 d24052 u61440 alloc=15*4096
    Jan 1 00:00:02 (none) user.debug kernel: pcpu-alloc: [0] 0 [0] 1
    Jan 1 00:00:02 (none) user.info kernel: Built 1 zonelists, mobility grouping on. Total pages: 130048
    Jan 1 00:00:02 (none) user.notice kernel: Kernel command line: console=ttyPS0,115200 maxcpus=1 rootfstype=ramfs root=/dev/ram0 rw quiet loglevel=4 uboot=U-Boot PlutoSDR v0.20-PlutoSDR-00053-g89d0754 (Jan 14 2019 - 13:15:56 +0100)
    Jan 1 00:00:02 (none) user.info kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    Jan 1 00:00:02 (none) user.info kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
    Jan 1 00:00:02 (none) user.info kernel: mem auto-init: stack:off, heap alloc:off, heap free:off
    Jan 1 00:00:02 (none) user.info kernel: Memory: 241008K/524288K available (6144K kernel code, 613K rwdata, 1616K rodata, 1024K init, 138K bss, 21136K reserved, 262144K cma-reserved, 0K highmem)
    Jan 1 00:00:02 (none) user.info kernel: rcu: Preemptible hierarchical RCU implementation.
    Jan 1 00:00:02 (none) user.info kernel: rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
    Jan 1 00:00:02 (none) user.info kernel: Tasks RCU enabled.
    Jan 1 00:00:02 (none) user.info kernel: rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    Jan 1 00:00:02 (none) user.info kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    Jan 1 00:00:02 (none) user.info kernel: NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    Jan 1 00:00:02 (none) user.info kernel: efuse mapped to (ptrval)
    Jan 1 00:00:02 (none) user.info kernel: slcr mapped to (ptrval)
    Jan 1 00:00:02 (none) user.warn kernel: L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
    Jan 1 00:00:02 (none) user.warn kernel: L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
    Jan 1 00:00:02 (none) user.info kernel: L2C-310 erratum 769419 enabled
    Jan 1 00:00:02 (none) user.info kernel: L2C-310 enabling early BRESP for Cortex-A9
    Jan 1 00:00:02 (none) user.info kernel: L2C-310 full line of zeros enabled for Cortex-A9
    Jan 1 00:00:02 (none) user.info kernel: L2C-310 ID prefetch enabled, offset 1 lines
    Jan 1 00:00:02 (none) user.info kernel: L2C-310 dynamic clock gating enabled, standby mode enabled
    Jan 1 00:00:02 (none) user.info kernel: L2C-310 cache controller enabled, 8 ways, 512 kB
    Jan 1 00:00:02 (none) user.info kernel: L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
    Jan 1 00:00:02 (none) user.notice kernel: random: get_random_bytes called from start_kernel+0x270/0x450 with crng_init=0
    Jan 1 00:00:02 (none) user.info kernel: zynq_clock_init: clkc starts at (ptrval)
    Jan 1 00:00:02 (none) user.info kernel: Zynq clock init
    Jan 1 00:00:02 (none) user.info kernel: sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
    Jan 1 00:00:02 (none) user.info kernel: clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
    Jan 1 00:00:02 (none) user.info kernel: Switching to timer-based delay loop, resolution 3ns
    Jan 1 00:00:02 (none) user.info kernel: clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
    Jan 1 00:00:02 (none) user.info kernel: timer #0 at (ptrval), irq=17
    Jan 1 00:00:02 (none) user.info kernel: Console: colour dummy device 80x30
    Jan 1 00:00:02 (none) user.info kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 666.66 BogoMIPS (lpj=3333333)
    Jan 1 00:00:02 (none) user.info kernel: pid_max: default: 32768 minimum: 301
    Jan 1 00:00:02 (none) user.info kernel: Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
    Jan 1 00:00:02 (none) user.info kernel: Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
    Jan 1 00:00:02 (none) user.info kernel: CPU: Testing write buffer coherency: ok
    Jan 1 00:00:02 (none) user.info kernel: CPU0: Spectre v2: using BPIALL workaround
    Jan 1 00:00:02 (none) user.info kernel: CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    Jan 1 00:00:02 (none) user.info kernel: Setting up static identity map for 0x100000 - 0x100060
    Jan 1 00:00:02 (none) user.info kernel: rcu: Hierarchical SRCU implementation.
    Jan 1 00:00:02 (none) user.info kernel: smp: Bringing up secondary CPUs ...
    Jan 1 00:00:02 (none) user.info kernel: smp: Brought up 1 node, 1 CPU
    Jan 1 00:00:02 (none) user.info kernel: SMP: Total of 1 processors activated (666.66 BogoMIPS).
    Jan 1 00:00:02 (none) user.info kernel: CPU: All CPU(s) started in SVC mode.
    Jan 1 00:00:02 (none) user.info kernel: devtmpfs: initialized
    Jan 1 00:00:02 (none) user.info kernel: VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
    Jan 1 00:00:02 (none) user.info kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    Jan 1 00:00:02 (none) user.info kernel: futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    Jan 1 00:00:02 (none) user.info kernel: pinctrl core: initialized pinctrl subsystem
    Jan 1 00:00:02 (none) user.info kernel: NET: Registered protocol family 16
    Jan 1 00:00:02 (none) user.info kernel: DMA: preallocated 256 KiB pool for atomic coherent allocations
    Jan 1 00:00:02 (none) user.info kernel: cpuidle: using governor ladder
    Jan 1 00:00:02 (none) user.info kernel: hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
    Jan 1 00:00:02 (none) user.info kernel: hw-breakpoint: maximum watchpoint size is 4 bytes.
    Jan 1 00:00:02 (none) user.info kernel: zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0x(ptrval)
    Jan 1 00:00:02 (none) user.info kernel: e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 25, base_baud = 6249999) is a xuartps
    Jan 1 00:00:02 (none) user.info kernel: printk: console [ttyPS0] enabled
    Jan 1 00:00:02 (none) user.notice kernel: SCSI subsystem initialized
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver usbfs
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver hub
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new device driver usb
    Jan 1 00:00:02 (none) user.info kernel: FPGA manager framework
    Jan 1 00:00:02 (none) user.info kernel: clocksource: Switched to clocksource arm_global_timer
    Jan 1 00:00:02 (none) user.info kernel: thermal_sys: Registered thermal governor 'step_wise'
    Jan 1 00:00:02 (none) user.info kernel: NET: Registered protocol family 2
    Jan 1 00:00:02 (none) user.info kernel: tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    Jan 1 00:00:02 (none) user.info kernel: TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
    Jan 1 00:00:02 (none) user.info kernel: TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
    Jan 1 00:00:02 (none) user.info kernel: TCP: Hash tables configured (established 4096 bind 4096)
    Jan 1 00:00:02 (none) user.info kernel: UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
    Jan 1 00:00:02 (none) user.info kernel: UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
    Jan 1 00:00:02 (none) user.info kernel: Trying to unpack rootfs image as initramfs...
    Jan 1 00:00:02 (none) user.info kernel: Freeing initrd memory: 5436K
    Jan 1 00:00:02 (none) user.warn kernel: hw perfevents: no interrupt-affinity property for /pmu@f8891000, guessing.
    Jan 1 00:00:02 (none) user.info kernel: hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
    Jan 1 00:00:02 (none) user.notice kernel: Initialise system trusted keyrings
    Jan 1 00:00:02 (none) user.info kernel: workingset: timestamp_bits=30 max_order=17 bucket_order=0
    Jan 1 00:00:02 (none) user.info kernel: jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
    Jan 1 00:00:02 (none) user.notice kernel: Key type asymmetric registered
    Jan 1 00:00:02 (none) user.notice kernel: Asymmetric key parser 'x509' registered
    Jan 1 00:00:02 (none) user.info kernel: io scheduler mq-deadline registered
    Jan 1 00:00:02 (none) user.info kernel: io scheduler kyber registered
    Jan 1 00:00:02 (none) user.info kernel: zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
    Jan 1 00:00:02 (none) user.info kernel: brd: module loaded
    Jan 1 00:00:02 (none) user.info kernel: loop: module loaded
    Jan 1 00:00:02 (none) user.info kernel: spi-nor spi1.0: SPI-NOR-UniqueID 1044739659930004180010009d1128f096
    Jan 1 00:00:02 (none) user.warn kernel: spi-nor spi1.0: found n25q256ax1, expected n25q256a
    Jan 1 00:00:02 (none) user.info kernel: spi-nor spi1.0: n25q256ax1 (32768 Kbytes)
    Jan 1 00:00:02 (none) user.notice kernel: 4 fixed-partitions partitions found on MTD device spi1.0
    Jan 1 00:00:02 (none) user.notice kernel: Creating 4 MTD partitions on "spi1.0":
    Jan 1 00:00:02 (none) user.notice kernel: 0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
    Jan 1 00:00:02 (none) user.notice kernel: 0x000000100000-0x000000120000 : "qspi-uboot-env"
    Jan 1 00:00:02 (none) user.notice kernel: 0x000000120000-0x000000200000 : "qspi-nvmfs"
    Jan 1 00:00:02 (none) user.notice kernel: 0x000000200000-0x000002000000 : "qspi-linux"
    Jan 1 00:00:02 (none) user.info kernel: libphy: Fixed MDIO Bus: probed
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver rt2500usb
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver rt73usb
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver rt2800usb
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver rtl8187
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver rtl8192cu
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver rtl8xxxu
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver r8152
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver lan78xx
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver asix
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver ax88179_178a
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver cdc_ether
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver dm9601
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver smsc75xx
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver smsc95xx
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver rndis_host
    Jan 1 00:00:02 (none) user.info kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver usb-storage
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver usbserial_generic
    Jan 1 00:00:02 (none) user.info kernel: usbserial: USB Serial support registered for generic
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver ftdi_sio
    Jan 1 00:00:02 (none) user.info kernel: usbserial: USB Serial support registered for FTDI USB Serial Device
    Jan 1 00:00:02 (none) user.warn kernel: chipidea-usb2 e0002000.usb: e0002000.usb supply vbus not found, using dummy regulator
    Jan 1 00:00:02 (none) user.info kernel: ULPI transceiver vendor/product ID 0x0424/0x0007
    Jan 1 00:00:02 (none) user.info kernel: Found SMSC USB3320 ULPI transceiver.
    Jan 1 00:00:02 (none) user.info kernel: ULPI integrity check: passed.
