ADALM PLUTO is not recognized in pcDuino4 nano [SOLVED]
I have two raspberrypi like computers, one is an orangepi +2E (OS Armbian) and the other is a pcDuino4 nano (OS Armbian). In both cases, I went through the steps indicated (here f1atb.fr/.../) to register the ADALM PLUTO device, but it does not recognize it in any case.
I am feeding externally yet there is nothing new in `lsusb` or `ip a` command.
[edited by: huguitovi at 1:47 AM (GMT -4) on 3 Nov 2021]
Top Replies
Parents
  • I am feeding externally
    I assume you mean you are using external power + the data port.
    What are the LEDs doing?
    Does anything change in dmesg after plugging in Pluto?
    -Travis
  • Thanks for responding so promptly Travis, I've watched your videos on youtube, my pleasure.
    On the SBCs, that is. The external power supply + data port. I also have Linux Debian on a desktop computer and everything works correctly there, the firmware is up to date. There I have done acceptance tests such as transmitting and receiving signals (sdrangel) and it worked like a charm, of course there I only use one cable since it does not require more power. On the other hand, on the SBC computers the device behaves the same way, turning on the power LED and blinking LED1. But it remains invisible on the command line.
    thank you very much
    Regards
    VH
  • Can you plugin Pluto and then provide the output of dmesg?
    -Travis
  • the output of the dmesg command in OrangePi +2E
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 5.10.60-sunxi (root@runner4) (arm-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #21.08.2 SMP Tue Sep 14 16:28:44 UTC 2021
    [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] OF: fdt: Machine model: Xunlong Orange Pi Plus 2E
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] cma: Reserved 128 MiB at 0xb7c00000
    [    0.000000] Zone ranges:
    [    0.000000]   Normal   [mem 0x0000000040000000-0x000000006fffffff]
    [    0.000000]   HighMem  [mem 0x0000000070000000-0x00000000bfffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000bfffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
    [    0.000000] On node 0 totalpages: 524288
    [    0.000000]   Normal zone: 1728 pages used for memmap
    [    0.000000]   Normal zone: 0 pages reserved
    [    0.000000]   Normal zone: 196608 pages, LIFO batch:63
    [    0.000000]   HighMem zone: 327680 pages, LIFO batch:63
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: Using PSCI v0.1 Function IDs from DT
    [    0.000000] percpu: Embedded 20 pages/cpu s50764 r8192 d22964 u81920
    [    0.000000] pcpu-alloc: s50764 r8192 d22964 u81920 alloc=20*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 522560
    [    0.000000] Kernel command line: root=UUID=85eba9d2-7707-4ba6-82db-708626ebe6fb rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart= ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
    [    0.000000] Memory: 1920592K/2097152K available (9216K kernel code, 1460K rwdata, 3232K rodata, 1024K init, 333K bss, 45488K reserved, 131072K cma-reserved, 1179636K highmem)
    [    0.000000] random: get_random_u32 called from __kmem_cache_create+0x1b/0x298 with crng_init=0
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] ftrace: allocating 42134 entries in 83 pages
    [    0.000000] ftrace: allocated 83 pages with 4 groups
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
    [    0.000000]     Rude variant of Tasks RCU enabled.
    [    0.000000]     Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
    [    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
    [    0.000017] Switching to timer-based delay loop, resolution 41ns
    [    0.000250] Console: colour dummy device 80x30
    [    0.000311] printk: console [tty1] enabled
    [    0.000364] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
    [    0.000380] pid_max: default: 32768 minimum: 301
    [    0.000573] LSM: Security Framework initializing
    [    0.000629] Yama: becoming mindful.
    [    0.000799] AppArmor: AppArmor initialized
    [    0.000877] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.000892] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.001907] CPU: Testing write buffer coherency: ok
    [    0.002271] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.002943] Setting up static identity map for 0x40100000 - 0x40100054
    [    0.003060] rcu: Hierarchical SRCU implementation.
    [    0.004225] smp: Bringing up secondary CPUs ...
    [    0.014997] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.025853] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [    0.036623] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [    0.036725] smp: Brought up 1 node, 4 CPUs
    [    0.036739] SMP: Total of 4 processors activated (192.00 BogoMIPS).
    [    0.036745] CPU: All CPU(s) started in HYP mode.
    [    0.036749] CPU: Virtualization extensions available.
    [    0.038008] allocated 2097152 bytes of page_ext
    [    0.038591] devtmpfs: initialized
    [    0.045828] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
    [    0.046037] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.046080] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.049332] pinctrl core: initialized pinctrl subsystem
    [    0.050472] NET: Registered protocol family 16
    [    0.052084] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.052675] audit: initializing netlink subsys (disabled)
    [    0.052943] audit: type=2000 audit(0.032:1): state=initialized audit_enabled=0 res=1
    [    0.053439] thermal_sys: Registered thermal governor 'fair_share'
    [    0.053446] thermal_sys: Registered thermal governor 'bang_bang'
    [    0.053452] thermal_sys: Registered thermal governor 'step_wise'
    [    0.054000] cpuidle: using governor ladder
    [    0.054121] cpuidle: using governor menu
    [    0.054646] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.054652] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.080947] cryptd: max_cpu_qlen set to 1000
    [    0.152784] raid6: neonx8   gen()   777 MB/s
    [    0.220887] raid6: neonx8   xor()   578 MB/s
    [    0.288999] raid6: neonx4   gen()   829 MB/s
    [    0.357107] raid6: neonx4   xor()   631 MB/s
    [    0.425217] raid6: neonx2   gen()   915 MB/s
    [    0.493308] raid6: neonx2   xor()   653 MB/s
    [    0.561421] raid6: neonx1   gen()   815 MB/s
    [    0.629520] raid6: neonx1   xor()   565 MB/s
    [    0.697660] raid6: int32x8  gen()   303 MB/s
    [    0.765746] raid6: int32x8  xor()   180 MB/s
    [    0.833853] raid6: int32x4  gen()   354 MB/s
    [    0.901942] raid6: int32x4  xor()   205 MB/s
    [    0.970104] raid6: int32x2  gen()   399 MB/s
    [    1.038181] raid6: int32x2  xor()   213 MB/s
    [    1.106283] raid6: int32x1  gen()   400 MB/s
    [    1.174437] raid6: int32x1  xor()   192 MB/s
    [    1.174443] raid6: using algorithm neonx2 gen() 915 MB/s
    [    1.174448] raid6: .... xor() 653 MB/s, rmw enabled
    [    1.174453] raid6: using neon recovery algorithm
    [    1.175917] iommu: Default domain type: Translated
    [    1.176273] SCSI subsystem initialized
    [    1.176489] libata version 3.00 loaded.
    [    1.176701] usbcore: registered new interface driver usbfs
    [    1.176785] usbcore: registered new interface driver hub
    [    1.176825] usbcore: registered new device driver usb
    [    1.176916] mc: Linux media interface: v0.10
    [    1.176959] videodev: Linux video capture interface: v2.00
    [    1.177084] pps_core: LinuxPPS API ver. 1 registered
    [    1.177091] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    1.177109] PTP clock support registered
    [    1.177597] Advanced Linux Sound Architecture Driver Initialized.
    [    1.178339] NetLabel: Initializing
    [    1.178348] NetLabel:  domain hash size = 128
    [    1.178353] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
    [    1.178435] NetLabel:  unlabeled traffic allowed by default
    [    1.179116] clocksource: Switched to clocksource arch_sys_counter
    [    1.290035] VFS: Disk quotas dquot_6.6.0
    [    1.290129] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    1.290699] AppArmor: AppArmor Filesystem Enabled
    [    1.298874] NET: Registered protocol family 2
    [    1.299051] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    1.300223] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    [    1.300290] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [    1.300394] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    1.300508] TCP: Hash tables configured (established 8192 bind 8192)
    [    1.300652] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    1.300709] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    1.300973] NET: Registered protocol family 1
    [    1.301668] Trying to unpack rootfs image as initramfs...
    [    1.932049] Freeing initrd memory: 9656K
    [    1.933455] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
    [    1.934616] Initialise system trusted keyrings
    [    1.934674] Key type Denylist registered
    [    1.934897] workingset: timestamp_bits=14 max_order=19 bucket_order=5
    [    1.940166] zbud: loaded
    [    1.941540] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    1.942467] fuse: init (API version 7.32)
    [    1.945016] integrity: Platform Keyring initialized
    [    2.053726] xor: measuring software checksum speed
    [    2.061331]    arm4regs        :  1303 MB/sec
    [    2.072259]    8regs           :   900 MB/sec
    [    2.083814]    32regs          :   851 MB/sec
    [    2.091267]    neon            :  1322 MB/sec
    [    2.091273] xor: using function: neon (1322 MB/sec)
    [    2.091287] Key type asymmetric registered
    [    2.091293] Asymmetric key parser 'x509' registered
    [    2.091452] bounce: pool size: 64 pages
    [    2.091525] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
    [    2.091687] io scheduler mq-deadline registered
    [    2.091694] io scheduler kyber registered
    [    2.091936] io scheduler bfq registered
    [    2.097970] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
    [    2.099751] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
    [    2.106850] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
    [    2.109301] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pa not found, using dummy regulator
    [    2.109819] printk: console [ttyS0] disabled
    [    2.109905] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 52, base_baud = 1500000) is a 16550A
    [    2.110135] printk: console [ttyS0] enabled
    [    2.127141] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc0a9f6a4)
    [    2.127466] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0a9b60c)
    [    2.127537] sun8i-dw-hdmi 1ee0000.hdmi: supply hvcc not found, using dummy regulator
    [    2.128369] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
    [    2.128723] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
    [    2.128991] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xc0a9ec5c)
    [    2.129513] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
    [    2.129589] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
    [    2.130597] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
    [    2.133152] brd: module loaded
    [    2.259146] loop: module loaded
    [    2.260999] libphy: Fixed MDIO Bus: probed
    [    2.261856] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pd not found, using dummy regulator
    [    2.262062] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
    [    2.262071] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
    [    2.263389] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    2.263423] ehci-platform: EHCI generic platform driver
    [    2.263610] ehci-platform 1c1a000.usb: EHCI Host Controller
    [    2.263639] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
    [    2.264023] ehci-platform 1c1a000.usb: irq 37, io mem 0x01c1a000
    [    2.279126] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
    [    2.279401] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [    2.279412] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.279420] usb usb1: Product: EHCI Host Controller
    [    2.279427] usb usb1: Manufacturer: Linux 5.10.60-sunxi ehci_hcd
    [    2.279434] usb usb1: SerialNumber: 1c1a000.usb
    [    2.280044] hub 1-0:1.0: USB hub found
    [    2.280087] hub 1-0:1.0: 1 port detected
    [    2.280970] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    [    2.280996] ohci-platform: OHCI generic platform driver
    [    2.281171] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
    [    2.281195] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
    [    2.281348] ohci-platform 1c1a400.usb: irq 38, io mem 0x01c1a400
    [    2.343321] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
    [    2.343331] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.343339] usb usb2: Product: Generic Platform OHCI controller
    [    2.343345] usb usb2: Manufacturer: Linux 5.10.60-sunxi ohci_hcd
    [    2.343353] usb usb2: SerialNumber: 1c1a400.usb
    [    2.343863] hub 2-0:1.0: USB hub found
    [    2.343903] hub 2-0:1.0: 1 port detected
    [    2.345263] usbcore: registered new interface driver usb-storage
    [    2.346291] sun6i-rtc 1f00000.rtc: registered as rtc0
    [    2.346333] sun6i-rtc 1f00000.rtc: setting system clock to 2021-10-26T16:22:19 UTC (1635265339)
    [    2.346340] sun6i-rtc 1f00000.rtc: RTC enabled
    [    2.346649] i2c /dev entries driver
    [    2.347008] sun8i-h3-r-pinctrl 1f02c00.pinctrl: supply vcc-pl not found, using dummy regulator
    [    2.349071] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
    [    2.349970] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
    [    2.350057] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pg not found, using dummy regulator
    [    2.350887] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pc not found, using dummy regulator
    [    2.351413] sunxi-mmc 1c0f000.mmc: Got CD GPIO
    [    2.351706] ledtrig-cpu: registered to indicate activity on CPUs
    [    2.352272] sun8i-ce 1c15000.crypto: Set mod clock to 50000000 (50 Mhz) from 24000000 (24 Mhz)
    [    2.352483] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
    [    2.352622] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
    [    2.352739] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
    [    2.352851] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
    [    2.352952] sun8i-ce 1c15000.crypto: Register cbc(aes)
    [    2.353094] sun8i-ce 1c15000.crypto: Register ecb(aes)
    [    2.353205] sun8i-ce 1c15000.crypto: Register cbc(des3_ede)
    [    2.353310] sun8i-ce 1c15000.crypto: Register ecb(des3_ede)
    [    2.353414] sun8i-ce 1c15000.crypto: Register md5
    [    2.353515] sun8i-ce 1c15000.crypto: Register sha1
    [    2.353615] sun8i-ce 1c15000.crypto: Register sha224
    [    2.353747] sun8i-ce 1c15000.crypto: Register sha256
    [    2.353848] sun8i-ce 1c15000.crypto: Register sha384
    [    2.353950] sun8i-ce 1c15000.crypto: Register sha512
    [    2.354080] sun8i-ce 1c15000.crypto: Register stdrng
    [    2.354207] sun8i-ce 1c15000.crypto: TRNG not supported
    [    2.354218] sun8i-ce 1c15000.crypto: CryptoEngine Die ID 1
    [    2.354647] hid: raw HID events driver (C) Jiri Kosina
    [    2.354791] usbcore: registered new interface driver usbhid
    [    2.354797] usbhid: USB HID core driver
    [    2.358918] debugfs: Directory '1c22c00.codec' with parent 'H3 Audio Codec' already present!
