ACE 1.29 X64 not working. It was working okay on ACE1.28
Product Number: Analysis Control Software
Software Version: ACE 1.29
I upgraded from ACE 1.28 to 1.29.  Now the X64 version crashes at the splash screen.  Same issue on two computers. Computers have internet access.
I tried the manual cert install but no luck.
I will attach the x86 and the x68 log file.
Is it possible to get a copy of ACE 1.28 so I can go back to that version?
TNX  Peter Doherty
APPTRACE86.LOG
14:27:31 AceCore is setting environment variables
14:27:31 AceCore is setting required default culture
14:27:31 AceCore is initializing the IOC container
14:27:31 AceCore is adding facilities
14:27:31 AceCore is registering components
14:27:31 Current FFT implementation is AnalogDevices.Csa.Evaluation.Analyzers.CommonFFT.CommonFFTAnalyzer
14:27:32 Configuring package provider.
14:27:32 InstalledPackageSourceReader is looking for installed packages.
14:27:32 PackageProvider is creating the background worker.
14:27:32 PackageProvider is building the list of sources.
14:27:33 AnalogDevices.Csa.App.Wpf.Usage.ACEUsageLoggingProvider is using table name suffix "" for application usage logging
14:27:33 Restoring configuration settings from C:\Users\systems-shared\AppData\Local\Analog Devices\ACE\UserSettings\Configuration.Settings.xml
14:27:33 InstalledPackageSourceReader is finding plug-in for Hardware.ClockSupport 1.2022.28200.
14:27:33 InstalledPackageSourceReader found plug-in for Hardware.ClockSupport 1.2022.28200 in 46.165ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Hardware.DeviceApiSupport 1.2022.28200.
14:27:33 InstalledPackageSourceReader found plug-in for Hardware.DeviceApiSupport 1.2022.28200 in 0.387ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Hardware.HsdacSupport 1.2022.28200.
14:27:33 InstalledPackageSourceReader found plug-in for Hardware.HsdacSupport 1.2022.28200 in 0.256ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Hardware.LinduinoSupport 1.2023.27300.
14:27:33 InstalledPackageSourceReader found plug-in for Hardware.LinduinoSupport 1.2023.27300 in 4.409ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Hardware.IIOSupport 1.2023.42100.
14:27:33 InstalledPackageSourceReader found plug-in for Hardware.IIOSupport 1.2023.42100 in 0.299ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Hardware.UnifiedSpiMaster 1.2022.28400.
14:27:33 InstalledPackageSourceReader found plug-in for Hardware.UnifiedSpiMaster 1.2022.28400 in 0.361ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Hardware.SdpSupport 1.2023.43101.
14:27:33 InstalledPackageSourceReader found plug-in for Hardware.SdpSupport 1.2023.43101 in 0.267ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.Generic 1.2021.28300.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.Generic 1.2021.28300 in 0.243ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.GenericFpga 1.2021.46402.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.GenericFpga 1.2021.46402 in 0.264ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Board.CsaControllers 1.2023.43100.
14:27:33 InstalledPackageSourceReader found plug-in for Board.CsaControllers 1.2023.43100 in 0.255ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Board.Linduino 1.2021.29300.
14:27:33 InstalledPackageSourceReader found plug-in for Board.Linduino 1.2021.29300 in 0.246ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Vector.Common 1.29.3286.
14:27:33 InstalledPackageSourceReader found plug-in for Vector.Common 1.29.3286 in 0.222ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Vector.File 1.29.3286.
14:27:33 InstalledPackageSourceReader found plug-in for Vector.File 1.29.3286 in 0.22ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.AD9164 1.2020.24300.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.AD9164 1.2020.24300 in 0.225ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.AD9508 1.2.0.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.AD9508 1.2.0 in 0.215ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.ADMV8513 1.2023.30500.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.ADMV8513 1.2023.30500 in 0.227ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.AD9161 1.2020.24300.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.AD9161 1.2020.24300 in 0.221ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.ADF4355 1.1.1.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.ADF4355 1.1.1 in 0.224ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.ADF4371 1.2022.24300.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.ADF4371 1.2022.24300 in 0.226ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Board.LegacyQevModules 1.2021.28300.
14:27:33 InstalledPackageSourceReader found plug-in for Board.LegacyQevModules 1.2021.28300 in 0.241ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Board.ADF4371 1.2022.3300.
14:27:33 InstalledPackageSourceReader found plug-in for Board.ADF4371 1.2022.3300 in 0.235ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.AD9162 1.2020.24300.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.AD9162 1.2020.24300 in 0.232ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.ADMV1013 0.1.5.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.ADMV1013 0.1.5 in 0.221ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Board.ADMV8513 1.2023.30500.
14:27:33 InstalledPackageSourceReader found plug-in for Board.ADMV8513 1.2023.30500 in 0.232ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.AD9172 1.2021.32300.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.AD9172 1.2021.32300 in 0.235ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.AD9163 1.2020.24300.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.AD9163 1.2020.24300 in 0.229ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.AD9528 1.1.2.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.AD9528 1.1.2 in 0.215ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.ADA2200 1.10.2.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.ADA2200 1.10.2 in 0.227ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.AD9695 1.2020.33400.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.AD9695 1.2020.33400 in 0.269ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Support.IronPython 1.2023.38300.
14:27:33 InstalledPackageSourceReader found plug-in for Support.IronPython 1.2023.38300 in 0.364ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Board.AD9208 1.2022.20500.
14:27:33 InstalledPackageSourceReader found plug-in for Board.AD9208 1.2022.20500 in 0.387ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.ADMV8505 1.2022.2200.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.ADMV8505 1.2022.2200 in 0.302ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Board.ADIIOController 1.2021.42100.
14:27:33 InstalledPackageSourceReader found plug-in for Board.ADIIOController 1.2021.42100 in 0.241ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Support.Transactions 1.2023.22200.
14:27:33 InstalledPackageSourceReader found plug-in for Support.Transactions 1.2023.22200 in 0.273ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.ADF4372 1.2022.24300.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.ADF4372 1.2022.24300 in 0.323ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Board.ADF4372 1.2020.5500.
14:27:33 InstalledPackageSourceReader found plug-in for Board.ADF4372 1.2020.5500 in 0.277ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.AD9208 1.2022.20500.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.AD9208 1.2022.20500 in 0.229ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.HMC7044 0.1.0.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.HMC7044 0.1.0 in 0.223ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Board.AD9695 1.2019.43402.
14:27:33 InstalledPackageSourceReader found plug-in for Board.AD9695 1.2019.43402 in 0.23ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.ADMV8052 1.2021.6200.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.ADMV8052 1.2021.6200 in 0.233ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.AD9689 1.2020.33400.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.AD9689 1.2020.33400 in 0.228ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Board.ADMV8052 1.2021.6200.
14:27:33 InstalledPackageSourceReader found plug-in for Board.ADMV8052 1.2021.6200 in 0.36ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Board.AD9689 1.2020.6400.
14:27:33 InstalledPackageSourceReader found plug-in for Board.AD9689 1.2020.6400 in 0.362ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Board.ADMV1013 1.2019.9400.
14:27:33 InstalledPackageSourceReader found plug-in for Board.ADMV1013 1.2019.9400 in 0.33ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Board.ADMV8505 1.2022.2200.
14:27:33 InstalledPackageSourceReader found plug-in for Board.ADMV8505 1.2022.2200 in 0.343ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Chip.AD738X 1.2023.36500.
14:27:33 InstalledPackageSourceReader found plug-in for Chip.AD738X 1.2023.36500 in 0.303ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Board.AD9162 1.2020.47400.
14:27:33 InstalledPackageSourceReader found plug-in for Board.AD9162 1.2020.47400 in 0.246ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Board.AD9172 1.2020.8500.
14:27:33 InstalledPackageSourceReader found plug-in for Board.AD9172 1.2020.8500 in 0.244ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Support.BlockGallery 1.2023.29400.
14:27:33 InstalledPackageSourceReader found plug-in for Support.BlockGallery 1.2023.29400 in 0.245ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Board.AD738X 1.2023.36500.
14:27:33 InstalledPackageSourceReader found plug-in for Board.AD738X 1.2023.36500 in 0.239ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Board.ADA2200 1.10.2.
14:27:33 InstalledPackageSourceReader found plug-in for Board.ADA2200 1.10.2 in 0.252ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Support.NationalInstruments.MeasurementStudio 15.0.187.
14:27:33 InstalledPackageSourceReader found plug-in for Support.NationalInstruments.MeasurementStudio 15.0.187 in 0.245ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Support.ScriptRunner 1.2023.19300.
14:27:33 InstalledPackageSourceReader found plug-in for Support.ScriptRunner 1.2023.19300 in 0.232ms.
14:27:33 InstalledPackageSourceReader is finding plug-in for Support.IIO 1.2023.42100.
14:27:33 InstalledPackageSourceReader found plug-in for Support.IIO 1.2023.42100 in 2.843ms.
14:27:33 InstalledPackageSourceReader is finished finding plug-ins for installed packages in 74.214ms
14:27:33 Clearing blocked plug-ins.
14:27:33 Scanning folder "C:\ProgramData\Analog Devices\ACE\Plugins" for plug-ins.