    Jan 1 00:00:02 (none) user.info kernel: i2c /dev entries driver
    Jan 1 00:00:02 (none) user.info kernel: cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer with timeout 10s
    Jan 1 00:00:02 (none) user.info kernel: Xilinx Zynq CpuIdle Driver started
    Jan 1 00:00:02 (none) user.info kernel: ledtrig-cpu: registered to indicate activity on CPUs
    Jan 1 00:00:02 (none) user.info kernel: hidraw: raw HID events driver (C) Jiri Kosina
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver usbhid
    Jan 1 00:00:02 (none) user.info kernel: usbhid: USB HID core driver
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver r8712u
    Jan 1 00:00:02 (none) user.info kernel: usbcore: registered new interface driver r8188eu
    Jan 1 00:00:02 (none) user.info kernel: ad9361 spi0.0: ad9361_probe : enter (ad9363a)
    Jan 1 00:00:02 (none) user.notice kernel: random: fast init done
    Jan 1 00:00:02 (none) user.info kernel: ad9361 spi0.0: ad9361_probe : AD936x Rev 2 successfully initialized
    Jan 1 00:00:02 (none) user.info kernel: cf_axi_dds 79024000.cf-ad9361-dds-core-lpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x79024000 mapped to 0x(ptrval), probed DDS AD9364
    Jan 1 00:00:02 (none) user.info kernel: fpga_manager fpga0: Xilinx Zynq FPGA Manager registered
    Jan 1 00:00:02 (none) user.info kernel: NET: Registered protocol family 17
    Jan 1 00:00:02 (none) user.info kernel: lib80211: common routines for IEEE802.11 drivers
    Jan 1 00:00:02 (none) user.debug kernel: lib80211_crypt: registered algorithm 'NULL'
    Jan 1 00:00:02 (none) user.debug kernel: lib80211_crypt: registered algorithm 'WEP'
    Jan 1 00:00:02 (none) user.debug kernel: lib80211_crypt: registered algorithm 'CCMP'
    Jan 1 00:00:02 (none) user.notice kernel: Registering SWP/SWPB emulation handler
    Jan 1 00:00:02 (none) user.notice kernel: Loading compiled-in X.509 certificates
    Jan 1 00:00:02 (none) user.info kernel: cf_axi_adc 79020000.cf-ad9361-lpc: ADI AIM (10.01.b) at 0x79020000 mapped to 0x(ptrval), probed ADC AD9364 as MASTER
    Jan 1 00:00:02 (none) user.info kernel: input: gpio_keys as /devices/soc0/gpio_keys/input/input0
    Jan 1 00:00:02 (none) user.notice kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
    Jan 1 00:00:02 (none) user.notice kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    Jan 1 00:00:02 (none) user.warn kernel: platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    Jan 1 00:00:02 (none) user.info kernel: cfg80211: failed to load regulatory.db
    Jan 1 00:00:02 (none) user.info kernel: Freeing unused kernel memory: 1024K
    Jan 1 00:00:02 (none) user.info kernel: Run /init as init process
    Jan 1 00:00:03 (none) user.info kernel: file system registered
    Jan 1 00:00:03 (none) user.warn kernel: using random self ethernet address
    Jan 1 00:00:03 (none) user.warn kernel: using random host ethernet address
    Jan 1 00:00:03 (none) user.info kernel: Mass Storage Function, version: 2009/09/11
    Jan 1 00:00:03 (none) user.info kernel: LUN: removable file: (no medium)
    Jan 1 00:00:03 (none) user.info kernel: read descriptors
    Jan 1 00:00:03 (none) user.info kernel: read strings
    Jan 1 00:00:03 (none) user.info kernel: usb0: HOST MAC 00:e0:22:a0:6b:0c
    Jan 1 00:00:03 (none) user.info kernel: usb0: MAC 00:05:f7:8b:6c:aa
    Jan 1 00:00:03 (none) user.notice kernel: random: dbus-uuidgen: uninitialized urandom read (12 bytes read)
    Jan 1 00:00:03 (none) user.notice kernel: random: dbus-uuidgen: uninitialized urandom read (8 bytes read)
    Jan 1 00:00:03 (none) user.notice kernel: random: dbus-daemon: uninitialized urandom read (12 bytes read)
    Jan 1 00:00:03 (none) user.notice kernel: random: crng init done
    Jan 1 00:00:03 (none) user.notice kernel: random: 1 urandom warning(s) missed due to ratelimiting
    Jan 1 00:00:03 (none) user.info kernel: configfs-gadget gadget: high-speed config #1: c
    Jan 1 00:00:04 (none) user.notice root: ip: SIOCGIFFLAGS: No such device
    Jan 1 00:00:04 (none) daemon.info avahi-daemon[324]: Found user 'avahi' (UID 1000) and group 'avahi' (GID 1000).
    Jan 1 00:00:04 (none) daemon.info avahi-daemon[324]: Successfully dropped root privileges.
    Jan 1 00:00:04 (none) daemon.info avahi-daemon[324]: avahi-daemon 0.7 starting up.
    Jan 1 00:00:04 (none) daemon.warn avahi-daemon[324]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
    Jan 1 00:00:04 (none) daemon.warn avahi-daemon[324]: Failed to open /etc/resolv.conf: No such file or directory
    Jan 1 00:00:04 (none) daemon.info avahi-daemon[324]: Loading service file /etc/avahi/services/sftp-ssh.service.
    Jan 1 00:00:04 (none) daemon.info avahi-daemon[324]: Loading service file /etc/avahi/services/ssh.service.
    Jan 1 00:00:04 (none) daemon.warn avahi-daemon[324]: socket() failed: Address family not supported by protocol
    Jan 1 00:00:04 (none) daemon.notice avahi-daemon[324]: Failed to create IPv6 socket, proceeding in IPv4 only mode
    Jan 1 00:00:04 (none) daemon.info avahi-daemon[324]: Joining mDNS multicast group on interface usb0.IPv4 with address 192.168.2.1.
    Jan 1 00:00:04 (none) daemon.info avahi-daemon[324]: New relevant interface usb0.IPv4 for mDNS.
    Jan 1 00:00:04 (none) daemon.info avahi-daemon[324]: Network interface enumeration completed.
    Jan 1 00:00:04 (none) daemon.info avahi-daemon[324]: Registering new address record for 192.168.2.1 on usb0.IPv4.
    Jan 1 00:00:04 (none) authpriv.info dropbear[332]: Running in background
    Jan 1 00:00:04 (none) daemon.info : starting pid 336, tty '/dev/ttyPS0': '/sbin/getty -L ttyPS0 0 vt100 '
    Jan 1 00:00:04 (none) daemon.info : starting pid 337, tty '/dev/ttyGS0': '/sbin/getty -L ttyGS0 0 vt100 '
    Jan 1 00:00:05 (none) daemon.info avahi-daemon[324]: Server startup complete. Host name is pluto.local. Local service cookie is 610619128.
    Jan 1 00:00:06 (none) daemon.info avahi-daemon[324]: Service "pluto" (/etc/avahi/services/ssh.service) successfully established.
    Jan 1 00:00:06 (none) daemon.info avahi-daemon[324]: Service "pluto" (/etc/avahi/services/sftp-ssh.service) successfully established.
    Jan 1 00:03:16 (none) auth.info login[337]: root login on 'ttyGS0'
    processor : 0
    model name : ARMv7 Processor rev 0 (v7l)
    BogoMIPS : 666.66
    Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpd32
    CPU implementer : 0x41
    CPU architecture: 7
    CPU variant : 0x3
    CPU part : 0xc09
    CPU revision : 0
    Hardware : Xilinx Zynq Platform
    Revision : 0003
    Serial : 0000000000000000
    CPU0
    16: 0 GIC-0 27 Edge gt
    17: 0 GIC-0 43 Level ttc_clockevent
    18: 59444 GIC-0 29 Edge twd
    19: 0 GIC-0 37 Level arm-pmu
    20: 0 GIC-0 38 Level arm-pmu
    21: 54 GIC-0 39 Level f8007100.adc
    24: 0 GIC-0 35 Level f800c000.ocmc
    25: 30 GIC-0 82 Level xuartps
    26: 4133 GIC-0 58 Level e0006000.spi
    27: 43739 GIC-0 51 Level e000d000.spi
    38: 0 GIC-0 40 Level f8007000.devcfg
    44: 3829 GIC-0 53 Level e0002000.usb
    46: 6 GIC-0 91 Level 41600000.i2c
    47: 0 GIC-0 89 Level 7c400000.dma
    48: 0 GIC-0 88 Level 7c420000.dma
    49: 0 zynq-gpio 14 Edge Button
    IPI1: 0 0 Timer broadcast interrupts
    IPI2: 0 0 Rescheduling interrupts
    IPI3: 0 0 Function call interrupts
    IPI4: 0 0 CPU stop interrupts
    IPI5: 0 0 IRQ work interrupts
    IPI6: 0 0 completion interrupts
    Err: 0
    00000000-1fffffff : System RAM
    00008000-008fffff : Kernel code
    00a00000-00abc15f : Kernel data
    41600000-4160ffff : 41600000.i2c
    79020000-79025fff : 79020000.cf-ad9361-lpc
    7c400000-7c40ffff : 7c400000.dma
    7c420000-7c42ffff : 7c420000.dma
    e0001000-e0001fff : xuartps
    e0002000-e0002fff : usb@e0002000
    e0002000-e0002fff : ci_hdrc.0
    e0006000-e0006fff : e0006000.spi
    e000a000-e000afff : e000a000.gpio
    e000d000-e000dfff : e000d000.spi
    f8003000-f8003fff : dmac@f8003000
    f8005000-f8005fff : f8005000.watchdog
    f8007000-f80070ff : f8007000.devcfg
    f8007100-f800711f : f8007100.adc
    f800c000-f800cfff : f800c000.ocmc
    f8801000-f8801fff : etb@f8801000
    f8803000-f8803fff : tpiu@f8803000
    f8804000-f8804fff : funnel@f8804000
    f889c000-f889cfff : ptm@f889c000
    f889d000-f889dfff : ptm@f889d000
    fffc0000-ffffffff : f800c000.ocmc
    MemTotal: 509612 kB
    MemFree: 454312 kB
    MemAvailable: 452756 kB
    Buffers: 28 kB
    Cached: 44680 kB
    SwapCached: 0 kB
    Active: 1628 kB
    Inactive: 44 kB
    Active(anon): 1600 kB
    Inactive(anon): 44 kB
    Active(file): 28 kB
    Inactive(file): 0 kB
    Unevictable: 44580 kB
    Mlocked: 0 kB
    HighTotal: 0 kB
    HighFree: 0 kB
    LowTotal: 509612 kB
    LowFree: 454312 kB
    SwapTotal: 0 kB
    SwapFree: 0 kB
    Dirty: 24 kB
    Writeback: 0 kB
    AnonPages: 1588 kB
    Mapped: 4040 kB
    Shmem: 72 kB
    KReclaimable: 2728 kB
    Slab: 5808 kB
    SReclaimable: 2728 kB
    SUnreclaim: 3080 kB
    KernelStack: 416 kB
    PageTables: 240 kB
    NFS_Unstable: 0 kB
    Bounce: 0 kB
    WritebackTmp: 0 kB
    CommitLimit: 254804 kB
    Committed_AS: 30560 kB
    VmallocTotal: 507904 kB
    VmallocUsed: 340 kB
    VmallocChunk: 0 kB
    Percpu: 208 kB
    CmaTotal: 262144 kB
    CmaFree: 261884 kB
    enable prepare protect duty
    clock count count count rate accuracy phase cycle nshot
    spi0.0-tx_lo_dummy 0 0 0 1225000000 0 0 50000 0
    spi0.0-rx_lo_dummy 0 0 0 1200000000 0 0 50000 0
    ad9364_ext_refclk 4 4 0 39999778 200000 0 50000 0
    spi0.0-bb_refclk 1 1 0 39999778 200000 0 50000 0
    spi0.0-bbpll_clk 1 1 0 983040002 200000 0 50000 0
    spi0.0-adc_clk 1 1 0 245760000 200000 0 50000 0
    spi0.0-dac_clk 1 1 0 122880000 200000 0 50000 0
    spi0.0-t2_clk 1 1 0 122880000 200000 0 50000 0
    spi0.0-t1_clk 1 1 0 61440000 200000 0 50000 0
    spi0.0-clktf_clk 1 1 0 30720000 200000 0 50000 0
    spi0.0-tx_sampl_clk 1 1 0 30720000 200000 0 50000 0
    spi0.0-r2_clk 0 0 0 122880000 200000 0 50000 0
    spi0.0-r1_clk 0 0 0 61440000 200000 0 50000 0
    spi0.0-clkrf_clk 0 0 0 30720000 200000 0 50000 0
    spi0.0-rx_sampl_clk 0 0 0 30720000 200000 0 50000 0
    spi0.0-rx_refclk 1 1 0 79999556 200000 0 50000 0
    spi0.0-rx_rfpll_int 1 1 0 1200000000 200000 0 50000 0
    spi0.0-rx_rfpll 1 1 0 1200000000 200000 0 50000 0
    spi0.0-tx_refclk 1 1 0 79999556 200000 0 50000 0
    spi0.0-tx_rfpll_int 1 1 0 1225000000 200000 0 50000 0
    spi0.0-tx_rfpll 1 1 0 1225000000 200000 0 50000 0
    ps_clk 3 3 0 33333333 0 0 50000 0
    iopll_int 1 1 0 999999990 0 0 50000 0
    iopll 9 9 0 999999990 0 0 50000 0
    dbg_mux 1 1 0 999999990 0 0 50000 0
    dbg_div 1 1 0 66666666 0 0 50000 0
    dbg_emio_mux 1 1 0 66666666 0 0 50000 0
    dbg_trc 1 1 0 66666666 0 0 50000 0
    can_mux 0 0 0 999999990 0 0 50000 0
    can_div0 0 0 0 40000000 0 0 50000 0
    can_div1 0 0 0 8000000 0 0 50000 0
    can1_gate 0 0 0 8000000 0 0 50000 0
    can1 0 0 0 8000000 0 0 50000 0
    can0_gate 0 0 0 8000000 0 0 50000 0
    can0 0 0 0 8000000 0 0 50000 0
    gem1_mux 0 0 0 999999990 0 0 50000 0
    gem1_div0 0 0 0 16666667 0 0 50000 0
    gem1_div1 0 0 0 16666667 0 0 50000 0
    gem1_emio_mux 0 0 0 16666667 0 0 50000 0
    gem1 0 0 0 16666667 0 0 50000 0
    gem0_mux 0 0 0 999999990 0 0 50000 0
    gem0_div0 0 0 0 16666667 0 0 50000 0
    gem0_div1 0 0 0 16666667 0 0 50000 0
    gem0_emio_mux 0 0 0 16666667 0 0 50000 0
    gem0 0 0 0 16666667 0 0 50000 0
    spi0_mux 1 1 0 999999990 0 0 50000 0
    spi0_div 1 1 0 166666665 0 0 50000 0
    spi1 0 0 0 166666665 0 0 50000 0
    spi0 1 1 0 166666665 0 0 50000 0
    uart0_mux 1 1 0 999999990 0 0 50000 0
    uart0_div 1 1 0 99999999 0 0 50000 0
    uart1 1 1 0 99999999 0 0 50000 0
    uart0 0 0 0 99999999 0 0 50000 0
    sdio0_mux 0 0 0 999999990 0 0 50000 0
    sdio0_div 0 0 0 33333333 0 0 50000 0
    sdio1 0 0 0 33333333 0 0 50000 0
    sdio0 0 0 0 33333333 0 0 50000 0
    pcap_mux 1 1 0 999999990 0 0 50000 0
    pcap_div 1 1 0 199999998 0 0 50000 0
    pcap 1 2 0 199999998 0 0 50000 0
    lqspi_mux 1 1 0 999999990 0 0 50000 0
    lqspi_div 1 1 0 199999998 0 0 50000 0
    lqspi 1 1 0 199999998 0 0 50000 0
    fclk3_mux 1 1 0 999999990 0 0 50000 0
    fclk3_div0 1 1 0 41666667 0 0 50000 0
    fclk3_div1 1 1 0 41666667 0 0 50000 0
    fclk3 1 1 0 41666667 0 0 50000 0
    fclk2_mux 1 1 0 999999990 0 0 50000 0
    fclk2_div0 1 1 0 41666667 0 0 50000 0
    fclk2_div1 1 1 0 41666667 0 0 50000 0
    fclk2 1 1 0 41666667 0 0 50000 0
    fclk1_mux 1 1 0 999999990 0 0 50000 0
    fclk1_div0 1 1 0 199999998 0 0 50000 0
    fclk1_div1 1 1 0 199999998 0 0 50000 0
    fclk1 3 3 0 199999998 0 0 50000 0
    fclk0_mux 1 1 0 999999990 0 0 50000 0
    fclk0_div0 1 1 0 199999998 0 0 50000 0
    fclk0_div1 1 1 0 99999999 0 0 50000 0
    fclk0 1 2 0 99999999 0 0 50000 0
    ddrpll_int 1 1 0 1066666656 0 0 50000 0
    ddrpll 3 3 0 1066666656 0 0 50000 0
    dci_div0 1 1 0 71111111 0 0 50000 0
    dci_div1 1 1 0 10158731 0 0 50000 0
    dci 1 1 0 10158731 0 0 50000 0
    ddr3x_div 1 1 0 533333328 0 0 50000 0
    ddr3x 1 1 0 533333328 0 0 50000 0
    ddr2x_div 1 1 0 355555552 0 0 50000 0
    ddr2x 1 1 0 355555552 0 0 50000 0
    armpll_int 1 1 0 1333333320 0 0 50000 0
    armpll 1 1 0 1333333320 0 0 50000 0
    smc_mux 0 0 0 1333333320 0 0 50000 0
    smc_div 0 0 0 22222222 0 0 50000 0
    smc 0 0 0 22222222 0 0 50000 0
    cpu_mux 1 1 0 1333333320 0 0 50000 0
    cpu_div 3 3 0 666666660 0 0 50000 0
    cpu_1x_div 1 1 0 111111110 0 0 50000 0
    cpu_1x 9 9 0 111111110 0 0 50000 0
    smc_aper 0 0 0 111111110 0 0 50000 0
    lqspi_aper 1 1 0 111111110 0 0 50000 0
    gpio_aper 1 1 0 111111110 0 0 50000 0
    uart1_aper 1 1 0 111111110 0 0 50000 0
    uart0_aper 0 0 0 111111110 0 0 50000 0
    i2c1_aper 0 0 0 111111110 0 0 50000 0
    i2c0_aper 0 0 0 111111110 0 0 50000 0
    can1_aper 0 0 0 111111110 0 0 50000 0
    can0_aper 0 0 0 111111110 0 0 50000 0
    spi1_aper 0 0 0 111111110 0 0 50000 0
    spi0_aper 1 1 0 111111110 0 0 50000 0
    sdio1_aper 0 0 0 111111110 0 0 50000 0
    sdio0_aper 0 0 0 111111110 0 0 50000 0
    gem1_aper 0 0 0 111111110 0 0 50000 0
    gem0_aper 0 0 0 111111110 0 0 50000 0
    usb1_aper 0 0 0 111111110 0 0 50000 0
    usb0_aper 1 1 0 111111110 0 0 50000 0
    dbg_apb 1 1 0 111111110 0 0 50000 0
    swdt 1 1 0 111111110 0 0 50000 0
    cpu_2x_div 1 1 0 222222220 0 0 50000 0
    cpu_2x 1 1 0 222222220 0 0 50000 0
    dma 0 0 0 222222220 0 0 50000 0
    cpu_3or2x_div 1 1 0 333333330 0 0 50000 0
    cpu_3or2x 2 2 0 333333330 0 0 50000 0
    cpu_6or4x 0 0 0 666666660 0 0 50000 0
    can1_mio_mux 0 0 0 0 0 0 50000 0
    can0_mio_mux 0 0 0 0 0 0 50000 0
    /sys/kernel/debug/regmap/7c420000.dma/access:080: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:084: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:088: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:400: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:404: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:408: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:40c: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:410: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:414: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:418: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:41c: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:420: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:424: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:428: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:42c: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:430: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:434: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:438: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:43c: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:440: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:444: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:44c: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/access:450: y y y n
    /sys/kernel/debug/regmap/7c420000.dma/registers:080: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:084: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:088: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:400: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:404: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:408: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:40c: 00000001
    /sys/kernel/debug/regmap/7c420000.dma/registers:410: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:414: 1ffffff8
    /sys/kernel/debug/regmap/7c420000.dma/registers:418: 00000007
    /sys/kernel/debug/regmap/7c420000.dma/registers:41c: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:420: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:424: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:428: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:42c: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:430: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:434: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:438: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:43c: 00000701
    /sys/kernel/debug/regmap/7c420000.dma/registers:440: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:444: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:44c: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/registers:450: 00000000
    /sys/kernel/debug/regmap/7c420000.dma/range:80-88
    /sys/kernel/debug/regmap/7c420000.dma/range:400-444
    /sys/kernel/debug/regmap/7c420000.dma/range:44c-450
    /sys/kernel/debug/regmap/7c420000.dma/name:dma-axi-dmac
    /sys/kernel/debug/regmap/7c400000.dma/access:080: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:084: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:088: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:400: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:404: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:408: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:40c: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:410: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:414: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:418: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:41c: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:420: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:424: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:428: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:42c: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:430: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:434: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:438: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:43c: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:440: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:444: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:44c: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/access:450: y y y n
    /sys/kernel/debug/regmap/7c400000.dma/registers:080: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:084: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:088: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:400: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:404: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:408: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:40c: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:410: 1ffffff8
    /sys/kernel/debug/regmap/7c400000.dma/registers:414: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:418: 00000007
    /sys/kernel/debug/regmap/7c400000.dma/registers:41c: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:420: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:424: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:428: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:42c: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:430: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:434: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:438: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:43c: 00000701
    /sys/kernel/debug/regmap/7c400000.dma/registers:440: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:444: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:44c: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/registers:450: 00000000
    /sys/kernel/debug/regmap/7c400000.dma/range:80-88
    /sys/kernel/debug/regmap/7c400000.dma/range:400-444
    /sys/kernel/debug/regmap/7c400000.dma/range:44c-450
    /sys/kernel/debug/regmap/7c400000.dma/name:dma-axi-dmac
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:000: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:004: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:008: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:00c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:010: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:014: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:018: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:01c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:020: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:024: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:028: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:02c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:030: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:034: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:038: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:03c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:040: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:044: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:048: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:04c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:050: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:054: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:058: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:05c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:060: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:064: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:068: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:06c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:070: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:074: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:078: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:07c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:080: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:084: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:088: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:08c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:090: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:094: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:098: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:09c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0a0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0a4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0a8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0ac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0b0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0b4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0b8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0bc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0c0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0c4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0c8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0cc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0d0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0d4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0d8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0dc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0e0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0e4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0e8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0ec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0f0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0f4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0f8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:0fc