We are working on the configuration of the X-band radar platform. Since we don't have a RF signal generator and a spectrum analyzer, we can only test the radar system by setting part of subarray on Stingray as Tx mode and the others as Rx mode. So we combine the example code "XBDP_SimpleRx.m" and "XBDP_SimpleTx.m". Then, the result of code is as following:
It appears that the results are incorrect, as the frequency of the transmitter (Tx) does not affect the results of the receiver (Rx). So we are wondering what's wrong with the configuration. We use the on-board LO signal on the ADXUD1A board. And we are not sure whether ADXUD1A is working well. The following is our control code, could you give us some suggestion?
In summary, we would like to know:
1. whether the code is correct.
2.how to see whether ADXUD1A is working well?
3. Do we need to enable the on-board LO on the software side?
Finally, we would really appreciate it if you could give us some advice! Looking forward to your reply!
clear all, close all, clc %% Array Mapping %verify element maps correctly to hardware! subarray = ... [[1 2 5 6 9 10 13 14];... %subarray 1 [3 4 7 8 11 12 15 16];... %subarray 2 [19 20 23 24 27 28 31 32];... %subarray 3 [17 18 21 22 25 26 29 30]]'; %subarray 4 subarray_ref = [2 4 18 20]; %subarray reference elements dac_map = [4 3 2 1]; %DAC map to subarray dac_ref = 4; %DAC reference channel adc_map = [4 2 1 3]; %ADC map to subarray adc_ref = 4; %ADC reference channel %% Config Dev Kit % uri = 'ip:192.168.1.101'; uri = 'ip:169.254.183.161'; amplitude = 2^15*db2mag(-6); %Tx Baseband Amplitude [dBFS] interFreq = 4.5e9; %Tx NCO Frequency [Hz] fs_TxIQ = 250e6; %Tx Decimated IQ Sample Rate [Hz] periods = 32; %Desired Number Of Periods For Tx Signal basebandFreq = fs_TxIQ/periods; %Baseband Frequency [Hz] %Setup AD9081 Tx tx = adi.AD9081.Tx; tx.uri = uri; tx.EnabledChannels = [1 2 3 4];%Enabled Tx Channels, Only Needed for DMA tx.SamplesPerFrame = 2^10; %Number Of Samples tx.NCOEnables = ones(1,numel(tx.EnabledChannels)); tx.ChannelNCOGainScales = ones(1,numel(tx.EnabledChannels)).*0.5; %MxFE0 Digital Gain Code %DMA Configuration tx.DataSource = 'DMA'; %'DMA' or 'DDS' tx.EnableCyclicBuffers = 1; %0: Don't Cycle Tx Waveform, 1: Cycle Tx Waveform swv1 = dsp.SineWave(amplitude, basebandFreq); swv1.ComplexOutput = true; swv1.SamplesPerFrame = tx.SamplesPerFrame; swv1.SampleRate = fs_TxIQ; y = swv1(); waveform = ones(tx.SamplesPerFrame,numel(tx.EnabledChannels)).*y; release(tx) tx(waveform); tx.MainNCOFrequencies = ones(1,numel(tx.EnabledChannels))*interFreq; %NCO Frequency tx.MainNCOPhases = zeros(1,numel(tx.EnabledChannels)); %NCO Phase % Setup ADAR1000EVAL1Z in Tx Mode sray = adi.Stingray; sray.uri = uri; sray.Mode(2,:) = {'Tx'}; %set mode, 'Rx', 'Tx, 'Disabled' txPhaseCalOffsets = zeros(size(sray.TxGain)); sray.TxAttn(3:4,:) = 1; %1: Attenuation Off, 0: Attenuation On sray.TxGain(3:4,:) = 127; %127: Highest Gain, 0: Lowest Gain, Decimal Value sray(); %Stingray Constructor sray.SteerTx(0,0,txPhaseCalOffsets); %Broadside sray.LatchTxSettings; %Latch settings to devices %Setup ADXUD1AEBZ, %Tx Mode sray.TXRX0 = 0; %0: RX, 1: TX sray.TXRX1 = 0; sray.TXRX2 = 1; sray.TXRX3 = 1; % sray.RxGainMode = 0; %0: Low Gain, 1: High Gain, RX Mode only sray.ADF4371Frequency = 14.5e9; %program if using on-board LO PLL sray.PllOutputSel = 1; %1: ADF4371 RF1 (8 GHz to 16 GHz), 0: ADF4371 RF2 (16 GHz to 32 GHz) sray.PABiasOn(3:4,:) = -1.06; sray.TxPAEnable(3:4,:) = true; sray.TxPowerDown(3:4,:) = false; %Enable