Hello!
Greeting!
We are trying to use subarray #2 and #3 of Stingray as Tx and subarray #1 and #4 as Rx. And we also directly connect the ADC0 and DAC0 on the AD9081 board to provide a reference of Tx. In this case, we are trying to achieve the following test:
While, we found that the waterfall spectrum of Tx_Ref and Rx are always the same (Tx_Ref has higher SNR), see the results below. So, it's hard to determine whether the received signal is right, because it seems not include the target information. In this case, how can we know the received signal is from the reflection of target?
The following is our code:
clear all, close all, clc %% Array Mapping %verify element maps correctly to hardware! subarray = ... [[1 2 5 6 9 10 13 14];... %subarray 1 [3 4 7 8 11 12 15 16];... %subarray 2 [19 20 23 24 27 28 31 32];... %subarray 3 [17 18 21 22 25 26 29 30]]'; %subarray 4 subarray_ref = [2 4 18 20]; %subarray reference elements dac_map = [4 3 2 1]; %DAC map to subarray dac_ref = 20; %DAC reference channel adc_map = [4 1 2 3]; %ADC map to subarray adc_ref = 4; %ADC reference channel %% Config Dev Kit uri = 'ip:192.168.0.101'; % uri = 'ip:169.254.183.161'; amplitude = 2^15*db2mag(-6); %Tx Baseband Amplitude [dBFS] interFreq = 4.5e9; %Tx NCO Frequency [Hz] fs_TxIQ = 250e6; %Tx Decimated IQ Sample Rate [Hz] periods = 16; %Desired Number Of Periods For Tx Signal basebandFreq = fs_TxIQ/periods; %Baseband Frequency [Hz] %Setup AD9081 Tx tx = adi.AD9081.Tx; tx.uri = uri; tx.EnabledChannels = [1 2 3 4];%Enabled Tx Channels, Only Needed for DMA tx.SamplesPerFrame = 2^10; %Number Of Samples tx.NCOEnables = ones(1,numel(tx.EnabledChannels)); tx.ChannelNCOGainScales = ones(1,numel(tx.EnabledChannels)).*0.5; %MxFE0 Digital Gain Code %DMA Configuration tx.DataSource = 'DMA'; %'DMA' or 'DDS' tx.EnableCyclicBuffers = 1; %0: Don't Cycle Tx Waveform, 1: Cycle Tx Waveform % swv1 = dsp.SineWave(amplitude, basebandFreq); % swv1.ComplexOutput = true; % swv1.SamplesPerFrame = tx.SamplesPerFrame; % swv1.SampleRate = fs_TxIQ; % y = swv1(); % swv1 = phased.FMCWWaveform('SampleRate', fs_TxIQ, ... 'SweepBandwidth', 50e6, 'SweepTime', tx.SamplesPerFrame/fs_TxIQ); y = swv1(); y = y.*amplitude; waveform = ones(tx.SamplesPerFrame,numel(tx.EnabledChannels)).*y; waveform(:,1) = waveform(:,1).*0.5; % plot(linspace((-fs_TxIQ/1e6/2), (fs_TxIQ/1e6/2), length(y)),20*log10(abs(fftshift(fft(y))))) figure;spectrogram(y,[],[],[],fs_TxIQ); title('Waterfall Spectrum of Tx'); release(tx) tx(waveform); tx.MainNCOFrequencies = ones(1,numel(tx.EnabledChannels))*interFreq; %NCO Frequency tx.MainNCOPhases = zeros(1,numel(tx.EnabledChannels)); %NCO Phase % Setup ADAR1000EVAL1Z in Tx Mode sray = adi.Stingray; sray.uri = uri; sray.Mode(2,:) = {'Tx'}; %set mode, 'Rx', 'Tx, 'Disabled' txPhaseCalOffsets = zeros(size(sray.TxGain)); sray.TxAttn(3:4,:) = 1; %1: Attenuation Off, 0: Attenuation On sray.TxGain(3:4,:) = 127; %127: Highest Gain, 0: Lowest Gain, Decimal Value sray(); %Stingray Constructor sray.SteerTx(0,0,txPhaseCalOffsets); %Broadside sray.LatchTxSettings; %Latch settings to devices %Setup ADXUD1AEBZ, %Tx Mode sray.TXRX0 = 0; %0: RX, 1: TX Subarray 4 sray.TXRX1 = 1; % Subarray 3 sray.TXRX2 = 1; % Subarray 2 sray.TXRX3 = 0; % Subarray 1 sray.ADF4371Frequency = 14.6e9; %program if using on-board LO PLL sray.PllOutputSel = 1; %1: ADF4371 RF1 (8 GHz to 16 GHz), 0: ADF4371 RF2 (16 GHz to 32 GHz) sray.PABiasOn(3:4,:) = -1.06; sray.TxPAEnable(2,:) = true; sray.TxPowerDown(3:4,:) = false; %Enable