AD3542R
Recommended for New Designs
The AD3542R is a low drift, dual channel, ultra-fast, 12-/16-bit accuracy, voltage output digital-to-analog converter (DAC) that can be configured in multiple...
Datasheet
AD3542R on Analog.com
AD5432
Production
The AD5426 / AD5432 / AD5443 are CMOS 8-, 10-, and 12-bit current output digital-to-analog converters (DACs), respectively. These devices operate from...
Datasheet
AD5432 on Analog.com
Hi Team,
I am trying to evaluate AD3542R DAC using SDP-H1 controller board, I installed the ACE software ( ACE 1.30.3311.1463) in my PC which has Windows 11 Enterprise version- 21H2. whenever I open the waveform generator in ACE tool, the ACE software window vanishes. Please let me know the fix for this issue and how to get the log files from ACE tool to see what went wrong.
One more thing is, while installing the ACE tool, I got "IronPython 2.7 Download Failed: Access Forbidden(403)", but I ignored that and installed rest of the items
Hi MOHANCS ,
Apologies for the delay in responding to your query, yesterday was a public holiday where our support team is based. I can see that you also posted in another forum and the thread was moved here, I'll stick with responding on this ticket since it was the initial one.
I'll address the two queries here separately - firstly, the installation error. I've just tried to replicate your issue by running the same ACE installer version as you on a Windows 11 machine and was able to download IronPython successfully. Given this, and the AccessForbidden error you are seeing (which presents as a SendRequest error if there is no internet connection) would suggest that a firewall is at fault for this issue, either on your machine or your network.
Given this, it might be useful for you to try our offline installer (also available at analog.com/ace) - this comes with all dependencies bundled in the download rather than connecting to the web at install time to download any packages the user does not have installed already. The benefit here is that the IronPython installer would be bundled and this would avoid any firewall issues when installing. The installer download is a bit bigger as it bundles all the dependencies, but when ACE is running there is no difference between the standard version and the offline version, it's purely an installer difference.
As for your other issue, where the window vanishes once the waveform generator is opened, I'm not sure what the cause is here but it may be related to the above error as other components may have had similar issues downloading and installing to the IronPython installer, so it is possible that the offline installer may resolve this issue too.
Of course, it's also possible the issues are not related, so if you are still seeing the issue where the window disappears, you can find a log file at %localappdata%\Analog Devices\ACE\AppTrace.log in your file explorer and attach it in a reply here. That should give us some more details as to what is causing the error and let us debug further.
Any other questions just let me know,
EoinM
Hi EoinM,
I tried in Windows10 OS with offline installer, but we still see the same ACE application issue as mentioned above. Could you please review the below Trace.log file and let us know the fix.
12:09:00 Logging Started - 8/13/2024 12:09:00 PM
12:09:00 Analysis | Control | Evaluation 1.30.3311.1463
12:09:00 Using .NET Framework 4.8.9256.0
12:09:00 Loading from path C:\Program Files\Analog Devices\ACE\ACE.exe
12:09:00 Checking command line for DEBUGFROM option...
12:09:00 - Debugging path is
12:09:02 AceCore is setting environment variables
12:09:02 AceCore is setting required default culture
12:09:02 AceCore is initializing the IOC container
12:09:02 AceCore is adding facilities
12:09:02 AceCore is registering components
12:09:03 Current FFT implementation is AnalogDevices.Csa.Evaluation.Analyzers.CommonFFT.CommonFFTAnalyzer
12:09:06 Configuring package provider.
12:09:10 InstalledPackageSourceReader is looking for installed packages.
12:09:10 PackageProvider is creating the background worker.
12:09:10 PackageProvider is building the list of sources.
12:09:10 Server manager started remote control server on port number 2357
12:09:11 AnalogDevices.Csa.App.Wpf.Usage.ACEUsageLoggingProvider is using table name suffix "" for application usage logging
12:09:11 Restoring configuration settings from C:\Users\mahalakshmi_c\AppData\Local\Analog Devices\ACE\UserSettings\Configuration.Settings.xml
12:09:11 Error while finding nuspec for Support.AnalogDevices.VectorFile.Legacy in folder C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.VectorFile.Legacy.1.19.187!
System.InvalidOperationException: Sequence contains no elements
at System.Linq.Enumerable.Single[TSource](IEnumerable`1 source)
at AnalogDevices.Csa.PackageManagement.Plugins.PluginFolderInfo.<get_NuspecPath>b__33_0()
at AnalogDevices.Csa.ExceptionExtensions.TryExecute[TResult](Func`1 taskToCatch, Boolean logOnError, String errorMsg, TResult& result)
12:09:11 Error while finding nuspec for Support.AnalogDevices.Vector.Generator.WIFR in folder C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.Vector.Generator.WIFR.1.19.187!
12:09:14 Thread #1, ran UI.ShowToolTab - ViewId = "tool.pluginmanager", Position = "Right"
12:09:14 Thread #1, ran UI.NavigateToPath - Path = "Root::"
12:09:14 InstalledPackageSourceReader is finding plug-in for Hardware.ClockSupport 1.2022.28200.
12:09:14 InstalledPackageSourceReader found plug-in for Hardware.ClockSupport 1.2022.28200 in 173.903ms.
12:09:14 InstalledPackageSourceReader is finding plug-in for Hardware.UnifiedSpiMaster 1.2022.28400.
12:09:14 InstalledPackageSourceReader found plug-in for Hardware.UnifiedSpiMaster 1.2022.28400 in 2.703ms.
12:09:14 InstalledPackageSourceReader is finding plug-in for Hardware.DeviceApiSupport 1.2022.28200.
12:09:14 InstalledPackageSourceReader found plug-in for Hardware.DeviceApiSupport 1.2022.28200 in 1.976ms.
12:09:14 InstalledPackageSourceReader is finding plug-in for Hardware.IIOSupport 1.2024.30300.
12:09:14 InstalledPackageSourceReader found plug-in for Hardware.IIOSupport 1.2024.30300 in 2.443ms.
12:09:14 InstalledPackageSourceReader is finding plug-in for Hardware.COMSupport 1.2024.31200.
12:09:14 InstalledPackageSourceReader found plug-in for Hardware.COMSupport 1.2024.31200 in 1.855ms.
12:09:14 InstalledPackageSourceReader is finding plug-in for Hardware.HsdacSupport 1.2022.28200.
12:09:14 InstalledPackageSourceReader found plug-in for Hardware.HsdacSupport 1.2022.28200 in 2.946ms.
12:09:14 InstalledPackageSourceReader is finding plug-in for Hardware.SdpSupport 1.2024.11300.
12:09:14 InstalledPackageSourceReader found plug-in for Hardware.SdpSupport 1.2024.11300 in 2.373ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Hardware.LinduinoSupport 1.2023.27300.
12:09:15 InstalledPackageSourceReader found plug-in for Hardware.LinduinoSupport 1.2023.27300 in 14.802ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Chip.GenericFpga 1.2021.46402.
12:09:15 InstalledPackageSourceReader found plug-in for Chip.GenericFpga 1.2021.46402 in 17.634ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Chip.Generic 1.2021.28300.
12:09:15 InstalledPackageSourceReader found plug-in for Chip.Generic 1.2021.28300 in 2.673ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Board.CsaControllers 1.2023.43100.
12:09:15 InstalledPackageSourceReader found plug-in for Board.CsaControllers 1.2023.43100 in 2.297ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Board.Linduino 1.2021.29300.
12:09:15 InstalledPackageSourceReader found plug-in for Board.Linduino 1.2021.29300 in 2.681ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Vector.Common 1.30.3311.
12:09:15 InstalledPackageSourceReader found plug-in for Vector.Common 1.30.3311 in 2.129ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Vector.File 1.30.3311.
12:09:15 InstalledPackageSourceReader found plug-in for Vector.File 1.30.3311 in 2.051ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.VectorFile.Legacy 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.VectorFile.Legacy 1.23.197 in 8.2ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.VectorFile.Legacy 1.19.187.
12:09:15 InstalledPackageSourceReader has no local package for plug-in Support.AnalogDevices.VectorFile.Legacy 1.19.187
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.Vector.Generator.WIFR 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.Vector.Generator.WIFR 1.23.197 in 2.955ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.Vector.Generator.WIFR 1.19.187.
12:09:15 InstalledPackageSourceReader has no local package for plug-in Support.AnalogDevices.Vector.Generator.WIFR 1.19.187
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.HardwareControl 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.HardwareControl 1.23.197 in 2.553ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.PluginFinder 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.PluginFinder 1.23.197 in 2.624ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.Interfaces 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.Interfaces 1.23.197 in 2.174ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Chip.ADF4355 1.1.1.
12:09:15 InstalledPackageSourceReader found plug-in for Chip.ADF4355 1.1.1 in 14.281ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.Vector.Common 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.Vector.Common 1.23.197 in 16.011ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.NationalInstruments.MeasurementStudio 15.0.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.NationalInstruments.MeasurementStudio 15.0.197 in 18.15ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9747 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9747 1.23.197 in 3.094ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.Vector.Generator.DC 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.Vector.Generator.DC 1.23.197 in 2.674ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.Vector.Generator.Noise 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.Vector.Generator.Noise 1.23.197 in 19.106ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.IdlePatternTool 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.IdlePatternTool 1.23.197 in 2.595ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.DPGDownloader 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.DPGDownloader 1.23.197 in 19.542ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Chip.ADMV1013 0.1.5.
12:09:15 InstalledPackageSourceReader found plug-in for Chip.ADMV1013 0.1.5 in 18.858ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.Vector.Generator.Chirp 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.Vector.Generator.Chirp 1.23.197 in 16.144ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9717 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9717 1.23.197 in 2.845ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9707 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9707 1.23.197 in 2.891ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Chip.ADA2200 1.10.2.
12:09:15 InstalledPackageSourceReader found plug-in for Chip.ADA2200 1.10.2 in 15.073ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9993 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9993 1.23.197 in 2.472ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9162 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9162 1.23.197 in 2.57ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Chip.AD9689 1.2020.33400.
12:09:15 InstalledPackageSourceReader found plug-in for Chip.AD9689 1.2020.33400 in 42.046ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9172 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9172 1.23.197 in 2.917ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.HsdacFpga 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.HsdacFpga 1.23.197 in 2.349ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.IronPython 1.2023.38300.
12:09:15 InstalledPackageSourceReader found plug-in for Support.IronPython 1.2023.38300 in 14.772ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Chip.AD9208 1.2022.20500.
12:09:15 InstalledPackageSourceReader found plug-in for Chip.AD9208 1.2022.20500 in 15.84ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AdiNSpi 1.2022.28400.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AdiNSpi 1.2022.28400 in 12.96ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.Hardware.ADS9 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.Hardware.ADS9 1.23.197 in 2.696ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9144 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9144 1.23.197 in 2.702ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.Vector.AdvancedVectorGenerator 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.Vector.AdvancedVectorGenerator 1.23.197 in 2.777ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Chip.AD9528 1.1.2.
12:09:15 InstalledPackageSourceReader found plug-in for Chip.AD9528 1.1.2 in 21.827ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9779A 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9779A 1.23.197 in 2.56ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.FilterTool 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.FilterTool 1.23.197 in 2.403ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.Hardware.ADS72 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.Hardware.ADS72 1.23.197 in 2.427ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9788 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9788 1.23.197 in 2.366ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9963 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9963 1.23.197 in 2.73ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9962 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9962 1.23.197 in 2.718ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9122 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9122 1.23.197 in 13.373ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.Hardware.SDPH1 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.Hardware.SDPH1 1.23.197 in 2.747ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.Hardware.DPG3 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.Hardware.DPG3 1.23.197 in 2.498ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Chip.HMC7044 0.1.0.
12:09:15 InstalledPackageSourceReader found plug-in for Chip.HMC7044 0.1.0 in 12.563ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Board.ADMV1013 1.2019.9400.
12:09:15 InstalledPackageSourceReader found plug-in for Board.ADMV1013 1.2019.9400 in 17.521ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.Vector.Generator.CIFR 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.Vector.Generator.CIFR 1.23.197 in 2.981ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9783 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9783 1.23.197 in 2.579ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9144wDPG3 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9144wDPG3 1.23.197 in 15.325ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.Lexicon 1.2023.51400.