14:27:33 Lookup time for plug-in Hardware.ClockSupport, Version 1.2022.28200 was 0.163ms
14:27:33 Lookup time for plug-in Hardware.SdpSupport, Version 1.2023.43101 was 0.005ms
14:27:33 Lookup time for plug-in Vector.File, Version 1.29.3286 was 0.005ms
14:27:33 Lookup time for plug-in Chip.ADF4371, Version 1.2022.24300 was 0.004ms
14:27:33 Lookup time for plug-in Board.AD9208, Version 1.2022.20500 was 0.006ms
14:27:33 Lookup time for plug-in Chip.AD9172, Version 1.2021.32300 was 0.005ms
14:27:33 Lookup time for plug-in Chip.AD9208, Version 1.2022.20500 was 0.005ms
14:27:33 Dependency Chip.AD9208 loaded in 1.545ms
14:27:33 Assembly registration time for plug-in Vector.File, Version 1.29.3286 was 9.218ms
14:27:33 Assembly registration time for plug-in Hardware.SdpSupport, Version 1.2023.43101 was 12.594ms
14:27:33 Assembly registration time for plug-in Chip.AD9208, Version 1.2022.20500 was 3.015ms
14:27:33 Assembly registration time for plug-in Board.AD9208, Version 1.2022.20500 was 14.012ms
14:27:33 Loaded Extensions - Plug-in Chip.AD9208, Version 1.2022.20500 - 19.435ms
14:27:33 Assembly registration time for plug-in Hardware.ClockSupport, Version 1.2022.28200 was 17.294ms
14:27:33 Initialization time for plug-in Chip.AD9208, Version 1.2022.20500 was 96.818ms
14:27:33 Loaded plug-in Chip.AD9208, Version 1.2022.20500 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9208.1.2022.20500 in 97.014ms
14:27:33 Lookup time for plug-in Chip.HMC7044, Version 0.1.0 was 0.006ms
14:27:33 Assembly registration time for plug-in Chip.ADF4371, Version 1.2022.24300 was 3.646ms
14:27:33 Loaded Extensions - Plug-in Chip.ADF4371, Version 1.2022.24300 - 38.505ms
14:27:33 Initialization time for plug-in Chip.ADF4371, Version 1.2022.24300 was 129.304ms
14:27:33 Loaded plug-in Chip.ADF4371, Version 1.2022.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADF4371.1.2022.24300 in 131.804ms
14:27:33 Lookup time for plug-in Board.LegacyQevModules, Version 1.2021.28300 was 0.007ms
14:27:33 Lookup time for plug-in Hardware.LinduinoSupport, Version 1.2023.27300 was 0.004ms
14:27:33 Assembly registration time for plug-in Chip.HMC7044, Version 0.1.0 was 3.428ms
14:27:33 Loaded Extensions - Plug-in Chip.HMC7044, Version 0.1.0 - 4.071ms
14:27:33 Initialization time for plug-in Chip.HMC7044, Version 0.1.0 was 32.257ms
14:27:33 Loaded plug-in Chip.HMC7044, Version 0.1.0 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.HMC7044.0.1.0 in 32.422ms
14:27:33 Lookup time for plug-in Board.AD9695, Version 1.2019.43402 was 0.005ms
14:27:33 Dependency Hardware.SdpSupport loaded in 0.225ms
14:27:33 Lookup time for plug-in Chip.AD9695, Version 1.2020.33400 was 0.004ms
14:27:33 Assembly registration time for plug-in Hardware.LinduinoSupport, Version 1.2023.27300 was 13.042ms
14:27:33 Loaded Extensions - Plug-in Board.AD9208, Version 1.2022.20500 - 74.714ms
14:27:33 Initialization time for plug-in Board.AD9208, Version 1.2022.20500 was 152.598ms
14:27:33 Loaded plug-in Board.AD9208, Version 1.2022.20500 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD9208.1.2022.20500 in 155.679ms
14:27:33 Lookup time for plug-in Chip.ADMV8505, Version 1.2022.2200 was 0.01ms
14:27:33 Assembly registration time for plug-in Chip.AD9172, Version 1.2021.32300 was 3.727ms
14:27:33 Loaded Extensions - Plug-in Chip.AD9172, Version 1.2021.32300 - 84.867ms
14:27:33 Initialization time for plug-in Chip.AD9172, Version 1.2021.32300 was 161.023ms
14:27:33 Loaded plug-in Chip.AD9172, Version 1.2021.32300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9172.1.2021.32300 in 164.237ms
14:27:33 Lookup time for plug-in Chip.AD9163, Version 1.2020.24300 was 0.006ms
14:27:33 Loaded Extensions - Plug-in Vector.File, Version 1.29.3286 - 188.953ms
14:27:33 Initialization time for plug-in Vector.File, Version 1.29.3286 was 193.23ms
14:27:33 Loaded plug-in Vector.File, Version 1.29.3286 from C:\ProgramData\Analog Devices\ACE\Plugins\Vector.File.1.29.3286 in 195.568ms
14:27:33 Lookup time for plug-in Chip.AD9164, Version 1.2020.24300 was 0.009ms
14:27:33 Assembly registration time for plug-in Chip.ADMV8505, Version 1.2022.2200 was 3.495ms
14:27:33 Loaded Extensions - Plug-in Hardware.ClockSupport, Version 1.2022.28200 - 193.792ms
14:27:33 Loaded Extensions - Plug-in Chip.ADMV8505, Version 1.2022.2200 - 41.55ms
14:27:33 Initialization time for plug-in Hardware.ClockSupport, Version 1.2022.28200 was 198.679ms
14:27:33 Loaded plug-in Hardware.ClockSupport, Version 1.2022.28200 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.ClockSupport.1.2022.28200 in 200.608ms
14:27:33 Initialization time for plug-in Chip.ADMV8505, Version 1.2022.2200 was 44.636ms
14:27:33 Loaded plug-in Chip.ADMV8505, Version 1.2022.2200 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADMV8505.1.2022.2200 in 44.828ms
14:27:33 Lookup time for plug-in Board.ADIIOController, Version 1.2021.42100 was 0.009ms
14:27:33 Assembly registration time for plug-in Chip.AD9163, Version 1.2020.24300 was 3.308ms
14:27:33 Lookup time for plug-in Hardware.DeviceApiSupport, Version 1.2022.28200 was 0.005ms
14:27:33 Loaded Extensions - Plug-in Chip.AD9163, Version 1.2020.24300 - 36.294ms
14:27:33 Initialization time for plug-in Chip.AD9163, Version 1.2020.24300 was 37.754ms
14:27:33 Loaded plug-in Chip.AD9163, Version 1.2020.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9163.1.2020.24300 in 37.919ms
14:27:33 Lookup time for plug-in Chip.AD9528, Version 1.1.2 was 0.005ms
14:27:33 Assembly registration time for plug-in Board.ADIIOController, Version 1.2021.42100 was 19.474ms
14:27:33 Assembly registration time for plug-in Hardware.DeviceApiSupport, Version 1.2022.28200 was 19.452ms
14:27:33 Loaded Extensions - Plug-in Board.ADIIOController, Version 1.2021.42100 - 26.614ms
14:27:33 Initialization time for plug-in Board.ADIIOController, Version 1.2021.42100 was 27.883ms
14:27:33 Loaded plug-in Board.ADIIOController, Version 1.2021.42100 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADIIOController.1.2021.42100 in 28.055ms
14:27:33 Lookup time for plug-in Support.Transactions, Version 1.2023.22200 was 0.012ms
14:27:33 Assembly registration time for plug-in Chip.AD9164, Version 1.2020.24300 was 3.899ms
14:27:33 Loaded Extensions - Plug-in Chip.AD9164, Version 1.2020.24300 - 33.242ms
14:27:33 Initialization time for plug-in Chip.AD9164, Version 1.2020.24300 was 34.569ms
14:27:33 Loaded plug-in Chip.AD9164, Version 1.2020.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9164.1.2020.24300 in 34.74ms
14:27:33 Lookup time for plug-in Chip.AD9508, Version 1.2.0 was 0.005ms
14:27:33 Assembly registration time for plug-in Support.Transactions, Version 1.2023.22200 was 8.668ms
14:27:33 Loaded Extensions - Plug-in Support.Transactions, Version 1.2023.22200 - 9.614ms
14:27:33 Assembly registration time for plug-in Chip.AD9508, Version 1.2.0 was 3.374ms
14:27:33 Loaded Extensions - Plug-in Chip.AD9508, Version 1.2.0 - 12.338ms
14:27:33 Initialization time for plug-in Chip.AD9508, Version 1.2.0 was 13.816ms
14:27:33 Loaded plug-in Chip.AD9508, Version 1.2.0 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9508.1.2.0 in 13.989ms
14:27:33 Lookup time for plug-in Chip.ADMV8513, Version 1.2023.30500 was 0.007ms
14:27:33 Assembly registration time for plug-in Chip.AD9528, Version 1.1.2 was 3.472ms
14:27:33 Loaded Extensions - Plug-in Chip.AD9528, Version 1.1.2 - 25.681ms
14:27:33 Initialization time for plug-in Chip.AD9528, Version 1.1.2 was 45.754ms
14:27:33 Loaded plug-in Chip.AD9528, Version 1.1.2 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9528.1.1.2 in 45.921ms
14:27:33 Lookup time for plug-in Chip.ADA2200, Version 1.10.2 was 0.005ms
14:27:33 Initialization time for plug-in Support.Transactions, Version 1.2023.22200 was 19.526ms
14:27:33 Loaded plug-in Support.Transactions, Version 1.2023.22200 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.Transactions.1.2023.22200 in 19.705ms
14:27:33 Lookup time for plug-in Chip.ADF4372, Version 1.2022.24300 was 0.004ms
14:27:33 Loaded Extensions - Plug-in Hardware.LinduinoSupport, Version 1.2023.27300 - 141.841ms
14:27:33 Initialization time for plug-in Hardware.LinduinoSupport, Version 1.2023.27300 was 145.627ms
14:27:33 Dependency Hardware.LinduinoSupport loaded in 146.099ms
14:27:33 Assembly registration time for plug-in Chip.ADMV8513, Version 1.2023.30500 was 3.473ms
14:27:33 Loaded Extensions - Plug-in Chip.ADMV8513, Version 1.2023.30500 - 33.067ms
14:27:33 Assembly registration time for plug-in Chip.ADA2200, Version 1.10.2 was 3.218ms
14:27:33 Initialization time for plug-in Chip.ADMV8513, Version 1.2023.30500 was 37.67ms
14:27:33 Loaded plug-in Chip.ADMV8513, Version 1.2023.30500 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADMV8513.1.2023.30500 in 37.959ms
14:27:33 Lookup time for plug-in Chip.AD9161, Version 1.2020.24300 was 0.005ms
14:27:33 Loaded Extensions - Plug-in Chip.ADA2200, Version 1.10.2 - 32.906ms
14:27:33 Initialization time for plug-in Chip.ADA2200, Version 1.10.2 was 34.703ms
14:27:33 Loaded plug-in Chip.ADA2200, Version 1.10.2 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADA2200.1.10.2 in 34.862ms
14:27:33 Loaded plug-in Chip.AD9695, Version 1.2020.33400 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9695.1.2020.33400 in 0.002ms
14:27:33 Lookup time for plug-in Support.IronPython, Version 1.2023.38300 was 0.005ms
14:27:33 Assembly registration time for plug-in Chip.AD9695, Version 1.2020.33400 was 5.728ms
14:27:33 Loaded Extensions - Plug-in Chip.AD9695, Version 1.2020.33400 - 89.466ms
