Pluto sdr
Hi
I am using python iio module to Rx samples from Pluto sdr. I have set multiple sample_rate like 2e6, 2.5e6, 3e6, 4e6.
Buffer length is set as n*sample_rate. With n having values of 0.5,1,1.5 and 2. For any combination of sample_rate and n, the commands refill and read take n seconds to complete. Hi thought the time taken to retrieve data is dependent on usb speed and how come it is not changing with sample rate.
Top Replies
    Oct 27, 2020 in reply to lmodur +1 suggested
    Please explain this. I was expecting that USB wil operate at its highest possible speed and time taken will change with amount of data to be transferred.
    This will only happen if the USB interface…
    on Oct 26, 2020 3:35 PM 1 month ago
    You are likely overflowing at the higher rates, meaning that you will just see the limit imposed by USB2.0.
    How many buffers are you measuring to arrive at n seconds in each configuration? If you start from lower rates does this trend change?
    -Travis
  • Hi Travis
    sample_rate = 5000000
    duration = 1
    buf_len = sample_rate*duration
    ctrl.find_channel('voltage0').attrs["rf_bandwidth"].value = str(int(sample_rate)) ctrl.find_channel('voltage0').attrs["sampling_frequency"].value = str(int(sample_rate))
    rxbuf = iio.Buffer(rxadc,int(buf_len), False)
    time1 = time.time()
    print('Rx start time is ',time1)
     rxbuf.refill()
     data = rxbuf.read()
     time2 = time.time()
    time2-time1 is equal to 1sec (duration) irrespective of sample_rate value ( I have tried 2.5e6,5e6)
    For 2.5e6 sampling rate,  we need USB speed to be 10MBps which may be towards the edge of the capability?
    If I change sampling rate to less than 2e6, I get this error
      File "/usr/lib/python2.7/site-packages/iio.py", line 707, in <lambda>
        lambda self, x: self._write(x),
     File "/usr/lib/python2.7/site-packages/iio.py", line 739, in _write
        _c_write_attr(self._channel, self._name_ascii, value.encode("ascii"))
      File "/usr/lib/python2.7/site-packages/iio.py", line 70, in _check_negative
        raise OSError(-result, _strerror(-result))
    on Oct 26, 2020 6:09 PM 1 month ago in reply to lmodur
    You cannot set the sample rate below 2.08333 MHz unless you have a filter loaded to get more decimation. This is automatically done with our higher-level module pyadi-iio: https://wiki.analog.com/resources/tools-software/linux-software/pyadi-iio
    time1 = time.time()
     rxbuf.refill()
     data = rxbuf.read()
     time2 = time.time()
    The first time this is done there will be a large overhead setting up the DMA. Subsequent buffer pulls will be faster.
    Also, only performing this once is also not very statistically significant. We would recommend pulling thousands of buffers and measuring the latency to get a reasonable measurement.
    -Travis
  • I tried this script:
    import numpy as np
    import adi
    import matplotlib.pyplot as plt
    import time
    sample_rate = 0.525e6 # Hz
    center_freq = 91.1e6 # Hz
    duration = 2
    sdr = adi.Pluto("ip:192.168.2.1")
    sdr.sample_rate = int(sample_rate)
    sdr.rx_rf_bandwidth = int(sample_rate) # filter cutoff, just set it to the same as sample rate
    sdr.rx_lo = int(center_freq)
    sdr.rx_buffer_size = int(sample_rate*duration) # this is the buffer the Pluto uses to buffer samples
    delta = 0
    sample_len = 0
    time1 = time.time()
    for i in range(1000):
    samples = sdr.rx() # receive samples off Pluto
    sample_len = sample_len + np.size(samples)
    time2 = time.time()
    delta = time2-time1
    print(sample_len)
    print('Rx time is ',delta)
    print('speed MBps is ',2*2*1*1e-6*sample_len/delta)
    Results:
    With duration =1 and sample_rate = 0.525e6 ---
    lmodur@lmodur-ThinkPad-T440s:~/laksdr$ python3.7 adi_test.py
    525000000
    Rx time  is  1000.099428653717
    speed MBps is  2.09979122058585
    With duration =2 and sample_rate = 0.525e6 ---
    1050000000
    Rx time  is  2000.3163378238678
    speed MBps is  2.0996678978131804
    With duration =1 and sample_rate = 1e6   ---
    1000000000
    Rx time is 1000.2784714698792
    speed MBps is 3.9988864242195676
    With duration =0.5 and sample_rate = 1e6   ---
    500000000
    Rx time is 500.160227060318
    speed MBps is 3.998718594149241
    It appears the speed is adjusting and the time taken for the data retrieval is  fixed.
    on Oct 27, 2020 8:20 PM 1 month ago in reply to lmodur
    This will only happen if the USB interface is the bottleneck, which does not seem to be the case with the two rates you were using above. If you keep increasing the sample rate, there will be a point where the time it takes to get data back will not get faster. This is where the USB limit is hit.
    -Travis