    [    2.362997] Initializing XFRM netlink socket
    [    2.363576] NET: Registered protocol family 10
    [    2.375209] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB
    [    2.375217] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
    [    2.407752] Segment Routing with IPv6
    [    2.407885] NET: Registered protocol family 17
    [    2.407929] NET: Registered protocol family 15
    [    2.408011] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [    2.408132] 8021q: 802.1Q VLAN Support v1.8
    [    2.408188] Key type dns_resolver registered
    [    2.408645] Registering SWP/SWPB emulation handler
    [    2.408951] registered taskstats version 1
    [    2.408963] Loading compiled-in X.509 certificates
    [    2.415678] Loaded X.509 cert 'Build time autogenerated kernel key: ccb8f1e1f0425ca2ac90594b8a1efc7ac41ccb85'
    [    2.420122] zswap: loaded using pool zstd/z3fold
    [    2.420848] Key type ._fscrypt registered
    [    2.420857] Key type .fscrypt registered
    [    2.420862] Key type fscrypt-provisioning registered
    [    2.425428] Btrfs loaded, crc32c=crc32c-generic
    [    2.446868] Key type encrypted registered
    [    2.446893] AppArmor: AppArmor sha1 policy hashing enabled
    [    2.457885] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pd not found, using dummy regulator
    [    2.458324] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pg not found, using dummy regulator
    [    2.460147] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
    [    2.460160] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
    [    2.460372] dwmac-sun8i 1c30000.ethernet: supply phy-io not found, using dummy regulator
    [    2.460597] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
    [    2.460621] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 50006 (expect 58000)
    [    2.499250] mmc2: new DDR MMC card at address 0001
    [    2.500494] mmcblk2: mmc2:0001 AWPD3R 14.6 GiB
    [    2.501440] mmcblk2boot0: mmc2:0001 AWPD3R partition 1 4.00 MiB
    [    2.502353] mmcblk2boot1: mmc2:0001 AWPD3R partition 2 4.00 MiB
    [    2.505176]  mmcblk2: p1
    [    2.567366] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
    [    2.567382] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
    [    2.567390] dwmac-sun8i 1c30000.ethernet: COE Type 2
    [    2.567396] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
    [    2.567405] dwmac-sun8i 1c30000.ethernet: Normal descriptors
    [    2.567411] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
    [    2.567916] libphy: stmmac: probed
    [    2.569153] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
    [    2.569599] libphy: mdio_mux: probed
    [    2.569624] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
    [    2.569638] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
    [    2.581331] libphy: mdio_mux: probed
    [    2.581366] dwmac-sun8i 1c30000.ethernet: Switch mux to external PHY
    [    2.606486] ehci-platform 1c1b000.usb: EHCI Host Controller
    [    2.606518] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
    [    2.607016] ehci-platform 1c1b000.usb: irq 39, io mem 0x01c1b000
    [    2.619134] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
    [    2.619412] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [    2.619423] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.619432] usb usb3: Product: EHCI Host Controller
    [    2.619439] usb usb3: Manufacturer: Linux 5.10.60-sunxi ehci_hcd
    [    2.619447] usb usb3: SerialNumber: 1c1b000.usb
    [    2.620040] hub 3-0:1.0: USB hub found
    [    2.620084] hub 3-0:1.0: 1 port detected
    [    2.621095] ehci-platform 1c1c000.usb: EHCI Host Controller
    [    2.621117] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4
    [    2.621331] ehci-platform 1c1c000.usb: irq 41, io mem 0x01c1c000
    [    2.635133] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
    [    2.635375] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [    2.635385] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.635393] usb usb4: Product: EHCI Host Controller
    [    2.635400] usb usb4: Manufacturer: Linux 5.10.60-sunxi ehci_hcd
    [    2.635407] usb usb4: SerialNumber: 1c1c000.usb
    [    2.635928] hub 4-0:1.0: USB hub found
    [    2.635968] hub 4-0:1.0: 1 port detected
    [    2.636932] ehci-platform 1c1d000.usb: EHCI Host Controller
    [    2.636956] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5
    [    2.637171] ehci-platform 1c1d000.usb: irq 43, io mem 0x01c1d000
    [    2.651127] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
    [    2.651377] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [    2.651388] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.651396] usb usb5: Product: EHCI Host Controller
    [    2.651403] usb usb5: Manufacturer: Linux 5.10.60-sunxi ehci_hcd
    [    2.651409] usb usb5: SerialNumber: 1c1d000.usb
    [    2.651897] hub 5-0:1.0: USB hub found
    [    2.651935] hub 5-0:1.0: 1 port detected
    [    2.652904] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
    [    2.652927] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
    [    2.653085] ohci-platform 1c1b400.usb: irq 40, io mem 0x01c1b400
    [    2.715295] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
    [    2.715306] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.715314] usb usb6: Product: Generic Platform OHCI controller
    [    2.715321] usb usb6: Manufacturer: Linux 5.10.60-sunxi ohci_hcd
    [    2.715328] usb usb6: SerialNumber: 1c1b400.usb
    [    2.715828] hub 6-0:1.0: USB hub found
    [    2.715870] hub 6-0:1.0: 1 port detected
    [    2.716784] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
    [    2.716814] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
    [    2.716976] ohci-platform 1c1c400.usb: irq 42, io mem 0x01c1c400
    [    2.779375] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
    [    2.779387] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.779395] usb usb7: Product: Generic Platform OHCI controller
    [    2.779402] usb usb7: Manufacturer: Linux 5.10.60-sunxi ohci_hcd
    [    2.779409] usb usb7: SerialNumber: 1c1c400.usb
    [    2.779896] hub 7-0:1.0: USB hub found
    [    2.779934] hub 7-0:1.0: 1 port detected
    [    2.780834] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
    [    2.780855] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
    [    2.781009] ohci-platform 1c1d400.usb: irq 44, io mem 0x01c1d400
    [    2.843314] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
    [    2.843323] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.843331] usb usb8: Product: Generic Platform OHCI controller
    [    2.843338] usb usb8: Manufacturer: Linux 5.10.60-sunxi ohci_hcd
    [    2.843345] usb usb8: SerialNumber: 1c1d400.usb
    [    2.843810] hub 8-0:1.0: USB hub found
    [    2.843848] hub 8-0:1.0: 1 port detected
    [    2.846274] of_cfs_init
    [    2.846394] of_cfs_init: OK
    [    2.846538] ALSA device list:
    [    2.846547]   #0: H3 Audio Codec
    [    2.850988] Freeing unused kernel memory: 1024K
    [    2.859367] Run /init as init process
    [    2.859378]   with arguments:
    [    2.859384]     /init
    [    2.859389]   with environment:
    [    2.859394]     HOME=/
    [    2.859399]     TERM=linux
    [    2.859404]     ubootpart=
    [    2.859409]     ubootsource=mmc
    [    2.859414]     sunxi_ve_mem_reserve=0
    [    2.859419]     sunxi_g2d_mem_reserve=0
    [    2.859424]     sunxi_fb_mem_reserve=16
    [    2.859429]     cgroup_enable=memory
    [    2.911202] usb 5-1: new high-speed USB device number 2 using ehci-platform
    [    3.069973] usb 5-1: Dual-Role OTG device on non-HNP port
    [    3.070219] usb 5-1: set a_alt_hnp_support failed: -32
    [    3.203163] usb 5-1: new high-speed USB device number 3 using ehci-platform
    [    3.260643] input: r_gpio_keys as /devices/platform/r_gpio_keys/input/input0
    [    3.325502] usb_phy_generic usb_phy_generic.3.auto: supply vcc not found, using dummy regulator
    [    3.328098] phy id_det change to device
    [    3.328219] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver
    [    3.328248] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 9
    [    3.328541] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [    3.328555] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    3.328562] usb usb9: Product: MUSB HDRC host driver
    [    3.328570] usb usb9: Manufacturer: Linux 5.10.60-sunxi musb-hcd
    [    3.328577] usb usb9: SerialNumber: musb-hdrc.4.auto
    [    3.329421] hub 9-0:1.0: USB hub found
    [    3.329513] hub 9-0:1.0: 1 port detected
    [    3.362481] usb 5-1: Dual-Role OTG device on non-HNP port
    [    3.362719] usb 5-1: set a_alt_hnp_support failed: -32
    [    3.367211] usb usb5-port1: attempt power cycle
    [    3.371935] random: fast init done
    [    3.419872] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
    [    3.444236] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
    [    3.463380] mmc1: new high speed SDIO card at address 0001
    [    3.575138] usb 5-1: new high-speed USB device number 4 using ehci-platform
    [    3.605955] usb 5-1: Dual-Role OTG device on non-HNP port
    [    3.606205] usb 5-1: set a_alt_hnp_support failed: -32
    [    3.739122] usb 5-1: new high-speed USB device number 5 using ehci-platform
    [    3.769954] usb 5-1: Dual-Role OTG device on non-HNP port
    [    3.770203] usb 5-1: set a_alt_hnp_support failed: -32
    [    3.775128] usb usb5-port1: unable to enumerate USB device
    [    4.125889] EXT4-fs (mmcblk2p1): mounted filesystem with ordered data mode. Opts: (null)
    [    4.163184] usb 8-1: new full-speed USB device number 2 using ohci-platform
    [    4.382208] usb 8-1: not running at top speed; connect to a high speed hub
    [    4.394191] usb 8-1: Dual-Role OTG device on non-HNP port
    [    4.396181] usb 8-1: set a_alt_hnp_support failed: -32
    [    4.489480] systemd[1]: Inserted module 'autofs4'
    [    4.552331] systemd[1]: systemd 247.3-6 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
    [    4.553190] systemd[1]: Detected architecture arm.
    [    4.556675] systemd[1]: Set hostname to <simor>.
    [    4.591161] usb 8-1: new full-speed USB device number 3 using ohci-platform
    [    4.817189] usb 8-1: not running at top speed; connect to a high speed hub
    [    4.829199] usb 8-1: Dual-Role OTG device on non-HNP port
    [    4.831170] usb 8-1: set a_alt_hnp_support failed: -32
    [    4.839160] usb usb8-port1: attempt power cycle
    [    5.055157] usb 8-1: new full-speed USB device number 4 using ohci-platform
    [    5.088182] usb 8-1: not running at top speed; connect to a high speed hub
    [    5.100178] usb 8-1: Dual-Role OTG device on non-HNP port
    [    5.102162] usb 8-1: set a_alt_hnp_support failed: -32
    [    5.295161] usb 8-1: new full-speed USB device number 5 using ohci-platform
    [    5.328184] usb 8-1: not running at top speed; connect to a high speed hub
    [    5.340239] usb 8-1: Dual-Role OTG device on non-HNP port
    [    5.342173] usb 8-1: set a_alt_hnp_support failed: -32
    [    5.347171] usb usb8-port1: unable to enumerate USB device
    [    5.430007] systemd[1]: Queued start job for default target Graphical Interface.