14:27:33 Initialization time for plug-in Chip.AD9695, Version 1.2020.33400 was 149.68ms
14:27:33 Dependency Chip.AD9695 loaded in 150.093ms
14:27:33 Assembly registration time for plug-in Support.IronPython, Version 1.2023.38300 was 3.367ms
14:27:33 Assembly registration time for plug-in Board.LegacyQevModules, Version 1.2021.28300 was 7.755ms
14:27:33 Loaded Extensions - Plug-in Board.LegacyQevModules, Version 1.2021.28300 - 8.369ms
14:27:33 Initialization time for plug-in Board.LegacyQevModules, Version 1.2021.28300 was 156.239ms
14:27:33 Loaded plug-in Board.LegacyQevModules, Version 1.2021.28300 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.LegacyQevModules.1.2021.28300 in 156.416ms
14:27:33 Lookup time for plug-in Board.ADF4371, Version 1.2022.3300 was 0.005ms
14:27:33 Loaded Extensions - Plug-in Support.IronPython, Version 1.2023.38300 - 12.96ms
14:27:33 Assembly registration time for plug-in Chip.AD9161, Version 1.2020.24300 was 3.62ms
14:27:33 Loaded Extensions - Plug-in Chip.AD9161, Version 1.2020.24300 - 14.562ms
14:27:33 Initialization time for plug-in Chip.AD9161, Version 1.2020.24300 was 15.893ms
14:27:33 Loaded plug-in Chip.AD9161, Version 1.2020.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9161.1.2020.24300 in 16.051ms
14:27:33 Lookup time for plug-in Chip.ADF4355, Version 1.1.1 was 0.007ms
14:27:33 Assembly registration time for plug-in Board.ADF4371, Version 1.2022.3300 was 3.5ms
14:27:33 Loaded Extensions - Plug-in Board.ADF4371, Version 1.2022.3300 - 4.451ms
14:27:33 Initialization time for plug-in Board.ADF4371, Version 1.2022.3300 was 11.397ms
14:27:33 Loaded plug-in Board.ADF4371, Version 1.2022.3300 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADF4371.1.2022.3300 in 11.55ms
14:27:33 Lookup time for plug-in Chip.AD9162, Version 1.2020.24300 was 0.005ms
14:27:33 Assembly registration time for plug-in Board.AD9695, Version 1.2019.43402 was 3.247ms
14:27:33 Assembly registration time for plug-in Chip.ADF4372, Version 1.2022.24300 was 3.186ms
14:27:33 Loaded Extensions - Plug-in Chip.ADF4372, Version 1.2022.24300 - 21.195ms
14:27:33 Initialization time for plug-in Chip.ADF4372, Version 1.2022.24300 was 52.377ms
14:27:33 Loaded plug-in Chip.ADF4372, Version 1.2022.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADF4372.1.2022.24300 in 52.533ms
14:27:33 Lookup time for plug-in Board.ADF4372, Version 1.2020.5500 was 0.005ms
14:27:33 Loaded Extensions - Plug-in Board.AD9695, Version 1.2019.43402 - 15.103ms
14:27:33 Initialization time for plug-in Board.AD9695, Version 1.2019.43402 was 167.771ms
14:27:33 Loaded plug-in Board.AD9695, Version 1.2019.43402 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD9695.1.2019.43402 in 167.939ms
14:27:33 Lookup time for plug-in Chip.ADMV8052, Version 1.2021.6200 was 0.004ms
14:27:33 Initialization time for plug-in Support.IronPython, Version 1.2023.38300 was 33.448ms
14:27:33 Loaded plug-in Support.IronPython, Version 1.2023.38300 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.IronPython.1.2023.38300 in 33.68ms
14:27:33 Lookup time for plug-in Board.AD9689, Version 1.2020.6400 was 0.008ms
14:27:33 Assembly registration time for plug-in Board.ADF4372, Version 1.2020.5500 was 14.175ms
14:27:33 Loaded Extensions - Plug-in Board.ADF4372, Version 1.2020.5500 - 15.274ms
14:27:33 Initialization time for plug-in Board.ADF4372, Version 1.2020.5500 was 16.673ms
14:27:33 Loaded plug-in Board.ADF4372, Version 1.2020.5500 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADF4372.1.2020.5500 in 16.835ms
14:27:33 Lookup time for plug-in Support.BlockGallery, Version 1.2023.29400 was 0.005ms
14:27:33 Lookup time for plug-in Chip.AD9689, Version 1.2020.33400 was 0.003ms
14:27:33 Assembly registration time for plug-in Support.BlockGallery, Version 1.2023.29400 was 28.233ms
14:27:33 Loaded Extensions - Plug-in Hardware.DeviceApiSupport, Version 1.2022.28200 - 147.489ms
14:27:33 Assembly registration time for plug-in Chip.AD9162, Version 1.2020.24300 was 3.446ms
14:27:33 Loaded Extensions - Plug-in Chip.AD9162, Version 1.2020.24300 - 49.381ms
14:27:33 Initialization time for plug-in Hardware.DeviceApiSupport, Version 1.2022.28200 was 148.262ms
14:27:33 Loaded plug-in Hardware.DeviceApiSupport, Version 1.2022.28200 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.DeviceApiSupport.1.2022.28200 in 148.529ms
14:27:33 Lookup time for plug-in Hardware.HsdacSupport, Version 1.2022.28200 was 0.006ms
14:27:33 Initialization time for plug-in Chip.AD9162, Version 1.2020.24300 was 50.197ms
14:27:33 Loaded plug-in Chip.AD9162, Version 1.2020.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9162.1.2020.24300 in 50.462ms
14:27:33 Lookup time for plug-in Chip.ADMV1013, Version 0.1.5 was 0.004ms
14:27:33 Assembly registration time for plug-in Hardware.HsdacSupport, Version 1.2022.28200 was 3.541ms
14:27:33 Assembly registration time for plug-in Chip.ADMV1013, Version 0.1.5 was 14.999ms
14:27:33 Loaded Extensions - Plug-in Chip.ADMV1013, Version 0.1.5 - 17.819ms
14:27:33 Initialization time for plug-in Chip.ADMV1013, Version 0.1.5 was 18.764ms
14:27:33 Loaded plug-in Chip.ADMV1013, Version 0.1.5 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADMV1013.0.1.5 in 18.926ms
14:27:33 Lookup time for plug-in Board.ADMV8513, Version 1.2023.30500 was 0.006ms
14:27:33 Assembly registration time for plug-in Board.ADMV8513, Version 1.2023.30500 was 17.448ms
14:27:33 Loaded Extensions - Plug-in Board.ADMV8513, Version 1.2023.30500 - 18.269ms
14:27:33 Initialization time for plug-in Board.ADMV8513, Version 1.2023.30500 was 19.285ms
14:27:33 Loaded plug-in Board.ADMV8513, Version 1.2023.30500 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADMV8513.1.2023.30500 in 19.454ms
14:27:33 Loaded plug-in Hardware.LinduinoSupport, Version 1.2023.27300 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.LinduinoSupport.1.2023.27300 in 0.003ms
14:27:33 Lookup time for plug-in Hardware.IIOSupport, Version 1.2023.42100 was 0.006ms
14:27:33 Assembly registration time for plug-in Chip.AD9689, Version 1.2020.33400 was 3.254ms
14:27:33 Loaded Extensions - Plug-in Chip.AD9689, Version 1.2020.33400 - 38.695ms
14:27:33 Initialization time for plug-in Chip.AD9689, Version 1.2020.33400 was 75.293ms
14:27:33 Dependency Chip.AD9689 loaded in 75.775ms
14:27:33 Assembly registration time for plug-in Hardware.IIOSupport, Version 1.2023.42100 was 6.999ms
14:27:33 Assembly registration time for plug-in Board.AD9689, Version 1.2020.6400 was 3.302ms
14:27:33 Assembly registration time for plug-in Chip.ADMV8052, Version 1.2021.6200 was 17.796ms
14:27:33 Assembly registration time for plug-in Chip.ADF4355, Version 1.1.1 was 15.186ms
14:27:33 Loaded Extensions - Plug-in Chip.ADF4355, Version 1.1.1 - 113.622ms
14:27:33 Loaded Extensions - Plug-in Chip.ADMV8052, Version 1.2021.6200 - 42.582ms
14:27:33 Initialization time for plug-in Chip.ADF4355, Version 1.1.1 was 115.052ms
14:27:33 Initialization time for plug-in Chip.ADMV8052, Version 1.2021.6200 was 111.227ms
14:27:33 Loaded plug-in Chip.ADMV8052, Version 1.2021.6200 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADMV8052.1.2021.6200 in 111.419ms
14:27:33 Loaded plug-in Chip.AD9689, Version 1.2020.33400 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9689.1.2020.33400 in 0.003ms
14:27:33 Lookup time for plug-in Board.ADMV8052, Version 1.2021.6200 was 0.007ms
14:27:33 Loaded Extensions - Plug-in Board.AD9689, Version 1.2020.6400 - 19.976ms
14:27:33 Loaded plug-in Chip.ADF4355, Version 1.1.1 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADF4355.1.1.1 in 115.23ms
14:27:33 Lookup time for plug-in Chip.Generic, Version 1.2021.28300 was 0.004ms
14:27:33 Initialization time for plug-in Board.AD9689, Version 1.2020.6400 was 97.919ms
14:27:33 Loaded plug-in Board.AD9689, Version 1.2020.6400 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD9689.1.2020.6400 in 98.101ms
14:27:33 Lookup time for plug-in Board.ADMV1013, Version 1.2019.9400 was 0.004ms
14:27:33 Assembly registration time for plug-in Chip.Generic, Version 1.2021.28300 was 3.488ms
14:27:33 Loaded Extensions - Plug-in Chip.Generic, Version 1.2021.28300 - 3.836ms
14:27:33 Initialization time for plug-in Chip.Generic, Version 1.2021.28300 was 4.531ms
14:27:33 Loaded plug-in Chip.Generic, Version 1.2021.28300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.Generic.1.2021.28300 in 4.705ms
14:27:33 Lookup time for plug-in Chip.GenericFpga, Version 1.2021.46402 was 0.022ms
14:27:33 Assembly registration time for plug-in Board.ADMV1013, Version 1.2019.9400 was 3.373ms
14:27:33 Dependency Hardware.SdpSupport loaded in 0.247ms
14:27:33 Loaded Extensions - Plug-in Board.ADMV1013, Version 1.2019.9400 - 4.583ms
14:27:33 Lookup time for plug-in Hardware.UnifiedSpiMaster, Version 1.2022.28400 was 0.012ms
14:27:33 Initialization time for plug-in Board.ADMV1013, Version 1.2019.9400 was 5.587ms
14:27:33 Loaded plug-in Board.ADMV1013, Version 1.2019.9400 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADMV1013.1.2019.09400 in 5.744ms
14:27:33 Lookup time for plug-in Board.ADMV8505, Version 1.2022.2200 was 0.005ms
14:27:33 Castle.MicroKernel.ComponentActivator.ComponentActivatorException: ComponentActivator: could not instantiate AnalogDevices.Csa.Hardware.HsdacSupport.HsdacControllerFinder ---> System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.IO.FileNotFoundException: Could not load file or assembly 'AnalogDevices.DPG.EvaluationBoards, Version=1.0.0.0, Culture=neutral, PublicKeyToken=cf4fed3ab3d3bf1a' or one of its dependencies. The system cannot find the file specified.