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:100: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:104: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:108: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:10c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:110: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:114: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:118: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:11c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:120: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:124: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:128: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:12c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:130: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:134: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:138: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:13c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:140: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:144: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:148: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:14c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:150: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:154: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:158: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:15c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:160: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:164: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:168: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:16c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:170: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:174: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:178: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:17c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:180: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:184: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:188: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:18c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:190: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:194: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:198: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:19c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1a0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1a4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1a8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1ac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1b0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1b4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1b8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1bc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1c0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1c4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1c8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1cc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1d0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1d4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1d8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1dc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1e0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1e4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1e8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1ec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1f0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1f4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1f8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:1fc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:200: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:204: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:208: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:20c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:210: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:214: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:218: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:21c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:220: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:224: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:228: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:22c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:230: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:234: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:238: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:23c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:240: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:244: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:248: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:24c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:250: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:254: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:258: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:25c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:260: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:264: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:268: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:26c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:270: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:274: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:278: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:27c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:280: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:284: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:288: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:28c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:290: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:294: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:298: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:29c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2a0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2a4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2a8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2ac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2b0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2b4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2b8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2bc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2c0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2c4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2c8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2cc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2d0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2d4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2d8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2dc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2e0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2e4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2e8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2ec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2f0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2f4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2f8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:2fc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:300: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:304: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:308: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:30c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:310: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:314: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:318: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:31c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:320: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:324: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:328: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:32c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:330: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:334: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:338: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:33c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:340: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:344: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:348: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:34c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:350: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:354: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:358: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:35c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:360: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:364: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:368: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:36c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:370: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:374: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:378: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:37c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:380: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:384: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:388: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:38c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:390: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:394: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:398: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:39c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3a0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3a4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3a8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3ac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3b0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3b4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3b8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3bc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3c0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3c4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3c8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3cc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3d0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3d4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3d8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3dc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3e0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3e4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3e8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3ec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3f0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3f4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3f8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:3fc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:400: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:404: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:408: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:40c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:410: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:414: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:418: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:41c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:420: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:424: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:428: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:42c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:430: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:434: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:438: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:43c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:440: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:444: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:448: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:44c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:450: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:454: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:458: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:45c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:460: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:464: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:468: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:46c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:470: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:474: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:478: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:47c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:480: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:484: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:488: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:48c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:490: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:494: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:498: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:49c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4a0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4a4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4a8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4ac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4b0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4b4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4b8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4bc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4c0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4c4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4c8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4cc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4d0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4d4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4d8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4dc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4e0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4e4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4e8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4ec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4f0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4f4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4f8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:4fc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:500: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:504: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:508: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:50c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:510: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:514: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:518: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:51c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:520: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:524: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:528: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:52c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:530: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:534: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:538: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:53c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:540: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:544: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:548: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:54c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:550: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:554: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:558: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:55c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:560: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:564: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:568: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:56c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:570: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:574: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:578: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:57c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:580: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:584: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:588: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:58c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:590: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:594: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:598: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:59c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5a0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5a4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5a8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5ac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5b0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5b4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5b8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5bc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5c0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5c4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5c8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5cc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5d0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5d4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5d8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5dc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5e0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5e4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5e8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5ec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5f0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5f4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5f8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:5fc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:600: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:604: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:608: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:60c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:610: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:614: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:618: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:61c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:620: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:624: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:628: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:62c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:630: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:634: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:638: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:63c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:640: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:644: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:648: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:64c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:650: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:654: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:658: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:65c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:660: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:664: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:668: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:66c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:670: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:674: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:678: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:67c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:680: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:684: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:688: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:68c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:690: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:694: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:698: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:69c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6a0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6a4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6a8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6ac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6b0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6b4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6b8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6bc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6c0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6c4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6c8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6cc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6d0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6d4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6d8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6dc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6e0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6e4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6e8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6ec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6f0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6f4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6f8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:6fc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:700: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:704: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:708: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:70c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:710: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:714: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:718: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:71c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:720: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:724: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:728: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:72c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:730: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:734: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:738: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:73c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:740: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:744: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:748: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:74c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:750: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:754: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:758: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:75c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:760: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:764: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:768: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:76c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:770: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:774: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:778: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:77c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:780: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:784: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:788: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:78c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:790: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:794: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:798: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:79c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7a0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7a4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7a8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7ac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7b0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7b4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7b8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7bc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7c0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7c4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7c8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7cc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7d0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7d4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7d8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7dc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7e0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7e4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7e8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7ec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7f0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7f4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7f8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:7fc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:800: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:804: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:808: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:80c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:810: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:814: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:818: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:81c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:820: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:824: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:828: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:82c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:830: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:834: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:838: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:83c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:840: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:844: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:848: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:84c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:850: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:854: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:858: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:85c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:860: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:864: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:868: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:86c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:870: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:874: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:878: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:87c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:880: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:884: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:888: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:88c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:890: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:894: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:898: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:89c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8a0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8a4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8a8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8ac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8b0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8b4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8b8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8bc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8c0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8c4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8c8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8cc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8d0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8d4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8d8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8dc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8e0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8e4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8e8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8ec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8f0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8f4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8f8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:8fc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:900: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:904: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:908: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:90c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:910: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:914: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:918: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:91c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:920: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:924: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:928: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:92c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:930: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:934: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:938: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:93c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:940: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:944: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:948: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:94c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:950: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:954: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:958: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:95c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:960: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:964: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:968: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:96c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:970: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:974: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:978: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:97c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:980: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:984: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:988: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:98c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:990: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:994: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:998: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:99c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9a0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9a4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9a8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9ac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9b0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9b4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9b8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9bc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9c0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9c4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9c8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9cc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9d0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9d4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9d8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9dc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9e0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9e4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9e8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9ec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9f0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9f4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9f8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:9fc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a00: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a04: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a08: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a0c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a10: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a14: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a18: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a1c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a20: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a24: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a28: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a2c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a30: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a34: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a38: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a3c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a40: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a44: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a48: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a4c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a50: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a54: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a58: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a5c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a60: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a64: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a68: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a6c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a70: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a74: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a78: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a7c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a80: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a84: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a88: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a8c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a90: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a94: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a98: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:a9c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:aa0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:aa4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:aa8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:aac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ab0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ab4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ab8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:abc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ac0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ac4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ac8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:acc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ad0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ad4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ad8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:adc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ae0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ae4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ae8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:aec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:af0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:af4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:af8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:afc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b00: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b04: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b08: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b0c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b10: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b14: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b18: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b1c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b20: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b24: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b28: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b2c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b30: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b34: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b38: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b3c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b40: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b44: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b48: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b4c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b50: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b54: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b58: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b5c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b60: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b64: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b68: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b6c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b70: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b74: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b78: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b7c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b80: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b84: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b88: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b8c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b90: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b94: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b98: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:b9c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ba0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ba4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ba8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bb0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bb4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bb8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bbc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bc0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bc4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bc8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bcc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bd0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bd4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bd8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bdc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:be0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:be4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:be8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bf0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bf4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bf8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:bfc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c00: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c04: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c08: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c0c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c10: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c14: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c18: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c1c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c20: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c24: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c28: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c2c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c30: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c34: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c38: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c3c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c40: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c44: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c48: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c4c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c50: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c54: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c58: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c5c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c60: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c64: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c68: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c6c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c70: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c74: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c78: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c7c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c80: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c84: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c88: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c8c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c90: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c94: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c98: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:c9c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ca0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ca4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ca8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cb0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cb4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cb8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cbc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cc0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cc4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cc8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ccc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cd0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cd4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cd8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cdc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ce0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ce4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ce8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cf0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cf4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cf8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:cfc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d00: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d04: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d08: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d0c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d10: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d14: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d18: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d1c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d20: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d24: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d28: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d2c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d30: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d34: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d38: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d3c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d40: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d44: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d48: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d4c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d50: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d54: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d58: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d5c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d60: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d64: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d68: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d6c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d70: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d74: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d78: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d7c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d80: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d84: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d88: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d8c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d90: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d94: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d98: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:d9c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:da0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:da4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:da8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:db0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:db4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:db8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dbc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dc0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dc4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dc8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dcc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dd0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dd4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dd8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ddc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:de0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:de4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:de8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:df0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:df4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:df8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:dfc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e00: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e04: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e08: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e0c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e10: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e14: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e18: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e1c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e20: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e24: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e28: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e2c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e30: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e34: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e38: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e3c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e40: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e44: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e48: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e4c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e50: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e54: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e58: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