    [    5.432054] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.436969] systemd[1]: Created slice system-getty.slice.
    [    5.437777] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.439468] systemd[1]: Created slice system-modprobe.slice.
    [    5.439878] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.441572] systemd[1]: Created slice system-postgresql.slice.
    [    5.443500] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [    5.445048] systemd[1]: Created slice User and Session Slice.
    [    5.445441] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
    [    5.445900] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    5.447543] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
    [    5.448103] systemd[1]: Reached target Local Encrypted Volumes.
    [    5.448944] systemd[1]: Reached target Paths.
    [    5.449511] systemd[1]: Reached target Slices.
    [    5.449942] systemd[1]: Reached target Swap.
    [    5.450338] systemd[1]: Reached target System Time Set.
    [    5.470540] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    5.472133] systemd[1]: Listening on Syslog Socket.
    [    5.473233] systemd[1]: Listening on fsck to fsckd communication Socket.
    [    5.473916] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    5.475339] systemd[1]: Listening on Journal Audit Socket.
    [    5.476310] systemd[1]: Listening on Journal Socket (/dev/log).
    [    5.477445] systemd[1]: Listening on Journal Socket.
    [    5.479394] systemd[1]: Listening on udev Control Socket.
    [    5.480412] systemd[1]: Listening on udev Kernel Socket.
    [    5.481533] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
    [    5.486344] systemd[1]: Mounting POSIX Message Queue File System...
    [    5.492674] systemd[1]: Mounting RPC Pipe File System...
    [    5.500823] systemd[1]: Mounting Kernel Debug File System...
    [    5.508128] systemd[1]: Mounting Kernel Trace File System...
    [    5.510105] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
    [    5.519817] systemd[1]: Starting Restore / save the current clock...
    [    5.527719] systemd[1]: Starting Set the console keyboard layout...
    [    5.535728] systemd[1]: Starting Create list of static device nodes for the current kernel...
    [    5.544289] systemd[1]: Starting Load Kernel Module configfs...
    [    5.552614] systemd[1]: Starting Load Kernel Module drm...
    [    5.561460] systemd[1]: Starting Load Kernel Module fuse...
    [    5.570228] systemd[1]: Started Nameserver information manager.
    [    5.572182] systemd[1]: Reached target Network (Pre).
    [    5.583559] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
    [    5.584002] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    5.596639] systemd[1]: Starting Load Kernel Modules...
    [    5.604073] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    5.612041] systemd[1]: Starting Coldplug All udev Devices...
    [    5.629253] systemd[1]: Mounted POSIX Message Queue File System.
    [    5.630746] systemd[1]: Mounted Kernel Debug File System.
    [    5.632256] systemd[1]: Mounted Kernel Trace File System.
    [    5.635264] systemd[1]: Finished Restore / save the current clock.
    [    5.638509] systemd[1]: Finished Create list of static device nodes for the current kernel.
    [    5.642009] systemd[1]: modprobe@configfs.service: Succeeded.
    [    5.644243] systemd[1]: Finished Load Kernel Module configfs.
    [    5.647147] systemd[1]: modprobe@drm.service: Succeeded.
    [    5.647213] RPC: Registered named UNIX socket transport module.
    [    5.647221] RPC: Registered udp transport module.
    [    5.647226] RPC: Registered tcp transport module.
    [    5.647232] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    5.649179] systemd[1]: Finished Load Kernel Module drm.
    [    5.654962] systemd[1]: Mounted RPC Pipe File System.
    [    5.657376] systemd[1]: modprobe@fuse.service: Succeeded.
    [    5.659965] systemd[1]: Finished Load Kernel Module fuse.
    [    5.665115] systemd[1]: Finished Load Kernel Modules.
    [    5.675048] systemd[1]: Mounting FUSE Control File System...
    [    5.682659] systemd[1]: Mounting Kernel Configuration File System...
    [    5.682716] EXT4-fs (mmcblk2p1): re-mounted. Opts: commit=600,errors=remount-ro
    [    5.691087] systemd[1]: Starting Apply Kernel Variables...
    [    5.704061] systemd[1]: Finished Remount Root and Kernel File Systems.
    [    5.710217] systemd[1]: Mounted FUSE Control File System.
    [    5.717759] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
    [    5.718244] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
    [    5.724163] systemd[1]: Starting Load/Save Random Seed...
    [    5.731261] systemd[1]: Starting Create System Users...
    [    5.738690] systemd[1]: Mounted Kernel Configuration File System.
    [    5.779875] systemd[1]: Finished Apply Kernel Variables.
    [    5.818638] systemd[1]: Finished Create System Users.
    [    5.825139] systemd[1]: Starting Create Static Device Nodes in /dev...
    [    5.889619] systemd[1]: Finished Create Static Device Nodes in /dev.
    [    5.901130] systemd[1]: Starting Rule-based Manager for Device Events and Files...
    [    6.042241] systemd[1]: Started Rule-based Manager for Device Events and Files.
    [    6.093537] systemd[1]: Finished Set the console keyboard layout.
    [    6.094737] systemd[1]: Reached target Local File Systems (Pre).
    [    6.104133] systemd[1]: Mounting /tmp...
    [    6.144890] systemd[1]: Mounted /tmp.
    [    6.145990] systemd[1]: Reached target Local File Systems.
    [    6.152743] systemd[1]: Starting Armbian ZRAM config...
    [    6.159725] systemd[1]: Starting Set console font and keymap...
    [    6.177080] systemd[1]: Starting Preprocess NFS configuration...
    [    6.182535] systemd[1]: Finished Coldplug All udev Devices.
    [    6.196036] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
    [    6.228022] systemd[1]: Finished Set console font and keymap.
    [    6.233564] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
    [    6.240514] systemd[1]: Starting Raise network interfaces...
    [    6.256225] systemd[1]: nfs-config.service: Succeeded.
    [    6.269814] systemd[1]: Finished Preprocess NFS configuration.
    [    6.272261] systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
    [    6.272382] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
    [    6.272576] systemd[1]: Reached target NFS client services.
    [    6.683847] zram: Added device: zram0
    [    6.687710] zram: Added device: zram1
    [    6.691593] zram: Added device: zram2
    [    6.720030] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    6.739851] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    6.753256] systemd[1]: Reached target Hardware activated USB gadget.
    [    6.761477] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
    [    6.762778] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
    [    6.779538] cedrus 1c0e000.video-codec: Device registered as /dev/video0
    [    6.854658] RTL871X: module init start
    [    6.854673] RTL871X: rtl8189fs v4.3.24.8_22657.20170607
    [    6.941095] RTL871X: HW EFUSE
    [    6.941157] RTL871X: rtw_read_efuse_from_file /system/etc/wifi/wifi_efuse_8189fs.map is not readable
    [    6.941162] RTL871X: ERROR invalid phy efuse and read from file fail, will use driver default!!
    [    6.941184] RTL871X: rtw_read_macaddr_from_file /data/wifimac.txt is not readable
    [    6.941205] RTL871X: hal_com_config_channel_plan use def_chplan:0x20
    [    6.947967] systemd[1]: Found device /dev/ttyS0.
    [    7.080572] zram0: detected capacity change from 0 to 1055920128
    [    7.108373] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
    [    7.108430] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
    [    7.108479] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
    [    7.108516] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
    [    7.112026] lima 1c40000.gpu: bus rate = 200000000
    [    7.112041] lima 1c40000.gpu: mod rate = 297000000
    [    7.112142] lima 1c40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
    [    7.112537] lima 1c40000.gpu: Failed to register cooling device
    [    7.113017] [drm] Initialized lima 1.2.0 20200215 for 1c40000.gpu on minor 1
    [    7.179474] Registered IR keymap rc-empty
    [    7.179626] rc rc0: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0
    [    7.187467] rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter
    [    7.187680] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0/input1
    [    7.199180] usb 8-1: new full-speed USB device number 6 using ohci-platform
    [    7.202274] sunxi-ir 1f02000.ir: initialized sunXi IR driver
    [    7.289605] RTL871X: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
    [    7.290676] RTL871X: rtw_ndev_init(wlan0) if1 mac_addr=12:81:88:e2:9e:fb
    [    7.297300] RTL871X: module init ret=0
    [    7.364541] systemd[1]: Finished Raise network interfaces.
    [    7.415914] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
    [    7.416870] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
    [    7.417633] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
    [    7.418271] usb 8-1: not running at top speed; connect to a high speed hub
    [    7.418378] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
    [    7.418719] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
    [    7.432716] usb 8-1: Dual-Role OTG device on non-HNP port
    [    7.433228] usb 8-1: set a_alt_hnp_support failed: -32
    [    7.503203] random: crng init done
    [    7.503222] random: 7 urandom warning(s) missed due to ratelimiting
    [    7.518181] systemd[1]: Finished Load/Save Random Seed.
    [    7.535060] systemd[1]: Condition check resulted in First Boot Complete being skipped.
    [    7.535534] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    [    7.536637] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
    [    7.540660] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
    [    7.562620] systemd[1]: Starting Load/Save RF Kill Switch Status...
    [    7.616909] systemd[1]: Started Load/Save RF Kill Switch Status.
    [    7.627240] usb 8-1: new full-speed USB device number 7 using ohci-platform
    [    7.668679] Adding 1031168k swap on /dev/zram0.  Priority:5 extents:1 across:1031168k SSFS
    [    7.714603] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
    [    7.715431] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
    [    7.716076] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
    [    7.716263] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
    [    7.716663] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
    [    7.716944] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
    [    7.717109] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
    [    7.819986] zram1: detected capacity change from 0 to 52428800
    [    7.846222] usb 8-1: not running at top speed; connect to a high speed hub
    [    7.858242] usb 8-1: Dual-Role OTG device on non-HNP port
    [    7.860237] usb 8-1: set a_alt_hnp_support failed: -32
    [    7.867479] usb usb8-port1: attempt power cycle
    [    7.871818] systemd[1]: Finished Armbian ZRAM config.
    [    7.877179] systemd[1]: Starting Armbian memory supported logging...
    [    7.962688] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
    [    7.962737] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
    [    8.083200] usb 8-1: new full-speed USB device number 8 using ohci-platform
    [    8.116244] usb 8-1: not running at top speed; connect to a high speed hub
    [    8.128247] usb 8-1: Dual-Role OTG device on non-HNP port
    [    8.130228] usb 8-1: set a_alt_hnp_support failed: -32
    [    8.323228] usb 8-1: new full-speed USB device number 9 using ohci-platform
    [    8.356240] usb 8-1: not running at top speed; connect to a high speed hub
    [    8.368240] usb 8-1: Dual-Role OTG device on non-HNP port
    [    8.370253] usb 8-1: set a_alt_hnp_support failed: -32
    [    8.375201] usb usb8-port1: unable to enumerate USB device
    [    9.007236] usb 8-1: new full-speed USB device number 10 using ohci-platform
    [    9.250302] usb 8-1: not running at top speed; connect to a high speed hub
    [    9.262312] usb 8-1: Dual-Role OTG device on non-HNP port
    [    9.264306] usb 8-1: set a_alt_hnp_support failed: -32
    [    9.459202] usb 8-1: new full-speed USB device number 11 using ohci-platform
    [    9.678304] usb 8-1: not running at top speed; connect to a high speed hub
    [    9.690303] usb 8-1: Dual-Role OTG device on non-HNP port
    [    9.692301] usb 8-1: set a_alt_hnp_support failed: -32
    [    9.699177] usb usb8-port1: attempt power cycle
    [    9.915204] usb 8-1: new full-speed USB device number 12 using ohci-platform
    [    9.948313] usb 8-1: not running at top speed; connect to a high speed hub
    [    9.960313] usb 8-1: Dual-Role OTG device on non-HNP port
    [    9.962302] usb 8-1: set a_alt_hnp_support failed: -32
    [   10.155199] usb 8-1: new full-speed USB device number 13 using ohci-platform
    [   10.188332] usb 8-1: not running at top speed; connect to a high speed hub
    [   10.200313] usb 8-1: Dual-Role OTG device on non-HNP port
    [   10.202309] usb 8-1: set a_alt_hnp_support failed: -32
    [   10.207202] usb usb8-port1: unable to enumerate USB device
    [   10.491176] usb 8-1: new full-speed USB device number 14 using ohci-platform
    [   10.710249] usb 8-1: not running at top speed; connect to a high speed hub
    [   10.722253] usb 8-1: Dual-Role OTG device on non-HNP port
    [   10.724236] usb 8-1: set a_alt_hnp_support failed: -32
    [   10.919204] usb 8-1: new full-speed USB device number 15 using ohci-platform
    [   11.138243] usb 8-1: not running at top speed; connect to a high speed hub
    [   11.150241] usb 8-1: Dual-Role OTG device on non-HNP port
    [   11.152227] usb 8-1: set a_alt_hnp_support failed: -32
    [   11.159218] usb usb8-port1: attempt power cycle
    [   11.375210] usb 8-1: new full-speed USB device number 16 using ohci-platform
    [   11.416244] usb 8-1: not running at top speed; connect to a high speed hub
    [   11.428252] usb 8-1: Dual-Role OTG device on non-HNP port
    [   11.430241] usb 8-1: set a_alt_hnp_support failed: -32
    [   11.623184] usb 8-1: new full-speed USB device number 17 using ohci-platform
    [   11.684241] usb 8-1: not running at top speed; connect to a high speed hub
    [   11.696237] usb 8-1: Dual-Role OTG device on non-HNP port
    [   11.698220] usb 8-1: set a_alt_hnp_support failed: -32
    [   11.703196] usb usb8-port1: unable to enumerate USB device
    [   12.626566] systemd[1]: systemd-rfkill.service: Succeeded.
