Product Number: ADALM2000
Software Version: analogdevicesinc/u-boot-xlnx at both current master (f06dec3) and (90401ce) as linked from analogdevicesinc/m2k-fw master (d0b6016)
It seems that the version of analogdevicesinc/u-boot-xlnx (90401ce) linked from analogdevicesinc/m2k-fw master (d0b6016) doesn't have an option for USB_ETHER.
I've tried the current master alogdevicesinc/u-boot-xlnx (f06dec3) which does have an option for USB_ETHER. However, it doesn't have ./configs/zynq_m2k_defconfig.
I've tried using the ./configs/zynq_m2k_defconfig from the older u-boot-xlnx but run into difficulties, maybe because the old defconfig is incompatible. Specifically, the make error I'm getting is:
.config:146:warning: symbol value '' invalid for SYS_TEXT_BASE * * Restart config... * * * Boot images * Enable support for Android Boot Images (ANDROID_BOOT_IMAGE) [N/y/?] n Support Flattened Image Tree (FIT) [Y/n/?] y Support SHA256 checksum of FIT image contents (FIT_ENABLE_SHA256_SUPPORT) [Y/n/?] y Enable signature verification of FIT uImages (FIT_SIGNATURE) [Y/n/?] y Show verbose messages when FIT images fail (FIT_VERBOSE) [Y/n/?] y Select the best match for the kernel device tree (FIT_BEST_MATCH) [N/y/?] n Support Flattened Image Tree within SPL (SPL_FIT) [N/y] n Enable signature verification of FIT firmware within SPL (SPL_FIT_SIGNATURE) [N/y] n Enable SPL loading U-Boot as a FIT (SPL_LOAD_FIT) [N/y/?] n Set up board-specific details in device tree before boot (OF_BOARD_SETUP) [N/y/?] n Set up system-specific details in device tree before boot (OF_SYSTEM_SETUP) [N/y/?] n Update the device-tree stdout alias from U-Boot (OF_STDOUT_VIA_ALIAS) [N/y/?] n Extra Options (DEPRECATED) (SYS_EXTRA_OPTIONS) [] Text Base (SYS_TEXT_BASE) [] (NEW) aborted! Console input/output is redirected. Run 'make oldconfig' to update configuration.
I've tried adding a sensible value for SYS_TEXT_BASE using menuconfig but this gets lost in the resulting .config
# CONFIG_ARCH_ASPEED is not set CONFIG_SYS_TEXT_BASE= # CONFIG_SPL_GPIO_SUPPORT is not set
Can anyone help please.
DrFlute1