all channels for TX detect = sray.LTC2314RFPower; %reads detected power (dBm) for J9 Input %% Rx fs_RxTxIQ = 250e6; %I/Q Data Rate in MSPS %Setup AD9081 RX rx = adi.AD9081.Rx; rx.uri = uri; rx.EnabledChannels = [1 2 3 4]; rx.MainNCOFrequencies = ones(1,4)*500e6; %NCO Frequency rx.SamplesPerFrame = 2^10; %Number Of Samples To Capture: 4096 rx.kernelBuffersCount = 1; %Number Of Buffers To Subsequently Capture rx.EnablePFIRs = true; %MxFE pFIR Configuration; false: Don't Use pFIRs, true: Use pFIRs rx.PFIRFilenames = 'disabled.cfg'; %MxFE0 pFIR File data = rx(); %Initialize The Rx System; Grab The Rx Data Into 'data' Matrix rx.setRegister(hex2dec('FF'),'19'); %Fine DDC Page rx.setRegister(hex2dec('61'),'283'); %Fine DDC Control, bypass fine NCO % Setup ADAR1000EVAL1Z in RX Mode rxPhaseCalOffsets = zeros(size(sray.RxGain)); sray.Mode(1,:) = {'Rx'}; %set mode, 'Rx', 'Tx, 'Disabled' sray.RxAttn(1:2,:) = 1; %1: Attenuation Off, 0: Attenuation On sray.RxGain(1:2,:) = 127; %127: Highest Gain, 0: Lowest Gain, Decimal Value sray.SteerRx(0,0,rxPhaseCalOffsets); %Broadside sray.LatchRxSettings; %Latch SPI settings to devices %Setup ADXUD1AEBZ, %Rx High Gain Mode sray.RxGainMode = 1; %0: Low Gain, 1: High Gain - RX Mode only sray.RxPowerDown(1:2,:) = false; %Enable RX Channels data = rx(); %capture data from ADCs, 4096x4 matrix sray.RxPowerDown(1:2,:) = true; %Disable Rx channels sray.TxPowerDown(3:4,:) = true; combinedComplexData = sum(data,2); %complex addition for all 4 ADCs %% plot %Calculate FFT of sample domain data for frequency response plots hanningWindow = hanning(rx.SamplesPerFrame); hanNoiseEqBw = enbw(hanningWindow); scalingFactor = sqrt(hanNoiseEqBw)*(rx.SamplesPerFrame/2)*2^15; scalingFactorArray = sqrt(hanNoiseEqBw)*(rx.SamplesPerFrame/2)*2^17; %bit growth due to coherent combining 4 ADCs %FFT for each subarray complexData = data./scalingFactor; windowedData = complexData.*hanningWindow; fftComplex = fft(windowedData); fftComplexShifted = fftshift(fftComplex); fftMags = abs(fftComplexShifted); fftMagsdB = 20*log10(fftMags); freqAxis = linspace((-fs_RxTxIQ/1e6/2), (fs_RxTxIQ/1e6/2), length(fftMagsdB)); %%frequency response plot for each subarray figure subplot(2,2,1) plot(freqAxis, fftMagsdB(:,adc_map(1))) grid on; hold on; title('Frequency Response Of Subarray 1'); xlabel('Frequency (MHz)','FontSize',12); ylabel('Amplitude (dBFS)','FontSize',12); axis([-fs_RxTxIQ/1e6/2, fs_RxTxIQ/1e6/2, -120, 0]); subplot(2,2,2) plot(freqAxis, fftMagsdB(:,adc_map(2))) grid on; hold on; title('Frequency Response Of Subarray 2'); xlabel('Frequency (MHz)','FontSize',12); ylabel('Amplitude (dBFS)','FontSize',12); axis([-fs_RxTxIQ/1e6/2, fs_RxTxIQ/1e6/2, -120, 0]); subplot(2,2,3) plot(freqAxis, fftMagsdB(:,adc_map(3))) grid on; hold on; title('Frequency Response Of Subarray 3'); xlabel('Frequency (MHz)','FontSize',12); ylabel('Amplitude (dBFS)','FontSize',12); axis([-fs_RxTxIQ/1e6/2, fs_RxTxIQ/1e6/2, -120, 0]); subplot(2,2,4) plot(freqAxis, fftMagsdB(:,adc_map(4))) grid on; hold on; title('Frequency Response Of Subarray 4'); xlabel('Frequency (MHz)','FontSize',12); ylabel('Amplitude (dBFS)','FontSize',12); axis([-fs_RxTxIQ/1e6/2, fs_RxTxIQ/1e6/2, -120, 0]); %% figure; subplot(1,2,1) spectrogram(windowedData(:,2),[],[],[],fs_RxTxIQ); title('Waterfall Spectrum of Rx'); subplot(1,2,2) spectrogram(windowedData(:,1),[],[],[],fs_RxTxIQ); title('Frequency-time of Tx Ref');
Could anyone give us some suggestions? Thanks in advance!
Best,
Dongyu