    [   14.381889] systemd[1]: Finished Armbian memory supported logging.
    [   14.390267] systemd[1]: Starting Journal Service...
    [   14.711699] systemd[1]: Started Journal Service.
    [   14.747227] systemd-journald[616]: Received client request to flush runtime journal.
    [   14.747575] systemd-journald[616]: File /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system.journal corrupted or uncleanly shut down, renaming and replacing.
    [   14.750944] systemd-journald[616]: Failed to open system journal: No space left on device
    [   31.104728] dwmac-sun8i 1c30000.ethernet eth0: PHY [0.2:01] driver [RTL8211E Gigabit Ethernet] (irq=POLL)
    [   31.121232] dwmac-sun8i 1c30000.ethernet eth0: No Safety Features support found
    [   31.121254] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
    [   31.121263] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
    [   31.121991] dwmac-sun8i 1c30000.ethernet eth0: configuring for phy/rgmii-id link mode
    [   33.779333] vcc3v0: disabling
    [   33.779356] vcc5v0: disabling
    [   33.779363] usb0-vbus: disabling
    [   33.848339] RTL871X: nolinked power save enter
    [   34.765954] RTL871X: nolinked power save leave
    [   35.398388] RTL871X: rtw_set_802_11_connect(wlan0)  fw_state=0x00000008
    [   35.471963] RTL871X: start auth
    [   35.478278] RTL871X: auth success, start assoc
    [   35.487636] RTL871X: assoc success
    [   35.575819] RTL871X: recv eapol packet
    [   35.576624] RTL871X: send eapol packet
    [   35.594366] RTL871X: recv eapol packet
    [   35.594871] RTL871X: send eapol packet
    [   35.595220] RTL871X: set pairwise key camid:4, addr:a4:33:d7:af:2e:88, kid:0, type:AES
    [   35.595950] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [   35.596027] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    [   86.100664] RTL871X: recv eapol packet
    [   86.102103] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [   86.102412] RTL871X: send eapol packet
    [  145.662428] usbcore: registered new interface driver cdc_ether
    [  145.670111] usbcore: registered new interface driver rndis_host
    [  145.680066] usbcore: registered new interface driver rndis_wlan
    [  145.781067] usbcore: registered new interface driver cdc_acm
    [  145.781080] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
    [ 1012.159882] usb 5-1: new high-speed USB device number 6 using ehci-platform
    [ 1012.322399] usb 5-1: Dual-Role OTG device on non-HNP port
    [ 1012.322632] usb 5-1: set a_alt_hnp_support failed: -32
    [ 1012.455826] usb 5-1: new high-speed USB device number 7 using ehci-platform
    [ 1012.614357] usb 5-1: Dual-Role OTG device on non-HNP port
    [ 1012.614598] usb 5-1: set a_alt_hnp_support failed: -32
    [ 1012.619855] usb usb5-port1: attempt power cycle
    [ 1012.823819] usb 5-1: new high-speed USB device number 8 using ehci-platform
    [ 1012.854730] usb 5-1: Dual-Role OTG device on non-HNP port
    [ 1012.854973] usb 5-1: set a_alt_hnp_support failed: -32
    [ 1012.987837] usb 5-1: new high-speed USB device number 9 using ehci-platform
    [ 1013.018734] usb 5-1: Dual-Role OTG device on non-HNP port
    [ 1013.018975] usb 5-1: set a_alt_hnp_support failed: -32
    [ 1013.023833] usb usb5-port1: unable to enumerate USB device
    [ 1013.411815] usb 8-1: new full-speed USB device number 18 using ohci-platform
    [ 1013.630850] usb 8-1: not running at top speed; connect to a high speed hub
    [ 1013.642846] usb 8-1: Dual-Role OTG device on non-HNP port
    [ 1013.644849] usb 8-1: set a_alt_hnp_support failed: -32
    [ 1013.839815] usb 8-1: new full-speed USB device number 19 using ohci-platform
    [ 1014.058852] usb 8-1: not running at top speed; connect to a high speed hub
    [ 1014.070843] usb 8-1: Dual-Role OTG device on non-HNP port
    [ 1014.072847] usb 8-1: set a_alt_hnp_support failed: -32
    [ 1014.083805] usb usb8-port1: attempt power cycle
    [ 1014.299815] usb 8-1: new full-speed USB device number 20 using ohci-platform
    [ 1014.332846] usb 8-1: not running at top speed; connect to a high speed hub
    [ 1014.344854] usb 8-1: Dual-Role OTG device on non-HNP port
    [ 1014.346879] usb 8-1: set a_alt_hnp_support failed: -32
    [ 1014.543842] usb 8-1: new full-speed USB device number 21 using ohci-platform
    [ 1014.576877] usb 8-1: not running at top speed; connect to a high speed hub
    [ 1014.588882] usb 8-1: Dual-Role OTG device on non-HNP port
    [ 1014.590862] usb 8-1: set a_alt_hnp_support failed: -32
    [ 1014.595892] usb usb8-port1: unable to enumerate USB device
    [ 1060.615079] usb 5-1: new high-speed USB device number 10 using ehci-platform
    [ 1060.774114] usb 5-1: Dual-Role OTG device on non-HNP port
    [ 1060.774341] usb 5-1: set a_alt_hnp_support failed: -32
    [ 1060.907093] usb 5-1: new high-speed USB device number 11 using ehci-platform
    [ 1061.065474] usb 5-1: Dual-Role OTG device on non-HNP port
    [ 1061.065705] usb 5-1: set a_alt_hnp_support failed: -32
    [ 1061.071155] usb usb5-port1: attempt power cycle
    [ 1061.275085] usb 5-1: new high-speed USB device number 12 using ehci-platform
    [ 1061.305965] usb 5-1: Dual-Role OTG device on non-HNP port
    [ 1061.306205] usb 5-1: set a_alt_hnp_support failed: -32
    [ 1061.439074] usb 5-1: new high-speed USB device number 13 using ehci-platform
    [ 1061.469975] usb 5-1: Dual-Role OTG device on non-HNP port
    [ 1061.470209] usb 5-1: set a_alt_hnp_support failed: -32
    [ 1061.475138] usb usb5-port1: unable to enumerate USB device
    [ 1061.863063] usb 8-1: new full-speed USB device number 22 using ohci-platform
    [ 1062.082116] usb 8-1: not running at top speed; connect to a high speed hub
    [ 1062.094105] usb 8-1: Dual-Role OTG device on non-HNP port
    [ 1062.096110] usb 8-1: set a_alt_hnp_support failed: -32
    [ 1062.291074] usb 8-1: new full-speed USB device number 23 using ohci-platform
    [ 1062.510121] usb 8-1: not running at top speed; connect to a high speed hub
    [ 1062.522110] usb 8-1: Dual-Role OTG device on non-HNP port
    [ 1062.524118] usb 8-1: set a_alt_hnp_support failed: -32
    [ 1062.531072] usb usb8-port1: attempt power cycle
    [ 1062.747042] usb 8-1: new full-speed USB device number 24 using ohci-platform
    [ 1062.780111] usb 8-1: not running at top speed; connect to a high speed hub
    [ 1062.792108] usb 8-1: Dual-Role OTG device on non-HNP port
    [ 1062.794093] usb 8-1: set a_alt_hnp_support failed: -32
    [ 1062.987046] usb 8-1: new full-speed USB device number 25 using ohci-platform
    [ 1063.020112] usb 8-1: not running at top speed; connect to a high speed hub
    [ 1063.032120] usb 8-1: Dual-Role OTG device on non-HNP port
    [ 1063.034092] usb 8-1: set a_alt_hnp_support failed: -32
    [ 1063.039047] usb usb8-port1: unable to enumerate USB device
    [ 1346.562909] usb 3-1: new high-speed USB device number 2 using ehci-platform
    [ 1346.721403] usb 3-1: Dual-Role OTG device on non-HNP port
    [ 1346.721637] usb 3-1: set a_alt_hnp_support failed: -32
    [ 1346.854925] usb 3-1: new high-speed USB device number 3 using ehci-platform
    [ 1347.013401] usb 3-1: Dual-Role OTG device on non-HNP port
    [ 1347.013632] usb 3-1: set a_alt_hnp_support failed: -32
    [ 1347.018987] usb usb3-port1: attempt power cycle
    [ 1347.222960] usb 3-1: new high-speed USB device number 4 using ehci-platform
    [ 1347.253772] usb 3-1: Dual-Role OTG device on non-HNP port
    [ 1347.254008] usb 3-1: set a_alt_hnp_support failed: -32
    [ 1347.386951] usb 3-1: new high-speed USB device number 5 using ehci-platform
    [ 1347.417898] usb 3-1: Dual-Role OTG device on non-HNP port
    [ 1347.418137] usb 3-1: set a_alt_hnp_support failed: -32
    [ 1347.422998] usb usb3-port1: unable to enumerate USB device
    [ 1347.810974] usb 6-1: new full-speed USB device number 2 using ohci-platform
    [ 1348.029994] usb 6-1: not running at top speed; connect to a high speed hub
    [ 1348.041994] usb 6-1: Dual-Role OTG device on non-HNP port
    [ 1348.044004] usb 6-1: set a_alt_hnp_support failed: -32
    [ 1348.238996] usb 6-1: new full-speed USB device number 3 using ohci-platform
    [ 1348.457999] usb 6-1: not running at top speed; connect to a high speed hub
    [ 1348.469992] usb 6-1: Dual-Role OTG device on non-HNP port
    [ 1348.472007] usb 6-1: set a_alt_hnp_support failed: -32
    [ 1348.478994] usb usb6-port1: attempt power cycle
    [ 1348.694992] usb 6-1: new full-speed USB device number 4 using ohci-platform
    [ 1348.727989] usb 6-1: not running at top speed; connect to a high speed hub
    [ 1348.740002] usb 6-1: Dual-Role OTG device on non-HNP port
    [ 1348.741973] usb 6-1: set a_alt_hnp_support failed: -32
    [ 1348.934996] usb 6-1: new full-speed USB device number 5 using ohci-platform
    [ 1348.967990] usb 6-1: not running at top speed; connect to a high speed hub
    [ 1348.979989] usb 6-1: Dual-Role OTG device on non-HNP port
    [ 1348.981969] usb 6-1: set a_alt_hnp_support failed: -32
    [ 1348.990984] usb usb6-port1: unable to enumerate USB device
    [ 1376.303972] usb 4-1: new high-speed USB device number 2 using ehci-platform
    [ 1376.462539] usb 4-1: Dual-Role OTG device on non-HNP port
    [ 1376.462766] usb 4-1: set a_alt_hnp_support failed: -32
    [ 1376.595991] usb 4-1: new high-speed USB device number 3 using ehci-platform
    [ 1376.754532] usb 4-1: Dual-Role OTG device on non-HNP port
    [ 1376.754765] usb 4-1: set a_alt_hnp_support failed: -32
    [ 1376.760065] usb usb4-port1: attempt power cycle
    [ 1376.964004] usb 4-1: new high-speed USB device number 4 using ehci-platform
    [ 1376.994900] usb 4-1: Dual-Role OTG device on non-HNP port
    [ 1376.995140] usb 4-1: set a_alt_hnp_support failed: -32
    [ 1377.128007] usb 4-1: new high-speed USB device number 5 using ehci-platform
    [ 1377.162898] usb 4-1: Dual-Role OTG device on non-HNP port
    [ 1377.163136] usb 4-1: set a_alt_hnp_support failed: -32
    [ 1377.168023] usb usb4-port1: unable to enumerate USB device
    [ 1377.556064] usb 7-1: new full-speed USB device number 2 using ohci-platform
    [ 1377.775071] usb 7-1: not running at top speed; connect to a high speed hub
    [ 1377.787060] usb 7-1: Dual-Role OTG device on non-HNP port
    [ 1377.789066] usb 7-1: set a_alt_hnp_support failed: -32
    [ 1377.984041] usb 7-1: new full-speed USB device number 3 using ohci-platform
    [ 1378.203066] usb 7-1: not running at top speed; connect to a high speed hub
    [ 1378.215059] usb 7-1: Dual-Role OTG device on non-HNP port
    [ 1378.217069] usb 7-1: set a_alt_hnp_support failed: -32
    [ 1378.224094] usb usb7-port1: attempt power cycle
    [ 1378.440086] usb 7-1: new full-speed USB device number 4 using ohci-platform
    [ 1378.473058] usb 7-1: not running at top speed; connect to a high speed hub
    [ 1378.485056] usb 7-1: Dual-Role OTG device on non-HNP port
    [ 1378.487052] usb 7-1: set a_alt_hnp_support failed: -32
    [ 1378.680078] usb 7-1: new full-speed USB device number 5 using ohci-platform
    [ 1378.713060] usb 7-1: not running at top speed; connect to a high speed hub
    [ 1378.725061] usb 7-1: Dual-Role OTG device on non-HNP port