   at AnalogDevices.Csa.Hardware.HsdacSupport.HsdacControllerFinder..ctor(IEvalComponentRepository repo, ITransactionBroker handlerBroker)
   --- End of inner exception stack trace ---
   at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
   at System.Reflection.RuntimeConstructorInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
   at Castle.MicroKernel.ComponentActivator.DefaultComponentActivator.FastCreateInstance(Type implType, Object[] arguments, ConstructorCandidate constructor)
   at Castle.MicroKernel.ComponentActivator.DefaultComponentActivator.CreateInstanceCore(ConstructorCandidate constructor, Object[] arguments, Type implType)
   at Castle.MicroKernel.ComponentActivator.DefaultComponentActivator.CreateInstance(CreationContext context, ConstructorCandidate constructor, Object[] arguments)
   at Castle.MicroKernel.ComponentActivator.DefaultComponentActivator.Instantiate(CreationContext context)
   at Castle.MicroKernel.ComponentActivator.DefaultComponentActivator.InternalCreate(CreationContext context)
   at Castle.MicroKernel.ComponentActivator.AbstractComponentActivator.Create(CreationContext context, Burden burden)
   at Castle.MicroKernel.Lifestyle.AbstractLifestyleManager.CreateInstance(CreationContext context, Boolean trackedExternally)
   at Castle.MicroKernel.Lifestyle.AbstractLifestyleManager.Resolve(CreationContext context, IReleasePolicy releasePolicy)
   at Castle.MicroKernel.Handlers.DefaultHandler.ResolveCore(CreationContext context, Boolean requiresDecommission, Boolean instanceRequired, Burden& burden)
   at Castle.MicroKernel.Handlers.DefaultHandler.Resolve(CreationContext context, Boolean instanceRequired)
   at Castle.MicroKernel.Handlers.AbstractHandler.Resolve(CreationContext context)
   at Castle.MicroKernel.DefaultKernel.ResolveComponent(IHandler handler, Type service, Arguments additionalArguments, IReleasePolicy policy, Boolean ignoreParentContext)
   at Castle.MicroKernel.DefaultKernel.ResolveComponent(IHandler handler, Type service, Arguments additionalArguments, IReleasePolicy policy)
   at Castle.MicroKernel.DefaultKernel.Castle.MicroKernel.IKernelInternal.Resolve(String key, Type service, Arguments arguments, IReleasePolicy policy)
   at Castle.Facilities.TypedFactory.TypedFactoryComponentResolver.Resolve(IKernelInternal kernel, IReleasePolicy scope)
   at Castle.Facilities.TypedFactory.Internal.TypedFactoryInterceptor.Resolve(IInvocation invocation)
   at Castle.Facilities.TypedFactory.Internal.TypedFactoryInterceptor.Intercept(IInvocation invocation)
   at Castle.DynamicProxy.AbstractInvocation.Proceed()
   at AnalogDevices.Csa.CastleSupport.FactoryInterceptor.Intercept(IInvocation invocation)
14:27:33 Loaded Extensions - Plug-in Hardware.IIOSupport, Version 1.2023.42100 - 32.945ms
14:27:33 Initialization time for plug-in Hardware.IIOSupport, Version 1.2023.42100 was 33.681ms
14:27:33 Loaded plug-in Hardware.IIOSupport, Version 1.2023.42100 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.IIOSupport.1.2023.42100 in 33.918ms
14:27:33 Loaded plug-in Hardware.UnifiedSpiMaster, Version 1.2022.28400 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.UnifiedSpiMaster.1.2022.28400 in 0.003ms
14:27:33 Assembly registration time for plug-in Board.ADMV8052, Version 1.2021.6200 was 9.671ms
14:27:33 Loaded Extensions - Plug-in Board.ADMV8052, Version 1.2021.6200 - 10.426ms
14:27:33 Initialization time for plug-in Board.ADMV8052, Version 1.2021.6200 was 11.3ms
14:27:33 Loaded plug-in Board.ADMV8052, Version 1.2021.6200 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADMV8052.1.2021.6200 in 11.463ms
14:27:33 Assembly registration time for plug-in Board.ADMV8505, Version 1.2022.2200 was 3.661ms
14:27:33 Loaded Extensions - Plug-in Board.ADMV8505, Version 1.2022.2200 - 4.557ms
14:27:33 Plug-in Hardware.HsdacSupport.HsdacControllerFinder Validation Error: Error registering controller finder
System.ArgumentNullException: finder cannot be null
Parameter name: finder
   at AnalogDevices.Csa.ValidationExtensions.AssertNotNull(Object instance, String name, String message)
   at AnalogDevices.Csa.Hardware.AggregateFinder.RegisterFinder(String id, IControllerFinder finder)
   at AnalogDevices.Csa.Hardware.AggregateFinder.DoProcess(Extension extension)
14:27:33 Loaded Extensions - Plug-in Hardware.HsdacSupport, Version 1.2022.28200 - 76.08ms
14:27:33 Initialization time for plug-in Board.ADMV8505, Version 1.2022.2200 was 5.672ms
14:27:33 Loaded plug-in Board.ADMV8505, Version 1.2022.2200 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADMV8505.1.2022.2200 in 5.868ms
14:27:33 Lookup time for plug-in Chip.AD738X, Version 1.2023.36500 was 0.006ms
14:27:33 Initialization time for plug-in Hardware.HsdacSupport, Version 1.2022.28200 was 76.955ms
14:27:33 Loaded plug-in Hardware.HsdacSupport, Version 1.2022.28200 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.HsdacSupport.1.2022.28200 in 77.129ms
14:27:33 Assembly registration time for plug-in Hardware.UnifiedSpiMaster, Version 1.2022.28400 was 3.835ms
14:27:33 Loaded Extensions - Plug-in Hardware.UnifiedSpiMaster, Version 1.2022.28400 - 4.08ms
14:27:33 Initialization time for plug-in Hardware.UnifiedSpiMaster, Version 1.2022.28400 was 7.366ms
14:27:33 Dependency Hardware.UnifiedSpiMaster loaded in 7.781ms
14:27:33 Assembly registration time for plug-in Chip.GenericFpga, Version 1.2021.46402 was 3.459ms
14:27:33 Loaded Extensions - Plug-in Chip.GenericFpga, Version 1.2021.46402 - 3.827ms
14:27:33 Initialization time for plug-in Chip.GenericFpga, Version 1.2021.46402 was 12.814ms
14:27:33 Loaded plug-in Chip.GenericFpga, Version 1.2021.46402 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.GenericFpga.1.2021.46402 in 13.011ms
14:27:33 Lookup time for plug-in Board.CsaControllers, Version 1.2023.43100 was 0.006ms
14:27:33 Dependency Hardware.SdpSupport loaded in 0.249ms
14:27:33 Finished caching XML from C:\ProgramData\Analog Devices\ACE\Plugins in 500.773ms
14:27:33 Assembly registration time for plug-in Board.CsaControllers, Version 1.2023.43100 was 3.813ms
14:27:33 Loaded Extensions - Plug-in Board.CsaControllers, Version 1.2023.43100 - 24.718ms
14:27:33 Initialization time for plug-in Board.CsaControllers, Version 1.2023.43100 was 26.315ms
14:27:33 Loaded plug-in Board.CsaControllers, Version 1.2023.43100 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.CsaControllers.1.2023.43100 in 26.551ms
14:27:33 Lookup time for plug-in Board.Linduino, Version 1.2021.29300 was 0.006ms
14:27:33 Assembly registration time for plug-in Board.Linduino, Version 1.2021.29300 was 3.218ms
14:27:33 Loaded Extensions - Plug-in Board.Linduino, Version 1.2021.29300 - 5.573ms
14:27:33 Initialization time for plug-in Board.Linduino, Version 1.2021.29300 was 6.449ms
14:27:33 Loaded plug-in Board.Linduino, Version 1.2021.29300 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.Linduino.1.2021.29300 in 6.633ms
14:27:33 Lookup time for plug-in Vector.Common, Version 1.29.3286 was 0.004ms
14:27:33 Assembly registration time for plug-in Vector.Common, Version 1.29.3286 was 20.699ms
14:27:33 Loaded Extensions - Plug-in Vector.Common, Version 1.29.3286 - 24.445ms
14:27:33 Initialization time for plug-in Vector.Common, Version 1.29.3286 was 25.127ms
14:27:33 Loaded plug-in Vector.Common, Version 1.29.3286 from C:\ProgramData\Analog Devices\ACE\Plugins\Vector.Common.1.29.3286 in 25.278ms
14:27:33 Assembly registration time for plug-in Chip.AD738X, Version 1.2023.36500 was 3.315ms
14:27:33 Loaded Extensions - Plug-in Chip.AD738X, Version 1.2023.36500 - 67.391ms
14:27:33 Initialization time for plug-in Chip.AD738X, Version 1.2023.36500 was 68.691ms
14:27:33 Loaded plug-in Chip.AD738X, Version 1.2023.36500 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD738X.1.2023.36500 in 68.835ms
14:27:33 Lookup time for plug-in Board.AD9162, Version 1.2020.47400 was 0.011ms
14:27:33 Assembly registration time for plug-in Board.AD9162, Version 1.2020.47400 was 3.034ms
14:27:33 Loaded Extensions - Plug-in Board.AD9162, Version 1.2020.47400 - 24.334ms
14:27:33 Initialization time for plug-in Board.AD9162, Version 1.2020.47400 was 25.138ms
14:27:33 Loaded plug-in Board.AD9162, Version 1.2020.47400 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD9162.1.2020.47400 in 25.282ms
14:27:33 Lookup time for plug-in Board.AD9172, Version 1.2020.8500 was 0.004ms
14:27:33 Assembly registration time for plug-in Board.AD9172, Version 1.2020.8500 was 24.084ms
14:27:33 Loaded Extensions - Plug-in Board.AD9172, Version 1.2020.8500 - 48.043ms
14:27:33 Initialization time for plug-in Board.AD9172, Version 1.2020.8500 was 49.274ms
14:27:33 Loaded plug-in Board.AD9172, Version 1.2020.8500 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD9172.1.2020.8500 in 49.415ms
14:27:34 Loaded Extensions - Plug-in Support.BlockGallery, Version 1.2023.29400 - 412.416ms
14:27:34 Initialization time for plug-in Support.BlockGallery, Version 1.2023.29400 was 413.141ms
14:27:34 Loaded plug-in Support.BlockGallery, Version 1.2023.29400 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.BlockGallery.1.2023.29400 in 413.304ms
14:27:34 Lookup time for plug-in Board.AD738X, Version 1.2023.36500 was 0.006ms
14:27:34 Assembly registration time for plug-in Board.AD738X, Version 1.2023.36500 was 3.332ms
14:27:34 Loaded Extensions - Plug-in Board.AD738X, Version 1.2023.36500 - 56.58ms
14:27:34 Initialization time for plug-in Board.AD738X, Version 1.2023.36500 was 57.327ms
14:27:34 Loaded plug-in Board.AD738X, Version 1.2023.36500 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD738X.1.2023.36500 in 57.477ms
14:27:34 Lookup time for plug-in Board.ADA2200, Version 1.10.2 was 0.004ms
14:27:34 Assembly registration time for plug-in Board.ADA2200, Version 1.10.2 was 3.332ms
14:27:34 Loaded Extensions - Plug-in Board.ADA2200, Version 1.10.2 - 4.253ms
14:27:34 Initialization time for plug-in Board.ADA2200, Version 1.10.2 was 5.201ms
14:27:34 Loaded plug-in Board.ADA2200, Version 1.10.2 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADA2200.1.10.2 in 5.356ms
14:27:34 Lookup time for plug-in Support.NationalInstruments.MeasurementStudio, Version 15.0.187 was 0.006ms
14:27:34 Assembly registration time for plug-in Support.NationalInstruments.MeasurementStudio, Version 15.0.187 was 66.177ms
14:27:34 Loaded Extensions - Plug-in Support.NationalInstruments.MeasurementStudio, Version 15.0.187 - 67.435ms
14:27:34 Initialization time for plug-in Support.NationalInstruments.MeasurementStudio, Version 15.0.187 was 68.156ms
14:27:34 Loaded plug-in Support.NationalInstruments.MeasurementStudio, Version 15.0.187 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.NationalInstruments.MeasurementStudio.15.0.187 in 68.312ms
14:27:34 Lookup time for plug-in Support.ScriptRunner, Version 1.2023.19300 was 0.004ms
14:27:34 Assembly registration time for plug-in Support.ScriptRunner, Version 1.2023.19300 was 2.582ms
14:27:34 Loaded Extensions - Plug-in Support.ScriptRunner, Version 1.2023.19300 - 3.063ms
14:27:34 Initialization time for plug-in Support.ScriptRunner, Version 1.2023.19300 was 3.657ms
14:27:34 Loaded plug-in Support.ScriptRunner, Version 1.2023.19300 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.ScriptRunner.1.2023.19300 in 3.777ms
14:27:34 Lookup time for plug-in Support.IIO, Version 1.2023.42100 was 0.004ms
14:27:34 Assembly registration time for plug-in Support.IIO, Version 1.2023.42100 was 2.735ms
14:27:34 Loaded Extensions - Plug-in Support.IIO, Version 1.2023.42100 - 3.075ms
14:27:34 Initialization time for plug-in Support.IIO, Version 1.2023.42100 was 3.799ms
14:27:34 Loaded plug-in Support.IIO, Version 1.2023.42100 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.IIO.1.2023.42100 in 3.946ms
14:27:34 Thread #1, ran UI.NavigateToPath - Path = "Root::"
14:27:34 Startup time = 1.5844629 seconds.
