I'm not on 192.168.2.*
My home network is 192.168.178.* and I can't access my Pluto via ssh with USB under 192.168.2.1. I'm running with Linux. My routers adress is  192.168.178.1. I tried different settings. My actual config.txt is:
# Analog Devices PlutoSDR Rev.C (Z7010-AD9363)
# Device Configuration File
# 1. Open with an Editor
# 2. Edit this file
# 3. Save this file on the device USB drive
# 4. Eject the device USB Drive
# Doc: wiki.analog.com/.../customizing
[NETWORK]
hostname = pluto
ipaddr = 192.168.178.190
ipaddr_host = 192.168.178.1
netmask = 255.255.255.0
[WLAN]
ssid_wlan = MyWLAN
pwd_wlan = xxxxxxxxxx
ipaddr_wlan = 192.168.178.190
[USB_ETHERNET]
ipaddr_eth = 192.168.178.190
netmask_eth = 255.255.255.0
[SYSTEM]
xo_correction =
udc_handle_suspend = 0
# USB Communication Device Class Compatibility Mode [rndis|ncm|ecm]
usb_ethernet_mode = ncm
[ACTIONS]
diagnostic_report = 0
dfu = 0
reset = 0
calibrate = 0
Thanks for your help in advance!
Edit Notes
added router adress
[edited by: gatonero at 2:32 PM (GMT -4) on 9 May 2025]
  • Hello,
    Can you check if the drivers are installed there are detailed steps on how to do this here
  • Everything is installed.
    iio_info -s
    Available contexts:
           0: (mt7921_phy0,hidpp_battery_0,acpitz,hidpp_battery_1,coretemp,nvme on Default string) [local:]
           1: 0456:b673 (Analog Devices Inc. PlutoSDR (ADALM-PLUTO)), serial=10447318ac0f0011060036002b8c172932 [usb:3.9.5]
  • Seems like it only sees the usb.
    Considering your router ip is 192.168.178.1 can you try these settings
    [NETWORK]
    hostname = pluto
    ipaddr = 192.168.178.2
    [WLAN]
    ssid_wlan =
    pwd_wlan =
    ipaddr_wlan =
    [USB_ETHERNET]
    ipaddr_eth =
    [SYSTEM]
    xo_correction =
    [ACTIONS]
    dfu = 0
    reset = 0
    calibrate = 0
    if this does not work can you try to connect using usb connection just to make sure you are able to access Pluto ?
  • Seems that there is the same result:
    iio_info -s         Heavy check mark
    Available contexts:
    But there are three new files:
    1. ipaddr-usb0, which is empty
    2. status, content: "here 1:"
    3. SUCCESS_ENV_UPDATE, which is empty also
    These files disapear after a reboot.
  • can you run iio_info -u ip:192.168.178.2
    To check if we are able to see the context like this ?
  • iio_info -u ip:192.168.178.2         Heavy check mark
    Unable to create IIO context ip:192.168.178.2: Connection refused (111)
  • can you try to make a firmware update following the instructions here and then try again to configure your custom ip config ?
  • On 192.168.178.2 there was a repeater. The repeater is now offline and I removes it's settings in my router. Now:
    iio_info -u ip:192.168.178.2         1 ✘  3s 
    Unable to create IIO context ip:192.168.178.2: No route to host (113)
  • For now try to update the firmware.
    After the update try to run iio_info -u ip:192.168.2.1 with no other changes made.
  • If this does not work use the config file bellow.
    After you update and save the file eject the device and do a power cycle this should allow you to see the ip
    [NETWORK]
    hostname = pluto
    ipaddr = 172.169.2.3
    ipaddr_host = 172.169.2.10
    [WLAN]
    ssid_wlan =
    pwd_wlan =
    ipaddr_wlan =
    [USB_ETHERNET]
    ipaddr_eth =
    [SYSTEM]
    xo_correction =
    [ACTIONS]
    dfu = 0
    reset = 0
    calibrate = 0