12:09:15 InstalledPackageSourceReader found plug-in for Support.Lexicon 1.2023.51400 in 14.563ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9142 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9142 1.23.197 in 15.239ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Chip.ADF4371 1.2022.24300.
12:09:15 InstalledPackageSourceReader found plug-in for Chip.ADF4371 1.2022.24300 in 16.764ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Chip.AD9508 1.2.0.
12:09:15 InstalledPackageSourceReader found plug-in for Chip.AD9508 1.2.0 in 15.919ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Chip.AD9164 1.2020.24300.
12:09:15 InstalledPackageSourceReader found plug-in for Chip.AD9164 1.2020.24300 in 12.957ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Board.ADF4371 1.2022.3300.
12:09:15 InstalledPackageSourceReader found plug-in for Board.ADF4371 1.2022.3300 in 13.14ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Chip.AD9162 1.2020.24300.
12:09:15 InstalledPackageSourceReader found plug-in for Chip.AD9162 1.2020.24300 in 16.758ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.Vector.Generator.Tones 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.Vector.Generator.Tones 1.23.197 in 2.907ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Chip.AD9695 1.2023.48400.
12:09:15 InstalledPackageSourceReader found plug-in for Chip.AD9695 1.2023.48400 in 13.444ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.PatternGen 1.2022.28200.
12:09:15 InstalledPackageSourceReader found plug-in for Support.PatternGen 1.2022.28200 in 14.726ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.ScriptRunner 1.2023.19300.
12:09:15 InstalledPackageSourceReader found plug-in for Support.ScriptRunner 1.2023.19300 in 14.489ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.IIO 1.2024.30300.
12:09:15 InstalledPackageSourceReader found plug-in for Support.IIO 1.2024.30300 in 16.282ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.Vector.Generator.PtP 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.Vector.Generator.PtP 1.23.197 in 2.552ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Chip.AD35X2R 1.2022.18200.
12:09:15 InstalledPackageSourceReader found plug-in for Chip.AD35X2R 1.2022.18200 in 14.604ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9739 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9739 1.23.197 in 2.669ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.Transactions 1.2023.47200.
12:09:15 InstalledPackageSourceReader found plug-in for Support.Transactions 1.2023.47200 in 16.536ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9789 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9789 1.23.197 in 17.575ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9736 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9736 1.23.197 in 16.706ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9148 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9148 1.23.197 in 15.179ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9744 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9744 1.23.197 in 17.75ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Chip.AD9172 1.2021.32300.
12:09:15 InstalledPackageSourceReader found plug-in for Chip.AD9172 1.2021.32300 in 17.518ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Chip.AD9163 1.2020.24300.
12:09:15 InstalledPackageSourceReader found plug-in for Chip.AD9163 1.2020.24300 in 15.927ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Chip.AD9161 1.2020.24300.
12:09:15 InstalledPackageSourceReader found plug-in for Chip.AD9161 1.2020.24300 in 14.938ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Board.AD9172 1.2020.8500.
12:09:15 InstalledPackageSourceReader found plug-in for Board.AD9172 1.2020.8500 in 14.727ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.Generic 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.Generic 1.23.197 in 16.291ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9986 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9986 1.23.197 in 18.228ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Board.ADA2200 1.10.2.
12:09:15 InstalledPackageSourceReader found plug-in for Board.ADA2200 1.10.2 in 14.632ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Chip.ADF4372 1.2022.24300.
12:09:15 InstalledPackageSourceReader found plug-in for Chip.ADF4372 1.2022.24300 in 2.2ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Board.AD9208 1.2022.20500.
12:09:15 InstalledPackageSourceReader found plug-in for Board.AD9208 1.2022.20500 in 14.169ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Board.AD9162 1.2020.47400.
12:09:15 InstalledPackageSourceReader found plug-in for Board.AD9162 1.2020.47400 in 14.655ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Board.ADF4372 1.2020.5500.
12:09:15 InstalledPackageSourceReader found plug-in for Board.ADF4372 1.2020.5500 in 19.008ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Board.LegacyQevModules 1.2021.28300.
12:09:15 InstalledPackageSourceReader found plug-in for Board.LegacyQevModules 1.2021.28300 in 16.779ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9739A 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9739A 1.23.197 in 16.585ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9146 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9146 1.23.197 in 17.803ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9129 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.DPG.EvalBoard.AD9129 1.23.197 in 16.372ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Chip.AD738X 1.2023.36500.
12:09:15 InstalledPackageSourceReader found plug-in for Chip.AD738X 1.2023.36500 in 16.586ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Board.AD9695 1.2023.48400.
12:09:16 InstalledPackageSourceReader found plug-in for Board.AD9695 1.2023.48400 in 16.442ms.
12:09:16 InstalledPackageSourceReader is finding plug-in for Board.AD9689 1.2020.6400.
12:09:16 InstalledPackageSourceReader found plug-in for Board.AD9689 1.2020.6400 in 14.584ms.
12:09:16 InstalledPackageSourceReader is finding plug-in for Support.BlockGallery 1.2024.23300.
12:09:16 InstalledPackageSourceReader found plug-in for Support.BlockGallery 1.2024.23300 in 19.501ms.
12:09:16 InstalledPackageSourceReader is finding plug-in for Board.AD35X2R 1.2022.18200.
12:09:16 InstalledPackageSourceReader found plug-in for Board.AD35X2R 1.2022.18200 in 26.068ms.
12:09:16 InstalledPackageSourceReader is finding plug-in for Board.AD738X 1.2023.36500.
12:09:16 InstalledPackageSourceReader found plug-in for Board.AD738X 1.2023.36500 in 16.706ms.
12:09:16 InstalledPackageSourceReader is finished finding plug-ins for installed packages in 1276.354ms
12:09:16 Clearing blocked plug-ins.
12:09:16 Scanning folder "C:\ProgramData\Analog Devices\ACE\Plugins" for plug-ins.
12:09:17 Startup time = 5.2132249 seconds.
12:09:17 Downloading swdownloads.analog.com/.../latest_version.ini to C:\Users\mahalakshmi_c\AppData\Local\Analog Devices\ACE\Updater\latest_version.ini using WebClient.
12:09:17 Lookup time for plug-in Hardware.ClockSupport, Version 1.2022.28200 was 0.308ms
12:09:17 Lookup time for plug-in Support.AnalogDevices.Vector.Generator.Noise, Version 1.23.197 was 0.008ms
12:09:17 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9963, Version 1.23.197 was 0.176ms
12:09:17 Lookup time for plug-in Vector.Common, Version 1.30.3311 was 0.375ms
12:09:17 Lookup time for plug-in Support.HsdacFpga, Version 1.23.197 was 0.006ms
12:09:17 Plug-in Hardware.ClockSupport Validation Informational: Plug-in is not supported by the x64 version of ACE
12:09:17 Initialization time for plug-in Hardware.ClockSupport, Version 1.2022.28200 was 36.725ms
12:09:17 Loaded plug-in Hardware.ClockSupport, Version 1.2022.28200 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.ClockSupport.1.2022.28200 in 42.851ms
12:09:17 Lookup time for plug-in Support.NationalInstruments.MeasurementStudio, Version 15.0.197 was 0.022ms
12:09:17 Dependency Support.NationalInstruments.MeasurementStudio loaded in 20.151ms
12:09:17 Lookup time for plug-in Hardware.UnifiedSpiMaster, Version 1.2022.28400 was 0.015ms
12:09:17 Lookup time for plug-in Support.AnalogDevices.DPG.Interfaces, Version 1.23.197 was 0.005ms
12:09:18 Lookup time for plug-in Support.AnalogDevices.DPG.HardwareControl, Version 1.23.197 was 0.008ms
12:09:18 Lookup time for plug-in Chip.ADF4371, Version 1.2022.24300 was 0.016ms
12:09:18 Assembly registration time for plug-in Hardware.UnifiedSpiMaster, Version 1.2022.28400 was 30.075ms
12:09:18 Loaded Extensions - Plug-in Hardware.UnifiedSpiMaster, Version 1.2022.28400 - 515.962ms
12:09:18 Assembly registration time for plug-in Support.AnalogDevices.DPG.HardwareControl, Version 1.23.197 was 32.778ms
12:09:18 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.HardwareControl, Version 1.23.197 - 419.432ms
12:09:18 Initialization time for plug-in Hardware.UnifiedSpiMaster, Version 1.2022.28400 was 536.794ms
12:09:18 Loaded plug-in Hardware.UnifiedSpiMaster, Version 1.2022.28400 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.UnifiedSpiMaster.1.2022.28400 in 537.282ms
12:09:18 Lookup time for plug-in Hardware.DeviceApiSupport, Version 1.2022.28200 was 0.011ms
12:09:18 Initialization time for plug-in Support.AnalogDevices.DPG.HardwareControl, Version 1.23.197 was 474.399ms
12:09:18 Dependency Support.AnalogDevices.DPG.HardwareControl loaded in 479.438ms
12:09:18 Assembly registration time for plug-in Support.HsdacFpga, Version 1.23.197 was 33.001ms
12:09:18 Lookup time for plug-in Support.AnalogDevices.Vector.Common, Version 1.23.197 was 0.014ms
12:09:18 Assembly registration time for plug-in Chip.ADF4371, Version 1.2022.24300 was 33.124ms
12:09:18 Loaded Extensions - Plug-in Support.HsdacFpga, Version 1.23.197 - 567.35ms
12:09:18 Loaded Extensions - Plug-in Chip.ADF4371, Version 1.2022.24300 - 66.1ms
12:09:18 Assembly registration time for plug-in Vector.Common, Version 1.30.3311 was 53.004ms
12:09:18 Initialization time for plug-in Chip.ADF4371, Version 1.2022.24300 was 306.758ms
12:09:18 Loaded plug-in Chip.ADF4371, Version 1.2022.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADF4371.1.2022.24300 in 307.33ms
12:09:18 Lookup time for plug-in Chip.AD9508, Version 1.2.0 was 0.018ms
12:09:18 Initialization time for plug-in Support.HsdacFpga, Version 1.23.197 was 609.386ms
12:09:18 Loaded plug-in Support.HsdacFpga, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.HsdacFpga.1.23.197 in 616.387ms
12:09:18 Lookup time for plug-in Support.IronPython, Version 1.2023.38300 was 0.02ms
12:09:18 Assembly registration time for plug-in Hardware.DeviceApiSupport, Version 1.2022.28200 was 43.245ms
12:09:18 Assembly registration time for plug-in Support.IronPython, Version 1.2023.38300 was 22.701ms
12:09:18 Assembly registration time for plug-in Chip.AD9508, Version 1.2.0 was 28.675ms
12:09:18 Loaded Extensions - Plug-in Chip.AD9508, Version 1.2.0 - 40.631ms
12:09:18 Initialization time for plug-in Chip.AD9508, Version 1.2.0 was 73.705ms
12:09:18 Loaded plug-in Chip.AD9508, Version 1.2.0 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9508.1.2.0 in 74.182ms
12:09:18 Lookup time for plug-in Chip.AD9164, Version 1.2020.24300 was 0.014ms
12:09:18 Loaded Extensions - Plug-in Support.IronPython, Version 1.2023.38300 - 51.979ms
12:09:18 Dependency Support.NationalInstruments.MeasurementStudio loaded in 3.149ms
12:09:18 Initialization time for plug-in Support.IronPython, Version 1.2023.38300 was 75.639ms
12:09:18 Loaded plug-in Support.IronPython, Version 1.2023.38300 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.IronPython.1.2023.38300 in 76.147ms
12:09:18 Lookup time for plug-in Chip.AD9208, Version 1.2022.20500 was 0.014ms
12:09:18 Lookup time for plug-in Support.AnalogDevices.DPG.PluginFinder, Version 1.23.197 was 0.012ms
12:09:18 Assembly registration time for plug-in Support.NationalInstruments.MeasurementStudio, Version 15.0.197 was 141.875ms
12:09:18 Loaded Extensions - Plug-in Support.NationalInstruments.MeasurementStudio, Version 15.0.197 - 582.673ms
12:09:18 Initialization time for plug-in Support.NationalInstruments.MeasurementStudio, Version 15.0.197 was 658.427ms
12:09:18 Dependency Support.NationalInstruments.MeasurementStudio loaded in 680.278ms
12:09:18 Dependency Support.AnalogDevices.Vector.Common loaded in 2.051ms
12:09:18 Assembly registration time for plug-in Support.AnalogDevices.Vector.Generator.Noise, Version 1.23.197 was 30.424ms
12:09:18 Loaded Extensions - Plug-in Support.AnalogDevices.Vector.Generator.Noise, Version 1.23.197 - 49.039ms
12:09:18 Could not download swdownloads.analog.com/.../latest_version.ini to C:\Users\mahalakshmi_c\AppData\Local\Analog Devices\ACE\Updater\latest_version.ini. Exception Message: Download time exceeded 1 seconds.