e5c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e60: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e64: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e68: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e6c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e70: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e74: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e78: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e7c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e80: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e84: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e88: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e8c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e90: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e94: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e98: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:e9c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ea0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ea4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ea8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:eac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:eb0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:eb4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:eb8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ebc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ec0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ec4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ec8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ecc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ed0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ed4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ed8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:edc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ee0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ee4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ee8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:eec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ef0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ef4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ef8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:efc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f00: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f04: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f08: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f0c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f10: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f14: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f18: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f1c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f20: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f24: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f28: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f2c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f30: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f34: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f38: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f3c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f40: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f44: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f48: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f4c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f50: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f54: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f58: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f5c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f60: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f64: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f68: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f6c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f70: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f74: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f78: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f7c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f80: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f84: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f88: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f8c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f90: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f94: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f98: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:f9c: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fa0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fa4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fa8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fac: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fb0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fb4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fb8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fbc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fc0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fc4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fc8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fcc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fd0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fd4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fd8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fdc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fe0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fe4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fe8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:fec: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ff0: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ff4: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ff8: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/access:ffc: y y y n
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:000: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:004: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:008: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:00c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:010: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:014: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:018: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:01c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:020: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:024: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:028: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:02c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:030: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:034: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:038: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:03c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:040: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:044: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:048: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:04c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:050: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:054: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:058: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:05c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:060: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:064: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:068: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:06c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:070: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:074: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:078: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:07c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:080: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:084: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:088: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:08c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:090: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:094: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:098: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:09c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0a0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0a4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0a8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0ac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0b0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0b4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0b8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0bc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0c0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0c4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0c8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0cc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0d0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0d4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0d8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0dc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0e0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0e4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0e8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0ec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0f0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0f4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0f8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:0fc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:100: 00028000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:104: 00020000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:108: 0001e000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:10c: 0000003f
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:110: 000fa220
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:114: 0012c220
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:118: 001452c0
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:11c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:120: 1f000200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:124: 0c200003
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:128: 00700f01
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:12c: 00e04004
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:130: 00101941
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:134: 00101941
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:138: 00000001
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:13c: 00000001
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:140: 00003c00
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:144: 00003c00
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:148: 00003c20
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:14c: 00000501
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:150: 00001e00
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:154: 00000a02
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:158: 00000601
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:15c: 00501900
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:160: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:164: 00000f03
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:168: 00000501
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:16c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:170: 00200500
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:174: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:178: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:17c: 00010000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:180: 00100500
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:184: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:188: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:18c: 00010000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:190: 00101800
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:194: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:198: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:19c: 00010000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1a0: 00101800
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1a4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1a8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1ac: 00010000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1b0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1b4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1b8: 0000001f
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1bc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1c0: 00000001
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1c4: 00000001
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1c8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1cc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1d0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1d4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1d8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1dc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1e0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1e4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1e8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1ec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1f0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1f4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1f8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:1fc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:200: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:204: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:208: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:20c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:210: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:214: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:218: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:21c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:220: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:224: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:228: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:22c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:230: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:234: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:238: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:23c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:240: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:244: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:248: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:24c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:250: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:254: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:258: 00400000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:25c: 00000001
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:260: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:264: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:268: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:26c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:270: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:274: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:278: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:27c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:280: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:284: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:288: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:28c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:290: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:294: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:298: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:29c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2a0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2a4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2a8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2ac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2b0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2b4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2b8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2bc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2c0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2c4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2c8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2cc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2d0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2d4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2d8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2dc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2e0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2e4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2e8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2ec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2f0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2f4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2f8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:2fc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:300: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:304: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:308: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:30c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:310: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:314: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:318: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:31c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:320: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:324: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:328: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:32c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:330: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:334: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:338: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:33c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:340: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:344: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:348: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:34c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:350: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:354: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:358: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:35c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:360: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:364: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:368: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:36c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:370: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:374: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:378: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:37c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:380: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:384: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:388: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:38c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:390: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:394: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:398: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:39c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3a0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3a4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3a8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3ac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3b0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3b4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3b8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3bc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3c0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3c4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3c8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3cc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3d0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3d4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3d8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3dc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3e0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3e4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3e8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3ec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3f0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3f4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3f8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:3fc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:400: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:404: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:408: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:40c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:410: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:414: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:418: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:41c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:420: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:424: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:428: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:42c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:430: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:434: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:438: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:43c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:440: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:444: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:448: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:44c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:450: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:454: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:458: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:45c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:460: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:464: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:468: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:46c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:470: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:474: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:478: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:47c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:480: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:484: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:488: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:48c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:490: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:494: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:498: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:49c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4a0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4a4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4a8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4ac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4b0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4b4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4b8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4bc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4c0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4c4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4c8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4cc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4d0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4d4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4d8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4dc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4e0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4e4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4e8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4ec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4f0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4f4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4f8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:4fc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:500: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:504: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:508: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:50c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:510: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:514: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:518: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:51c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:520: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:524: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:528: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:52c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:530: 13722093