    [ 1378.727041] usb 7-1: set a_alt_hnp_support failed: -32
    [ 1378.732097] usb usb7-port1: unable to enumerate USB device
    [ 1882.762454] RTL871X: recv eapol packet
    [ 1882.763860] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [ 1882.764241] RTL871X: send eapol packet
    [ 2831.749936] usb 4-1: new high-speed USB device number 6 using ehci-platform
    [ 2831.908461] usb 4-1: Dual-Role OTG device on non-HNP port
    [ 2831.908692] usb 4-1: set a_alt_hnp_support failed: -32
    [ 2832.041956] usb 4-1: new high-speed USB device number 7 using ehci-platform
    [ 2832.200458] usb 4-1: Dual-Role OTG device on non-HNP port
    [ 2832.200694] usb 4-1: set a_alt_hnp_support failed: -32
    [ 2832.205999] usb usb4-port1: attempt power cycle
    [ 2832.410022] usb 4-1: new high-speed USB device number 8 using ehci-platform
    [ 2832.440833] usb 4-1: Dual-Role OTG device on non-HNP port
    [ 2832.441068] usb 4-1: set a_alt_hnp_support failed: -32
    [ 2832.573963] usb 4-1: new high-speed USB device number 9 using ehci-platform
    [ 2832.604827] usb 4-1: Dual-Role OTG device on non-HNP port
    [ 2832.605066] usb 4-1: set a_alt_hnp_support failed: -32
    [ 2832.610011] usb usb4-port1: unable to enumerate USB device
    [ 2833.001943] usb 7-1: new full-speed USB device number 6 using ohci-platform
    [ 2833.221025] usb 7-1: not running at top speed; connect to a high speed hub
    [ 2833.233017] usb 7-1: Dual-Role OTG device on non-HNP port
    [ 2833.235020] usb 7-1: set a_alt_hnp_support failed: -32
    [ 2833.429954] usb 7-1: new full-speed USB device number 7 using ohci-platform
    [ 2833.649026] usb 7-1: not running at top speed; connect to a high speed hub
    [ 2833.661017] usb 7-1: Dual-Role OTG device on non-HNP port
    [ 2833.663021] usb 7-1: set a_alt_hnp_support failed: -32
    [ 2833.669967] usb usb7-port1: attempt power cycle
    [ 2833.886006] usb 7-1: new full-speed USB device number 8 using ohci-platform
    [ 2833.919024] usb 7-1: not running at top speed; connect to a high speed hub
    [ 2833.931017] usb 7-1: Dual-Role OTG device on non-HNP port
    [ 2833.933008] usb 7-1: set a_alt_hnp_support failed: -32
    [ 2834.125981] usb 7-1: new full-speed USB device number 9 using ohci-platform
    [ 2834.159018] usb 7-1: not running at top speed; connect to a high speed hub
    [ 2834.171017] usb 7-1: Dual-Role OTG device on non-HNP port
    [ 2834.173009] usb 7-1: set a_alt_hnp_support failed: -32
    [ 2834.177989] usb usb7-port1: unable to enumerate USB device
    [ 2870.663351] usb 5-1: new high-speed USB device number 14 using ehci-platform
    [ 2870.821879] usb 5-1: Dual-Role OTG device on non-HNP port
    [ 2870.822110] usb 5-1: set a_alt_hnp_support failed: -32
    [ 2870.955352] usb 5-1: new high-speed USB device number 15 using ehci-platform
    [ 2871.113875] usb 5-1: Dual-Role OTG device on non-HNP port
    [ 2871.114110] usb 5-1: set a_alt_hnp_support failed: -32
    [ 2871.119374] usb usb5-port1: attempt power cycle
    [ 2871.323386] usb 5-1: new high-speed USB device number 16 using ehci-platform
    [ 2871.354247] usb 5-1: Dual-Role OTG device on non-HNP port
    [ 2871.354489] usb 5-1: set a_alt_hnp_support failed: -32
    [ 2871.487390] usb 5-1: new high-speed USB device number 17 using ehci-platform
    [ 2871.522248] usb 5-1: Dual-Role OTG device on non-HNP port
    [ 2871.522486] usb 5-1: set a_alt_hnp_support failed: -32
    [ 2871.527393] usb usb5-port1: unable to enumerate USB device
    [ 2871.915409] usb 8-1: new full-speed USB device number 26 using ohci-platform
    [ 2872.134471] usb 8-1: not running at top speed; connect to a high speed hub
    [ 2872.146467] usb 8-1: Dual-Role OTG device on non-HNP port
    [ 2872.148475] usb 8-1: set a_alt_hnp_support failed: -32
    [ 2872.343416] usb 8-1: new full-speed USB device number 27 using ohci-platform
    [ 2872.566472] usb 8-1: not running at top speed; connect to a high speed hub
    [ 2872.578463] usb 8-1: Dual-Role OTG device on non-HNP port
    [ 2872.580470] usb 8-1: set a_alt_hnp_support failed: -32
    [ 2872.587421] usb usb8-port1: attempt power cycle
    [ 2872.803449] usb 8-1: new full-speed USB device number 28 using ohci-platform
    [ 2872.840459] usb 8-1: not running at top speed; connect to a high speed hub
    [ 2872.852457] usb 8-1: Dual-Role OTG device on non-HNP port
    [ 2872.854451] usb 8-1: set a_alt_hnp_support failed: -32
    [ 2873.055388] usb 8-1: new full-speed USB device number 29 using ohci-platform
    [ 2873.088427] usb 8-1: not running at top speed; connect to a high speed hub
    [ 2873.100428] usb 8-1: Dual-Role OTG device on non-HNP port
    [ 2873.102419] usb 8-1: set a_alt_hnp_support failed: -32
    [ 2873.107397] usb usb8-port1: unable to enumerate USB device
    [ 3679.515739] RTL871X: recv eapol packet
    [ 3679.517306] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [ 3679.517530] RTL871X: send eapol packet
    [ 3801.124345] usb 5-1: new high-speed USB device number 18 using ehci-platform
    [ 3801.282743] usb 5-1: Dual-Role OTG device on non-HNP port
    [ 3801.282979] usb 5-1: set a_alt_hnp_support failed: -32
    [ 3801.416364] usb 5-1: new high-speed USB device number 19 using ehci-platform
    [ 3801.574871] usb 5-1: Dual-Role OTG device on non-HNP port
    [ 3801.575103] usb 5-1: set a_alt_hnp_support failed: -32
    [ 3801.580427] usb usb5-port1: attempt power cycle
    [ 3801.784385] usb 5-1: new high-speed USB device number 20 using ehci-platform
    [ 3801.815239] usb 5-1: Dual-Role OTG device on non-HNP port
    [ 3801.815477] usb 5-1: set a_alt_hnp_support failed: -32
    [ 3801.948451] usb 5-1: new high-speed USB device number 21 using ehci-platform
    [ 3801.979240] usb 5-1: Dual-Role OTG device on non-HNP port
    [ 3801.979478] usb 5-1: set a_alt_hnp_support failed: -32
    [ 3801.984422] usb usb5-port1: unable to enumerate USB device
    [ 3802.372386] usb 8-1: new full-speed USB device number 30 using ohci-platform
    [ 3802.591442] usb 8-1: not running at top speed; connect to a high speed hub
    [ 3802.603420] usb 8-1: Dual-Role OTG device on non-HNP port
    [ 3802.605438] usb 8-1: set a_alt_hnp_support failed: -32
    [ 3802.800420] usb 8-1: new full-speed USB device number 31 using ohci-platform
    [ 3803.019434] usb 8-1: not running at top speed; connect to a high speed hub
    [ 3803.031420] usb 8-1: Dual-Role OTG device on non-HNP port
    [ 3803.033431] usb 8-1: set a_alt_hnp_support failed: -32
    [ 3803.040428] usb usb8-port1: attempt power cycle
    [ 3803.256417] usb 8-1: new full-speed USB device number 32 using ohci-platform
    [ 3803.289420] usb 8-1: not running at top speed; connect to a high speed hub
    [ 3803.301425] usb 8-1: Dual-Role OTG device on non-HNP port
    [ 3803.303404] usb 8-1: set a_alt_hnp_support failed: -32
    [ 3803.496466] usb 8-1: new full-speed USB device number 33 using ohci-platform
    [ 3803.529426] usb 8-1: not running at top speed; connect to a high speed hub
    [ 3803.541422] usb 8-1: Dual-Role OTG device on non-HNP port
    [ 3803.543405] usb 8-1: set a_alt_hnp_support failed: -32
    [ 3803.548464] usb usb8-port1: unable to enumerate USB device
    [ 5476.185810] RTL871X: recv eapol packet
    [ 5476.187254] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [ 5476.187559] RTL871X: send eapol packet
    [ 7272.898279] RTL871X: recv eapol packet
    [ 7272.899987] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [ 7272.900015] RTL871X: send eapol packet
    [ 9069.629918] RTL871X: recv eapol packet
    [ 9069.631316] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [ 9069.631672] RTL871X: send eapol packet
    [10866.339378] RTL871X: recv eapol packet
    [10866.340701] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [10866.340910] RTL871X: send eapol packet
    [12663.040432] RTL871X: recv eapol packet
    [12663.042046] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [12663.042533] RTL871X: send eapol packet
    [14459.740497] RTL871X: recv eapol packet
    [14459.742033] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [14459.742393] RTL871X: send eapol packet
    [16256.493549] RTL871X: recv eapol packet
    [16256.494865] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [16256.495069] RTL871X: send eapol packet
    [18053.173834] RTL871X: recv eapol packet
    [18053.175419] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [18053.175661] RTL871X: send eapol packet
    [19849.774779] RTL871X: recv eapol packet
    [19849.776115] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [19849.776472] RTL871X: send eapol packet
    [21646.392715] RTL871X: recv eapol packet
    [21646.394108] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [21646.394487] RTL871X: send eapol packet
    [23443.144164] RTL871X: recv eapol packet
    [23443.145540] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [23443.145921] RTL871X: send eapol packet
    [25239.823507] RTL871X: recv eapol packet
    [25239.824853] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [25239.825293] RTL871X: send eapol packet
    [27036.526506] RTL871X: recv eapol packet
    [27036.527816] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [27036.528028] RTL871X: send eapol packet
    [28833.245109] RTL871X: recv eapol packet
    [28833.246658] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [28833.246945] RTL871X: send eapol packet
    [30629.883881] RTL871X: recv eapol packet
    [30629.885486] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [30629.885888] RTL871X: send eapol packet
    [32426.546282] RTL871X: recv eapol packet
    [32426.547609] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [32426.547810] RTL871X: send eapol packet
    [34223.156239] RTL871X: recv eapol packet
    [34223.157654] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [34223.157869] RTL871X: send eapol packet
    [36019.798478] RTL871X: recv eapol packet
    [36019.799837] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [36019.800167] RTL871X: send eapol packet
    [37816.430668] RTL871X: recv eapol packet
    [37816.432009] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [37816.432339] RTL871X: send eapol packet
    [39613.053290] RTL871X: recv eapol packet
    [39613.054835] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [39613.055224] RTL871X: send eapol packet
    [41409.669766] RTL871X: recv eapol packet
    [41409.671250] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [41409.671500] RTL871X: send eapol packet
    [43206.421415] RTL871X: recv eapol packet
    [43206.422719] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [43206.422918] RTL871X: send eapol packet
    [45002.944570] RTL871X: recv eapol packet
    [45002.946020] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [45002.946247] RTL871X: send eapol packet
    [46799.553433] RTL871X: recv eapol packet
    [46799.554802] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [46799.555013] RTL871X: send eapol packet
    [48596.174978] RTL871X: recv eapol packet
    [48596.176413] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [48596.176648] RTL871X: send eapol packet
    [50392.787480] RTL871X: recv eapol packet
