Hi, I'm confused about using "sync_external" and "sync_internal" params when configuring TDD over pyadi.
Can somebody describe how it works and how it depends on whether to use "sync_soft" or trigger the physical "burst" pin in Pluto?
| SLA Status | Assignee | Support Status |
| SLA Closed. Missed after 281 hours |
Awaiting Customer Response | |
So, "sync_internal" is when you have a configured internal signal to be generated based on a dedicated counter, and it happens continuously in the design without any other sync request. When enabling "sync_external" it means you have an external GPIO tied, and the pulses are generated by triggering said GPIO.
The "sync_soft" mechanism a soft pulse that triggers the burst in the tdd channels, simply by writing 1 to the sync_soft attribute.
I attach here a link to the wiki for a slightly more detailed explanation of the 3 modes:
https://wiki.analog.com/resources/fpga/docs/axi_tdd#detailed_description
Best Regards,
Ramona