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:534: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:538: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:53c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:540: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:544: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:548: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:54c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:550: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:554: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:558: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:55c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:560: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:564: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:568: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:56c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:570: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:574: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:578: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:57c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:580: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:584: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:588: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:58c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:590: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:594: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:598: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:59c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5a0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5a4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5a8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5ac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5b0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5b4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5b8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5bc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5c0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5c4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5c8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5cc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5d0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5d4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5d8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5dc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5e0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5e4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5e8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5ec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5f0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5f4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5f8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:5fc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:600: 0000000c
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:604: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:608: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:60c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:610: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:614: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:618: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:61c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:620: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:624: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:628: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:62c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:630: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:634: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:638: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:63c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:640: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:644: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:648: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:64c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:650: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:654: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:658: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:65c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:660: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:664: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:668: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:66c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:670: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:674: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:678: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:67c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:680: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:684: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:688: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:68c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:690: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:694: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:698: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:69c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6a0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6a4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6a8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6ac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6b0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6b4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6b8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6bc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6c0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6c4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6c8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6cc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6d0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6d4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6d8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6dc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6e0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6e4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6e8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6ec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6f0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6f4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6f8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:6fc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:700: 00001200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:704: 00001202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:708: 00000202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:70c: 00000202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:710: 00000202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:714: 00000202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:718: 00000202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:71c: 00000200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:720: 00000200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:724: 00001200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:728: 00001200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:72c: 00001200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:730: 000012e0
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:734: 000012e1
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:738: 00001200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:73c: 00001200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:740: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:744: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:748: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:74c: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:750: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:754: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:758: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:75c: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:760: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:764: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:768: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:76c: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:770: 00001204
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:774: 00001205
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:778: 00001204
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:77c: 00001205
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:780: 00001204
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:784: 00001204
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:788: 00001204
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:78c: 00001204
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:790: 00001205
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:794: 00001204
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:798: 00001204
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:79c: 00001204
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7a0: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7a4: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7a8: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7ac: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7b0: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7b4: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7b8: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7bc: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7c0: 00001200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7c4: 00001200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7c8: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7cc: 00001201
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7d0: 00001200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7d4: 00001200
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7d8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7dc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7e0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7e4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7e8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7ec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7f0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7f4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7f8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:7fc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:800: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:804: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:808: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:80c: afff2000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:810: 000cff10
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:814: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:818: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:81c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:820: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:824: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:828: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:82c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:830: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:834: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:838: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:83c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:840: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:844: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:848: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:84c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:850: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:854: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:858: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:85c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:860: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:864: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:868: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:86c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:870: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:874: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:878: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:87c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:880: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:884: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:888: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:88c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:890: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:894: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:898: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:89c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8a0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8a4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8a8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8ac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8b0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8b4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8b8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8bc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8c0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8c4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8c8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8cc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8d0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8d4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8d8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8dc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8e0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8e4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8e8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8ec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8f0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8f4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8f8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:8fc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:900: 0000000f
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:904: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:908: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:90c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:910: 0000001f
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:914: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:918: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:91c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:920: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:924: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:928: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:92c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:930: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:934: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:938: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:93c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:940: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:944: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:948: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:94c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:950: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:954: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:958: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:95c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:960: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:964: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:968: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:96c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:970: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:974: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:978: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:97c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:980: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:984: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:988: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:98c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:990: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:994: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:998: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:99c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9a0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9a4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9a8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9ac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9b0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9b4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9b8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9bc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9c0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9c4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9c8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9cc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9d0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9d4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9d8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9dc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9e0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9e4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9e8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9ec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9f0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9f4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9f8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:9fc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a00: 00020202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a04: 00020202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a08: 02020202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a0c: 00020202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a10: 00020202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a14: 02020202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a18: 00000002
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a1c: 00020202
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a20: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a24: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a28: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a2c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a30: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a34: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a38: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a3c: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a40: 00090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a44: 00090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a48: 00000909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a4c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a50: 00000009
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a54: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a58: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a5c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a60: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a64: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a68: 00000909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a6c: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a70: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a74: 00000909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a78: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a7c: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a80: 00000909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a84: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a88: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a8c: 00000909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a90: 01010101
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a94: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a98: 09090909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:a9c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:aa0: 00000909
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:aa4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:aa8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:aac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ab0: 00000001
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ab4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ab8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:abc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ac0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ac4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ac8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:acc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ad0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ad4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ad8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:adc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ae0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ae4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ae8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:aec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:af0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:af4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:af8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:afc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b00: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b04: 0c301166
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b08: 0c301100
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b0c: 0c301166
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b10: 0c301166
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b14: 0c750077
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b18: 80008000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b1c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b20: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b24: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b28: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b2c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b30: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b34: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b38: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b3c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b40: 00000600
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b44: 00000600
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b48: 000007f2
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b4c: 00000800
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b50: 000007f4
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b54: 00000800