12:09:18 Assembly registration time for plug-in Chip.AD9164, Version 1.2020.24300 was 29.149ms
12:09:18 Initialization time for plug-in Support.AnalogDevices.Vector.Generator.Noise, Version 1.23.197 was 765.135ms
12:09:18 Loaded Extensions - Plug-in Chip.AD9164, Version 1.2020.24300 - 76.89ms
12:09:18 Loaded plug-in Support.AnalogDevices.Vector.Generator.Noise, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.Vector.Generator.Noise.1.23.197 in 771.336ms
12:09:18 Lookup time for plug-in Support.AnalogDevices.DPG.IdlePatternTool, Version 1.23.197 was 0.02ms
12:09:18 Initialization time for plug-in Chip.AD9164, Version 1.2020.24300 was 93.026ms
12:09:18 Loaded plug-in Chip.AD9164, Version 1.2020.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9164.1.2020.24300 in 93.643ms
12:09:18 Lookup time for plug-in Board.ADF4371, Version 1.2022.3300 was 0.016ms
12:09:18 Dependency Support.AnalogDevices.DPG.Interfaces loaded in 2.507ms
12:09:18 Assembly registration time for plug-in Support.AnalogDevices.DPG.PluginFinder, Version 1.23.197 was 33.557ms
12:09:18 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.PluginFinder, Version 1.23.197 - 34.269ms
12:09:18 Initialization time for plug-in Support.AnalogDevices.DPG.PluginFinder, Version 1.23.197 was 114.153ms
12:09:18 Dependency Support.AnalogDevices.DPG.PluginFinder loaded in 116.557ms
12:09:18 Assembly registration time for plug-in Chip.AD9208, Version 1.2022.20500 was 55.677ms
12:09:18 Loaded Extensions - Plug-in Vector.Common, Version 1.30.3311 - 808.765ms
12:09:18 Assembly registration time for plug-in Support.AnalogDevices.Vector.Common, Version 1.23.197 was 30.914ms
12:09:18 Loaded Extensions - Plug-in Chip.AD9208, Version 1.2022.20500 - 120.812ms
12:09:18 Loaded Extensions - Plug-in Hardware.DeviceApiSupport, Version 1.2022.28200 - 235.6ms
12:09:18 Loaded Extensions - Plug-in Support.AnalogDevices.Vector.Common, Version 1.23.197 - 34.04ms
12:09:18 Initialization time for plug-in Vector.Common, Version 1.30.3311 was 836.819ms
12:09:18 Loaded plug-in Vector.Common, Version 1.30.3311 from C:\ProgramData\Analog Devices\ACE\Plugins\Vector.Common.1.30.3311 in 844.091ms
12:09:18 Lookup time for plug-in Vector.File, Version 1.30.3311 was 0.015ms
12:09:18 Error downloading latest version file:
AnalogDevices.Csa.Exceptions.DownloadException: Failed to complete download. ---> System.TimeoutException: Download time exceeded 1 seconds.
at AnalogDevices.Csa.Downloader.WebClientDownloader.GetFile(Uri sourceUrl, String targetPath, Int32 milliTimeout)
--- End of inner exception stack trace ---
at AnalogDevices.Csa.Downloader.Updater.ApplicationUpdater.CheckForUpdate(Object state)
12:09:18 Initialization time for plug-in Hardware.DeviceApiSupport, Version 1.2022.28200 was 258.572ms
12:09:18 Loaded plug-in Hardware.DeviceApiSupport, Version 1.2022.28200 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.DeviceApiSupport.1.2022.28200 in 258.978ms
12:09:18 Lookup time for plug-in Hardware.IIOSupport, Version 1.2024.30300 was 0.012ms
12:09:18 Initialization time for plug-in Chip.AD9208, Version 1.2022.20500 was 152.103ms
12:09:18 Loaded plug-in Chip.AD9208, Version 1.2022.20500 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9208.1.2022.20500 in 152.427ms
12:09:18 Lookup time for plug-in Support.AdiNSpi, Version 1.2022.28400 was 0.016ms
12:09:18 Initialization time for plug-in Support.AnalogDevices.Vector.Common, Version 1.23.197 was 257.919ms
12:09:18 Dependency Support.AnalogDevices.Vector.Common loaded in 260.686ms
12:09:18 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9739, Version 1.23.197 was 0.023ms
12:09:18 Assembly registration time for plug-in Board.ADF4371, Version 1.2022.3300 was 31.621ms
12:09:18 Assembly registration time for plug-in Support.AnalogDevices.DPG.IdlePatternTool, Version 1.23.197 was 32.795ms
12:09:18 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.IdlePatternTool, Version 1.23.197 - 78.465ms
12:09:18 Initialization time for plug-in Support.AnalogDevices.DPG.IdlePatternTool, Version 1.23.197 was 106.984ms
12:09:18 Loaded plug-in Support.AnalogDevices.DPG.IdlePatternTool, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.IdlePatternTool.1.23.197 in 107.516ms
12:09:18 Lookup time for plug-in Support.DPGDownloader, Version 1.23.197 was 0.016ms
12:09:18 Assembly registration time for plug-in Support.AnalogDevices.DPG.Interfaces, Version 1.23.197 was 33.933ms
12:09:18 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.Interfaces, Version 1.23.197 - 34.567ms
12:09:18 Dependency Support.AnalogDevices.DPG.Interfaces loaded in 2.795ms
12:09:18 Initialization time for plug-in Support.AnalogDevices.DPG.Interfaces, Version 1.23.197 was 837.323ms
12:09:18 Dependency Support.AnalogDevices.DPG.Interfaces loaded in 840.164ms
12:09:18 Assembly registration time for plug-in Vector.File, Version 1.30.3311 was 26.359ms
12:09:18 Loaded Extensions - Plug-in Vector.File, Version 1.30.3311 - 27.825ms
12:09:18 Initialization time for plug-in Vector.File, Version 1.30.3311 was 50.329ms
12:09:18 Loaded plug-in Vector.File, Version 1.30.3311 from C:\ProgramData\Analog Devices\ACE\Plugins\Vector.File.1.30.3311 in 50.818ms
12:09:18 Lookup time for plug-in Support.AnalogDevices.VectorFile.Legacy, Version 1.23.197 was 0.017ms
12:09:18 Assembly registration time for plug-in Support.AdiNSpi, Version 1.2022.28400 was 34.297ms
12:09:18 Loaded Extensions - Plug-in Support.AdiNSpi, Version 1.2022.28400 - 34.9ms
12:09:18 Initialization time for plug-in Support.AdiNSpi, Version 1.2022.28400 was 62.309ms
12:09:18 Loaded plug-in Support.AdiNSpi, Version 1.2022.28400 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AdiNSpi.1.2022.28400 in 62.747ms
12:09:18 Lookup time for plug-in Support.AnalogDevices.DPG.Hardware.ADS9, Version 1.23.197 was 0.014ms
12:09:18 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9963, Version 1.23.197 was 29.015ms
12:09:18 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9963, Version 1.23.197 - 50.864ms
12:09:18 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9963, Version 1.23.197 was 935.879ms
12:09:18 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9963, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9963.1.23.197 in 942.506ms
12:09:18 Assembly registration time for plug-in Support.AnalogDevices.VectorFile.Legacy, Version 1.23.197 was 26.842ms
12:09:18 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9962, Version 1.23.197 was 0.017ms
12:09:18 Loaded Extensions - Plug-in Support.AnalogDevices.VectorFile.Legacy, Version 1.23.197 - 27.591ms
12:09:18 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9739, Version 1.23.197 was 39.413ms
12:09:18 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9739, Version 1.23.197 - 59.75ms
12:09:18 Initialization time for plug-in Support.AnalogDevices.VectorFile.Legacy, Version 1.23.197 was 51.935ms
12:09:18 Loaded plug-in Support.AnalogDevices.VectorFile.Legacy, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.VectorFile.Legacy.1.23.197 in 52.416ms
12:09:18 Lookup time for plug-in Support.AnalogDevices.Vector.Generator.WIFR, Version 1.23.197 was 0.025ms
12:09:18 Loaded Extensions - Plug-in Board.ADF4371, Version 1.2022.3300 - 118.024ms
12:09:18 Assembly registration time for plug-in Support.AnalogDevices.DPG.Hardware.ADS9, Version 1.23.197 was 33.647ms
12:09:18 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.Hardware.ADS9, Version 1.23.197 - 34.398ms
12:09:18 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9739, Version 1.23.197 was 109.183ms
12:09:18 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9739, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9739.1.23.197 in 109.987ms
12:09:18 Lookup time for plug-in Support.Transactions, Version 1.2023.47200 was 0.015ms
12:09:18 Initialization time for plug-in Board.ADF4371, Version 1.2022.3300 was 178.125ms
12:09:18 Loaded plug-in Board.ADF4371, Version 1.2022.3300 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADF4371.1.2022.3300 in 178.508ms
12:09:18 Assembly registration time for plug-in Support.DPGDownloader, Version 1.23.197 was 41.345ms
12:09:18 Lookup time for plug-in Chip.AD9162, Version 1.2020.24300 was 0.016ms
12:09:18 Loaded Extensions - Plug-in Support.DPGDownloader, Version 1.23.197 - 61.526ms
12:09:18 Initialization time for plug-in Support.AnalogDevices.DPG.Hardware.ADS9, Version 1.23.197 was 55.894ms
12:09:18 Loaded plug-in Support.AnalogDevices.DPG.Hardware.ADS9, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.Hardware.ADS9.1.23.197 in 56.275ms
12:09:18 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9144, Version 1.23.197 was 0.017ms
12:09:18 Initialization time for plug-in Support.DPGDownloader, Version 1.23.197 was 85.714ms
12:09:18 Loaded plug-in Support.DPGDownloader, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.DPGDownloader.1.23.197 in 86.137ms
12:09:18 Lookup time for plug-in Chip.ADMV1013, Version 0.1.5 was 0.013ms
12:09:18 Assembly registration time for plug-in Hardware.IIOSupport, Version 1.2024.30300 was 54.184ms
12:09:18 Lookup time for plug-in Support.AnalogDevices.Vector.AdvancedVectorGenerator, Version 1.23.197 was 0.018ms
12:09:18 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9962, Version 1.23.197 was 23.425ms
12:09:18 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9962, Version 1.23.197 - 50.034ms
12:09:18 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9144, Version 1.23.197 was 24.909ms
12:09:18 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9144, Version 1.23.197 - 25.463ms
12:09:18 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9962, Version 1.23.197 was 75.001ms
12:09:18 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9962, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9962.1.23.197 in 75.592ms
12:09:18 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9122, Version 1.23.197 was 0.021ms
12:09:18 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9144, Version 1.23.197 was 54.484ms
12:09:18 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9144, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9144.1.23.197 in 54.903ms
12:09:18 Loaded plug-in Support.AnalogDevices.Vector.AdvancedVectorGenerator, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.Vector.AdvancedVectorGenerator.1.23.197 in 0.011ms
12:09:18 Lookup time for plug-in Chip.AD9528, Version 1.1.2 was 0.019ms
12:09:18 Assembly registration time for plug-in Support.Transactions, Version 1.2023.47200 was 23.674ms
12:09:18 Loaded Extensions - Plug-in Support.Transactions, Version 1.2023.47200 - 51.729ms
12:09:18 Lookup time for plug-in Support.AnalogDevices.DPG.FilterTool, Version 1.23.197 was 0.014ms
12:09:18 Assembly registration time for plug-in Chip.AD9162, Version 1.2020.24300 was 27.897ms
12:09:18 Loaded Extensions - Plug-in Chip.AD9162, Version 1.2020.24300 - 37.181ms
12:09:18 Initialization time for plug-in Chip.AD9162, Version 1.2020.24300 was 86.437ms
12:09:18 Loaded plug-in Chip.AD9162, Version 1.2020.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9162.1.2020.24300 in 87.063ms
12:09:18 Lookup time for plug-in Support.AnalogDevices.Vector.Generator.Tones, Version 1.23.197 was 0.026ms
12:09:18 Assembly registration time for plug-in Chip.ADMV1013, Version 0.1.5 was 24.729ms
12:09:18 Loaded Extensions - Plug-in Chip.ADMV1013, Version 0.1.5 - 37.442ms
12:09:18 Initialization time for plug-in Chip.ADMV1013, Version 0.1.5 was 101.518ms
12:09:18 Loaded plug-in Chip.ADMV1013, Version 0.1.5 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADMV1013.0.1.5 in 101.922ms
12:09:18 Lookup time for plug-in Support.AnalogDevices.Vector.Generator.Chirp, Version 1.23.197 was 0.03ms
12:09:18 Assembly registration time for plug-in Support.AnalogDevices.Vector.AdvancedVectorGenerator, Version 1.23.197 was 36.582ms
12:09:18 Loaded Extensions - Plug-in Support.AnalogDevices.Vector.AdvancedVectorGenerator, Version 1.23.197 - 37.154ms
12:09:18 Loaded Extensions - Plug-in Hardware.IIOSupport, Version 1.2024.30300 - 220.097ms