14:27:35 Loaded Extensions - Plug-in Hardware.SdpSupport, Version 1.2023.43101 - 2172.34ms
14:27:35 Initialization time for plug-in Hardware.SdpSupport, Version 1.2023.43101 was 2177.193ms
14:27:35 Loaded plug-in Hardware.SdpSupport, Version 1.2023.43101 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.SdpSupport.1.2023.43101 in 2179.442ms
14:27:35 Time to check signing for plugins 49.063ms
14:27:35 Finished loading plugins from C:\ProgramData\Analog Devices\ACE\Plugins in 2277.43ms
14:27:37 Details.txt file not found for drive C:\!
14:27:38 Downloading swdownloads.analog.com/.../latest_version.ini to C:\Users\systems-shared\AppData\Local\Analog Devices\ACE\Updater\latest_version.ini using WebClient.
14:27:41 Application RunDuration = 0:00:00:10.2267280
14:27:41 Application PeakPhysicalMemory = 245,137,408
14:27:41 Application PeakVirtualMemory = 902,082,560
APPTRACE64.LOG
14:26:21 Configuring package provider.
14:26:21 InstalledPackageSourceReader is looking for installed packages.
14:26:21 PackageProvider is creating the background worker.
14:26:21 PackageProvider is building the list of sources.
14:26:21 AnalogDevices.Csa.App.Wpf.Usage.ACEUsageLoggingProvider is using table name suffix "" for application usage logging
14:26:21 InstalledPackageSourceReader is finding plug-in for Hardware.ClockSupport 1.2022.28200.
14:26:21 InstalledPackageSourceReader found plug-in for Hardware.ClockSupport 1.2022.28200 in 66.313ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Hardware.DeviceApiSupport 1.2022.28200.
14:26:21 InstalledPackageSourceReader found plug-in for Hardware.DeviceApiSupport 1.2022.28200 in 0.479ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Hardware.LinduinoSupport 1.2023.27300.
14:26:21 InstalledPackageSourceReader found plug-in for Hardware.LinduinoSupport 1.2023.27300 in 6.331ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Hardware.HsdacSupport 1.2022.28200.
14:26:21 InstalledPackageSourceReader found plug-in for Hardware.HsdacSupport 1.2022.28200 in 0.338ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Hardware.IIOSupport 1.2023.42100.
14:26:21 InstalledPackageSourceReader found plug-in for Hardware.IIOSupport 1.2023.42100 in 0.258ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Hardware.UnifiedSpiMaster 1.2022.28400.
14:26:21 InstalledPackageSourceReader found plug-in for Hardware.UnifiedSpiMaster 1.2022.28400 in 0.243ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Hardware.SdpSupport 1.2023.43101.
14:26:21 InstalledPackageSourceReader found plug-in for Hardware.SdpSupport 1.2023.43101 in 0.257ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.Generic 1.2021.28300.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.Generic 1.2021.28300 in 0.246ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.GenericFpga 1.2021.46402.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.GenericFpga 1.2021.46402 in 0.365ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Board.CsaControllers 1.2023.43100.
14:26:21 InstalledPackageSourceReader found plug-in for Board.CsaControllers 1.2023.43100 in 7.864ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Board.Linduino 1.2021.29300.
14:26:21 InstalledPackageSourceReader found plug-in for Board.Linduino 1.2021.29300 in 0.329ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Vector.Common 1.29.3286.
14:26:21 InstalledPackageSourceReader found plug-in for Vector.Common 1.29.3286 in 0.231ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Vector.File 1.29.3286.
14:26:21 InstalledPackageSourceReader found plug-in for Vector.File 1.29.3286 in 0.227ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.ADMV1013 0.1.5.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.ADMV1013 0.1.5 in 0.215ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.AD9528 1.1.2.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.AD9528 1.1.2 in 0.214ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.ADMV8513 1.2023.30500.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.ADMV8513 1.2023.30500 in 0.222ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.ADMV8052 1.2021.6200.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.ADMV8052 1.2021.6200 in 0.221ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Support.IronPython 1.2023.38300.
14:26:21 InstalledPackageSourceReader found plug-in for Support.IronPython 1.2023.38300 in 0.227ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Board.ADMV8513 1.2023.30500.
14:26:21 InstalledPackageSourceReader found plug-in for Board.ADMV8513 1.2023.30500 in 0.227ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.AD9163 1.2020.24300.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.AD9163 1.2020.24300 in 0.221ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.ADA2200 1.10.2.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.ADA2200 1.10.2 in 0.22ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.ADMV8505 1.2022.2200.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.ADMV8505 1.2022.2200 in 0.217ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Support.Transactions 1.2023.22200.
14:26:21 InstalledPackageSourceReader found plug-in for Support.Transactions 1.2023.22200 in 0.224ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.HMC7044 0.1.0.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.HMC7044 0.1.0 in 0.233ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.AD9164 1.2020.24300.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.AD9164 1.2020.24300 in 0.215ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Board.LegacyQevModules 1.2021.28300.
14:26:21 InstalledPackageSourceReader found plug-in for Board.LegacyQevModules 1.2021.28300 in 0.229ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.AD9695 1.2020.33400.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.AD9695 1.2020.33400 in 0.233ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.AD9208 1.2022.20500.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.AD9208 1.2022.20500 in 0.222ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Board.AD9695 1.2019.43402.
14:26:21 InstalledPackageSourceReader found plug-in for Board.AD9695 1.2019.43402 in 0.224ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.AD738X 1.2023.36500.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.AD738X 1.2023.36500 in 0.229ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.AD9508 1.2.0.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.AD9508 1.2.0 in 0.213ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.AD9161 1.2020.24300.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.AD9161 1.2020.24300 in 0.22ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.AD9172 1.2021.32300.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.AD9172 1.2021.32300 in 0.219ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Board.ADMV8052 1.2021.6200.
14:26:21 InstalledPackageSourceReader found plug-in for Board.ADMV8052 1.2021.6200 in 0.251ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.ADF4372 1.2022.24300.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.ADF4372 1.2022.24300 in 0.229ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.AD9689 1.2020.33400.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.AD9689 1.2020.33400 in 0.235ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.ADF4355 1.1.1.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.ADF4355 1.1.1 in 0.325ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.ADF4371 1.2022.24300.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.ADF4371 1.2022.24300 in 0.271ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Board.ADF4371 1.2022.3300.
14:26:21 InstalledPackageSourceReader found plug-in for Board.ADF4371 1.2022.3300 in 0.26ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Chip.AD9162 1.2020.24300.
14:26:21 InstalledPackageSourceReader found plug-in for Chip.AD9162 1.2020.24300 in 0.314ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Board.ADF4372 1.2020.5500.
14:26:21 InstalledPackageSourceReader found plug-in for Board.ADF4372 1.2020.5500 in 0.251ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Board.ADMV8505 1.2022.2200.
14:26:21 InstalledPackageSourceReader found plug-in for Board.ADMV8505 1.2022.2200 in 0.23ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Board.AD9208 1.2022.20500.
14:26:21 InstalledPackageSourceReader found plug-in for Board.AD9208 1.2022.20500 in 0.245ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Board.ADIIOController 1.2021.42100.
14:26:21 InstalledPackageSourceReader found plug-in for Board.ADIIOController 1.2021.42100 in 0.228ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Board.AD9689 1.2020.6400.
14:26:21 InstalledPackageSourceReader found plug-in for Board.AD9689 1.2020.6400 in 0.222ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Board.ADMV1013 1.2019.9400.
14:26:21 InstalledPackageSourceReader found plug-in for Board.ADMV1013 1.2019.9400 in 0.22ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Board.AD9162 1.2020.47400.
14:26:21 InstalledPackageSourceReader found plug-in for Board.AD9162 1.2020.47400 in 0.251ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Board.AD9172 1.2020.8500.
14:26:21 InstalledPackageSourceReader found plug-in for Board.AD9172 1.2020.8500 in 0.23ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Support.BlockGallery 1.2023.29400.
14:26:21 InstalledPackageSourceReader found plug-in for Support.BlockGallery 1.2023.29400 in 0.223ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Board.AD738X 1.2023.36500.
14:26:21 InstalledPackageSourceReader found plug-in for Board.AD738X 1.2023.36500 in 0.224ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Board.ADA2200 1.10.2.
14:26:21 InstalledPackageSourceReader found plug-in for Board.ADA2200 1.10.2 in 0.237ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Support.NationalInstruments.MeasurementStudio 15.0.187.
14:26:21 InstalledPackageSourceReader found plug-in for Support.NationalInstruments.MeasurementStudio 15.0.187 in 0.238ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Support.ScriptRunner 1.2023.19300.
14:26:21 InstalledPackageSourceReader found plug-in for Support.ScriptRunner 1.2023.19300 in 0.231ms.
14:26:21 InstalledPackageSourceReader is finding plug-in for Support.IIO 1.2023.42100.
14:26:21 InstalledPackageSourceReader found plug-in for Support.IIO 1.2023.42100 in 3.373ms.
14:26:21 InstalledPackageSourceReader is finished finding plug-ins for installed packages in 104.339ms
14:26:21 Restoring configuration settings from C:\Users\systems-shared\AppData\Local\Analog Devices\ACE\UserSettings\Configuration.Settings.xml
14:26:21 Clearing blocked plug-ins.
14:26:21 Scanning folder "C:\ProgramData\Analog Devices\ACE\Plugins" for plug-ins.