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b58: 00000600
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b5c: 0018c61c
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b60: 00f9861c
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b64: 00f9861c
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b68: 00f9861c
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b6c: 00000220
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b70: 00000823
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b74: 00003417
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b78: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b7c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b80: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b84: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b88: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b8c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b90: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b94: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b98: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:b9c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ba0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ba4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ba8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bb0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bb4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bb8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bbc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bc0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bc4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bc8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bcc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bd0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bd4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bd8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bdc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:be0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:be4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:be8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bf0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bf4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bf8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:bfc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c00: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c04: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c08: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c0c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c10: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c14: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c18: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c1c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c20: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c24: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c28: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c2c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c30: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c34: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c38: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c3c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c40: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c44: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c48: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c4c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c50: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c54: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c58: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c5c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c60: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c64: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c68: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c6c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c70: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c74: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c78: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c7c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c80: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c84: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c88: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c8c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c90: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c94: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c98: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:c9c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ca0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ca4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ca8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cb0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cb4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cb8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cbc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cc0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cc4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cc8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ccc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cd0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cd4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cd8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cdc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ce0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ce4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ce8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cf0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cf4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cf8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:cfc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d00: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d04: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d08: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d0c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d10: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d14: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d18: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d1c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d20: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d24: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d28: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d2c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d30: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d34: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d38: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d3c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d40: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d44: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d48: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d4c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d50: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d54: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d58: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d5c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d60: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d64: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d68: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d6c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d70: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d74: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d78: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d7c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d80: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d84: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d88: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d8c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d90: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d94: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d98: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:d9c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:da0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:da4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:da8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:db0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:db4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:db8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dbc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dc0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dc4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dc8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dcc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dd0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dd4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dd8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ddc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:de0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:de4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:de8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:df0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:df4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:df8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:dfc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e00: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e04: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e08: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e0c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e10: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e14: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e18: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e1c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e20: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e24: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e28: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e2c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e30: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e34: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e38: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e3c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e40: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e44: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e48: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e4c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e50: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e54: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e58: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e5c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e60: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e64: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e68: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e6c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e70: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e74: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e78: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e7c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e80: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e84: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e88: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e8c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e90: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e94: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e98: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:e9c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ea0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ea4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ea8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:eac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:eb0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:eb4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:eb8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ebc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ec0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ec4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ec8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ecc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ed0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ed4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ed8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:edc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ee0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ee4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ee8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:eec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ef0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ef4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ef8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:efc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f00: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f04: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f08: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f0c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f10: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f14: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f18: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f1c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f20: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f24: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f28: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f2c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f30: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f34: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f38: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f3c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f40: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f44: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f48: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f4c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f50: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f54: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f58: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f5c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f60: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f64: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f68: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f6c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f70: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f74: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f78: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f7c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f80: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f84: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f88: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f8c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f90: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f94: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f98: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:f9c: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fa0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fa4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fa8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fac: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fb0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fb4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fb8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fbc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fc0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fc4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fc8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fcc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fd0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fd4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fd8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fdc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fe0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fe4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fe8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:fec: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ff0: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ff4: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ff8: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/registers:ffc: 00000000
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/range:0-ffc
    /sys/kernel/debug/regmap/dummy-slcr@f8000000/name:nodev
    Library version: 0.23 (git tag: v0.23)
    Compiled with backends: local xml ip usb serial
    IIO context created with local backend.
    Backend version: 0.23 (git tag: v0.23)
    Backend description string: Linux pluto 5.4.0-00535-g9c04de11ae53 #1 SMP PREEMPT Fri Aug 20 13:01:03 CEST 2021 armv7l
    IIO context has 8 attributes:
    hw_model: Analog Devices PlutoSDR Rev.B (Z7010-AD9363A)
    hw_model_variant: 1
    hw_serial: 1044739659930004180010009d1128f096
    fw_version: v0.34
    ad9361-phy,xo_correction: 39999778
    ad9361-phy,model: ad9363a
    local,kernel: 5.4.0-00535-g9c04de11ae53
    uri: local:
    IIO context has 5 devices:
    iio:device0: adm1177-iio
    2 channels found:
    voltage0: (input)
    2 channel-specific attributes found:
    attr 0: raw value: 771
    attr 1: scale value: 6.433105468
    current0: (input)
    attr 0: raw value: 826
    attr 1: scale value: 0.516601562
    No trigger on this device
    iio:device1: ad9361-phy
    9 channels found:
    altvoltage1: TX_LO (output)
    8 channel-specific attributes found:
    attr 0: external value: 0
    attr 1: fastlock_load value: 0
    attr 2: fastlock_recall ERROR: Invalid argument (22)
    attr 3: fastlock_save value: 0 247,250,64,147,27,210,130,145,217,255,145,217,217,240,153,230
    attr 4: fastlock_store value: 0
    attr 5: frequency value: 2450000000
    attr 6: frequency_available value: [325000000 1 3800000000]
    attr 7: powerdown value: 0
    voltage0: (input)
    15 channel-specific attributes found:
    attr 0: bb_dc_offset_tracking_en value: 1
    attr 1: filter_fir_en value: 0
    attr 2: gain_control_mode value: slow_attack
    attr 3: gain_control_mode_available value: manual fast_attack slow_attack hybrid
    attr 4: hardwaregain value: 71.000000 dB
    attr 5: hardwaregain_available value: [-3 1 71]
    attr 6: quadrature_tracking_en value: 1
    attr 7: rf_bandwidth value: 18000000
    attr 8: rf_bandwidth_available value: [200000 1 56000000]
    attr 9: rf_dc_offset_tracking_en value: 1
    attr 10: rf_port_select value: A_BALANCED
    attr 11: rf_port_select_available value: A_BALANCED B_BALANCED C_BALANCED A_N A_P B_N B_P C_N C_P TX_MONITOR1 TX_MONITOR2 TX_MONITOR1_2
    attr 12: rssi value: 111.75 dB
    attr 13: sampling_frequency value: 30720000
    attr 14: sampling_frequency_available value: [2083333 1 61440000]
    voltage3: (output)
    attr 0: filter_fir_en value: 0
    attr 1: raw value: 306
    attr 2: rf_bandwidth value: 18000000
    attr 3: rf_bandwidth_available value: [200000 1 40000000]
    attr 4: rf_port_select_available value: A B
    attr 5: sampling_frequency value: 30720000
    attr 6: sampling_frequency_available value: [2083333 1 61440000]
    attr 7: scale value: 1.000000
    altvoltage0: RX_LO (output)
    attr 3: fastlock_save value: 0 152,145,126,148,153,145,145,213,145,145,145,145,210,145,145,149
    attr 5: frequency value: 2400000000
    voltage2: (output)
    temp0: (input)
    1 channel-specific attributes found:
    attr 0: input value: 28070
    voltage0: (output)
    10 channel-specific attributes found:
    attr 1: hardwaregain value: -10.000000 dB
    attr 2: hardwaregain_available value: [-89.750000 0.250000 0.000000]
    attr 3: rf_bandwidth value: 18000000
    attr 4: rf_bandwidth_available value: [200000 1 40000000]
    attr 5: rf_port_select value: A
    attr 6: rf_port_select_available value: A B
    attr 7: rssi value: 0.00 dB
    attr 8: sampling_frequency value: 30720000
    attr 9: sampling_frequency_available value: [2083333 1 61440000]
    voltage2: (input)
    13 channel-specific attributes found:
    attr 2: gain_control_mode_available value: manual fast_attack slow_attack hybrid
    attr 3: offset value: 57
    attr 4: quadrature_tracking_en value: 1
    attr 5: raw value: 1189
    attr 6: rf_bandwidth value: 18000000
    attr 7: rf_bandwidth_available value: [200000 1 56000000]
    attr 8: rf_dc_offset_tracking_en value: 1
    attr 9: rf_port_select_available value: A_BALANCED B_BALANCED C_BALANCED A_N A_P B_N B_P C_N C_P TX_MONITOR1 TX_MONITOR2 TX_MONITOR1_2
    attr 10: sampling_frequency value: 30720000
    attr 11: sampling_frequency_available value: [2083333 1 61440000]
    attr 12: scale value: 0.305250
    out: (input, WARN:iio_channel_get_type()=UNKNOWN)
    attr 0: voltage_filter_fir_en value: 0
    18 device-specific attributes found:
    attr 0: calib_mode value: auto
    attr 1: calib_mode_available value: auto manual manual_tx_quad tx_quad rf_dc_offs rssi_gain_step
    attr 2: dcxo_tune_coarse ERROR: No such device (19)
    attr 3: dcxo_tune_coarse_available value: [0 0 0]
    attr 4: dcxo_tune_fine ERROR: No such device (19)
    attr 5: dcxo_tune_fine_available value: [0 0 0]
    attr 6: ensm_mode value: fdd
    attr 7: ensm_mode_available value: sleep wait alert fdd pinctrl pinctrl_fdd_indep
    attr 8: filter_fir_config value: FIR Rx: 0,0 Tx: 0,0
    attr 9: gain_table_config value: <gaintable AD9361 type=FULL dest=3 start=1300000000 end=4000000000>
    -3, 0x00, 0x00, 0x20
    -3, 0x00, 0x00, 0x00
    -2, 0x00, 0x01, 0x00
    -1, 0x00, 0x02, 0x00
    0, 0x00, 0x03, 0x00
    1, 0x00, 0x04, 0x00
    2, 0x00, 0x05, 0x00
    3, 0x01, 0x03, 0x20
    4, 0x01, 0x04, 0x00
    5, 0x01, 0x05, 0x00
    6, 0x01, 0x06, 0x00
    7, 0x01, 0x07, 0x00
    8, 0x01, 0x08, 0x00
    9, 0x01, 0x09, 0x00
    10, 0x01, 0x0A, 0x00
    11, 0x01, 0x0B, 0x00
    12, 0x01, 0x0C, 0x00
    13, 0x01, 0x0D, 0x00
    14, 0x01, 0x0E, 0x00
    15, 0x02, 0x09, 0x20
    16, 0x02, 0x0A, 0x00
    17, 0x02, 0x0B, 0x00
    18, 0x02, 0x0C, 0x00
    19, 0x02, 0x0D, 0x00
    20, 0x02, 0x0E, 0x00
    21, 0x02, 0x0F, 0x00
    22, 0x02, 0x10, 0x00
    23, 0x02, 0x2B, 0x20
    24, 0x02, 0x2C, 0x00
    25, 0x04, 0x27, 0x20
    26, 0x04, 0x28, 0x00
    27, 0x04, 0x29, 0x00
    28, 0x04, 0x2A, 0x00
    29, 0x04, 0x2B, 0x00
    30, 0x24, 0x21, 0x20
    31, 0x24, 0x22, 0x00
    32, 0x44, 0x20, 0x20
    33, 0x44, 0x21, 0x00
    34, 0x44, 0x22, 0x00
    35, 0x44, 0x23, 0x00
    36, 0x44, 0x24, 0x00
    37, 0x44, 0x25, 0x00
    38, 0x44, 0x26, 0x00
    39, 0x44, 0x27, 0x00
    40, 0x44, 0x28, 0x00
    41, 0x44, 0x29, 0x00
    42, 0x44, 0x2A, 0x00
    43, 0x44, 0x2B, 0x00
    44, 0x44, 0x2C, 0x00
    45, 0x44, 0x2D, 0x00
    46, 0x44, 0x2E, 0x00
    47, 0x44, 0x2F, 0x00
    48, 0x44, 0x30, 0x00
    49, 0x44, 0x31, 0x00
    50, 0x64, 0x2E, 0x20
    51, 0x64, 0x2F, 0x00
    52, 0x64, 0x30, 0x00
    53, 0x64, 0x31, 0x00
    54, 0x64, 0x32, 0x00
    55, 0x64, 0x33, 0x00
    56, 0x64, 0x34, 0x00
    57, 0x64, 0x35, 0x00
    58, 0x64, 0x36, 0x00
    59, 0x64, 0x37, 0x00
    60, 0x64, 0x38, 0x00
    61, 0x65, 0x38, 0x20
    62, 0x66, 0x38, 0x20
    63, 0x67, 0x38, 0x20
    64, 0x68, 0x38, 0x20
    65, 0x69, 0x38, 0x20
    66, 0x6A, 0x38, 0x20
    67, 0x6B, 0x38, 0x20
    68, 0x6C, 0x38, 0x20
    69, 0x6D, 0x38, 0x20
    70, 0x6E, 0x38, 0x20
    71, 0x6F, 0x38, 0x20
    </gaintable>
    attr 10: multichip_sync ERROR: Permission denied (13)
    attr 11: rssi_gain_step_error value: lna_error: 0 0 0 0
    mixer_error: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
    gain_step_calib_reg_val: 0 0 0 0 0
    attr 12: rx_path_rates value: BBPLL:983040002 ADC:245760000 R2:122880000 R1:61440000 RF:30720000 RXSAMP:30720000
    attr 13: trx_rate_governor value: nominal
    attr 14: trx_rate_governor_available value: nominal highest_osr