12:09:18 Initialization time for plug-in Support.AnalogDevices.Vector.AdvancedVectorGenerator, Version 1.23.197 was 115.285ms
12:09:18 Dependency Support.AnalogDevices.Vector.AdvancedVectorGenerator loaded in 117.977ms
12:09:18 Assembly registration time for plug-in Chip.AD9528, Version 1.1.2 was 29.318ms
12:09:18 Loaded Extensions - Plug-in Chip.AD9528, Version 1.1.2 - 45.898ms
12:09:18 Initialization time for plug-in Hardware.IIOSupport, Version 1.2024.30300 was 243.684ms
12:09:18 Loaded plug-in Hardware.IIOSupport, Version 1.2024.30300 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.IIOSupport.1.2024.30300 in 244.344ms
12:09:18 Initialization time for plug-in Chip.AD9528, Version 1.1.2 was 68.249ms
12:09:18 Loaded plug-in Chip.AD9528, Version 1.1.2 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9528.1.1.2 in 69.515ms
12:09:18 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9779A, Version 1.23.197 was 0.018ms
12:09:18 Lookup time for plug-in Hardware.COMSupport, Version 1.2024.31200 was 0.027ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.Vector.Generator.WIFR, Version 1.23.197 was 35.712ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.Vector.Generator.WIFR, Version 1.23.197 - 36.287ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.Vector.Generator.Tones, Version 1.23.197 was 29.812ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.Vector.Generator.Tones, Version 1.23.197 - 51.734ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.Vector.Generator.WIFR, Version 1.23.197 was 177.648ms
12:09:19 Loaded plug-in Support.AnalogDevices.Vector.Generator.WIFR, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.Vector.Generator.WIFR.1.23.197 in 178.108ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.HardwareControl, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.HardwareControl.1.23.197 in 0.009ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.PluginFinder, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.PluginFinder.1.23.197 in 0.005ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.Interfaces, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.Interfaces.1.23.197 in 0.005ms
12:09:19 Lookup time for plug-in Chip.ADF4355, Version 1.1.1 was 0.015ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.Vector.Generator.Tones, Version 1.23.197 was 77.673ms
12:09:19 Loaded plug-in Support.AnalogDevices.Vector.Generator.Tones, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.Vector.Generator.Tones.1.23.197 in 78.073ms
12:09:19 Lookup time for plug-in Chip.AD9695, Version 1.2023.48400 was 0.016ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.FilterTool, Version 1.23.197 was 30.091ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.FilterTool, Version 1.23.197 - 30.682ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.FilterTool, Version 1.23.197 was 93.106ms
12:09:19 Dependency Support.AnalogDevices.DPG.FilterTool loaded in 95.717ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9779A, Version 1.23.197 was 36.002ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9779A, Version 1.23.197 - 36.654ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9122, Version 1.23.197 was 26.062ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9122, Version 1.23.197 - 54.811ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9779A, Version 1.23.197 was 97.963ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9779A, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9779A.1.23.197 in 99.046ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.Vector.Generator.Chirp, Version 1.23.197 was 84.988ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.Vector.Generator.Chirp, Version 1.23.197 - 104.497ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.FilterTool, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.FilterTool.1.23.197 in 0.006ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.DPG.Hardware.ADS72, Version 1.23.197 was 0.014ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9122, Version 1.23.197 was 175.84ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9122, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9122.1.23.197 in 176.278ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.DPG.Hardware.SDPH1, Version 1.23.197 was 0.017ms
12:09:19 Initialization time for plug-in Support.Transactions, Version 1.2023.47200 was 233.742ms
12:09:19 Loaded plug-in Support.Transactions, Version 1.2023.47200 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.Transactions.1.2023.47200 in 234.153ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9789, Version 1.23.197 was 0.011ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.Vector.Generator.Chirp, Version 1.23.197 was 127.112ms
12:09:19 Loaded plug-in Support.AnalogDevices.Vector.Generator.Chirp, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.Vector.Generator.Chirp.1.23.197 in 127.975ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9717, Version 1.23.197 was 0.012ms
12:09:19 Dependency Support.AnalogDevices.DPG.Hardware.SDPH1 loaded in 1.845ms
12:09:19 Assembly registration time for plug-in Hardware.COMSupport, Version 1.2024.31200 was 43.165ms
12:09:19 Assembly registration time for plug-in Chip.ADF4355, Version 1.1.1 was 27.435ms
12:09:19 Loaded Extensions - Plug-in Chip.ADF4355, Version 1.1.1 - 76.598ms
12:09:19 Initialization time for plug-in Chip.ADF4355, Version 1.1.1 was 111.245ms
12:09:19 Loaded plug-in Chip.ADF4355, Version 1.1.1 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADF4355.1.1.1 in 111.644ms
12:09:19 Loaded plug-in Support.AnalogDevices.Vector.Common, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.Vector.Common.1.23.197 in 0.008ms
12:09:19 Loaded plug-in Support.NationalInstruments.MeasurementStudio, Version 15.0.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.NationalInstruments.MeasurementStudio.15.0.197 in 0.005ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9747, Version 1.23.197 was 0.017ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.Hardware.ADS72, Version 1.23.197 was 39.056ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.Hardware.ADS72, Version 1.23.197 - 39.701ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.Hardware.ADS72, Version 1.23.197 was 66.277ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.Hardware.ADS72, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.Hardware.ADS72.1.23.197 in 66.737ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9788, Version 1.23.197 was 0.047ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.Hardware.SDPH1, Version 1.23.197 was 27.57ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.Hardware.SDPH1, Version 1.23.197 - 48.873ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.Hardware.SDPH1, Version 1.23.197 was 76.121ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.Hardware.SDPH1, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.Hardware.SDPH1.1.23.197 in 76.515ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.DPG.Hardware.DPG3, Version 1.23.197 was 0.02ms
12:09:19 Assembly registration time for plug-in Chip.AD9695, Version 1.2023.48400 was 31.135ms
12:09:19 Loaded Extensions - Plug-in Chip.AD9695, Version 1.2023.48400 - 47.126ms
12:09:19 Initialization time for plug-in Chip.AD9695, Version 1.2023.48400 was 151.075ms
12:09:19 Loaded plug-in Chip.AD9695, Version 1.2023.48400 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9695.1.2023.48400 in 151.481ms
12:09:19 Lookup time for plug-in Support.PatternGen, Version 1.2022.28200 was 0.019ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9747, Version 1.23.197 was 39.368ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9747, Version 1.23.197 - 39.816ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9717, Version 1.23.197 was 42.277ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9717, Version 1.23.197 - 74.758ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9789, Version 1.23.197 was 43.072ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9789, Version 1.23.197 - 68.865ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9747, Version 1.23.197 was 76.188ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9747, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9747.1.23.197 in 76.622ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.Vector.Generator.DC, Version 1.23.197 was 0.016ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9717, Version 1.23.197 was 126.718ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9717, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9717.1.23.197 in 127.101ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9707, Version 1.23.197 was 0.034ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9789, Version 1.23.197 was 130.579ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9789, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9789.1.23.197 in 130.965ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9736, Version 1.23.197 was 0.016ms
12:09:19 Assembly registration time for plug-in Support.PatternGen, Version 1.2022.28200 was 31.679ms
12:09:19 Loaded Extensions - Plug-in Support.PatternGen, Version 1.2022.28200 - 32.299ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9788, Version 1.23.197 was 33.178ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9788, Version 1.23.197 - 34.539ms
12:09:19 Initialization time for plug-in Support.PatternGen, Version 1.2022.28200 was 53.895ms
12:09:19 Loaded plug-in Support.PatternGen, Version 1.2022.28200 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.PatternGen.1.2022.28200 in 54.439ms
12:09:19 Lookup time for plug-in Support.ScriptRunner, Version 1.2023.19300 was 0.016ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9788, Version 1.23.197 was 76.777ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9788, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9788.1.23.197 in 77.292ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.Vector.Generator.CIFR, Version 1.23.197 was 0.018ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.Hardware.DPG3, Version 1.23.197 was 29.421ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.Hardware.DPG3, Version 1.23.197 - 56.375ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.Hardware.DPG3, Version 1.23.197 was 84.474ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.Hardware.DPG3, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.Hardware.DPG3.1.23.197 in 84.897ms
12:09:19 Lookup time for plug-in Chip.HMC7044, Version 0.1.0 was 0.023ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.Vector.Generator.DC, Version 1.23.197 was 35.696ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.Vector.Generator.DC, Version 1.23.197 - 36.321ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.Vector.Generator.DC, Version 1.23.197 was 60.933ms
12:09:19 Loaded plug-in Support.AnalogDevices.Vector.Generator.DC, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.Vector.Generator.DC.1.23.197 in 61.442ms
12:09:19 Lookup time for plug-in Chip.ADA2200, Version 1.10.2 was 0.016ms
12:09:19 Assembly registration time for plug-in Support.ScriptRunner, Version 1.2023.19300 was 27.55ms
12:09:19 Loaded Extensions - Plug-in Hardware.COMSupport, Version 1.2024.31200 - 262.088ms
12:09:19 Loaded Extensions - Plug-in Support.ScriptRunner, Version 1.2023.19300 - 29.462ms
12:09:19 Initialization time for plug-in Hardware.COMSupport, Version 1.2024.31200 was 297.307ms
12:09:19 Loaded plug-in Hardware.COMSupport, Version 1.2024.31200 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.COMSupport.1.2024.31200 in 300.168ms
12:09:19 Lookup time for plug-in Hardware.HsdacSupport, Version 1.2022.28200 was 0.017ms
12:09:19 Initialization time for plug-in Support.ScriptRunner, Version 1.2023.19300 was 56.674ms
12:09:19 Loaded plug-in Support.ScriptRunner, Version 1.2023.19300 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.ScriptRunner.1.2023.19300 in 57.054ms