14:26:21 Lookup time for plug-in Hardware.ClockSupport, Version 1.2022.28200 was 0.221ms
14:26:21 Lookup time for plug-in Hardware.SdpSupport, Version 1.2023.43101 was 0.004ms
14:26:21 Lookup time for plug-in Board.ADMV8513, Version 1.2023.30500 was 0.005ms
14:26:21 Lookup time for plug-in Vector.File, Version 1.29.3286 was 0.04ms
14:26:21 Lookup time for plug-in Chip.AD9164, Version 1.2020.24300 was 0.003ms
14:26:21 Lookup time for plug-in Chip.AD9508, Version 1.2.0 was 0.007ms
14:26:21 Lookup time for plug-in Chip.ADF4355, Version 1.1.1 was 0.004ms
14:26:21 Plug-in Hardware.ClockSupport Validation Error: Plug-in is not supported by the x64 version of ACE
14:26:21 Initialization time for plug-in Hardware.ClockSupport, Version 1.2022.28200 was 7.725ms
14:26:21 Loaded plug-in Hardware.ClockSupport, Version 1.2022.28200 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.ClockSupport.1.2022.28200 in 9.998ms
14:26:21 Lookup time for plug-in Hardware.DeviceApiSupport, Version 1.2022.28200 was 0.011ms
14:26:21 Lookup time for plug-in Chip.ADMV8513, Version 1.2023.30500 was 0.006ms
14:26:21 Assembly registration time for plug-in Hardware.DeviceApiSupport, Version 1.2022.28200 was 1.454ms
14:26:21 Assembly registration time for plug-in Vector.File, Version 1.29.3286 was 10.268ms
14:26:21 Assembly registration time for plug-in Chip.AD9508, Version 1.2.0 was 1.792ms
14:26:21 Assembly registration time for plug-in Chip.AD9164, Version 1.2020.24300 was 0.888ms
14:26:21 Assembly registration time for plug-in Hardware.SdpSupport, Version 1.2023.43101 was 2.136ms
14:26:21 Loaded Extensions - Plug-in Chip.AD9164, Version 1.2020.24300 - 34.096ms
14:26:21 Loaded Extensions - Plug-in Chip.AD9508, Version 1.2.0 - 33.371ms
14:26:21 Initialization time for plug-in Chip.AD9164, Version 1.2020.24300 was 105.689ms
14:26:21 Loaded plug-in Chip.AD9164, Version 1.2020.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9164.1.2020.24300 in 107.877ms
14:26:21 Lookup time for plug-in Board.LegacyQevModules, Version 1.2021.28300 was 0.012ms
14:26:21 Initialization time for plug-in Chip.AD9508, Version 1.2.0 was 101.909ms
14:26:21 Loaded plug-in Chip.AD9508, Version 1.2.0 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9508.1.2.0 in 102.206ms
14:26:21 Lookup time for plug-in Chip.AD9161, Version 1.2020.24300 was 0.005ms
14:26:21 Lookup time for plug-in Hardware.LinduinoSupport, Version 1.2023.27300 was 0.005ms
14:26:21 Assembly registration time for plug-in Chip.ADMV8513, Version 1.2023.30500 was 1.149ms
14:26:21 Dependency Hardware.SdpSupport loaded in 0.258ms
14:26:21 Loaded Extensions - Plug-in Chip.ADMV8513, Version 1.2023.30500 - 13.338ms
14:26:21 Initialization time for plug-in Chip.ADMV8513, Version 1.2023.30500 was 28.747ms
14:26:21 Dependency Chip.ADMV8513 loaded in 30.622ms
14:26:21 Assembly registration time for plug-in Chip.ADF4355, Version 1.1.1 was 1.166ms
14:26:21 Assembly registration time for plug-in Chip.AD9161, Version 1.2020.24300 was 1.172ms
14:26:21 Assembly registration time for plug-in Hardware.LinduinoSupport, Version 1.2023.27300 was 1.123ms
14:26:21 Loaded Extensions - Plug-in Chip.ADF4355, Version 1.1.1 - 48.18ms
14:26:21 Loaded Extensions - Plug-in Chip.AD9161, Version 1.2020.24300 - 6.803ms
14:26:21 Initialization time for plug-in Chip.ADF4355, Version 1.1.1 was 115.346ms
14:26:21 Initialization time for plug-in Chip.AD9161, Version 1.2020.24300 was 13.693ms
14:26:21 Loaded plug-in Chip.AD9161, Version 1.2020.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9161.1.2020.24300 in 13.82ms
14:26:21 Lookup time for plug-in Chip.AD9172, Version 1.2021.32300 was 0.006ms
14:26:21 Loaded plug-in Chip.ADF4355, Version 1.1.1 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADF4355.1.1.1 in 115.509ms
14:26:21 Lookup time for plug-in Chip.ADF4371, Version 1.2022.24300 was 0.004ms
14:26:21 Assembly registration time for plug-in Board.ADMV8513, Version 1.2023.30500 was 1.433ms
14:26:21 Loaded Extensions - Plug-in Hardware.DeviceApiSupport, Version 1.2022.28200 - 132.307ms
14:26:21 Initialization time for plug-in Hardware.DeviceApiSupport, Version 1.2022.28200 was 133.214ms
14:26:21 Loaded plug-in Hardware.DeviceApiSupport, Version 1.2022.28200 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.DeviceApiSupport.1.2022.28200 in 133.443ms
14:26:21 Loaded plug-in Hardware.LinduinoSupport, Version 1.2023.27300 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.LinduinoSupport.1.2023.27300 in 0.003ms
14:26:21 Lookup time for plug-in Hardware.HsdacSupport, Version 1.2022.28200 was 0.007ms
14:26:21 Plug-in Hardware.HsdacSupport Validation Error: Plug-in is not supported by the x64 version of ACE
14:26:21 Initialization time for plug-in Hardware.HsdacSupport, Version 1.2022.28200 was 16.502ms
14:26:21 Loaded plug-in Hardware.HsdacSupport, Version 1.2022.28200 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.HsdacSupport.1.2022.28200 in 16.725ms
14:26:21 Lookup time for plug-in Hardware.IIOSupport, Version 1.2023.42100 was 0.007ms
14:26:21 Assembly registration time for plug-in Hardware.IIOSupport, Version 1.2023.42100 was 3.61ms
14:26:21 Loaded Extensions - Plug-in Hardware.LinduinoSupport, Version 1.2023.27300 - 64.288ms
14:26:21 Initialization time for plug-in Hardware.LinduinoSupport, Version 1.2023.27300 was 67.98ms
14:26:21 Dependency Hardware.LinduinoSupport loaded in 68.45ms
14:26:21 Assembly registration time for plug-in Board.LegacyQevModules, Version 1.2021.28300 was 1.159ms
14:26:21 Assembly registration time for plug-in Chip.ADF4371, Version 1.2022.24300 was 1.322ms
14:26:21 Loaded Extensions - Plug-in Chip.ADF4371, Version 1.2022.24300 - 64.267ms
14:26:21 Initialization time for plug-in Chip.ADF4371, Version 1.2022.24300 was 65.241ms
14:26:21 Loaded plug-in Chip.ADF4371, Version 1.2022.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADF4371.1.2022.24300 in 65.365ms
14:26:21 Loaded Extensions - Plug-in Vector.File, Version 1.29.3286 - 162.245ms
14:26:21 Lookup time for plug-in Board.ADF4371, Version 1.2022.3300 was 0.011ms
14:26:21 Initialization time for plug-in Vector.File, Version 1.29.3286 was 215.056ms
14:26:21 Loaded plug-in Vector.File, Version 1.29.3286 from C:\ProgramData\Analog Devices\ACE\Plugins\Vector.File.1.29.3286 in 216.243ms
14:26:21 Lookup time for plug-in Chip.ADMV1013, Version 0.1.5 was 0.006ms
14:26:21 Loaded Extensions - Plug-in Board.LegacyQevModules, Version 1.2021.28300 - 11.894ms
14:26:21 Initialization time for plug-in Board.LegacyQevModules, Version 1.2021.28300 was 109.977ms
14:26:21 Loaded plug-in Board.LegacyQevModules, Version 1.2021.28300 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.LegacyQevModules.1.2021.28300 in 110.123ms
14:26:21 Lookup time for plug-in Chip.AD9695, Version 1.2020.33400 was 0.005ms
14:26:21 Assembly registration time for plug-in Board.ADF4371, Version 1.2022.3300 was 1.178ms
14:26:21 Loaded Extensions - Plug-in Board.ADF4371, Version 1.2022.3300 - 1.858ms
14:26:21 Initialization time for plug-in Board.ADF4371, Version 1.2022.3300 was 3.147ms
14:26:21 Loaded plug-in Board.ADF4371, Version 1.2022.3300 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADF4371.1.2022.3300 in 3.409ms
14:26:21 Lookup time for plug-in Chip.AD9162, Version 1.2020.24300 was 0.007ms
14:26:21 Assembly registration time for plug-in Chip.AD9162, Version 1.2020.24300 was 1.17ms
14:26:21 Loaded Extensions - Plug-in Chip.AD9162, Version 1.2020.24300 - 4.057ms
14:26:21 Initialization time for plug-in Chip.AD9162, Version 1.2020.24300 was 4.915ms
14:26:21 Loaded plug-in Chip.AD9162, Version 1.2020.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9162.1.2020.24300 in 5.051ms
14:26:21 Lookup time for plug-in Board.ADF4372, Version 1.2020.5500 was 0.006ms
14:26:21 Assembly registration time for plug-in Chip.ADMV1013, Version 0.1.5 was 1.177ms
14:26:21 Loaded Extensions - Plug-in Chip.ADMV1013, Version 0.1.5 - 7.253ms
14:26:21 Lookup time for plug-in Chip.ADF4372, Version 1.2022.24300 was 0.008ms
14:26:21 Initialization time for plug-in Chip.ADMV1013, Version 0.1.5 was 9.135ms
14:26:22 Loaded Extensions - Plug-in Board.ADMV8513, Version 1.2023.30500 - 77.414ms
14:26:22 Loaded plug-in Chip.ADMV1013, Version 0.1.5 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADMV1013.0.1.5 in 33.098ms
14:26:22 Lookup time for plug-in Chip.AD9528, Version 1.1.2 was 0.008ms
14:26:22 Initialization time for plug-in Board.ADMV8513, Version 1.2023.30500 was 248.855ms
14:26:22 Loaded plug-in Board.ADMV8513, Version 1.2023.30500 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADMV8513.1.2023.30500 in 251.236ms
14:26:22 Lookup time for plug-in Chip.AD9163, Version 1.2020.24300 was 0.004ms
14:26:22 Assembly registration time for plug-in Chip.AD9172, Version 1.2021.32300 was 1.151ms
14:26:22 Loaded Extensions - Plug-in Chip.AD9172, Version 1.2021.32300 - 128.006ms
14:26:22 Initialization time for plug-in Chip.AD9172, Version 1.2021.32300 was 138.379ms
14:26:22 Loaded plug-in Chip.AD9172, Version 1.2021.32300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9172.1.2021.32300 in 138.533ms
14:26:22 Lookup time for plug-in Board.ADMV8052, Version 1.2021.6200 was 0.006ms
14:26:22 Assembly registration time for plug-in Chip.AD9163, Version 1.2020.24300 was 1.153ms
14:26:22 Loaded Extensions - Plug-in Chip.AD9163, Version 1.2020.24300 - 10.798ms
14:26:22 Initialization time for plug-in Chip.AD9163, Version 1.2020.24300 was 11.6ms
14:26:22 Lookup time for plug-in Chip.ADMV8052, Version 1.2021.6200 was 0.004ms
14:26:22 Loaded plug-in Chip.AD9163, Version 1.2020.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9163.1.2020.24300 in 11.724ms
14:26:22 Lookup time for plug-in Chip.ADA2200, Version 1.10.2 was 0.004ms
14:26:22 Assembly registration time for plug-in Chip.AD9528, Version 1.1.2 was 1.16ms
14:26:22 Loaded Extensions - Plug-in Chip.AD9528, Version 1.1.2 - 21.007ms
14:26:22 Loaded Extensions - Plug-in Hardware.IIOSupport, Version 1.2023.42100 - 110.259ms
14:26:22 Initialization time for plug-in Chip.AD9528, Version 1.1.2 was 22.013ms
