Does any documentation exist for using the phaser_prod_tst.py code to ascertain the health of the Phaser board? In particular, what is the test configuration required for the Phaser PCB, Raspberry Pi, and Pluto boards? Is the USB cable required to be attached to the Raspberry Pi to connect it to the Pluto for this test? Can the test be run on a terminal with the RealVNC Viewer, or only on a terminal resident on the Raspberry Pi? What is the format for the data provided by the phaser_prod_tst.py on a terminal, and will it identify if any problems exist with the hardware?
