I'm an application engineer. I have some questions when using some of ANALOG DEVICES's chips.
We encountered some problems in loop response testing with network analyzer ADALM2000. According to your article "ADALM2000 Measuring Loop Gain" published in the ADI Forum Student section in July 2019, we have tried to build the following circuit.
According to your test method, the functional relationship between PSRR and FREQUENCY of LM338 operational amplifier is measured. As shown below.
Because of this successful test we now want to test the loop response of the switching power supply with the ADALM2000. But we tried a variety of ADI DEMO circuits including the ADP5052 and LTC3894. Test the output part of the switching power supply according to the wiring mode below.
However, the loop response test results of the switching power supply are not satisfactory. After several tests, the PSRR does not change with the increase of FREQUENCY but maintains a value greater than 0. As shown below.
We have tried a number of approaches to this problem. We tried to modify the injection voltage, feedback resistance and other parameters can not be measured. And because there is no example of using ADALM2000 to test the loop response of switching power supply in the forum, I would like to ask you whether you can use ADALM2000 test by analogy. If so, what are the precautions in the test process?