14:26:22 Loaded plug-in Chip.AD9528, Version 1.1.2 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9528.1.1.2 in 22.24ms
14:26:22 Loaded plug-in Chip.ADMV8513, Version 1.2023.30500 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADMV8513.1.2023.30500 in 0.006ms
14:26:22 Loaded plug-in Chip.ADMV8052, Version 1.2021.6200 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADMV8052.1.2021.6200 in 0.002ms
14:26:22 Lookup time for plug-in Support.IronPython, Version 1.2023.38300 was 0.005ms
14:26:22 Initialization time for plug-in Hardware.IIOSupport, Version 1.2023.42100 was 111.34ms
14:26:22 Loaded plug-in Hardware.IIOSupport, Version 1.2023.42100 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.IIOSupport.1.2023.42100 in 111.563ms
14:26:22 Lookup time for plug-in Hardware.UnifiedSpiMaster, Version 1.2022.28400 was 0.004ms
14:26:22 Assembly registration time for plug-in Chip.ADA2200, Version 1.10.2 was 1.431ms
14:26:22 Loaded Extensions - Plug-in Chip.ADA2200, Version 1.10.2 - 10.877ms
14:26:22 Initialization time for plug-in Chip.ADA2200, Version 1.10.2 was 12.11ms
14:26:22 Loaded plug-in Chip.ADA2200, Version 1.10.2 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADA2200.1.10.2 in 12.271ms
14:26:22 Lookup time for plug-in Chip.ADMV8505, Version 1.2022.2200 was 0.009ms
14:26:22 Assembly registration time for plug-in Support.IronPython, Version 1.2023.38300 was 1.658ms
14:26:22 Assembly registration time for plug-in Hardware.UnifiedSpiMaster, Version 1.2022.28400 was 1.585ms
14:26:22 Loaded Extensions - Plug-in Hardware.UnifiedSpiMaster, Version 1.2022.28400 - 1.869ms
14:26:22 Initialization time for plug-in Hardware.UnifiedSpiMaster, Version 1.2022.28400 was 2.951ms
14:26:22 Loaded plug-in Hardware.UnifiedSpiMaster, Version 1.2022.28400 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.UnifiedSpiMaster.1.2022.28400 in 3.095ms
14:26:22 Lookup time for plug-in Chip.Generic, Version 1.2021.28300 was 0.005ms
14:26:22 Assembly registration time for plug-in Chip.AD9695, Version 1.2020.33400 was 1.249ms
14:26:22 Loaded Extensions - Plug-in Chip.AD9695, Version 1.2020.33400 - 56.287ms
14:26:22 Initialization time for plug-in Chip.AD9695, Version 1.2020.33400 was 60.766ms
14:26:22 Loaded plug-in Chip.AD9695, Version 1.2020.33400 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9695.1.2020.33400 in 60.904ms
14:26:22 Lookup time for plug-in Chip.AD9208, Version 1.2022.20500 was 0.006ms
14:26:22 Loaded Extensions - Plug-in Support.IronPython, Version 1.2023.38300 - 6.748ms
14:26:22 Initialization time for plug-in Support.IronPython, Version 1.2023.38300 was 22.084ms
14:26:22 Loaded plug-in Support.IronPython, Version 1.2023.38300 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.IronPython.1.2023.38300 in 22.291ms
14:26:22 Lookup time for plug-in Board.AD9208, Version 1.2022.20500 was 0.007ms
14:26:22 Dependency Chip.AD9208 loaded in 0.256ms
14:26:22 Assembly registration time for plug-in Chip.ADMV8505, Version 1.2022.2200 was 1.163ms
14:26:22 Loaded Extensions - Plug-in Chip.ADMV8505, Version 1.2022.2200 - 21.547ms
14:26:22 Assembly registration time for plug-in Board.AD9208, Version 1.2022.20500 was 1.043ms
14:26:22 Initialization time for plug-in Chip.ADMV8505, Version 1.2022.2200 was 24.992ms
14:26:22 Loaded plug-in Chip.ADMV8505, Version 1.2022.2200 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADMV8505.1.2022.2200 in 25.156ms
14:26:22 Lookup time for plug-in Support.Transactions, Version 1.2023.22200 was 0.006ms
14:26:22 Loaded Extensions - Plug-in Board.AD9208, Version 1.2022.20500 - 3.158ms
14:26:22 Initialization time for plug-in Board.AD9208, Version 1.2022.20500 was 5.445ms
14:26:22 Loaded plug-in Board.AD9208, Version 1.2022.20500 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD9208.1.2022.20500 in 5.583ms
14:26:22 Lookup time for plug-in Board.ADIIOController, Version 1.2021.42100 was 0.005ms
14:26:22 Assembly registration time for plug-in Chip.Generic, Version 1.2021.28300 was 1.312ms
14:26:22 Assembly registration time for plug-in Support.Transactions, Version 1.2023.22200 was 1.336ms
14:26:22 Loaded Extensions - Plug-in Chip.Generic, Version 1.2021.28300 - 35.602ms
14:26:22 Loaded Extensions - Plug-in Support.Transactions, Version 1.2023.22200 - 12.16ms
14:26:22 Initialization time for plug-in Chip.Generic, Version 1.2021.28300 was 36.714ms
14:26:22 Loaded plug-in Chip.Generic, Version 1.2021.28300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.Generic.1.2021.28300 in 36.839ms
14:26:22 Lookup time for plug-in Chip.GenericFpga, Version 1.2021.46402 was 0.005ms
14:26:22 Assembly registration time for plug-in Board.ADIIOController, Version 1.2021.42100 was 0.986ms
14:26:22 Loaded Extensions - Plug-in Board.ADIIOController, Version 1.2021.42100 - 1.907ms
14:26:22 Dependency Hardware.SdpSupport loaded in 0.244ms
14:26:22 Initialization time for plug-in Board.ADIIOController, Version 1.2021.42100 was 3.241ms
14:26:22 Loaded plug-in Board.ADIIOController, Version 1.2021.42100 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADIIOController.1.2021.42100 in 13.222ms
14:26:22 Lookup time for plug-in Board.AD9689, Version 1.2020.6400 was 0.004ms
14:26:22 Assembly registration time for plug-in Chip.GenericFpga, Version 1.2021.46402 was 8.208ms
14:26:22 Initialization time for plug-in Support.Transactions, Version 1.2023.22200 was 22.578ms
14:26:22 Loaded plug-in Support.Transactions, Version 1.2023.22200 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.Transactions.1.2023.22200 in 22.733ms
14:26:22 Loaded Extensions - Plug-in Chip.GenericFpga, Version 1.2021.46402 - 8.914ms
14:26:22 Lookup time for plug-in Chip.HMC7044, Version 0.1.0 was 0.014ms
14:26:22 Lookup time for plug-in Chip.AD9689, Version 1.2020.33400 was 0.004ms
14:26:22 Initialization time for plug-in Chip.GenericFpga, Version 1.2021.46402 was 10.056ms
14:26:22 Assembly registration time for plug-in Chip.ADF4372, Version 1.2022.24300 was 1.143ms
14:26:22 Loaded plug-in Chip.GenericFpga, Version 1.2021.46402 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.GenericFpga.1.2021.46402 in 10.179ms
14:26:22 Loaded Extensions - Plug-in Chip.ADF4372, Version 1.2022.24300 - 26.345ms
14:26:22 Initialization time for plug-in Chip.ADF4372, Version 1.2022.24300 was 97.945ms
14:26:22 Dependency Chip.ADF4372 loaded in 98.369ms
14:26:22 Lookup time for plug-in Board.CsaControllers, Version 1.2023.43100 was 0.005ms
14:26:22 Dependency Hardware.SdpSupport loaded in 0.256ms
14:26:22 Assembly registration time for plug-in Board.ADF4372, Version 1.2020.5500 was 1.148ms
14:26:22 Loaded Extensions - Plug-in Board.ADF4372, Version 1.2020.5500 - 1.894ms
14:26:22 Assembly registration time for plug-in Chip.AD9208, Version 1.2022.20500 was 1.077ms
14:26:22 Loaded Extensions - Plug-in Chip.AD9208, Version 1.2022.20500 - 29.128ms
14:26:22 Initialization time for plug-in Board.ADF4372, Version 1.2020.5500 was 101.206ms
14:26:22 Loaded plug-in Board.ADF4372, Version 1.2020.5500 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADF4372.1.2020.5500 in 101.364ms
14:26:22 Lookup time for plug-in Board.ADMV8505, Version 1.2022.2200 was 0.005ms
14:26:22 Initialization time for plug-in Chip.AD9208, Version 1.2022.20500 was 47.083ms
14:26:22 Loaded plug-in Chip.AD9208, Version 1.2022.20500 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9208.1.2022.20500 in 47.203ms
14:26:22 Lookup time for plug-in Board.AD9695, Version 1.2019.43402 was 0.004ms
14:26:22 Assembly registration time for plug-in Chip.HMC7044, Version 0.1.0 was 1.007ms
14:26:22 Loaded Extensions - Plug-in Chip.HMC7044, Version 0.1.0 - 1.801ms
14:26:22 Initialization time for plug-in Chip.HMC7044, Version 0.1.0 was 5.094ms
14:26:22 Loaded plug-in Chip.HMC7044, Version 0.1.0 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.HMC7044.0.1.0 in 5.352ms
14:26:22 Lookup time for plug-in Support.BlockGallery, Version 1.2023.29400 was 0.015ms
14:26:22 Assembly registration time for plug-in Board.AD9695, Version 1.2019.43402 was 1.241ms
14:26:22 Assembly registration time for plug-in Chip.ADMV8052, Version 1.2021.6200 was 1.228ms
14:26:22 Loaded Extensions - Plug-in Chip.ADMV8052, Version 1.2021.6200 - 18.048ms
14:26:22 Loaded Extensions - Plug-in Board.AD9695, Version 1.2019.43402 - 13.504ms
14:26:22 Assembly registration time for plug-in Support.BlockGallery, Version 1.2023.29400 was 1.196ms
14:26:22 Initialization time for plug-in Chip.ADMV8052, Version 1.2021.6200 was 78.745ms
14:26:22 Assembly registration time for plug-in Chip.AD9689, Version 1.2020.33400 was 1.143ms
14:26:22 Initialization time for plug-in Board.AD9695, Version 1.2019.43402 was 14.695ms
14:26:22 Loaded plug-in Board.AD9695, Version 1.2019.43402 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD9695.1.2019.43402 in 14.845ms
14:26:22 Lookup time for plug-in Chip.AD738X, Version 1.2023.36500 was 0.006ms
14:26:22 Loaded Extensions - Plug-in Chip.AD9689, Version 1.2020.33400 - 14.498ms
14:26:22 Initialization time for plug-in Chip.AD9689, Version 1.2020.33400 was 18.722ms
14:26:22 Dependency Chip.AD9689 loaded in 19.123ms
14:26:22 Dependency Chip.ADMV8052 loaded in 79.22ms
14:26:22 Assembly registration time for plug-in Board.CsaControllers, Version 1.2023.43100 was 1.25ms
14:26:22 Assembly registration time for plug-in Board.AD9689, Version 1.2020.6400 was 1.257ms
14:26:22 Assembly registration time for plug-in Board.ADMV8052, Version 1.2021.6200 was 1.173ms
14:26:22 Loaded Extensions - Plug-in Board.CsaControllers, Version 1.2023.43100 - 26.053ms
14:26:22 Loaded Extensions - Plug-in Board.ADMV8052, Version 1.2021.6200 - 8.866ms
14:26:22 Initialization time for plug-in Board.CsaControllers, Version 1.2023.43100 was 27.555ms
14:26:22 Loaded plug-in Board.CsaControllers, Version 1.2023.43100 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.CsaControllers.1.2023.43100 in 27.702ms
14:26:22 Lookup time for plug-in Board.Linduino, Version 1.2021.29300 was 0.006ms
