We would like to use TDD engine to achieve the full TX and RX cycle. We run the "XBDP_TDD_Example.m" code. But we are confused about that there seems no setting of the RX module. And there is no output result. So we are wondering how to get the received data. We try to use the same way in "XBDP_SimpleRX.m" that is the code "data=rx()". But it doesn't work. Could you give some suggestion about that? Is there any instruction documents about the adi.Stingray? It will be helpful to understand and custom the code. Thanks!
Best,
Dongyu