all channels for TX detect = sray.LTC2314RFPower; %reads detected power (dBm) for J9 Input sray.TxPowerDown(3:4,:) = true; %Disable all channels for TX %% Rx fs_RxTxIQ = 250e6; %I/Q Data Rate in MSPS %Setup AD9081 RX rx = adi.AD9081.Rx; rx.uri = uri; rx.EnabledChannels = [1 2 3 4]; rx.MainNCOFrequencies = ones(1,4)*0e6; %NCO Frequency rx.SamplesPerFrame = 2^12; %Number Of Samples To Capture: 4096 rx.kernelBuffersCount = 1; %Number Of Buffers To Subsequently Capture rx.EnablePFIRs = true; %MxFE pFIR Configuration; false: Don't Use pFIRs, true: Use pFIRs rx.PFIRFilenames = 'disabled.cfg'; %MxFE0 pFIR File data = rx(); %Initialize The Rx System; Grab The Rx Data Into 'data' Matrix rx.setRegister(hex2dec('FF'),'19'); %Fine DDC Page rx.setRegister(hex2dec('61'),'283'); %Fine DDC Control, bypass fine NCO % Setup ADAR1000EVAL1Z in RX Mode rxPhaseCalOffsets = zeros(size(sray.RxGain)); sray.Mode(1,:) = {'Rx'}; %set mode, 'Rx', 'Tx, 'Disabled' sray.RxAttn(1:2,:) = 1; %1: Attenuation Off, 0: Attenuation On sray.RxGain(1:2,:) = 127; %127: Highest Gain, 0: Lowest Gain, Decimal Value sray(); %constructor to write properties to hardware sray.SteerRx(0,0,rxPhaseCalOffsets); %Broadside sray.LatchRxSettings; %Latch SPI settings to devices %Setup ADXUD1AEBZ, %Rx High Gain Mode sray.RxGainMode = 1; %0: Low Gain, 1: High Gain - RX Mode only % sray.ADF4371Frequency = 14.5e9; %program if using on-board LO PLL % sray.PllOutputSel = 1; %1: ADF4371 RF1 (8 GHz to 16 GHz), 0: ADF4371 RF2 (16 GHz to 32 GHz) sray.RxPowerDown(1:2,:) = false; %Enable RX Channels data = rx(); %capture data from ADCs, 4096x4 matrix sray.RxPowerDown(1:2,:) = true; %Disable Rx channels combinedComplexData = sum(data,2); %complex addition for all 4 ADCs %% plot %Calculate FFT of sample domain data for frequency response plots hanningWindow = hanning(rx.SamplesPerFrame); hanNoiseEqBw = enbw(hanningWindow); scalingFactor = sqrt(hanNoiseEqBw)*(rx.SamplesPerFrame/2)*2^15; scalingFactorArray = sqrt(hanNoiseEqBw)*(rx.SamplesPerFrame/2)*2^17; %bit growth due to coherent combining 4 ADCs %FFT for each subarray complexData = data./scalingFactor; windowedData = complexData.*hanningWindow; fftComplex = fft(windowedData); fftComplexShifted = fftshift(fftComplex); fftMags = abs(fftComplexShifted); fftMagsdB = 20*log10(fftMags); freqAxis = linspace((-fs_RxTxIQ/1e6/2), (fs_RxTxIQ/1e6/2), length(fftMagsdB)); %frequency response plot for each subarray figure subplot(2,2,1) plot(freqAxis, fftMagsdB(:,adc_map(1))) grid on; hold on; title('Frequency Response Of Subarray 1'); xlabel('Frequency (MHz)','FontSize',12); ylabel('Amplitude (dBFS)','FontSize',12); axis([-fs_RxTxIQ/1e6/2, fs_RxTxIQ/1e6/2, -120, 0]); subplot(2,2,2) plot(freqAxis, fftMagsdB(:,adc_map(2))) grid on; hold on; title('Frequency Response Of Subarray 2'); xlabel('Frequency (MHz)','FontSize',12); ylabel('Amplitude (dBFS)','FontSize',12); axis([-fs_RxTxIQ/1e6/2, fs_RxTxIQ/1e6/2, -120, 0]); subplot(2,2,3) plot(freqAxis, fftMagsdB(:,adc_map(3))) grid on; hold on; title('Frequency Response Of Subarray 3'); xlabel('Frequency (MHz)','FontSize',12); ylabel('Amplitude (dBFS)','FontSize',12); axis([-fs_RxTxIQ/1e6/2, fs_RxTxIQ/1e6/2, -120, 0]); subplot(2,2,4) plot(freqAxis, fftMagsdB(:,adc_map(4))) grid on; hold on; title('Frequency Response Of Subarray 4'); xlabel('Frequency (MHz)','FontSize',12); ylabel('Amplitude (dBFS)','FontSize',12); axis([-fs_RxTxIQ/1e6/2, fs_RxTxIQ/1e6/2, -120, 0]);
Best,
Dongyu