12:09:19 Lookup time for plug-in Support.IIO, Version 1.2024.30300 was 0.018ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9736, Version 1.23.197 was 33.057ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9736, Version 1.23.197 - 54.056ms
12:09:19 Plug-in Hardware.HsdacSupport Validation Informational: Plug-in is not supported by the x64 version of ACE
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9736, Version 1.23.197 was 83.639ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9736, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9736.1.23.197 in 84.123ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9148, Version 1.23.197 was 0.015ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.Vector.Generator.CIFR, Version 1.23.197 was 31.198ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.Vector.Generator.CIFR, Version 1.23.197 - 53.006ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9707, Version 1.23.197 was 43.676ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9707, Version 1.23.197 - 70.539ms
12:09:19 Initialization time for plug-in Hardware.HsdacSupport, Version 1.2022.28200 was 22.496ms
12:09:19 Loaded plug-in Hardware.HsdacSupport, Version 1.2022.28200 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.HsdacSupport.1.2022.28200 in 22.888ms
12:09:19 Lookup time for plug-in Hardware.SdpSupport, Version 1.2024.11300 was 0.015ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.Vector.Generator.CIFR, Version 1.23.197 was 80.378ms
12:09:19 Loaded plug-in Support.AnalogDevices.Vector.Generator.CIFR, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.Vector.Generator.CIFR.1.23.197 in 80.857ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9783, Version 1.23.197 was 0.013ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9707, Version 1.23.197 was 92.641ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9707, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9707.1.23.197 in 93.951ms
12:09:19 Lookup time for plug-in Chip.AD9163, Version 1.2020.24300 was 0.044ms
12:09:19 Assembly registration time for plug-in Chip.HMC7044, Version 0.1.0 was 26.534ms
12:09:19 Loaded Extensions - Plug-in Chip.HMC7044, Version 0.1.0 - 33.065ms
12:09:19 Assembly registration time for plug-in Support.IIO, Version 1.2024.30300 was 29.848ms
12:09:19 Loaded Extensions - Plug-in Support.IIO, Version 1.2024.30300 - 30.714ms
12:09:19 Initialization time for plug-in Chip.HMC7044, Version 0.1.0 was 85.86ms
12:09:19 Loaded plug-in Chip.HMC7044, Version 0.1.0 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.HMC7044.0.1.0 in 86.208ms
12:09:19 Lookup time for plug-in Board.ADMV1013, Version 1.2019.9400 was 0.017ms
12:09:19 Initialization time for plug-in Support.IIO, Version 1.2024.30300 was 53.815ms
12:09:19 Loaded plug-in Support.IIO, Version 1.2024.30300 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.IIO.1.2024.30300 in 54.291ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.Vector.Generator.PtP, Version 1.23.197 was 0.012ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9148, Version 1.23.197 was 27.077ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9148, Version 1.23.197 - 27.68ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9148, Version 1.23.197 was 51.12ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9148, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9148.1.23.197 in 51.622ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9744, Version 1.23.197 was 0.016ms
12:09:19 Assembly registration time for plug-in Chip.ADA2200, Version 1.10.2 was 39.032ms
12:09:19 Loaded Extensions - Plug-in Chip.ADA2200, Version 1.10.2 - 57.608ms
12:09:19 Initialization time for plug-in Chip.ADA2200, Version 1.10.2 was 113.712ms
12:09:19 Loaded plug-in Chip.ADA2200, Version 1.10.2 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADA2200.1.10.2 in 114.194ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9993, Version 1.23.197 was 0.017ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9783, Version 1.23.197 was 37.071ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9783, Version 1.23.197 - 81.102ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.Vector.Generator.PtP, Version 1.23.197 was 35.531ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.Vector.Generator.PtP, Version 1.23.197 - 37.374ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9744, Version 1.23.197 was 34.583ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9744, Version 1.23.197 - 35.094ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9783, Version 1.23.197 was 108.652ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9783, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9783.1.23.197 in 109.086ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.Vector.Generator.PtP, Version 1.23.197 was 79.655ms
12:09:19 Loaded plug-in Support.AnalogDevices.Vector.Generator.PtP, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.Vector.Generator.PtP.1.23.197 in 79.97ms
12:09:19 Lookup time for plug-in Chip.AD35X2R, Version 1.2022.18200 was 0.007ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9144wDPG3, Version 1.23.197 was 0.013ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9744, Version 1.23.197 was 65.036ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9744, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9744.1.23.197 in 65.402ms
12:09:19 Lookup time for plug-in Chip.AD9172, Version 1.2021.32300 was 0.016ms
12:09:19 Assembly registration time for plug-in Chip.AD9163, Version 1.2020.24300 was 28.578ms
12:09:19 Loaded Extensions - Plug-in Chip.AD9163, Version 1.2020.24300 - 82.755ms
12:09:19 Initialization time for plug-in Chip.AD9163, Version 1.2020.24300 was 135.115ms
12:09:19 Loaded plug-in Chip.AD9163, Version 1.2020.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9163.1.2020.24300 in 135.765ms
12:09:19 Lookup time for plug-in Chip.AD9161, Version 1.2020.24300 was 0.013ms
12:09:19 Assembly registration time for plug-in Hardware.SdpSupport, Version 1.2024.11300 was 85.933ms
12:09:19 Assembly registration time for plug-in Board.ADMV1013, Version 1.2019.9400 was 33.09ms
12:09:19 Loaded Extensions - Plug-in Board.ADMV1013, Version 1.2019.9400 - 41.968ms
12:09:19 Initialization time for plug-in Board.ADMV1013, Version 1.2019.9400 was 125.142ms
12:09:19 Loaded plug-in Board.ADMV1013, Version 1.2019.9400 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADMV1013.1.2019.09400 in 125.501ms
12:09:19 Lookup time for plug-in Board.ADA2200, Version 1.10.2 was 0.022ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9993, Version 1.23.197 was 24.644ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9993, Version 1.23.197 - 48.833ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9993, Version 1.23.197 was 87.394ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9993, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9993.1.23.197 in 87.845ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9162, Version 1.23.197 was 0.017ms
12:09:19 Assembly registration time for plug-in Chip.AD35X2R, Version 1.2022.18200 was 28.765ms
12:09:19 Loaded Extensions - Plug-in Chip.AD35X2R, Version 1.2022.18200 - 47.137ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9144wDPG3, Version 1.23.197 was 31.889ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9144wDPG3, Version 1.23.197 - 53.873ms
12:09:19 Initialization time for plug-in Chip.AD35X2R, Version 1.2022.18200 was 78.123ms
12:09:19 Loaded plug-in Chip.AD35X2R, Version 1.2022.18200 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD35X2R.1.2022.18200 in 78.461ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9129, Version 1.23.197 was 0.014ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9144wDPG3, Version 1.23.197 was 95.311ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9144wDPG3, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9144wDPG3.1.23.197 in 96.301ms
12:09:19 Lookup time for plug-in Support.Lexicon, Version 1.2023.51400 was 0.017ms
12:09:19 Assembly registration time for plug-in Chip.AD9161, Version 1.2020.24300 was 29.487ms
12:09:19 Loaded Extensions - Plug-in Chip.AD9161, Version 1.2020.24300 - 34.421ms
12:09:19 Initialization time for plug-in Chip.AD9161, Version 1.2020.24300 was 82.837ms
12:09:19 Loaded plug-in Chip.AD9161, Version 1.2020.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9161.1.2020.24300 in 83.247ms
12:09:19 Lookup time for plug-in Board.AD9172, Version 1.2020.8500 was 0.018ms
12:09:19 Assembly registration time for plug-in Board.ADA2200, Version 1.10.2 was 27.177ms
12:09:19 Loaded Extensions - Plug-in Board.ADA2200, Version 1.10.2 - 34.781ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9162, Version 1.23.197 was 31.913ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9162, Version 1.23.197 - 58.562ms
12:09:19 Initialization time for plug-in Board.ADA2200, Version 1.10.2 was 90.169ms
12:09:19 Loaded plug-in Board.ADA2200, Version 1.10.2 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADA2200.1.10.2 in 90.661ms
12:09:19 Lookup time for plug-in Chip.ADF4372, Version 1.2022.24300 was 0.015ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9162, Version 1.23.197 was 82.421ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9162, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9162.1.23.197 in 82.849ms
12:09:19 Lookup time for plug-in Chip.AD9689, Version 1.2020.33400 was 0.012ms
12:09:19 Assembly registration time for plug-in Chip.AD9172, Version 1.2021.32300 was 23.922ms
12:09:19 Loaded Extensions - Plug-in Chip.AD9172, Version 1.2021.32300 - 70.919ms
12:09:19 Initialization time for plug-in Chip.AD9172, Version 1.2021.32300 was 138.851ms
12:09:19 Loaded plug-in Chip.AD9172, Version 1.2021.32300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9172.1.2021.32300 in 139.257ms
12:09:19 Lookup time for plug-in Support.BlockGallery, Version 1.2024.23300 was 0.02ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9129, Version 1.23.197 was 42.694ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9129, Version 1.23.197 - 61.193ms
12:09:19 Assembly registration time for plug-in Support.Lexicon, Version 1.2023.51400 was 30.752ms
12:09:19 Loaded Extensions - Plug-in Support.Lexicon, Version 1.2023.51400 - 49.388ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9129, Version 1.23.197 was 86.49ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9129, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9129.1.23.197 in 86.887ms
12:09:19 Lookup time for plug-in Chip.AD738X, Version 1.2023.36500 was 0.013ms
12:09:19 Assembly registration time for plug-in Support.BlockGallery, Version 1.2024.23300 was 23.405ms
12:09:19 Assembly registration time for plug-in Chip.ADF4372, Version 1.2022.24300 was 25.737ms
12:09:19 Loaded Extensions - Plug-in Chip.ADF4372, Version 1.2022.24300 - 55.589ms
12:09:19 Initialization time for plug-in Chip.ADF4372, Version 1.2022.24300 was 132.813ms
12:09:19 Loaded plug-in Chip.ADF4372, Version 1.2022.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADF4372.1.2022.24300 in 133.562ms
12:09:19 Lookup time for plug-in Board.AD9208, Version 1.2022.20500 was 0.02ms
12:09:19 Assembly registration time for plug-in Chip.AD9689, Version 1.2020.33400 was 21.933ms
12:09:19 Loaded Extensions - Plug-in Chip.AD9689, Version 1.2020.33400 - 79.86ms
12:09:19 Initialization time for plug-in Support.Lexicon, Version 1.2023.51400 was 175.904ms
12:09:19 Loaded plug-in Support.Lexicon, Version 1.2023.51400 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.Lexicon.1.2023.51400 in 176.316ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9142, Version 1.23.197 was 0.02ms
12:09:19 Initialization time for plug-in Chip.AD9689, Version 1.2020.33400 was 136.035ms
12:09:19 Loaded plug-in Chip.AD9689, Version 1.2020.33400 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9689.1.2020.33400 in 136.3ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9172, Version 1.23.197 was 0.012ms
