Hi all,
As my previous questions i'm working on yours evaluation board Quad MxFE. In order to reach my customer specifications i need to use a JESD configuration that is JESD204B, TX mode 9, RX mode 10 (M8, L4) with a SampleRate=125Msps, FDAC=4GHz and FADC=2GHz. The build works but i need to compute the MCS in order to achieve all channel syncronization.
The first issue that i encountered was about power level of the signal in this new custom mode. In this configuration, the power of received signal is about -32dBm, i was able to raise that level to -26dBm considering settings suggested in this thread: RE: Quad MxFe arbitrary JESD204B Lane Rates .
I figure out how to adapt the MCS Matlab script in order to achieve the chip syncronization. Since the default script suppose that all the FDDCs are enabled, i added the settings about the TX struct in order to reduce the number of enabled channels
%% Setup Tx Information tx = adi.QuadMxFE.Tx; tx.UpdateDACFullScaleCurrent = true; tx.DACFullScaleCurrentuA = 40000; tx.CalibrationBoardAttached = useCalibrationBoard; %0: Not Using Calibration Board, 1: Using Calibration Board tx.uri = uri; tx.num_coarse_attr_channels = 4; %Number of Coarse DUCs Used Per MxFE tx.num_fine_attr_channels = 4; %Number of Fine DUCs Used Per MxFE tx.num_data_channels = 4*tx.num_fine_attr_channels; %Total Number of Fine DUCs Used In System tx.num_dds_channels = tx.num_data_channels*4; %Total Number of DDSs Used In System (Not Used For 'DMA' Mode) tx.ChannelNCOGainScalesChipA = zeros(1,tx.num_fine_attr_channels); %MxFE0 Digital Gain Code tx.ChannelNCOGainScalesChipB = zeros(1,tx.num_fine_attr_channels); %MxFE1 Digital Gain Code tx.ChannelNCOGainScalesChipC = zeros(1,tx.num_fine_attr_channels); %MxFE2 Digital Gain Code tx.ChannelNCOGainScalesChipD = zeros(1,tx.num_fine_attr_channels); %MxFE3 Digital Gain Code tx.MainNCOFrequenciesChipA = zeros(1,tx.num_coarse_attr_channels); %MxFE0 Coarse DUC NCO Frequencies [Hz] tx.MainNCOFrequenciesChipB = zeros(1,tx.num_coarse_attr_channels); %MxFE1 Coarse DUC NCO Frequencies [Hz] tx.MainNCOFrequenciesChipC = zeros(1,tx.num_coarse_attr_channels); %MxFE2 Coarse DUC NCO Frequencies [Hz] tx.MainNCOFrequenciesChipD = zeros(1,tx.num_coarse_attr_channels); %MxFE3 Coarse DUC NCO Frequencies [Hz] tx.ChannelNCOFrequenciesChipA = zeros(1,tx.num_fine_attr_channels); %MxFE0 Fine DUC NCO Frequencies [Hz] tx.ChannelNCOFrequenciesChipB = zeros(1,tx.num_fine_attr_channels); %MxFE1 Fine DUC NCO Frequencies [Hz] tx.ChannelNCOFrequenciesChipC = zeros(1,tx.num_fine_attr_channels); %MxFE2 Fine DUC NCO Frequencies [Hz] tx.ChannelNCOFrequenciesChipD = zeros(1,tx.num_fine_attr_channels); %MxFE3 Fine DUC NCO Frequencies [Hz] tx.MainNCOPhasesChipA = zeros(1,tx.num_coarse_attr_channels); %MxFE0 Coarse DUC NCO Phase Offsets [Degrees*1e3] tx.MainNCOPhasesChipB = zeros(1,tx.num_coarse_attr_channels); %MxFE1 Coarse DUC NCO Phase Offsets [Degrees*1e3] tx.MainNCOPhasesChipC = zeros(1,tx.num_coarse_attr_channels); %MxFE2 Coarse DUC NCO Phase Offsets [Degrees*1e3] tx.MainNCOPhasesChipD = zeros(1,tx.num_coarse_attr_channels); %MxFE3 Coarse DUC NCO Phase Offsets [Degrees*1e3] tx.ChannelNCOPhasesChipA = zeros(1,tx.num_fine_attr_channels); %MxFE0 Fine DUC NCO Phase Offsets [Degrees*1e3] tx.ChannelNCOPhasesChipB = zeros(1,tx.num_fine_attr_channels); %MxFE1 Fine DUC NCO Phase Offsets [Degrees*1e3] tx.ChannelNCOPhasesChipC = zeros(1,tx.num_fine_attr_channels); %MxFE2 Fine DUC NCO Phase Offsets [Degrees*1e3] tx.ChannelNCOPhasesChipD = zeros(1,tx.num_fine_attr_channels); %MxFE3 Fine DUC NCO Phase Offsets [Degrees*1e3] tx.NCOEnablesChipA = zeros(1,tx.num_fine_attr_channels); %MxFE0 Fine DUC Enables tx.NCOEnablesChipB = zeros(1,tx.num_fine_attr_channels); %MxFE1 Fine DUC Enables tx.NCOEnablesChipC = zeros(1,tx.num_fine_attr_channels); %MxFE2 Fine DUC Enables tx.NCOEnablesChipD = zeros(1,tx.num_fine_attr_channels); %MxFE3 Fine DUC Enables
I supposed that if the received signal power is lower, the value of minCodeValue=500 (Default) needs to be lowered, so i put at 300, but i not was able to find a math relation between this two elements. Is there a math logic behind that?
The algorithm works until the PLL alignment. With the Align_ADF4371s parameter equal to 0, the script works and the result (not so good) are the following:
But if i use Align_ADF4371s=1 . I get the following error:
Error using matlabshared.libiio.base/cstatusid Failed to re-create buffer. Error in matlabshared.libiio.base/flushBuffers Error in matlabshared.libiio.base/preGetData Error in matlabshared.libiio.base/getData Error in adi.common.Rx/stepImpl (line 77) [dataRAW, valid] = getData(obj); Error in adi.QuadMxFE.Rx/stepImpl (line 445) [data,valid] = stepImpl@adi.common.Rx(obj); Error in QuadMxFE_MCS_tx9_rx10_test2 (line 564) data = rx();
Can anyone help me to adapt the script at my new configuration?
Thank you all!!
Best Regards!
-Lucian