    [50392.788895] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [50392.789111] RTL871X: send eapol packet
    [52189.436769] RTL871X: recv eapol packet
    [52189.438187] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [52189.438396] RTL871X: send eapol packet
    [53986.064669] RTL871X: recv eapol packet
    [53986.066011] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [53986.066421] RTL871X: send eapol packet
    [55782.706418] RTL871X: recv eapol packet
    [55782.707985] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [55782.708405] RTL871X: send eapol packet
    [57579.337221] RTL871X: recv eapol packet
    [57579.338646] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [57579.338848] RTL871X: send eapol packet
    [59375.967421] RTL871X: recv eapol packet
    [59375.968761] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [59375.969129] RTL871X: send eapol packet
    [61172.594630] RTL871X: recv eapol packet
    [61172.595970] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [61172.596336] RTL871X: send eapol packet
    [62969.245143] RTL871X: recv eapol packet
    [62969.246574] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [62969.246941] RTL871X: send eapol packet
    [64765.883211] RTL871X: recv eapol packet
    [64765.884521] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [64765.884744] RTL871X: send eapol packet
    [66562.484410] RTL871X: recv eapol packet
    [66562.485819] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [66562.486108] RTL871X: send eapol packet
    [68359.116916] RTL871X: recv eapol packet
    [68359.118335] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [68359.118702] RTL871X: send eapol packet
    [70155.747959] RTL871X: recv eapol packet
    [70155.749387] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [70155.749591] RTL871X: send eapol packet
    [71952.337760] RTL871X: recv eapol packet
    [71952.339216] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [71952.339477] RTL871X: send eapol packet
    [73748.954946] RTL871X: recv eapol packet
    [73748.956385] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [73748.956728] RTL871X: send eapol packet
    [75545.560501] RTL871X: recv eapol packet
    [75545.561996] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [75545.562220] RTL871X: send eapol packet
    [77342.190503] RTL871X: recv eapol packet
    [77342.191961] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [77342.192227] RTL871X: send eapol packet
    [79138.827656] RTL871X: recv eapol packet
    [79138.829020] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [79138.829234] RTL871X: send eapol packet
    [80935.466541] RTL871X: recv eapol packet
    [80935.467916] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [80935.468116] RTL871X: send eapol packet
    [82732.077549] RTL871X: recv eapol packet
    [82732.078900] RTL871X: set group key camid:6, addr:a4:33:d7:af:2e:88, kid:1, type:AES
    [82732.079234] RTL871X: send eapol packet
    [84528.689151] RTL871X: recv eapol packet
    [84528.690919] RTL871X: set group key camid:5, addr:a4:33:d7:af:2e:88, kid:2, type:AES
    [84528.691006] RTL871X: send eapol packet
    [85254.948954] usb 5-1: new high-speed USB device number 22 using ehci-platform
    [85255.107510] usb 5-1: Dual-Role OTG device on non-HNP port
    [85255.107739] usb 5-1: set a_alt_hnp_support failed: -32
    [85255.240962] usb 5-1: new high-speed USB device number 23 using ehci-platform
    [85255.399503] usb 5-1: Dual-Role OTG device on non-HNP port
    [85255.399737] usb 5-1: set a_alt_hnp_support failed: -32
    [85255.404988] usb usb5-port1: attempt power cycle
    [85255.608975] usb 5-1: new high-speed USB device number 24 using ehci-platform
    [85255.639868] usb 5-1: Dual-Role OTG device on non-HNP port
    [85255.640110] usb 5-1: set a_alt_hnp_support failed: -32
    [85255.773073] usb 5-1: new high-speed USB device number 25 using ehci-platform
    [85255.803875] usb 5-1: Dual-Role OTG device on non-HNP port
    [85255.804112] usb 5-1: set a_alt_hnp_support failed: -32
    [85255.808998] usb usb5-port1: unable to enumerate USB device
    [85256.197009] usb 8-1: new full-speed USB device number 34 using ohci-platform
    [85256.416047] usb 8-1: not running at top speed; connect to a high speed hub
    [85256.428042] usb 8-1: Dual-Role OTG device on non-HNP port
    [85256.430041] usb 8-1: set a_alt_hnp_support failed: -32
    [85256.629024] usb 8-1: new full-speed USB device number 35 using ohci-platform
    [85256.848049] usb 8-1: not running at top speed; connect to a high speed hub
    [85256.860044] usb 8-1: Dual-Role OTG device on non-HNP port
    [85256.862042] usb 8-1: set a_alt_hnp_support failed: -32
    [85256.873020] usb usb8-port1: attempt power cycle
    [85257.089066] usb 8-1: new full-speed USB device number 36 using ohci-platform
    [85257.122046] usb 8-1: not running at top speed; connect to a high speed hub
    [85257.134045] usb 8-1: Dual-Role OTG device on non-HNP port
    [85257.136021] usb 8-1: set a_alt_hnp_support failed: -32
    [85257.333020] usb 8-1: new full-speed USB device number 37 using ohci-platform
    [85257.366021] usb 8-1: not running at top speed; connect to a high speed hub
    [85257.378031] usb 8-1: Dual-Role OTG device on non-HNP port
    [85257.380011] usb 8-1: set a_alt_hnp_support failed: -32
    [85257.385035] usb usb8-port1: unable to enumerate USB device
  • in this case the response to the dmesg command on the pcDuino4 nano
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 5.10.60-sunxi (root@runner7) (arm-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #21.08.1 SMP Wed Aug 25 18:19:32 UTC 2021
    [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] OF: fdt: Machine model: Xunlong Orange Pi One
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] cma: Reserved 128 MiB at 0x77c00000
    [    0.000000] Zone ranges:
    [    0.000000]   Normal   [mem 0x0000000040000000-0x000000006fffffff]
    [    0.000000]   HighMem  [mem 0x0000000070000000-0x000000007fffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000040000000-0x000000007fffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007fffffff]
    [    0.000000] On node 0 totalpages: 262144
    [    0.000000]   Normal zone: 1728 pages used for memmap
    [    0.000000]   Normal zone: 0 pages reserved
    [    0.000000]   Normal zone: 196608 pages, LIFO batch:63
    [    0.000000]   HighMem zone: 65536 pages, LIFO batch:15
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: Using PSCI v0.1 Function IDs from DT
    [    0.000000] percpu: Embedded 20 pages/cpu s50764 r8192 d22964 u81920
    [    0.000000] pcpu-alloc: s50764 r8192 d22964 u81920 alloc=20*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 260416
    [    0.000000] Kernel command line: root=UUID=3e5a0e6e-6930-4493-b217-81e3fcd01f0a rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=a7168d39-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
    [    0.000000] Memory: 876564K/1048576K available (9216K kernel code, 1460K rwdata, 3232K rodata, 1024K init, 333K bss, 40940K reserved, 131072K cma-reserved, 131060K highmem)
    [    0.000000] random: get_random_u32 called from __kmem_cache_create+0x1b/0x298 with crng_init=0
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] ftrace: allocating 42134 entries in 83 pages
    [    0.000000] ftrace: allocated 83 pages with 4 groups
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
    [    0.000000]     Rude variant of Tasks RCU enabled.
    [    0.000000]     Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
    [    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
    [    0.000016] Switching to timer-based delay loop, resolution 41ns
    [    0.000249] Console: colour dummy device 80x30
    [    0.000311] printk: console [tty1] enabled
    [    0.000364] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
    [    0.000380] pid_max: default: 32768 minimum: 301
    [    0.000573] LSM: Security Framework initializing
    [    0.000630] Yama: becoming mindful.
    [    0.000801] AppArmor: AppArmor initialized
    [    0.000877] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.000892] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.001899] CPU: Testing write buffer coherency: ok
    [    0.002271] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.002947] Setting up static identity map for 0x40100000 - 0x40100054
    [    0.003059] rcu: Hierarchical SRCU implementation.
    [    0.004218] smp: Bringing up secondary CPUs ...
    [    0.014989] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.025845] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [    0.036607] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [    0.036707] smp: Brought up 1 node, 4 CPUs
    [    0.036721] SMP: Total of 4 processors activated (192.00 BogoMIPS).
    [    0.036726] CPU: All CPU(s) started in HYP mode.
    [    0.036730] CPU: Virtualization extensions available.
    [    0.037484] allocated 1048576 bytes of page_ext
    [    0.038063] devtmpfs: initialized
    [    0.045135] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
    [    0.045343] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.045386] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.048641] pinctrl core: initialized pinctrl subsystem
    [    0.049744] NET: Registered protocol family 16
    [    0.051414] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.051998] audit: initializing netlink subsys (disabled)
    [    0.052288] audit: type=2000 audit(0.028:1): state=initialized audit_enabled=0 res=1
    [    0.052797] thermal_sys: Registered thermal governor 'fair_share'
    [    0.052805] thermal_sys: Registered thermal governor 'bang_bang'
    [    0.052811] thermal_sys: Registered thermal governor 'step_wise'
    [    0.053368] cpuidle: using governor ladder
    [    0.053489] cpuidle: using governor menu
    [    0.054010] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.054017] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.076902] cryptd: max_cpu_qlen set to 1000
    [    0.148757] raid6: neonx8   gen()   778 MB/s
    [    0.216840] raid6: neonx8   xor()   576 MB/s
    [    0.284944] raid6: neonx4   gen()   832 MB/s
    [    0.353020] raid6: neonx4   xor()   631 MB/s
    [    0.421103] raid6: neonx2   gen()   915 MB/s
    [    0.489207] raid6: neonx2   xor()   652 MB/s
    [    0.557297] raid6: neonx1   gen()   815 MB/s
    [    0.625384] raid6: neonx1   xor()   565 MB/s
    [    0.693513] raid6: int32x8  gen()   303 MB/s
    [    0.761597] raid6: int32x8  xor()   180 MB/s
    [    0.829680] raid6: int32x4  gen()   354 MB/s
    [    0.897763] raid6: int32x4  xor()   205 MB/s
    [    0.965867] raid6: int32x2  gen()   399 MB/s
    [    1.033975] raid6: int32x2  xor()   213 MB/s
    [    1.102050] raid6: int32x1  gen()   399 MB/s
    [    1.170136] raid6: int32x1  xor()   192 MB/s
    [    1.170142] raid6: using algorithm neonx2 gen() 915 MB/s
    [    1.170147] raid6: .... xor() 652 MB/s, rmw enabled
    [    1.170152] raid6: using neon recovery algorithm
    [    1.171559] iommu: Default domain type: Translated
    [    1.171914] SCSI subsystem initialized
    [    1.172125] libata version 3.00 loaded.