12:09:19 Assembly registration time for plug-in Board.AD9208, Version 1.2022.20500 was 30.333ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9142, Version 1.23.197 was 31.539ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9142, Version 1.23.197 - 32.686ms
12:09:19 Loaded Extensions - Plug-in Board.AD9208, Version 1.2022.20500 - 33.912ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9142, Version 1.23.197 was 98.059ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9142, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9142.1.23.197 in 99.325ms
12:09:19 Initialization time for plug-in Board.AD9208, Version 1.2022.20500 was 102.85ms
12:09:19 Loaded plug-in Board.AD9208, Version 1.2022.20500 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD9208.1.2022.20500 in 103.712ms
12:09:19 Lookup time for plug-in Board.AD9162, Version 1.2020.47400 was 0.013ms
12:09:19 Lookup time for plug-in Hardware.LinduinoSupport, Version 1.2023.27300 was 0.017ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9172, Version 1.23.197 was 28.087ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9172, Version 1.23.197 - 53.928ms
12:09:19 Assembly registration time for plug-in Board.AD9172, Version 1.2020.8500 was 35.915ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9172, Version 1.23.197 was 108.337ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9172, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9172.1.23.197 in 108.693ms
12:09:19 Dependency Hardware.SdpSupport loaded in 2.169ms
12:09:19 Loaded Extensions - Plug-in Board.AD9172, Version 1.2020.8500 - 231.276ms
12:09:19 Initialization time for plug-in Board.AD9172, Version 1.2020.8500 was 316.348ms
12:09:19 Loaded plug-in Board.AD9172, Version 1.2020.8500 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD9172.1.2020.8500 in 316.774ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.Generic, Version 1.23.197 was 0.021ms
12:09:19 Assembly registration time for plug-in Hardware.LinduinoSupport, Version 1.2023.27300 was 33.233ms
12:09:19 Assembly registration time for plug-in Chip.AD738X, Version 1.2023.36500 was 90.869ms
12:09:19 Loaded Extensions - Plug-in Chip.AD738X, Version 1.2023.36500 - 317.617ms
12:09:19 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.Generic, Version 1.23.197 was 85.08ms
12:09:19 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.Generic, Version 1.23.197 - 86.507ms
12:09:19 Initialization time for plug-in Chip.AD738X, Version 1.2023.36500 was 371.824ms
12:09:19 Loaded plug-in Chip.AD738X, Version 1.2023.36500 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD738X.1.2023.36500 in 372.58ms
12:09:19 Lookup time for plug-in Board.AD9695, Version 1.2023.48400 was 0.016ms
12:09:19 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.Generic, Version 1.23.197 was 111.795ms
12:09:19 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.Generic, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.Generic.1.23.197 in 112.314ms
12:09:19 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9986, Version 1.23.197 was 0.023ms
12:09:20 Loaded Extensions - Plug-in Hardware.LinduinoSupport, Version 1.2023.27300 - 192.119ms
12:09:20 Initialization time for plug-in Hardware.LinduinoSupport, Version 1.2023.27300 was 242.011ms
12:09:20 Loaded plug-in Hardware.LinduinoSupport, Version 1.2023.27300 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.LinduinoSupport.1.2023.27300 in 243.696ms
12:09:20 Lookup time for plug-in Chip.GenericFpga, Version 1.2021.46402 was 0.015ms
12:09:20 Assembly registration time for plug-in Board.AD9162, Version 1.2020.47400 was 29.09ms
12:09:20 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9986, Version 1.23.197 was 61.478ms
12:09:20 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9986, Version 1.23.197 - 62.107ms
12:09:20 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9986, Version 1.23.197 was 86.096ms
12:09:20 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9986, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9986.1.23.197 in 86.558ms
12:09:20 Assembly registration time for plug-in Board.AD9695, Version 1.2023.48400 was 37.421ms
12:09:20 Dependency Hardware.SdpSupport loaded in 2.013ms
12:09:20 Loaded Extensions - Plug-in Board.AD9695, Version 1.2023.48400 - 57.126ms
12:09:20 Initialization time for plug-in Board.AD9695, Version 1.2023.48400 was 105.636ms
12:09:20 Loaded plug-in Board.AD9695, Version 1.2023.48400 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD9695.1.2023.48400 in 106.68ms
12:09:20 Lookup time for plug-in Board.AD9689, Version 1.2020.6400 was 0.019ms
12:09:20 Loaded Extensions - Plug-in Board.AD9162, Version 1.2020.47400 - 203.115ms
12:09:20 Initialization time for plug-in Board.AD9162, Version 1.2020.47400 was 278.854ms
12:09:20 Loaded plug-in Board.AD9162, Version 1.2020.47400 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD9162.1.2020.47400 in 279.295ms
12:09:20 Lookup time for plug-in Board.ADF4372, Version 1.2020.5500 was 0.02ms
12:09:20 Assembly registration time for plug-in Chip.GenericFpga, Version 1.2021.46402 was 27.515ms
12:09:20 Loaded Extensions - Plug-in Chip.GenericFpga, Version 1.2021.46402 - 28.383ms
12:09:20 Initialization time for plug-in Chip.GenericFpga, Version 1.2021.46402 was 52.798ms
12:09:20 Loaded plug-in Chip.GenericFpga, Version 1.2021.46402 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.GenericFpga.1.2021.46402 in 53.2ms
12:09:20 Lookup time for plug-in Chip.Generic, Version 1.2021.28300 was 0.023ms
12:09:20 Assembly registration time for plug-in Chip.Generic, Version 1.2021.28300 was 32.022ms
12:09:20 Loaded Extensions - Plug-in Chip.Generic, Version 1.2021.28300 - 32.764ms
12:09:20 Initialization time for plug-in Chip.Generic, Version 1.2021.28300 was 56.932ms
12:09:20 Loaded plug-in Chip.Generic, Version 1.2021.28300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.Generic.1.2021.28300 in 57.359ms
12:09:20 Lookup time for plug-in Board.CsaControllers, Version 1.2023.43100 was 0.018ms
12:09:20 Assembly registration time for plug-in Board.ADF4372, Version 1.2020.5500 was 31.791ms
12:09:20 Assembly registration time for plug-in Board.AD9689, Version 1.2020.6400 was 26.391ms
12:09:20 Loaded Extensions - Plug-in Board.ADF4372, Version 1.2020.5500 - 38.097ms
12:09:20 Loaded Extensions - Plug-in Board.AD9689, Version 1.2020.6400 - 37.519ms
12:09:20 Initialization time for plug-in Board.ADF4372, Version 1.2020.5500 was 83.181ms
12:09:20 Loaded plug-in Board.ADF4372, Version 1.2020.5500 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADF4372.1.2020.5500 in 83.616ms
12:09:20 Lookup time for plug-in Board.LegacyQevModules, Version 1.2021.28300 was 0.022ms
12:09:20 Initialization time for plug-in Board.AD9689, Version 1.2020.6400 was 90.653ms
12:09:20 Loaded plug-in Board.AD9689, Version 1.2020.6400 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD9689.1.2020.6400 in 91.088ms
12:09:20 Dependency Hardware.SdpSupport loaded in 2.096ms
12:09:20 Assembly registration time for plug-in Board.CsaControllers, Version 1.2023.43100 was 29.169ms
12:09:20 Loaded Extensions - Plug-in Board.CsaControllers, Version 1.2023.43100 - 48.463ms
12:09:20 Initialization time for plug-in Board.CsaControllers, Version 1.2023.43100 was 78.397ms
12:09:20 Loaded plug-in Board.CsaControllers, Version 1.2023.43100 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.CsaControllers.1.2023.43100 in 78.794ms
12:09:20 Lookup time for plug-in Board.Linduino, Version 1.2021.29300 was 0.017ms
12:09:20 Assembly registration time for plug-in Board.LegacyQevModules, Version 1.2021.28300 was 27.892ms
12:09:20 Loaded Extensions - Plug-in Board.LegacyQevModules, Version 1.2021.28300 - 28.938ms
12:09:20 Initialization time for plug-in Board.LegacyQevModules, Version 1.2021.28300 was 86.433ms
12:09:20 Loaded plug-in Board.LegacyQevModules, Version 1.2021.28300 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.LegacyQevModules.1.2021.28300 in 86.886ms
12:09:20 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9739A, Version 1.23.197 was 0.017ms
12:09:20 Assembly registration time for plug-in Board.Linduino, Version 1.2021.29300 was 25.695ms
12:09:20 Loaded Extensions - Plug-in Board.Linduino, Version 1.2021.29300 - 33.902ms
12:09:20 Initialization time for plug-in Board.Linduino, Version 1.2021.29300 was 57.295ms
12:09:20 Loaded plug-in Board.Linduino, Version 1.2021.29300 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.Linduino.1.2021.29300 in 57.752ms
12:09:20 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9739A, Version 1.23.197 was 29.804ms
12:09:20 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9739A, Version 1.23.197 - 30.42ms
12:09:20 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9739A, Version 1.23.197 was 53.184ms
12:09:20 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9739A, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9739A.1.23.197 in 53.581ms
12:09:20 Lookup time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9146, Version 1.23.197 was 0.025ms
12:09:20 Assembly registration time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9146, Version 1.23.197 was 45.654ms
12:09:20 Loaded Extensions - Plug-in Support.AnalogDevices.DPG.EvalBoard.AD9146, Version 1.23.197 - 46.434ms
12:09:20 Initialization time for plug-in Support.AnalogDevices.DPG.EvalBoard.AD9146, Version 1.23.197 was 70.43ms
12:09:20 Loaded plug-in Support.AnalogDevices.DPG.EvalBoard.AD9146, Version 1.23.197 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.AnalogDevices.DPG.EvalBoard.AD9146.1.23.197 in 70.845ms
12:09:20 Finished caching XML from C:\ProgramData\Analog Devices\ACE\Plugins in 4207.122ms
12:09:20 Loaded Extensions - Plug-in Support.BlockGallery, Version 1.2024.23300 - 1126.913ms
12:09:20 Initialization time for plug-in Support.BlockGallery, Version 1.2024.23300 was 1148.653ms
12:09:20 Loaded plug-in Support.BlockGallery, Version 1.2024.23300 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.BlockGallery.1.2024.23300 in 1149.088ms
12:09:20 Lookup time for plug-in Board.AD35X2R, Version 1.2022.18200 was 0.016ms
12:09:20 Assembly registration time for plug-in Board.AD35X2R, Version 1.2022.18200 was 12.599ms
12:09:20 Loaded Extensions - Plug-in Board.AD35X2R, Version 1.2022.18200 - 27.637ms
12:09:20 Initialization time for plug-in Board.AD35X2R, Version 1.2022.18200 was 39.091ms
12:09:20 Loaded plug-in Board.AD35X2R, Version 1.2022.18200 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD35X2R.1.2022.18200 in 39.371ms
12:09:20 Lookup time for plug-in Board.AD738X, Version 1.2023.36500 was 0.009ms
12:09:20 Assembly registration time for plug-in Board.AD738X, Version 1.2023.36500 was 16.785ms
12:09:20 Loaded Extensions - Plug-in Board.AD738X, Version 1.2023.36500 - 93.765ms
12:09:20 Initialization time for plug-in Board.AD738X, Version 1.2023.36500 was 104.385ms
12:09:20 Loaded plug-in Board.AD738X, Version 1.2023.36500 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD738X.1.2023.36500 in 104.648ms
12:09:23 Loaded Extensions - Plug-in Hardware.SdpSupport, Version 1.2024.11300 - 3987.595ms
12:09:23 Initialization time for plug-in Hardware.SdpSupport, Version 1.2024.11300 was 4009.573ms
12:09:23 Loaded plug-in Hardware.SdpSupport, Version 1.2024.11300 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.SdpSupport.1.2024.11300 in 4009.95ms
12:09:23 Time to check signing for plugins 403.065ms
12:09:23 Finished loading plugins from C:\ProgramData\Analog Devices\ACE\Plugins in 7555.368ms
12:09:24 Starting IIO Controller search
12:09:24 No tinyiiod compatible devices found
12:09:25 Hardware.COMSupport.SerialControllerFinder Found components:
Hardware.COMSupport.ControllerBoards.GenericSerialControllerBoard VID_0000&PID_FFFF
Hardware.COMSupport.ControllerBoards.KCU105ControllerBoard VID_10C4&PID_EA70
12:09:25 Hardware.COMSupport.SerialControllerFinder: Searching for supported controllers...
12:09:25 Details.txt file not found for drive C:\!
12:09:26 Thread #28, ran Hardware.IIOSupport.FindContextUris -
12:09:26 Hardware.COMSupport.SerialControllerFinder: No Controllers Found.