    attr 15: tx_path_rates value: BBPLL:983040002 DAC:122880000 T2:122880000 T1:61440000 TF:30720000 TXSAMP:30720000
    attr 16: xo_correction value: 39999778
    attr 17: xo_correction_available value: [39991779 1 40007777]
    179 debug attributes found:
    debug attr 0: digital_tune value: 0
    debug attr 1: calibration_switch_control value: 0
    debug attr 2: multichip_sync value: 0
    debug attr 3: gaininfo_rx2 ERROR: Resource temporarily unavailable (11)
    debug attr 4: gaininfo_rx1 value: 71 76 0 0 0 0 0 0
    debug attr 5: bist_timing_analysis value: 0
    debug attr 6: gpo_set value: 0
    debug attr 7: bist_tone value: 0
    debug attr 8: bist_prbs value: 0
    debug attr 9: loopback value: 0
    debug attr 10: initialize value: 0
    debug attr 11: adi,bb-clk-change-dig-tune-enable value: 0
    debug attr 12: adi,axi-half-dac-rate-enable value: 0
    debug attr 13: adi,txmon-2-lo-cm value: 48
    debug attr 14: adi,txmon-1-lo-cm value: 48
    debug attr 15: adi,txmon-2-front-end-gain value: 2
    debug attr 16: adi,txmon-1-front-end-gain value: 2
    debug attr 17: adi,txmon-duration value: 8192
    debug attr 18: adi,txmon-delay value: 511
    debug attr 19: adi,txmon-one-shot-mode-enable value: 0
    debug attr 20: adi,txmon-dc-tracking-enable value: 0
    debug attr 21: adi,txmon-high-gain value: 24
    debug attr 22: adi,txmon-low-gain value: 0
    debug attr 23: adi,txmon-low-high-thresh value: 37000
    debug attr 24: adi,gpo3-tx-delay-us value: 0
    debug attr 25: adi,gpo3-rx-delay-us value: 0
    debug attr 26: adi,gpo2-tx-delay-us value: 0
    debug attr 27: adi,gpo2-rx-delay-us value: 0
    debug attr 28: adi,gpo1-tx-delay-us value: 0
    debug attr 29: adi,gpo1-rx-delay-us value: 0
    debug attr 30: adi,gpo0-tx-delay-us value: 0
    debug attr 31: adi,gpo0-rx-delay-us value: 0
    debug attr 32: adi,gpo3-slave-tx-enable value: 0
    debug attr 33: adi,gpo3-slave-rx-enable value: 0
    debug attr 34: adi,gpo2-slave-tx-enable value: 0
    debug attr 35: adi,gpo2-slave-rx-enable value: 0
    debug attr 36: adi,gpo1-slave-tx-enable value: 0
    debug attr 37: adi,gpo1-slave-rx-enable value: 0
    debug attr 38: adi,gpo0-slave-tx-enable value: 0
    debug attr 39: adi,gpo0-slave-rx-enable value: 0
    debug attr 40: adi,gpo3-inactive-state-high-enable value: 0
    debug attr 41: adi,gpo2-inactive-state-high-enable value: 0
    debug attr 42: adi,gpo1-inactive-state-high-enable value: 0
    debug attr 43: adi,gpo0-inactive-state-high-enable value: 0
    debug attr 44: adi,gpo-manual-mode-enable-mask value: 0
    debug attr 45: adi,gpo-manual-mode-enable value: 0
    debug attr 46: adi,aux-dac2-tx-delay-us value: 0
    debug attr 47: adi,aux-dac2-rx-delay-us value: 0
    debug attr 48: adi,aux-dac2-active-in-alert-enable value: 0
    debug attr 49: adi,aux-dac2-active-in-tx-enable value: 0
    debug attr 50: adi,aux-dac2-active-in-rx-enable value: 0
    debug attr 51: adi,aux-dac2-default-value-mV value: 0
    debug attr 52: adi,aux-dac1-tx-delay-us value: 0
    debug attr 53: adi,aux-dac1-rx-delay-us value: 0
    debug attr 54: adi,aux-dac1-active-in-alert-enable value: 0
    debug attr 55: adi,aux-dac1-active-in-tx-enable value: 0
    debug attr 56: adi,aux-dac1-active-in-rx-enable value: 0
    debug attr 57: adi,aux-dac1-default-value-mV value: 0
    debug attr 58: adi,aux-dac-manual-mode-enable value: 1
    debug attr 59: adi,aux-adc-decimation value: 256
    debug attr 60: adi,aux-adc-rate value: 40000000
    debug attr 61: adi,temp-sense-decimation value: 256
    debug attr 62: adi,temp-sense-periodic-measurement-enable value: 1
    debug attr 63: adi,temp-sense-offset-signed value: 206
    debug attr 64: adi,temp-sense-measurement-interval-ms value: 1000
    debug attr 65: adi,elna-gaintable-all-index-enable value: 0
    debug attr 66: adi,elna-rx2-gpo1-control-enable value: 0
    debug attr 67: adi,elna-rx1-gpo0-control-enable value: 0
    debug attr 68: adi,elna-bypass-loss-mdB value: 0
    debug attr 69: adi,elna-gain-mdB value: 0
    debug attr 70: adi,elna-settling-delay-ns value: 0
    debug attr 71: adi,ctrl-outs-enable-mask value: 255
    debug attr 72: adi,ctrl-outs-index value: 0
    debug attr 73: adi,rssi-duration value: 1000
    debug attr 74: adi,rssi-wait value: 1
    debug attr 75: adi,rssi-delay value: 1
    debug attr 76: adi,rssi-unit-is-rx-samples-enable value: 0
    debug attr 77: adi,rssi-restart-mode value: 3
    debug attr 78: adi,fagc-adc-large-overload-inc-steps value: 2
    debug attr 79: adi,fagc-power-measurement-duration-in-state5 value: 64
    debug attr 80: adi,fagc-rst-gla-if-en-agc-pulled-high-mode value: 0
    debug attr 81: adi,fagc-rst-gla-en-agc-pulled-high-enable value: 0
    debug attr 82: adi,fagc-rst-gla-large-lmt-overload-enable value: 1
    debug attr 83: adi,fagc-rst-gla-large-adc-overload-enable value: 1
    debug attr 84: adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt value: 8
    debug attr 85: adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll value: 10
    debug attr 86: adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable value: 1
    debug attr 87: adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable value: 1
    debug attr 88: adi,fagc-rst-gla-stronger-sig-thresh-above-ll value: 10
    debug attr 89: adi,fagc-optimized-gain-offset value: 5
    debug attr 90: adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable value: 1
    debug attr 91: adi,fagc-use-last-lock-level-for-set-gain-enable value: 1
    debug attr 92: adi,fagc-gain-index-type-after-exit-rx-mode value: 0
    debug attr 93: adi,fagc-gain-increase-after-gain-lock-enable value: 0
    debug attr 94: adi,fagc-final-overrange-count value: 3
    debug attr 95: adi,fagc-lmt-final-settling-steps value: 1
    debug attr 96: adi,fagc-lpf-final-settling-steps value: 1
    debug attr 97: adi,fagc-lock-level-gain-increase-upper-limit value: 5
    debug attr 98: adi,fagc-lock-level-lmt-gain-increase-enable value: 1
    debug attr 99: adi,fagc-lp-thresh-increment-steps value: 1
    debug attr 100: adi,fagc-lp-thresh-increment-time value: 5
    debug attr 101: adi,fagc-allow-agc-gain-increase-enable value: 0
    debug attr 102: adi,fagc-state-wait-time-ns value: 260
    debug attr 103: adi,fagc-dec-pow-measurement-duration value: 64
    debug attr 104: adi,agc-immed-gain-change-if-large-lmt-overload-enable value: 0
    debug attr 105: adi,agc-immed-gain-change-if-large-adc-overload-enable value: 0
    debug attr 106: adi,agc-gain-update-interval-us value: 1000
    debug attr 107: adi,agc-sync-for-gain-counter-enable value: 0
    debug attr 108: adi,agc-dig-gain-step-size value: 4
    debug attr 109: adi,agc-dig-saturation-exceed-counter value: 3
    debug attr 110: adi,agc-lmt-overload-large-inc-steps value: 2
    debug attr 111: adi,agc-lmt-overload-small-exceed-counter value: 10
    debug attr 112: adi,agc-lmt-overload-large-exceed-counter value: 10
    debug attr 113: adi,agc-adc-lmt-small-overload-prevent-gain-inc-enable value: 0
    debug attr 114: adi,agc-adc-large-overload-inc-steps value: 2
    debug attr 115: adi,agc-adc-large-overload-exceed-counter value: 10
    debug attr 116: adi,agc-adc-small-overload-exceed-counter value: 10
    debug attr 117: adi,agc-outer-thresh-low-inc-steps value: 2
    debug attr 118: adi,agc-outer-thresh-low value: 18
    debug attr 119: adi,agc-inner-thresh-low-inc-steps value: 1
    debug attr 120: adi,agc-inner-thresh-low value: 12
    debug attr 121: adi,agc-inner-thresh-high-dec-steps value: 1
    debug attr 122: adi,agc-inner-thresh-high value: 10
    debug attr 123: adi,agc-outer-thresh-high-dec-steps value: 2
    debug attr 124: adi,agc-outer-thresh-high value: 5
    debug attr 125: adi,agc-attack-delay-extra-margin-us value: 1
    debug attr 126: adi,mgc-split-table-ctrl-inp-gain-mode value: 0
    debug attr 127: adi,mgc-dec-gain-step value: 2
    debug attr 128: adi,mgc-inc-gain-step value: 2
    debug attr 129: adi,mgc-rx2-ctrl-inp-enable value: 0
    debug attr 130: adi,mgc-rx1-ctrl-inp-enable value: 0
    debug attr 131: adi,gc-use-rx-fir-out-for-dec-pwr-meas-enable value: 0
    debug attr 132: adi,gc-max-dig-gain value: 15
    debug attr 133: adi,gc-dig-gain-enable value: 0
    debug attr 134: adi,gc-low-power-thresh value: 24
    debug attr 135: adi,gc-dec-pow-measurement-duration value: 8192
    debug attr 136: adi,gc-lmt-overload-low-thresh value: 704
    debug attr 137: adi,gc-lmt-overload-high-thresh value: 800
    debug attr 138: adi,gc-adc-large-overload-thresh value: 58
    debug attr 139: adi,gc-adc-small-overload-thresh value: 47
    debug attr 140: adi,gc-adc-ovr-sample-size value: 4
    debug attr 141: adi,gc-rx2-mode value: 2
    debug attr 142: adi,gc-rx1-mode value: 2
    debug attr 143: adi,update-tx-gain-in-alert-enable value: 0
    debug attr 144: adi,tx-attenuation-mdB value: 10000
    debug attr 145: adi,rf-tx-bandwidth-hz value: 18000000
    debug attr 146: adi,rf-rx-bandwidth-hz value: 18000000
    debug attr 147: adi,qec-tracking-slow-mode-enable value: 0
    debug attr 148: adi,dc-offset-count-low-range value: 50
    debug attr 149: adi,dc-offset-count-high-range value: 40
    debug attr 150: adi,dc-offset-attenuation-low-range value: 5
    debug attr 151: adi,dc-offset-attenuation-high-range value: 6
    debug attr 152: adi,dc-offset-tracking-update-event-mask value: 5
    debug attr 153: adi,clk-output-mode-select value: 0
    debug attr 154: adi,tx-lo-powerdown-managed-enable value: 1
    debug attr 155: adi,trx-synthesizer-target-fref-overwrite-hz value: 80008000
    debug attr 156: adi,rx1-rx2-phase-inversion-enable value: 0
    debug attr 157: adi,tx-rf-port-input-select-lock-enable value: 1
    debug attr 158: adi,rx-rf-port-input-select-lock-enable value: 1
    debug attr 159: adi,tx-rf-port-input-select value: 0
    debug attr 160: adi,rx-rf-port-input-select value: 0
    debug attr 161: adi,split-gain-table-mode-enable value: 0
    debug attr 162: adi,1rx-1tx-mode-use-tx-num value: 1
    debug attr 163: adi,1rx-1tx-mode-use-rx-num value: 1
    debug attr 164: adi,2rx-2tx-mode-enable value: 0
    debug attr 165: adi,digital-interface-tune-fir-disable value: 1
    debug attr 166: adi,digital-interface-tune-skip-mode value: 0
    debug attr 167: adi,tx-fastlock-pincontrol-enable value: 0
    debug attr 168: adi,rx-fastlock-pincontrol-enable value: 0
    debug attr 169: adi,rx-fastlock-delay-ns value: 0
    debug attr 170: adi,tx-fastlock-delay-ns value: 0
    debug attr 171: adi,tdd-skip-vco-cal-enable value: 0
    debug attr 172: adi,tdd-use-dual-synth-mode-enable value: 0
    debug attr 173: adi,debug-mode-enable value: 0
    debug attr 174: adi,ensm-enable-txnrx-control-enable value: 0
    debug attr 175: adi,ensm-enable-pin-pulse-mode-enable value: 0
    debug attr 176: adi,frequency-division-duplex-independent-mode-enable value: 0
    debug attr 177: adi,frequency-division-duplex-mode-enable value: 1
    debug attr 178: direct_reg_access value: 0x0
    iio:device2: xadc
    10 channels found:
    voltage5: vccoddr (input)
    attr 0: raw value: 1848
    attr 1: scale value: 0.732421875
    voltage0: vccint (input)
    attr 0: raw value: 1385
    voltage4: vccpaux (input)
    attr 0: raw value: 2457
    temp0: (input)
    attr 0: offset value: -2219
    attr 1: raw value: 2611
    attr 2: scale value: 123.040771484
    voltage7: vrefn (input)
    attr 0: raw value: 6
    voltage1: vccaux (input)
    attr 0: raw value: 2462
    voltage2: vccbram (input)
    attr 0: raw value: 1391
    voltage3: vccpint (input)
    attr 0: raw value: 1386
    voltage8: (input)
    attr 0: raw value: 3688
    attr 1: scale value: 0.244140625
    voltage6: vrefp (input)
    attr 0: raw value: 1705
    1 device-specific attributes found:
    attr 0: sampling_frequency value: 961538
    iio:device3: cf-ad9361-dds-core-lpc (buffer capable)
    6 channels found:
    voltage0: (output, index: 0, format: le:S16/16>>0)
    4 channel-specific attributes found:
    attr 0: calibphase value: 0.000000
    attr 1: calibscale value: 1.000000
    attr 2: sampling_frequency value: 30720000
    attr 3: sampling_frequency_available value: 30720000 3840000
    voltage1: (output, index: 1, format: le:S16/16>>0)
    altvoltage3: TX1_Q_F2 (output)
    attr 0: frequency value: 9279985
    attr 1: phase value: 0
    attr 2: raw value: 1
    attr 3: sampling_frequency value: 30720000
    attr 4: scale value: 0.000000
    altvoltage1: TX1_I_F2 (output)
    attr 1: phase value: 90000
    altvoltage0: TX1_I_F1 (output)
    altvoltage2: TX1_Q_F1 (output)
    3 buffer-specific attributes found:
    attr 0: data_available value: 0
    attr 1: length_align_bytes value: 8
    attr 2: watermark value: 2048
    1 debug attributes found:
    debug attr 0: direct_reg_access value: 0x90162
    iio:device4: cf-ad9361-lpc (buffer capable)
    2 channels found:
    voltage0: (input, index: 0, format: le:S12/16>>0)
    6 channel-specific attributes found:
    attr 0: calibbias value: 0
    attr 1: calibphase value: 0.000000
    attr 2: calibscale value: 1.000000
    attr 3: samples_pps ERROR: No such device (19)
    attr 4: sampling_frequency value: 30720000
    attr 5: sampling_frequency_available value: 30720000 3840000
    voltage1: (input, index: 1, format: le:S12/16>>0)
    2 debug attributes found:
    debug attr 0: pseudorandom_err_check value: CH0 : PN9 : Out of Sync : PN Error
    CH1 : PN9 : Out of Sync : PN Error
    debug attr 1: direct_reg_access value: 0x0
    lo Link encap:Local Loopback
    inet addr:127.0.0.1 Mask:255.0.0.0
    UP LOOPBACK RUNNING MTU:65536 Metric:1
    RX packets:0 errors:0 dropped:0 overruns:0 frame:0
    TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
    collisions:0 txqueuelen:1000
    RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
    usb0 Link encap:Ethernet HWaddr 00:05:F7:8B:6C:AA
    inet addr:192.168.2.1 Bcast:0.0.0.0 Mask:255.255.255.0
    UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
    RX packets:131 errors:0 dropped:49 overruns:0 frame:0
    TX packets:21 errors:0 dropped:0 overruns:0 carrier:0
    RX bytes:17536 (17.1 KiB) TX bytes:4850 (4.7 KiB)
    none on / type rootfs (rw)
    devtmpfs on /dev type devtmpfs (rw,relatime,size=120504k,nr_inodes=30126,mode=755)
    proc on /proc type proc (rw,relatime)
    devpts on /dev/pts type devpts (rw,relatime,gid=5,mode=620,ptmxmode=000)
    tmpfs on /dev/shm type tmpfs (rw,relatime,mode=777)
    tmpfs on /tmp type tmpfs (rw,relatime)
    tmpfs on /run type tmpfs (rw,nosuid,nodev,relatime,mode=755)
    sysfs on /sys type sysfs (rw,relatime)
    mtd2 on /mnt/jffs2 type jffs2 (rw,noatime)
    none on /sys/kernel/debug type debugfs (rw,relatime)
    configfs on /sys/kernel/config type configfs (rw,relatime)
    iio_ffs on /dev/iio_ffs type functionfs (rw,relatime)
    /dev/loop7 on /mnt/msd type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
    Mem: 55480K used, 454132K free, 72K shrd, 28K buff, 44848K cached
    CPU: 0% usr 9% sys 0% nic 90% idle 0% io 0% irq 0% sirq
    Load average: 0.00 0.00 0.00 1/47 1527
    PID PPID USER STAT VSZ %VSZ %CPU COMMAND
    185 1 root S 30468 6% 0% /usr/sbin/iiod -D -n 3 -F /dev/iio_ffs
    324 1 avahi S 3252 1% 0% avahi-daemon: running [pluto.local]
    208 1 dbus S 2804 1% 0% dbus-daemon --system
    337 1 root S 2736 1% 0% -sh
    1 0 root S 2608 1% 0% init
    317 1 root S 2608 1% 0% /bin/sh /sbin/update.sh
    96 1 root S 2608 1% 0% /sbin/klogd -n
    1527 317 root R 2608 1% 0% top -b -n1
    92 1 root S 2608 1% 0% /sbin/syslogd -n
    266 1 root S 2608 1% 0% /usr/sbin/udhcpd /etc/udhcpd.conf
    269 1 root S 2608 1% 0% httpd -h /www
    336 1 root S 2608 1% 0% /sbin/getty -L ttyPS0 0 vt100
    113 1 root S 2476 0% 0% watchdog -t 5 -T 10 /dev/watchdog
    332 1 root S 2252 0% 0% /usr/sbin/dropbear -R
    335 1 root S 1732 0% 0% input-event-daemon
    15 2 root IW 0 0% 0% [kworker/0:1-mm_]
    65 2 root SW 0 0% 0% [spi1]
    10 2 root IW 0 0% 0% [rcu_preempt]
    9 2 root SW 0 0% 0% [ksoftirqd/0]
    190 2 root SW 0 0% 0% [file-storage]
    64 2 root SW 0 0% 0% [spi0]
    2 0 root SW 0 0% 0% [kthreadd]
    3 2 root IW< 0 0% 0% [rcu_gp]
    4 2 root IW< 0 0% 0% [rcu_par_gp]
    6 2 root IW< 0 0% 0% [kworker/0:0H-kb]
    7 2 root IW 0 0% 0% [kworker/u4:0-ev]
    8 2 root IW< 0 0% 0% [mm_percpu_wq]
    11 2 root SW 0 0% 0% [migration/0]
    12 2 root SW 0 0% 0% [cpuhp/0]
    13 2 root SW 0 0% 0% [kdevtmpfs]
    14 2 root SW 0 0% 0% [rcu_tasks_kthre]
    16 2 root SW 0 0% 0% [khungtaskd]
    17 2 root SW 0 0% 0% [oom_reaper]
    18 2 root IW< 0 0% 0% [writeback]
    20 2 root IW 0 0% 0% [kworker/u4:1-ev]
    58 2 root IW< 0 0% 0% [kblockd]
    59 2 root SW 0 0% 0% [watchdogd]
    60 2 root IW< 0 0% 0% [cfg80211]
    61 2 root SW 0 0% 0% [kswapd0]
    67 2 root IW< 0 0% 0% [ci_otg]
    68 2 root SW 0 0% 0% [irq/46-41600000]
    69 2 root IW 0 0% 0% [kworker/0:2-pm]
    81 2 root SWN 0 0% 0% [jffs2_gcd_mtd2]
    305 2 root SW< 0 0% 0% [loop7]
    309 2 root IW< 0 0% 0% [kworker/0:1H-kb]
    ad936x_ext_refclk=<39999778>
    adi_loadvals=fdt addr ${fit_load_address} && fdt get value fdt_choosen /configurations/${fit_config}/ fdt && fdt get addr fdtaddr /images/${fdt_choosen} data && fdt addr ${fdtaddr}; if test -n ${ad936x_ext_refclk} && test ! -n ${ad936x_skip_ext_refclk}; then fdt set /clocks/clock@0 clock-frequency ${ad936x_ext_refclk}; fi; fdt get value model / model; if test -n ${ad936x_ext_refclk_override} && test "${model}" = "Analog Devices PlutoSDR Rev.C (Z7010/AD9363)"; then fdt set /clocks/clock@0 clock-frequency ${ad936x_ext_refclk_override}; fi; if test ${refclk_source} = internal || test ! "${model}" = "Analog Devices PlutoSDR Rev.C (Z7010/AD9363)" ; then fdt rm /amba/gpio@e000a000/clock_extern_en; fi; if test -n ${attr_name} && test -n ${attr_val}; then fdt set /amba/spi@e0006000/ad9361-phy@0 ${attr_name} ${attr_val}; fi; if test ${refclk_source} = external || test ! "${model}" = "Analog Devices PlutoSDR Rev.C (Z7010/AD9363)" ; then fdt rm /amba/gpio@e000a000/clock_internal_en; fi; if test -n ${compatible} && test ! ${compatible} = ad9361 && test ! ${compatible} = ad9363a && test ! ${compatible} = ad9364; then setenv compatible ad9363a; saveenv; fi; if test -n ${mode} && test ! ${mode} = 1r1t && test ! ${mode} = 2r2t; then setenv mode 1r1t; saveenv; fi; if test -n ${refclk_source} && test ! ${refclk_source} = internal && test ! ${refclk_source} = external; then setenv refclk_source internal; saveenv; fi; if test -n ${compatible}; then fdt set /amba/spi@e0006000/ad9361-phy@0 compatible ${compatible}; fi; if test ${compatible} = ad9361 && test ! "${model}" = "Analog Devices PlutoSDR Rev.C (Z7010/AD9363)" ; then fdt set /amba/spi@e0006000/ad9361-phy@0 compatible ad9363a; compatible=ad9363a; fi; if test ${mode} = 1r1t || test ! "${model}" = "Analog Devices PlutoSDR Rev.C (Z7010/AD9363)"; then fdt rm /amba/spi@e0006000/ad9361-phy@0 adi,2rx-2tx-mode-enable; fi; if test -n ${cs_gpio}; then fdt set /amba/axi_quad_spi@7C430000/ cs-gpios "<0x06 ${cs_gpio} 0>"; fi; if test ${compatible} = ad9364 || test -n ${attr_val} = ad9364; then fdt rm /amba/spi@e0006000/ad9361-phy@0 adi,2rx-2tx-mode-enable; fdt set /fpga-axi/cf-ad9361-dds-core-lpc@79024000 compatible adi,axi-ad9364-dds-6.00.a; setenv mode 1r1t; saveenv; fi;
    baudrate=115200
    bitstream_image=system.bit.bin
    bitstream_size=0x400000
    boot_image=BOOT.bin
    boot_size=0xF00000
    bootcmd=run $modeboot
    bootdelay=0
    bootenv=uEnv.txt
    clear_reset_cause=mw f8000008 df0d && mw f8000258 00400000 && mw f8000004 767b
    devicetree_image=devicetree.dtb
    devicetree_load_address=0x2000000
    devicetree_size=0x20000
    dfu_ram=echo Entering DFU RAM mode ... && run dfu_ram_info && dfu 0 ram 0
    dfu_ram_info=set dfu_alt_info dummy.dfu ram 0 0\\;firmware.dfu ram ${fit_load_address} 0x1E00000
    dfu_sf=gpio set 15;set stdout serial@e0001000;echo Entering DFU SF mode ... && run dfu_sf_info && dfu 0 sf 0:0:40000000:0 && if test -n ${dfu_alt_num} && test ${dfu_alt_num} = 1; then set fit_size ${filesize} && set dfu_alt_num && env save; fi;gpio clear 15;
    dfu_sf_info=set dfu_alt_info boot.dfu raw 0x0 0x100000\\;firmware.dfu raw 0x200000 0x1E00000\\;uboot-extra-env.dfu raw 0xFF000 0x1000\\;uboot-env.dfu raw 0x100000 0x20000\\;spare.dfu raw 0x120000 0xE0000
    ethaddr=00:0a:35:00:01:22
    extraenv_load_address=0x207E000
    fdt_choosen=fdt@2
    fdt_high=0x20000000
    fdtaddr=2084a50
    fdtcontroladdr=1ff99f50
    fit_config=config@9
    fit_load_address=0x2080000
    fit_size=A17363
    importbootenv=echo Importing environment from SD ...; env import -t ${loadbootenv_addr} $filesize
    initrd_high=0x20000000
    ipaddr=192.168.2.1
    ipaddr_host=192.168.2.10
    jtagboot=env default -a;sf probe && sf protect unlock 0 100000 && run dfu_sf;
    kernel_image=uImage
    loadbit_addr=0x100000
    loadbootenv=load mmc 0 ${loadbootenv_addr} ${bootenv}
    loadbootenv_addr=0x2000000
    mode=1r1t
    modeboot=qspiboot
    model=Analog Devices PlutoSDR Rev.B (Z7010/AD9363)
    netmask=255.255.255.0
    preboot=if test $modeboot = sdboot && env run sd_uEnvtxt_existence_test; then if env run loadbootenv; then env run importbootenv; fi; fi;
    productkey=1a6591d2fae29ed19e60e9ea5ef6c14cb6266d22
    qspiboot=set stdout nulldev;adi_hwref;test -n $PlutoRevA || gpio input 14 && set stdout serial@e0001000 && sf probe && sf protect lock 0 100000 && run dfu_sf; set stdout serial@e0001000;itest *f8000258 == 480003 && run clear_reset_cause && run dfu_sf; itest *f8000258 == 480007 && run clear_reset_cause && run ramboot_verbose; itest *f8000258 == 480006 && run clear_reset_cause && run qspiboot_verbose; itest *f8000258 == 480002 && run clear_reset_cause && exit; echo Booting silently && set stdout nulldev; run read_sf && run adi_loadvals; envversion;setenv bootargs console=ttyPS0,115200 maxcpus=${maxcpus} rootfstype=ramfs root=/dev/ram0 rw quiet loglevel=4 uboot="${uboot-version}" && bootm ${fit_load_address}#${fit_config} || set stdout serial@e0001000;echo BOOT failed entering DFU mode ... && sf protect lock 0 100000 && run dfu_sf
    qspiboot_extraenv=sf read ${extraenv_load_address} 0xFF000 0x1000 && env import -c ${extraenv_load_address} 0x1000 || true
    qspiboot_verbose=adi_hwref;echo Copying Linux from QSPI flash to RAM... && run read_sf && if run adi_loadvals; then echo Loaded AD936x refclk frequency and model into devicetree; fi; envversion;setenv bootargs console=ttyPS0,115200 maxcpus=${maxcpus} rootfstype=ramfs root=/dev/ram0 rw earlyprintk uboot="${uboot-version}" && bootm ${fit_load_address}#${fit_config} || echo BOOT failed entering DFU mode ... && run dfu_sf
    ramboot_verbose=adi_hwref;echo Copying Linux from DFU to RAM... && run dfu_ram;if run adi_loadvals; then echo Loaded AD936x refclk frequency and model into devicetree; fi; envversion;setenv bootargs console=ttyPS0,115200 maxcpus=${maxcpus} rootfstype=ramfs root=/dev/ram0 rw earlyprintk uboot="${uboot-version}" && bootm ${fit_load_address}#${fit_config}
    ramdisk_image=uramdisk.image.gz
    ramdisk_load_address=0x4000000
    ramdisk_size=0x400000
    read_sf=sf probe 0:0 50000000 0 && run qspiboot_extraenv &&sf read ${fit_load_address} 0x200000 ${fit_size} && iminfo ${fit_load_address} || sf read ${fit_load_address} 0x200000 0x1E00000;
    refclk_source=internal
    sd_uEnvtxt_existence_test=test -e mmc 0 /uEnv.txt
    serial=1044739659930004180010009d1128f096
    stderr=serial@e0001000
    stdin=serial@e0001000
    stdout=nulldev
    thor_ram=run dfu_ram_info && thordown 0 ram 0
    uenvboot=if run loadbootenv; then echo Loaded environment from ${bootenv}; run importbootenv; fi; if test -n $uenvcmd; then echo Running uenvcmd ...; run uenvcmd; fi
    usbboot=if usb start; then run uenvboot; echo Copying Linux from USB to RAM... && load usb 0 ${fit_load_address} ${kernel_image} && load usb 0 ${devicetree_load_address} ${devicetree_image} && load usb 0 ${ramdisk_load_address} ${ramdisk_image} && bootm ${fit_load_address} ${ramdisk_load_address} ${devicetree_load_address}; fi
    maxcpus=1
    hostname=pluto
    udc_handle_suspend=0
    usb_ethernet_mode=0
    netmask_eth=255.255.255.0
Children
No Data