    [    1.172336] usbcore: registered new interface driver usbfs
    [    1.172386] usbcore: registered new interface driver hub
    [    1.172425] usbcore: registered new device driver usb
    [    1.172519] mc: Linux media interface: v0.10
    [    1.172589] videodev: Linux video capture interface: v2.00
    [    1.172715] pps_core: LinuxPPS API ver. 1 registered
    [    1.172722] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    1.172740] PTP clock support registered
    [    1.173199] Advanced Linux Sound Architecture Driver Initialized.
    [    1.173925] NetLabel: Initializing
    [    1.173933] NetLabel:  domain hash size = 128
    [    1.173937] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
    [    1.174038] NetLabel:  unlabeled traffic allowed by default
    [    1.174728] clocksource: Switched to clocksource arch_sys_counter
    [    1.286490] VFS: Disk quotas dquot_6.6.0
    [    1.286577] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    1.287206] AppArmor: AppArmor Filesystem Enabled
    [    1.295233] NET: Registered protocol family 2
    [    1.295410] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    1.296658] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    [    1.296721] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [    1.296817] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    1.296931] TCP: Hash tables configured (established 8192 bind 8192)
    [    1.297071] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    1.297126] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    1.297378] NET: Registered protocol family 1
    [    1.298124] Trying to unpack rootfs image as initramfs...
    [    2.197485] Freeing initrd memory: 14328K
    [    2.198866] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
    [    2.200011] Initialise system trusted keyrings
    [    2.200062] Key type Denylist registered
    [    2.200256] workingset: timestamp_bits=14 max_order=18 bucket_order=4
    [    2.205506] zbud: loaded
    [    2.206962] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    2.207867] fuse: init (API version 7.32)
    [    2.210368] integrity: Platform Keyring initialized
    [    2.319588] xor: measuring software checksum speed
    [    2.327186]    arm4regs        :  1299 MB/sec
    [    2.338110]    8regs           :   902 MB/sec
    [    2.349666]    32regs          :   851 MB/sec
    [    2.357120]    neon            :  1323 MB/sec
    [    2.357126] xor: using function: neon (1323 MB/sec)
    [    2.357140] Key type asymmetric registered
    [    2.357147] Asymmetric key parser 'x509' registered
    [    2.357310] bounce: pool size: 64 pages
    [    2.357384] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
    [    2.357547] io scheduler mq-deadline registered
    [    2.357555] io scheduler kyber registered
    [    2.357814] io scheduler bfq registered
    [    2.363432] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
    [    2.365183] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
    [    2.371771] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
    [    2.374128] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pa not found, using dummy regulator
    [    2.374626] printk: console [ttyS0] disabled
    [    2.374762] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 45, base_baud = 1500000) is a 16550A
    [    2.374990] printk: console [ttyS0] enabled
    [    2.391231] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc0a9f6a4)
    [    2.391554] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0a9b60c)
    [    2.391631] sun8i-dw-hdmi 1ee0000.hdmi: supply hvcc not found, using dummy regulator
    [    2.392471] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
    [    2.392805] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
    [    2.393053] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xc0a9ec5c)
    [    2.393601] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
    [    2.393676] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
    [    2.394589] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
    [    2.397092] brd: module loaded
    [    2.526764] loop: module loaded
    [    2.528496] libphy: Fixed MDIO Bus: probed
    [    2.529063] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
    [    2.529072] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
    [    2.529160] dwmac-sun8i 1c30000.ethernet: supply phy not found, using dummy regulator
    [    2.529312] dwmac-sun8i 1c30000.ethernet: supply phy-io not found, using dummy regulator
    [    2.529439] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
    [    2.529463] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 58000)
    [    2.529749] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
    [    2.529758] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
    [    2.529766] dwmac-sun8i 1c30000.ethernet: COE Type 2
    [    2.529773] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
    [    2.529780] dwmac-sun8i 1c30000.ethernet: Normal descriptors
    [    2.529787] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
    [    2.530295] libphy: stmmac: probed
    [    2.531379] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
    [    2.531814] libphy: mdio_mux: probed
    [    2.531838] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
    [    2.531848] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
    [    2.544603] libphy: mdio_mux: probed
    [    2.545627] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    2.545662] ehci-platform: EHCI generic platform driver
    [    2.545878] ehci-platform 1c1a000.usb: EHCI Host Controller
    [    2.545907] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
    [    2.546266] ehci-platform 1c1a000.usb: irq 35, io mem 0x01c1a000
    [    2.558747] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
    [    2.559007] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [    2.559017] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.559024] usb usb1: Product: EHCI Host Controller
    [    2.559031] usb usb1: Manufacturer: Linux 5.10.60-sunxi ehci_hcd
    [    2.559038] usb usb1: SerialNumber: 1c1a000.usb
    [    2.559599] hub 1-0:1.0: USB hub found
    [    2.559644] hub 1-0:1.0: 1 port detected
    [    2.560292] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    [    2.560315] ohci-platform: OHCI generic platform driver
    [    2.560486] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
    [    2.560511] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
    [    2.560669] ohci-platform 1c1a400.usb: irq 36, io mem 0x01c1a400
    [    2.622918] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
    [    2.622928] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.622935] usb usb2: Product: Generic Platform OHCI controller
    [    2.622942] usb usb2: Manufacturer: Linux 5.10.60-sunxi ohci_hcd
    [    2.622949] usb usb2: SerialNumber: 1c1a400.usb
    [    2.623445] hub 2-0:1.0: USB hub found
    [    2.623483] hub 2-0:1.0: 1 port detected
    [    2.624555] usbcore: registered new interface driver usb-storage
    [    2.625520] sun6i-rtc 1f00000.rtc: registered as rtc0
    [    2.625559] sun6i-rtc 1f00000.rtc: setting system clock to 2021-10-27T16:34:01 UTC (1635352441)
    [    2.625566] sun6i-rtc 1f00000.rtc: RTC enabled
    [    2.625844] i2c /dev entries driver
    [    2.627277] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
    [    2.628066] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
    [    2.628230] sun8i-h3-r-pinctrl 1f02c00.pinctrl: supply vcc-pl not found, using dummy regulator
    [    2.629025] sunxi-mmc 1c0f000.mmc: Got CD GPIO
    [    2.629260] ledtrig-cpu: registered to indicate activity on CPUs
    [    2.629685] sun8i-ce 1c15000.crypto: Set mod clock to 50000000 (50 Mhz) from 24000000 (24 Mhz)
    [    2.629905] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
    [    2.630051] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
    [    2.630173] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
    [    2.630283] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
    [    2.630378] sun8i-ce 1c15000.crypto: Register cbc(aes)
    [    2.630521] sun8i-ce 1c15000.crypto: Register ecb(aes)
    [    2.630635] sun8i-ce 1c15000.crypto: Register cbc(des3_ede)
    [    2.630937] sun8i-ce 1c15000.crypto: Register ecb(des3_ede)
    [    2.631063] sun8i-ce 1c15000.crypto: Register md5
    [    2.631176] sun8i-ce 1c15000.crypto: Register sha1
    [    2.631303] sun8i-ce 1c15000.crypto: Register sha224
    [    2.631412] sun8i-ce 1c15000.crypto: Register sha256
    [    2.631518] sun8i-ce 1c15000.crypto: Register sha384
    [    2.631625] sun8i-ce 1c15000.crypto: Register sha512
    [    2.631731] sun8i-ce 1c15000.crypto: Register stdrng
    [    2.631857] sun8i-ce 1c15000.crypto: TRNG not supported
    [    2.631868] sun8i-ce 1c15000.crypto: CryptoEngine Die ID 1
    [    2.632268] hid: raw HID events driver (C) Jiri Kosina
    [    2.632428] usbcore: registered new interface driver usbhid
    [    2.632434] usbhid: USB HID core driver
    [    2.637298] Initializing XFRM netlink socket
    [    2.637804] NET: Registered protocol family 10
    [    2.654454] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
    [    2.683429] Segment Routing with IPv6
    [    2.683547] NET: Registered protocol family 17
    [    2.683582] NET: Registered protocol family 15
    [    2.683660] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [    2.683775] 8021q: 802.1Q VLAN Support v1.8
    [    2.683830] Key type dns_resolver registered
    [    2.684286] Registering SWP/SWPB emulation handler
    [    2.684613] registered taskstats version 1
    [    2.684625] Loading compiled-in X.509 certificates
    [    2.691323] Loaded X.509 cert 'Build time autogenerated kernel key: 8a253d6735cd65910a63c6d97c40747ce9ff7e4b'
    [    2.694101] mmc0: host does not support reading read-only switch, assuming write-enable
    [    2.695939] zswap: loaded using pool zstd/z3fold
    [    2.696602] mmc0: new high speed SDHC card at address aaaa
    [    2.696807] Key type ._fscrypt registered
    [    2.696815] Key type .fscrypt registered
    [    2.696821] Key type fscrypt-provisioning registered
    [    2.698105] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
    [    2.702501] Btrfs loaded, crc32c=crc32c-generic
    [    2.703037]  mmcblk0: p1
    [    2.724734] Key type encrypted registered
    [    2.724757] AppArmor: AppArmor sha1 policy hashing enabled
    [    2.736092] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pg not found, using dummy regulator
    [    2.737806] ehci-platform 1c1b000.usb: EHCI Host Controller
    [    2.737837] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
    [    2.738462] ehci-platform 1c1b000.usb: irq 37, io mem 0x01c1b000
    [    2.750746] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
    [    2.751025] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [    2.751035] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.751043] usb usb3: Product: EHCI Host Controller
    [    2.751050] usb usb3: Manufacturer: Linux 5.10.60-sunxi ehci_hcd
    [    2.751058] usb usb3: SerialNumber: 1c1b000.usb
    [    2.751631] hub 3-0:1.0: USB hub found
    [    2.751673] hub 3-0:1.0: 1 port detected
    [    2.752666] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
    [    2.752700] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 4
    [    2.752868] ohci-platform 1c1b400.usb: irq 38, io mem 0x01c1b400
    [    2.814911] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
    [    2.814921] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.814929] usb usb4: Product: Generic Platform OHCI controller
    [    2.814936] usb usb4: Manufacturer: Linux 5.10.60-sunxi ohci_hcd
    [    2.814943] usb usb4: SerialNumber: 1c1b400.usb
    [    2.815457] hub 4-0:1.0: USB hub found
    [    2.815497] hub 4-0:1.0: 1 port detected
    [    2.817237] of_cfs_init
    [    2.817384] of_cfs_init: OK
    [    2.817534] ALSA device list:
    [    2.817544]   No soundcards found.
    [    2.821425] Freeing unused kernel memory: 1024K
    [    2.830960] Run /init as init process
    [    2.830969]   with arguments:
    [    2.830975]     /init
    [    2.830980]   with environment:
    [    2.830985]     HOME=/
    [    2.830990]     TERM=linux
    [    2.830995]     ubootpart=a7168d39-01
    [    2.831000]     ubootsource=mmc
    [    2.831005]     sunxi_ve_mem_reserve=0
    [    2.831010]     sunxi_g2d_mem_reserve=0
    [    2.831015]     sunxi_fb_mem_reserve=16
    [    2.831020]     cgroup_enable=memory
    [    2.831408] process '/usr/bin/sh' started with executable stack
    [    3.006802] usb 3-1: new high-speed USB device number 2 using ehci-platform
    [    3.175022] usb 3-1: New USB device found, idVendor=0bda, idProduct=2838, bcdDevice= 1.00
    [    3.175040] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [    3.175048] usb 3-1: Product: RTL2838UHIDIR
    [    3.175055] usb 3-1: Manufacturer: Realtek
    [    3.175062] usb 3-1: SerialNumber: 00000001
    [    3.225502] input: r_gpio_keys as /devices/platform/r_gpio_keys/input/input0
    [    3.277890] usb_phy_generic usb_phy_generic.3.auto: supply vcc not found, using dummy regulator
    [    3.279064] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver
    [    3.279096] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 5
    [    3.279746] phy id_det change to device
    [    3.280030] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [    3.280041] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    3.280048] usb usb5: Product: MUSB HDRC host driver
    [    3.280055] usb usb5: Manufacturer: Linux 5.10.60-sunxi musb-hcd
    [    3.280063] usb usb5: SerialNumber: musb-hdrc.4.auto
    [    3.280699] hub 5-0:1.0: USB hub found
    [    3.280755] hub 5-0:1.0: 1 port detected
    [    3.737837] random: fast init done
    [    3.840904] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
    [    4.759820] systemd[1]: Inserted module 'autofs4'
    [    4.845523] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
    [    4.846274] systemd[1]: Detected architecture arm.