12:09:28 Attempted to load dll C:\ProgramData\Analog Devices\ACE\Plugins\Support.NationalInstruments.MeasurementStudio.15.0.197\build\x64\LV150000_BLASLAPACK.dll failed, this may not be a .NET dll\n Could not load file or assembly 'LV150000_BLASLAPACK.dll' or one of its dependencies. The module was expected to contain an assembly manifest.\n at System.Reflection.AssemblyName.nGetFileInformation(String s)
at System.Reflection.AssemblyName.GetAssemblyName(String assemblyFile)
at AnalogDevices.DPG.PluginFinder.AssemblyReference..ctor(String path)
at AnalogDevices.DPG.PluginFinder.PluginFinderBase.RegisterAssemblies(IEnumerable`1 paths)
12:09:28 Attempted to load dll C:\ProgramData\Analog Devices\ACE\Plugins\Support.NationalInstruments.MeasurementStudio.15.0.197\build\x64\nianlys.dll failed, this may not be a .NET dll\n Could not load file or assembly 'nianlys.dll' or one of its dependencies. The module was expected to contain an assembly manifest.\n at System.Reflection.AssemblyName.nGetFileInformation(String s)
12:09:28 Attempted to load dll C:\ProgramData\Analog Devices\ACE\Plugins\Support.NationalInstruments.MeasurementStudio.15.0.197\build\x86\LV150000_BLASLAPACK.dll failed, this may not be a .NET dll\n Could not load file or assembly 'LV150000_BLASLAPACK.dll' or one of its dependencies. The module was expected to contain an assembly manifest.\n at System.Reflection.AssemblyName.nGetFileInformation(String s)
12:09:28 Attempted to load dll C:\ProgramData\Analog Devices\ACE\Plugins\Support.NationalInstruments.MeasurementStudio.15.0.197\build\x86\nianlys.dll failed, this may not be a .NET dll\n Could not load file or assembly 'nianlys.dll' or one of its dependencies. The module was expected to contain an assembly manifest.\n at System.Reflection.AssemblyName.nGetFileInformation(String s)
12:09:32 Thread #1, ran Sessions.CreateNewSession - SkipOnExisting = False
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference b0b1069737a1f58c078cbd535cee7f4a4d6dd136
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference b74403bc483ac9914d2fa8a28af743e0456e68dd
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference dce246016bdc8f6026df1cbd0835a618a8c3a24e
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference e62ca3ba319d5c4b790fd99abb03f3dd73711879
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference b2fa58e39c5ea2bb0fe7978fea115712d29aa58c
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 4beba120eb2770b0b3e48a09b17d0b3c44557391
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 43ba0fc9851f236eb937bb34d2b8cd94f608236f
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 963ae8e7ca8768aa915efbc1bf324ed79de1cac0
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference e9c94349c810bb295fabbf3c52c0f30efd4bd851
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 9600492cbf3648b7302b8827c653cc411275ae91
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 347813d37cfb4c28d0a64b93821873a8b40308bc
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 6c9cae461441484a5d30cfaf4d60428183c1c79c
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 38510abfa45bc6495dd954dbfe864d2de3f1decc
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference df2f95a7be30391199bf5ca1b70ed7ce066d740a
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 265084db9e72daef99ee56ebc351654dbb241a00
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference c9014054bc0e89997683ef7ce7706ff4f281c5ef
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference beb20f92d214bf4d930791ac53e1eeff667c37d9
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference b49ceb3b9b839db80e49b44add72c46d5ce27774
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 1e76c978f19e0f4dc8da47b42b6116e8d94216b3
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 18c3dfb61f009b9d14c87f2b6b14e7bb23e79506
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference ac1917746588de2c160c96227e1e28b78908faf6
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 6ebbc7efcac889068350992eaed2d642b95e4876
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 8db487acf36faaba87b8dd4f854a15d3c556067a
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference ca73f8246a97fd556e9d192b609fbcf450e386db
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference e5f8f52a4768a194eb99748565cc8ce4aa90bab4
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference c28c4855f8409e3a75cc32ffd5c9d9162d7ed57a
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference d6a9bef3c374cd78f9661b7919dd7580e29cf600
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference a8e9a245696b1f8a66d650675955bd830895abee
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 25d04e234e7cc6b7a2acf68eec7793976b8a8f45
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 73240e5766ead096a40a69915343da5a027b0e54
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 616dff229961063fe99658b8e93dd9c68ac3351d
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference d883e3eda2de07f582e32026a675e524c037c4f6
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference f13d9b261ce14f80ed8aad94e2674659765e943c
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference c8fab7509c7622b8b558483756578e892f524e67
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 37cfdfd4fef916c9957aba587f47d9f3b6da7528
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference eabecadb5d600ab1982235c051284e1fd8ff3d45
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference dfa8ad41d7883e58b9275c5b1936041ef3946eca
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 529f41a0b2d06f32df7852cb9fad9e941da66a56
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference ea3004a70195d181d195cd40cf7422f882ebe4fd
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference b36cb4a2fa4edc413b22a3166ee1dd1a47010068
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference d35d9622581e666c766c18cebb0548252bfb288e
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference bb3310e5a3a54ade66c01252a61ad020dff6ccdf
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 4df03f00d38089e7a12c3f760cd1e980958ff60c
12:09:32 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 3bbbe403de133d212392ebe64d5d5451447834f2
12:09:32 Plug-in Board.AD35X2R Validation Warning: Yoda File='SDP_h1_v2_regs_2p15.space' BitField["minor_revision"]: DefaultValue error: The value could not be parsed.
12:09:32 Plug-in Board.AD35X2R Validation Warning: Yoda File='SDP_h1_v2_regs_2p15.space' BitField["spim_hw_reserved"]: DefaultValue error: The value could not be parsed.
12:09:32 Plug-in Board.AD35X2R Validation Warning: Yoda File='SDP_h1_v2_regs_2p15.space' BitField["fmc_in_p"]: DefaultValue error: The value could not be parsed.
12:09:32 Yoda parsing exception: System.ArgumentException: DefaultValue error: The value could not be parsed. ---> System.FormatException: The value could not be parsed.
at System.Numerics.BigNumber.ParseBigInteger(String value, NumberStyles style, NumberFormatInfo info)
at AnalogDevices.Csa.Numerics.IntegralTypeHelperExtensions.BigIntegerTypeHelper.StringToBigInteger(String s, Int32 i)
at AnalogDevices.Csa.Numerics.StringParsingExtensions.ParseFromBase[T](String numericString, Int32 numericBase)
at AnalogDevices.Csa.Evaluation.MemoryMap.Yoda.YodaValueConverter.ConvertUnsignedYodaValueToBigInteger(String yodaValue, String fieldName)
at AnalogDevices.Csa.Evaluation.MemoryMap.Yoda.YodaRangeBitfieldFactory.CreatePagedBitField(ModuleMemoryMapBitField bitField, PageGroup pageGroup)
at AnalogDevices.Csa.Evaluation.MemoryMap.Yoda.YodaMemoryMapFactorySupport.CreateBitFieldsAction(IEnumerable`1 xrefs)
12:09:32 Plug-in Board.AD35X2R Validation Warning: Yoda File='SDP_h1_v2_regs_2p15.space' BitField["major_revision"]: DefaultValue error: The value could not be parsed.
12:09:32 Plug-in Board.AD35X2R Validation Warning: Yoda File='SDP_h1_v2_regs_2p15.space' BitField["fmc_in_n"]: DefaultValue error: The value could not be parsed.
12:09:32 The Yoda default value for register address 2 is not specified and is substituted with '0'
12:09:32 The Yoda default value for register address 512 is not specified and is substituted with '0'
12:09:32 The Yoda default value for register address 540 is not specified and is substituted with '0'
12:09:32 The Yoda default value for register address 542 is not specified and is substituted with '0'
12:09:32 The Yoda default value for register address 16400 is not specified and is substituted with '0'
12:09:32 The Yoda default value for register address 16402 is not specified and is substituted with '0'
12:09:32 The Yoda default value for register address 16404 is not specified and is substituted with '0'
12:09:32 The Yoda default value for register address 16408 is not specified and is substituted with '0'
12:09:32 The Yoda default value for register address 16410 is not specified and is substituted with '0'
12:09:32 The Yoda default value for register address 16412 is not specified and is substituted with '0'
12:09:32 Error parsing YODA file BuildDate. Consider rebuilding .space file to ensure it was generated correctly.
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference c8b1b1b2f41029fadf03dd1a756769d5c65e2467
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 52b106298d784a1850e0900f73008fb436004c1a
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 60f9658f1839103e895698c16cdc0a774e5f088b
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 1368e09d08e8df7f9add73938d26ec160249d3e6
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 5e49b317c459b2a03b84893a428ceea7d036080a
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 9f49c9332c2f5cd665a3889966173a2531438e3b
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 3f00f4cd510b749d8e410ea315c668fad9c464fb
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 1c4e5684ccab4fb0e29608bea9661c0f27e433a7
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 2f04b1804961f488ed82e3773eb383736f7b36f4
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 208531a1b6e544a068ea5059d3a47054e42e1c4e
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference d6c215d2d26bf8caed5920b7d84142fa1ec96af4
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference e9f05f5bfe8f80c6d39d208140c7c97012e21c5a
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 0443b529a1f911e34239cf741fb77a95055473bc
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 8d42796f4daa4d6cd5e3f03fb2483a7d022c0d71
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 011155e37c6426db0175116f885c385f93102d41
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference efc5db4d2f5fa8e9f3347dbabd2f9489593b9919
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 6db2d7fe8f59d9c7c7e593d3e065008c97d51284
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 4a875ca1613fe84ab8ec5813736f213ea0491042
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference e78811545ead812b7eb964abe2a218463bafd6a0
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 3bc74d1267130f7c1457f3b8c49eb4014f4c081b
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference c2749452a1a66ac1711c984d2c83d91951fa48d7
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference db040ff4e3c83b7fc5293e4584713dd7ab06b593
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 64ff48f65c3bb138764cc3403d1e80a708eb83d8
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 3aada1d7fcfec366e1d3a052f3b6d3716524c402
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 8b3fd930002edbcddcc74a483c867151b6ea294b
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference b64f3232bc860ad81bd85a0b6de7de0d0ea17fad
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference c28846f26c73d0df056d72e3665544eefcba2604
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 4a6dac72b1da13913fdcb0ac4ca6d26f304bc98a
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 47e09c0afd6a7e7f72a252f0fe2b1c189722c8e7
12:09:32 Chip.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 099b116056925dbae8fd02df619f98ef671467a0
12:09:33 Error parsing YODA file BuildDate. Consider rebuilding .space file to ensure it was generated correctly.
12:09:34 Error invoking transaction Evaluation.Control.SetStringEnumParameter on Thread 1:
Context: Root::VectorGenerator.DefaultSingleTone
Arguments: ParameterId = "vector-parameter-Amplitude Control", EnumValue = , PageIndex = -1
Level: 1
System.InvalidOperationException: EnumValue is required
at AnalogDevices.Csa.Evaluation.Control.SetEnumParameterTransaction`1.DoInvoke()
at AnalogDevices.Csa.Transactions.Transaction.TryInvoke()
12:09:34 Error invoking transaction VectorGenerator.AddVector on Thread 1:
Context: None
Arguments: VectorExtensionId = "Common.SingleToneVector", VectorName = "DefaultSingleTone"
Level: 1
System.ArgumentException: The given node's name is already used in the Children collection.