    [    4.888282] systemd[1]: Set hostname to <pi>.
    [    5.876797] systemd[1]: /lib/systemd/system/spice-vdagentd.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/spice-vdagentd/spice-vdagentd.pid → /run/spice-vdagentd/spice-vdagentd.pid; please update the unit file accordingly.
    [    5.892441] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.911154] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.911250] systemd[1]: Reached target Remote File Systems.
    [    5.912044] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.912883] systemd[1]: Listening on Journal Socket (/dev/log).
    [    5.913664] systemd[1]: Listening on fsck to fsckd communication Socket.
    [    5.914436] systemd[1]: Listening on udev Control Socket.
    [    5.915000] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    5.915577] systemd[1]: Listening on udev Kernel Socket.
    [    6.132259] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
    [    6.138509] g_serial gadget: Gadget Serial v2.4
    [    6.138528] g_serial gadget: g_serial ready
    [    6.631637] systemd-journald[281]: Received request to flush runtime journal from PID 1
    [    6.987984] audit: type=1400 audit(1635352458.904:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/ipsec/stroke" pid=338 comm="apparmor_parser"
    [    6.995735] audit: type=1400 audit(1635352458.912:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=336 comm="apparmor_parser"
    [    7.021782] audit: type=1400 audit(1635352458.936:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=340 comm="apparmor_parser"
    [    7.021821] audit: type=1400 audit(1635352458.936:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=340 comm="apparmor_parser"
    [    7.021841] audit: type=1400 audit(1635352458.936:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=340 comm="apparmor_parser"
    [    7.022898] audit: type=1400 audit(1635352458.940:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/haveged" pid=342 comm="apparmor_parser"
    [    7.054299] audit: type=1400 audit(1635352458.968:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=337 comm="apparmor_parser"
    [    7.108807] audit: type=1400 audit(1635352459.024:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/arm-linux-gnueabihf/lightdm/lightdm-guest-session" pid=341 comm="apparmor_parser"
    [    7.108847] audit: type=1400 audit(1635352459.024:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/arm-linux-gnueabihf/lightdm/lightdm-guest-session//chromium" pid=341 comm="apparmor_parser"
    [    7.110163] audit: type=1400 audit(1635352459.024:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=343 comm="apparmor_parser"
    [    8.191777] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
    [    8.191799] cpu cpu0: _opp_add: OPP not supported by regulators (1104000000)
    [    8.191947] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
    [    8.191959] cpu cpu0: _opp_add: OPP not supported by regulators (1200000000)
    [    8.192083] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator
    [    8.192094] cpu cpu0: _opp_add: OPP not supported by regulators (1296000000)
    [    8.192200] core: _opp_supported_by_regulators: OPP minuV: 1400000 maxuV: 1400000, not supported by regulator
    [    8.192210] cpu cpu0: _opp_add: OPP not supported by regulators (1368000000)
    [    8.192660] thermal thermal_zone0: binding zone cpu_thermal with cdev thermal-cpufreq-0 failed:-22
    [    8.572975] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
    [    8.599379] cedrus 1c0e000.video-codec: Device registered as /dev/video0
    [    9.661133] usb 3-1: dvb_usb_v2: found a 'Realtek RTL2832U reference design' in warm state
    [    9.723118] usb 3-1: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
    [    9.723160] dvbdev: DVB: registering new adapter (Realtek RTL2832U reference design)
    [    9.723174] usb 3-1: media controller created
    [    9.725558] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
    [    9.819527] i2c i2c-1: Added multiplexed i2c bus 2
    [    9.819553] rtl2832 1-0010: Realtek RTL2832 successfully attached
    [    9.819663] usb 3-1: DVB: registering adapter 0 frontend 0 (Realtek RTL2832 (DVB-T))...
    [    9.819698] dvbdev: dvb_create_media_entity: media entity 'Realtek RTL2832 (DVB-T)' registered.
    [    9.890360] r820t 2-001a: creating new instance
    [    9.897712] r820t 2-001a: Rafael Micro r820t successfully identified
    [    9.959313] rtl2832_sdr rtl2832_sdr.6.auto: Registered as swradio0
    [    9.959327] rtl2832_sdr rtl2832_sdr.6.auto: Realtek RTL2832 SDR attached
    [    9.959335] rtl2832_sdr rtl2832_sdr.6.auto: SDR API is still slightly experimental and functionality changes may follow
    [    9.970128] Registered IR keymap rc-empty
    [    9.970359] rc rc0: Realtek RTL2832U reference design as /devices/platform/soc/1c1b000.usb/usb3/3-1/rc/rc0
    [    9.970678] rc rc0: lirc_dev: driver dvb_usb_rtl28xxu registered at minor = 0, raw IR receiver, no transmitter
    [    9.970942] input: Realtek RTL2832U reference design as /devices/platform/soc/1c1b000.usb/usb3/3-1/rc/rc0/input1
    [    9.978693] usb 3-1: dvb_usb_v2: schedule remote query interval to 200 msecs
    [    9.995442] usb 3-1: dvb_usb_v2: 'Realtek RTL2832U reference design' successfully initialized and connected
    [    9.995768] usbcore: registered new interface driver dvb_usb_rtl28xxu
    [   10.597736] random: crng init done
    [   10.597756] random: 7 urandom warning(s) missed due to ratelimiting
    [   12.852314] PPP generic driver version 2.4.2
    [   12.918209] NET: Registered protocol family 24
    [   13.100378] l2tp_core: L2TP core driver, V2.0
    [   13.162983] l2tp_netlink: L2TP netlink interface
    [   13.210085] l2tp_ppp: PPPoL2TP kernel driver, V2.0
    [   14.510361] dwmac-sun8i 1c30000.ethernet eth0: PHY [0.1:01] driver [Generic PHY] (irq=POLL)
    [   14.514386] dwmac-sun8i 1c30000.ethernet eth0: No Safety Features support found
    [   14.514415] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
    [   14.514427] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
    [   14.515501] dwmac-sun8i 1c30000.ethernet eth0: configuring for phy/mii link mode
    [   14.517979] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
    [   14.518025] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   16.749427] broken atomic modeset userspace detected, disabling atomic
    [   23.966876] broken atomic modeset userspace detected, disabling atomic
    [   33.779264] vcc3v0: disabling
    [   33.779284] vcc5v0: disabling
    [   33.779291] usb0-vbus: disabling
    [   36.647597] input: BRLTTY 5.6 Linux Screen Driver Keyboard as /devices/virtual/input/input2
    [  185.723983] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [  185.727014] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [  185.731734] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [  185.731754] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
    [  185.741478] cfg80211: failed to load regulatory.db
    [  185.761756] usbcore: registered new interface driver cdc_ether
    [  185.779094] usbcore: registered new interface driver rndis_host
    [  185.807191] usbcore: registered new interface driver rndis_wlan
    [  185.952488] usbcore: registered new interface driver cdc_acm
    [  185.952505] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Reply
    [    2.830975]     /init
    [    2.830985]     HOME=/
Children
  • So it looks like the Ethernet adaptor is getting initialized.
    What is the output of "ip -4 addr show" with Pluto connected?
    -Travis
  • the last part in the dmesg command
    correspond to those commands:
    sudo modprobe rndis_wlan
    sudo modprobe usbnet
    sudo modprobe cdc_acm
    sudo modprobe cdc_ether
    nothing changes when I connect PLUTO.
    lsusb
    Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 003 Device 002: ID 0bda:2838 Realtek Semiconductor Corp. RTL2838 DVB-T
    Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    and
    ip -4 addr show
    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    inet 127.0.0.1/8 scope host lo
    valid_lft forever preferred_lft forever
    2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    inet 192.168.1.43/24 brd 192.168.1.255 scope global dynamic noprefixroute eth0
    valid_lft 28584sec preferred_lft 28584sec
    also does not show the PLUTO interface.
    IMORTANT. you can see that I send separately the answers of pcDunio and OrangePi in two continuous messages, so that they are well separated and differentiated, I believe that the OrangePi (OS Armbian Bullseye) showed a greater exchange than the pcDuino.
  • in pcDunino
    in the pcDuino I have also connected a RTL-SDR Dongle, after disconnecting it and connecting only the PLUTO something similar to what happens in OrangePi happens.
    the last lines of the dmesg
    [ 2302.801480] usb 3-1: USB disconnect, device number 2
    [ 2302.850788] r820t 2-001a: destroying instance
    [ 2302.854448] dvb_usb_v2: 'Realtek RTL2832U reference design:3-1' successfully deinitialized and disconnected
    [ 2308.953240] usb 3-1: new high-speed USB device number 3 using ehci-platform
    [ 2309.111715] usb 3-1: Dual-Role OTG device on non-HNP port
    [ 2309.111948] usb 3-1: set a_alt_hnp_support failed: -32
    [ 2309.245246] usb 3-1: new high-speed USB device number 4 using ehci-platform
    [ 2309.403705] usb 3-1: Dual-Role OTG device on non-HNP port
    [ 2309.403947] usb 3-1: set a_alt_hnp_support failed: -32
    [ 2309.409233] usb usb3-port1: attempt power cycle
    [ 2309.613259] usb 3-1: new high-speed USB device number 5 using ehci-platform
    [ 2309.644085] usb 3-1: Dual-Role OTG device on non-HNP port
    [ 2309.644336] usb 3-1: set a_alt_hnp_support failed: -32
    [ 2309.777261] usb 3-1: new high-speed USB device number 6 using ehci-platform
    [ 2309.808207] usb 3-1: Dual-Role OTG device on non-HNP port
    [ 2309.808447] usb 3-1: set a_alt_hnp_support failed: -32
    [ 2309.813242] usb usb3-port1: unable to enumerate USB device
    [ 2310.201247] usb 4-1: new full-speed USB device number 2 using ohci-platform
    [ 2310.420277] usb 4-1: not running at top speed; connect to a high speed hub
    [ 2310.557303] usb 4-1: unable to read config index 0 descriptor/all
    [ 2310.557334] usb 4-1: can't read configurations, error -62
    [ 2310.753258] usb 4-1: new full-speed USB device number 3 using ohci-platform
    [ 2310.972279] usb 4-1: not running at top speed; connect to a high speed hub
    [ 2310.984288] usb 4-1: Dual-Role OTG device on non-HNP port
    [ 2310.986293] usb 4-1: set a_alt_hnp_support failed: -32
    [ 2310.993288] usb usb4-port1: attempt power cycle
    [ 2311.209250] usb 4-1: new full-speed USB device number 4 using ohci-platform
    [ 2311.242274] usb 4-1: not running at top speed; connect to a high speed hub
    [ 2311.254277] usb 4-1: Dual-Role OTG device on non-HNP port
    [ 2311.256260] usb 4-1: set a_alt_hnp_support failed: -32
    [ 2311.449266] usb 4-1: new full-speed USB device number 5 using ohci-platform
    [ 2311.482291] usb 4-1: not running at top speed; connect to a high speed hub
    [ 2311.494270] usb 4-1: Dual-Role OTG device on non-HNP port
    [ 2311.496251] usb 4-1: set a_alt_hnp_support failed: -32
    [ 2311.501289] usb usb4-port1: unable to enumerate USB device
  • Are there any special flags set in the USB nodes of the device's devicetree?
    -Travis
  • as far as I know, everything is in factory default.
    -VH