Parameter name: node
at AnalogDevices.Csa.Objects.ObjectNode`2.AddChild(TChildNode node, String prefix)
at AnalogDevices.Csa.VectorGenerator.VectorGeneratorSubSystem.AddVector(IVectorBuilder vector)
at AnalogDevices.Csa.VectorGenerator.VectorGeneratorSubSystem.LoadOverridenVectorBuilder(String vectorTypeId, String vectorName, StringKeyDictionary`1 vectorOverrideParameters, XElement savedState)
at AnalogDevices.Csa.VectorGenerator.VectorGeneratorSubSystem.LoadVectorBuilder(String vectorTypeId, String vectorName, XElement savedState)
at AnalogDevices.Csa.VectorGenerator.Transactions.AddVectorTransaction.DoInvoke()
Level: 1
12:09:34 Thread #1, ran Hardware.UI.AddAttachedHardware - EvalBoards = ("AD3542RBoard")
12:09:34 Thread #1, ran UI.NavigateToPath - Path = "Root::System"
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference b0b1069737a1f58c078cbd535cee7f4a4d6dd136
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference b74403bc483ac9914d2fa8a28af743e0456e68dd
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference dce246016bdc8f6026df1cbd0835a618a8c3a24e
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference e62ca3ba319d5c4b790fd99abb03f3dd73711879
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference b2fa58e39c5ea2bb0fe7978fea115712d29aa58c
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 4beba120eb2770b0b3e48a09b17d0b3c44557391
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 43ba0fc9851f236eb937bb34d2b8cd94f608236f
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 963ae8e7ca8768aa915efbc1bf324ed79de1cac0
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference e9c94349c810bb295fabbf3c52c0f30efd4bd851
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 9600492cbf3648b7302b8827c653cc411275ae91
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 347813d37cfb4c28d0a64b93821873a8b40308bc
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 6c9cae461441484a5d30cfaf4d60428183c1c79c
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 38510abfa45bc6495dd954dbfe864d2de3f1decc
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference df2f95a7be30391199bf5ca1b70ed7ce066d740a
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 265084db9e72daef99ee56ebc351654dbb241a00
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference c9014054bc0e89997683ef7ce7706ff4f281c5ef
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference beb20f92d214bf4d930791ac53e1eeff667c37d9
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference b49ceb3b9b839db80e49b44add72c46d5ce27774
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 1e76c978f19e0f4dc8da47b42b6116e8d94216b3
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 18c3dfb61f009b9d14c87f2b6b14e7bb23e79506
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference ac1917746588de2c160c96227e1e28b78908faf6
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 6ebbc7efcac889068350992eaed2d642b95e4876
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 8db487acf36faaba87b8dd4f854a15d3c556067a
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference ca73f8246a97fd556e9d192b609fbcf450e386db
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference e5f8f52a4768a194eb99748565cc8ce4aa90bab4
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference c28c4855f8409e3a75cc32ffd5c9d9162d7ed57a
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference d6a9bef3c374cd78f9661b7919dd7580e29cf600
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference a8e9a245696b1f8a66d650675955bd830895abee
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 25d04e234e7cc6b7a2acf68eec7793976b8a8f45
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 73240e5766ead096a40a69915343da5a027b0e54
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 616dff229961063fe99658b8e93dd9c68ac3351d
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference d883e3eda2de07f582e32026a675e524c037c4f6
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference f13d9b261ce14f80ed8aad94e2674659765e943c
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference c8fab7509c7622b8b558483756578e892f524e67
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 37cfdfd4fef916c9957aba587f47d9f3b6da7528
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference eabecadb5d600ab1982235c051284e1fd8ff3d45
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference dfa8ad41d7883e58b9275c5b1936041ef3946eca
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 529f41a0b2d06f32df7852cb9fad9e941da66a56
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference ea3004a70195d181d195cd40cf7422f882ebe4fd
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference b36cb4a2fa4edc413b22a3166ee1dd1a47010068
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference d35d9622581e666c766c18cebb0548252bfb288e
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference bb3310e5a3a54ade66c01252a61ad020dff6ccdf
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 4df03f00d38089e7a12c3f760cd1e980958ff60c
12:09:37 Board.AD35X2R yoda factory: Ignoring bad Yoda register bitfield reference 3bbbe403de133d212392ebe64d5d5451447834f2
12:09:37 Plug-in Board.AD35X2R Validation Warning: Yoda File='SDP_h1_v2_regs_2p15.space' BitField["minor_revision"]: DefaultValue error: The value could not be parsed.
12:09:37 Plug-in Board.AD35X2R Validation Warning: Yoda File='SDP_h1_v2_regs_2p15.space' BitField["spim_hw_reserved"]: DefaultValue error: The value could not be parsed.
12:09:37 Yoda parsing exception: System.ArgumentException: DefaultValue error: The value could not be parsed. ---> System.FormatException: The value could not be parsed.
--- End of inner exception stack trace ---
12:09:37 Plug-in Board.AD35X2R Validation Warning: Yoda File='SDP_h1_v2_regs_2p15.space' BitField["fmc_in_p"]: DefaultValue error: The value could not be parsed.
12:09:37 Plug-in Board.AD35X2R Validation Warning: Yoda File='SDP_h1_v2_regs_2p15.space' BitField["major_revision"]: DefaultValue error: The value could not be parsed.
12:09:37 Plug-in Board.AD35X2R Validation Warning: Yoda File='SDP_h1_v2_regs_2p15.space' BitField["fmc_in_n"]: DefaultValue error: The value could not be parsed.
12:09:37 The Yoda default value for register address 2 is not specified and is substituted with '0'
12:09:37 The Yoda default value for register address 512 is not specified and is substituted with '0'
12:09:37 The Yoda default value for register address 540 is not specified and is substituted with '0'
12:09:37 The Yoda default value for register address 542 is not specified and is substituted with '0'
12:09:37 The Yoda default value for register address 16400 is not specified and is substituted with '0'
12:09:37 The Yoda default value for register address 16402 is not specified and is substituted with '0'
12:09:37 The Yoda default value for register address 16404 is not specified and is substituted with '0'
12:09:37 The Yoda default value for register address 16408 is not specified and is substituted with '0'
12:09:37 The Yoda default value for register address 16410 is not specified and is substituted with '0'
12:09:37 The Yoda default value for register address 16412 is not specified and is substituted with '0'
12:09:37 Error parsing YODA file BuildDate. Consider rebuilding .space file to ensure it was generated correctly.
12:09:39 Thread #1, ran @DefaultView -
12:09:40 Thread #1, ran @CheckState -
12:09:41 Thread #1, ran @CheckState -
12:09:42 Thread #1, ran @CheckState -
12:09:43 Thread #1, ran @CheckState -
12:09:44 Thread #1, ran @CheckState -
12:09:45 Thread #1, ran @CheckState -
12:09:46 Thread #1, ran @CheckState -
12:09:46 Thread #1, ran UI.NavigateToPath - Path = "Root::System.Subsystem_1.AD3542RFMCZ Board.AD3542R"
12:09:47 Thread #1, ran @CheckState -
12:09:48 Thread #1, ran @CheckState -
12:09:48 Thread #1, ran UI.NavigateToRelativePath - Path = "AD3542R Memory Map"
12:09:50 Thread #1, ran @CheckState -
12:09:51 Thread #1, ran @CheckState -
12:09:52 Thread #1, ran @CheckState -
12:10:09 import time: 1991
12:10:09 Thread #1, ran Evaluation.Control.ImportRegisters - CsvPath = "C:\Users\mahalakshmi_c\Downloads\AD3542R_Allch0.csv"
12:10:10 Thread #1, ran @CheckState -
12:10:11 Thread #1, ran @ApplySettings -
12:10:11 Thread #1, ran @CheckState -
12:10:12 Thread #1, ran @CheckState -
12:10:13 Thread #1, ran @CheckState -
12:10:14 Thread #1, ran @ReadSettings -
12:10:14 Thread #1, ran @CheckState -
12:10:15 Thread #1, ran @CheckState -
12:10:16 Thread #1, ran @CheckState -
12:10:17 Thread #1, ran UI.SelectTab - ViewId = "Root::System.Subsystem_1.AD3542RFMCZ Board.AD3542R"
12:10:17 Thread #1, ran @CheckState -
12:10:18 Thread #1, ran @CheckState -
12:10:19 Thread #1, ran @CheckState -
12:10:20 Thread #1, ran @CheckState -
12:10:21 Thread #1, ran @CheckState -
12:10:22 Thread #1, ran @CheckState -
12:10:22 Thread #1, ran UI.SelectTab - ViewId = "Root::System.Subsystem_1.AD3542RFMCZ Board"
12:10:23 Thread #1, ran @CheckState -
12:10:24 Thread #1, ran @CheckState -
12:10:25 Thread #1, ran UI.SelectTab - ViewId = "Root::System.Subsystem_1.AD3542RFMCZ Board.AD3542R.AD3542R Memory Map"
12:10:25 Thread #1, ran @CheckState -
12:10:26 Thread #1, ran @CheckState -
12:10:26 Thread #1, ran UI.SelectTab - ViewId = "Root::System.Subsystem_1.AD3542RFMCZ Board.AD3542R"
12:10:27 Thread #1, ran @CheckState -
12:10:28 Thread #1, ran @CheckState -
12:10:29 Thread #1, ran @CheckState -
12:10:30 Thread #1, ran @CheckState -
12:10:31 Thread #1, ran @CheckState -
12:10:32 Thread #1, ran @CheckState -
12:10:33 Thread #1, ran @CheckState -
12:10:36 **VisualXcceleratorEngine. Setting IsEnabled flag
12:10:37 Visual Xccelerator Engine v6.4.0.13629
12:10:37 ### GPU Capability Test ###
Is BGRA feature required: TRUE
Examining Graphics Adapter: AMD Radeon(TM) Vega 8 Graphics
VRAM: 2033Mb
DeviceId: 5592
Visual Xccelerator Engine Direct3D9 Compatibility
Determines whether the adapter is blacklisted due to its unstable work... FALSE
Trying to create Direct3D9 Device... SUCCESS
Visual Xccelerator Engine Direct3D11 Compatibility
Trying to create Direct3D9Ex Device (WPF Compatibility)... SUCCESS
Trying to create Direct3D11 Device... SUCCESS
Rank: 2002033 Points
Selected Graphics Adapter, where DeviceId is: 5592
Is Direct3D9 Supported: TRUE
Is Direct3D11 Supported: TRUE
Is Blacklisted: FALSE
12:10:37 **VisualXcceleratorEngine: Setting the flags to enable VisualXcceleratorRenderSurface
12:10:37 VisualXcceleratorRenderSurface: attempt to initialize the engine with parameters:
12:10:37 Use Direct3D9 - False
12:10:37 **VisualXcceleratorEngine: SUCCESS!
12:10:37 **VisualXcceleratorEngine. Setting IsEnabled flag
12:10:37 Thread #1, ran UI.NavigateToPath - Path = "Root::VectorGenerator"
12:10:41 Thread #1, ran VectorGenerator.RemoveVector - VectorName = "DefaultSingleTone"
12:10:47 Thread #1, ran VectorGenerator.AddVector - VectorExtensionId = "Common.SquareVector", VectorName =
12:11:00 Thread #1, ran Evaluation.Control.SetDoubleParameter - ParameterId = "vector-parameter-Desired Frequency", Data = 1000000, PageIndex = -1
12:11:05 Thread #1, ran UI.SelectTab - ViewId = "Root::System.Subsystem_1.AD3542RFMCZ Board"
12:11:07 Thread #1, ran @CheckState -
12:11:08 Thread #1, ran @CheckState -
12:11:09 Thread #1, ran @CheckState -
12:11:10 Thread #1, ran @CheckState -
12:11:12 Thread #1, ran @CheckState -
12:11:13 Thread #1, ran @CheckState -
12:11:14 Thread #1, ran @CheckState -
12:11:16 Thread #1, ran @CheckState -
12:11:17 Thread #1, ran @CheckState -
12:11:18 Thread #1, ran @CheckState -
12:11:19 Thread #1, ran @CheckState -
12:11:20 Thread #1, ran @CheckState -
12:11:21 Thread #1, ran @CheckState -
12:11:22 Thread #1, ran @CheckState -
12:11:23 Thread #1, ran @CheckState -
12:11:24 Thread #1, ran @CheckState -
12:11:25 Thread #1, ran @CheckState -
12:11:26 Thread #1, ran @CheckState -
12:11:27 Thread #1, ran @CheckState -
12:11:28 Thread #1, ran @CheckState -
12:11:29 Thread #1, ran @CheckState -
12:11:30 Thread #1, ran @CheckState -
Hi MOHANCS ,
Thank you for sending on your log file,
I'm seeing some things related to Support plug-ins that may be the cause of the issue you are seeing.
The following snippet from your log seems to point to an issue with your Support.AnalogDevices.VectorGenerator packages. It looks like there may be two versions of one of the packages installed, one of them is quite outdated, which is causing a deadlock in ACE as it does not know which version should be loaded, and this may be the cause of your issue.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.Vector.Generator.WIFR 1.23.197.
12:09:15 InstalledPackageSourceReader found plug-in for Support.AnalogDevices.Vector.Generator.WIFR 1.23.197 in 2.955ms.
12:09:15 InstalledPackageSourceReader is finding plug-in for Support.AnalogDevices.Vector.Generator.WIFR 1.19.187.
12:09:15 InstalledPackageSourceReader has no local package for plug-in Support.AnalogDevices.Vector.Generator.WIFR 1.19.187
To verify this is the cause of the issue, could you please check the folder at C:\ProgramData\Analog Devices\ACE\Plugins and post a screenshot of the contents, specifically the Support packages.
If you see any packages that have multiple versions, try removing them to leave one a single version in the folder (leave the version with a higher number).
If not, I might also recommend a scrub reinstall following the instructions here:https://wiki.analog.com/resources/tools-software/ace/installscrub
This will clear your plug-ins folder completely and ensure that no older versions of any packages remain.
Eoin