14:26:22 Initialization time for plug-in Board.ADMV8052, Version 1.2021.6200 was 90.806ms
14:26:22 Loaded plug-in Board.ADMV8052, Version 1.2021.6200 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADMV8052.1.2021.6200 in 90.96ms
14:26:22 Loaded plug-in Chip.ADF4372, Version 1.2022.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADF4372.1.2022.24300 in 0.006ms
14:26:22 Loaded plug-in Chip.AD9689, Version 1.2020.33400 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9689.1.2020.33400 in 0.002ms
14:26:22 Loaded Extensions - Plug-in Board.AD9689, Version 1.2020.6400 - 9.559ms
14:26:22 Initialization time for plug-in Board.AD9689, Version 1.2020.6400 was 38.607ms
14:26:22 Loaded plug-in Board.AD9689, Version 1.2020.6400 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD9689.1.2020.6400 in 38.735ms
14:26:22 Lookup time for plug-in Board.ADMV1013, Version 1.2019.9400 was 0.006ms
14:26:22 Assembly registration time for plug-in Board.Linduino, Version 1.2021.29300 was 2.305ms
14:26:22 Assembly registration time for plug-in Board.ADMV1013, Version 1.2019.9400 was 2.904ms
14:26:22 Loaded Extensions - Plug-in Board.ADMV1013, Version 1.2019.9400 - 5.497ms
14:26:22 Initialization time for plug-in Board.ADMV1013, Version 1.2019.9400 was 7.78ms
14:26:22 Loaded plug-in Board.ADMV1013, Version 1.2019.9400 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADMV1013.1.2019.09400 in 7.929ms
14:26:22 Lookup time for plug-in Board.AD9162, Version 1.2020.47400 was 0.013ms
14:26:22 Loaded Extensions - Plug-in Board.Linduino, Version 1.2021.29300 - 9.225ms
14:26:22 Initialization time for plug-in Board.Linduino, Version 1.2021.29300 was 10.031ms
14:26:22 Loaded plug-in Board.Linduino, Version 1.2021.29300 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.Linduino.1.2021.29300 in 10.278ms
14:26:22 Lookup time for plug-in Vector.Common, Version 1.29.3286 was 0.006ms
14:26:22 Assembly registration time for plug-in Vector.Common, Version 1.29.3286 was 2.316ms
14:26:22 Loaded Extensions - Plug-in Vector.Common, Version 1.29.3286 - 14.341ms
14:26:22 Initialization time for plug-in Vector.Common, Version 1.29.3286 was 15.501ms
14:26:22 Loaded plug-in Vector.Common, Version 1.29.3286 from C:\ProgramData\Analog Devices\ACE\Plugins\Vector.Common.1.29.3286 in 15.672ms
14:26:22 Assembly registration time for plug-in Board.ADMV8505, Version 1.2022.2200 was 50.227ms
14:26:22 Loaded Extensions - Plug-in Board.ADMV8505, Version 1.2022.2200 - 51.3ms
14:26:22 Initialization time for plug-in Board.ADMV8505, Version 1.2022.2200 was 52.325ms
14:26:22 Loaded plug-in Board.ADMV8505, Version 1.2022.2200 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADMV8505.1.2022.2200 in 52.468ms
14:26:22 Assembly registration time for plug-in Board.AD9162, Version 1.2020.47400 was 1.218ms
14:26:22 Assembly registration time for plug-in Chip.AD738X, Version 1.2023.36500 was 7.294ms
14:26:22 Loaded Extensions - Plug-in Chip.AD738X, Version 1.2023.36500 - 93.249ms
14:26:22 Initialization time for plug-in Chip.AD738X, Version 1.2023.36500 was 94.503ms
14:26:22 Loaded plug-in Chip.AD738X, Version 1.2023.36500 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD738X.1.2023.36500 in 94.664ms
14:26:22 Loaded Extensions - Plug-in Board.AD9162, Version 1.2020.47400 - 69.429ms
14:26:22 Initialization time for plug-in Board.AD9162, Version 1.2020.47400 was 86.499ms
14:26:22 Loaded plug-in Board.AD9162, Version 1.2020.47400 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD9162.1.2020.47400 in 86.654ms
14:26:22 Lookup time for plug-in Board.AD9172, Version 1.2020.8500 was 0.011ms
14:26:22 Finished caching XML from C:\ProgramData\Analog Devices\ACE\Plugins in 547.452ms
14:26:22 Assembly registration time for plug-in Board.AD9172, Version 1.2020.8500 was 1.324ms
14:26:22 Loaded Extensions - Plug-in Board.AD9172, Version 1.2020.8500 - 72.203ms
14:26:22 Initialization time for plug-in Board.AD9172, Version 1.2020.8500 was 74.32ms
14:26:22 Loaded plug-in Board.AD9172, Version 1.2020.8500 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD9172.1.2020.8500 in 74.471ms
14:26:22 Loaded Extensions - Plug-in Support.BlockGallery, Version 1.2023.29400 - 471.989ms
14:26:22 Initialization time for plug-in Support.BlockGallery, Version 1.2023.29400 was 472.815ms
14:26:22 Loaded plug-in Support.BlockGallery, Version 1.2023.29400 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.BlockGallery.1.2023.29400 in 473.017ms
14:26:22 Lookup time for plug-in Board.AD738X, Version 1.2023.36500 was 0.007ms
14:26:22 Assembly registration time for plug-in Board.AD738X, Version 1.2023.36500 was 1.161ms
14:26:22 Loaded Extensions - Plug-in Board.AD738X, Version 1.2023.36500 - 63.846ms
14:26:22 Initialization time for plug-in Board.AD738X, Version 1.2023.36500 was 64.985ms
14:26:22 Loaded plug-in Board.AD738X, Version 1.2023.36500 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD738X.1.2023.36500 in 65.135ms
14:26:22 Lookup time for plug-in Board.ADA2200, Version 1.10.2 was 0.005ms
14:26:22 Assembly registration time for plug-in Board.ADA2200, Version 1.10.2 was 1.041ms
14:26:22 Loaded Extensions - Plug-in Board.ADA2200, Version 1.10.2 - 1.81ms
14:26:22 Initialization time for plug-in Board.ADA2200, Version 1.10.2 was 2.807ms
14:26:22 Loaded plug-in Board.ADA2200, Version 1.10.2 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADA2200.1.10.2 in 2.936ms
14:26:22 Lookup time for plug-in Support.NationalInstruments.MeasurementStudio, Version 15.0.187 was 0.004ms
14:26:22 Assembly registration time for plug-in Support.NationalInstruments.MeasurementStudio, Version 15.0.187 was 14.442ms
14:26:22 Loaded Extensions - Plug-in Support.NationalInstruments.MeasurementStudio, Version 15.0.187 - 16.327ms
14:26:22 Initialization time for plug-in Support.NationalInstruments.MeasurementStudio, Version 15.0.187 was 17.111ms
14:26:22 Loaded plug-in Support.NationalInstruments.MeasurementStudio, Version 15.0.187 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.NationalInstruments.MeasurementStudio.15.0.187 in 17.268ms
14:26:22 Lookup time for plug-in Support.ScriptRunner, Version 1.2023.19300 was 0.005ms
14:26:22 Assembly registration time for plug-in Support.ScriptRunner, Version 1.2023.19300 was 1.108ms
14:26:22 Loaded Extensions - Plug-in Support.ScriptRunner, Version 1.2023.19300 - 1.616ms
14:26:22 Initialization time for plug-in Support.ScriptRunner, Version 1.2023.19300 was 2.37ms
14:26:22 Loaded plug-in Support.ScriptRunner, Version 1.2023.19300 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.ScriptRunner.1.2023.19300 in 2.511ms
14:26:22 Lookup time for plug-in Support.IIO, Version 1.2023.42100 was 0.005ms
14:26:22 Assembly registration time for plug-in Support.IIO, Version 1.2023.42100 was 0.963ms
14:26:22 Loaded Extensions - Plug-in Support.IIO, Version 1.2023.42100 - 1.21ms
14:26:22 Initialization time for plug-in Support.IIO, Version 1.2023.42100 was 2.02ms
14:26:22 Loaded plug-in Support.IIO, Version 1.2023.42100 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.IIO.1.2023.42100 in 2.158ms
14:26:22 Thread #1, ran UI.NavigateToPath - Path = "Root::"
14:26:23 Startup time = 1.7413245 seconds.
14:26:23 Loaded Extensions - Plug-in Hardware.SdpSupport, Version 1.2023.43101 - 2029.253ms
14:26:23 Initialization time for plug-in Hardware.SdpSupport, Version 1.2023.43101 was 2036.79ms
14:26:23 Loaded plug-in Hardware.SdpSupport, Version 1.2023.43101 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.SdpSupport.1.2023.43101 in 2037.733ms
14:26:23 Time to check signing for plugins 48.408ms
14:26:23 Finished loading plugins from C:\ProgramData\Analog Devices\ACE\Plugins in 2141.318ms
14:26:24 Starting IIO Controller search
14:26:25 Details.txt file not found for drive C:\!
14:26:26 Downloading swdownloads.analog.com/.../latest_version.ini to C:\Users\systems-shared\AppData\Local\Analog Devices\ACE\Updater\latest_version.ini using WebClient.
14:26:27 Thread #12, ran Hardware.IIOSupport.FindContextUris -
14:26:27 No tinyiiod compatible devices found
14:26:27 Trying to create a new context for device at ip:plnx-navassa-6.local
14:26:27 Thread #12, ran Hardware.IIOSupport.CreateIIOContext -
14:26:27 Failed to get controller board info from hw_carrier attribute. Using Generic IIO Controller Board
14:26:27 Could not read IIO context attribute "hw_mezzanine". EEPROM ID is not available.
14:26:27 Failed to build system info due to exception: Object reference not set to an instance of an object.
14:26:27 Failed to build system information for IIOControllerBoardGeneric
14:26:27 Failed to build system info for ip:plnx-navassa-6.local
14:26:27 Unhandled application exception:
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.NullReferenceException: Object reference not set to an instance of an object.
   at AnalogDevices.Csa.Hardware.UI.ViewModels.AttachedHardwareViewModel.<>c__DisplayClass112_0.<CheckMultipleDetections>b__0(IController ctrl)
   at System.Linq.Enumerable.WhereListIterator`1.MoveNext()
   at System.Linq.Buffer`1..ctor(IEnumerable`1 source)
   at System.Linq.Enumerable.ToArray[TSource](IEnumerable`1 source)
   at AnalogDevices.Csa.Hardware.UI.ViewModels.AttachedHardwareViewModel.CheckMultipleDetections(List`1 controllers)
   at AnalogDevices.Csa.Hardware.UI.ViewModels.AttachedHardwareViewModel.RefreshHardwareItems()
   at AnalogDevices.Csa.Hardware.UI.ViewModels.AttachedHardwareViewModel.ControllerListChanged(Object sender, EventArgs e)
   at AnalogDevices.Csa.UI.Services.UISafeEventMediator.DoRaiseHandler[TEventArgs](EventHandlerObject`1 handler, Object sender, TEventArgs eventArgs)
   at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
   at System.Delegate.DynamicInvokeImpl(Object[] args)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
   at System.Windows.Threading.DispatcherOperation.InvokeImpl()
   at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.ProcessQueue()
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
   at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
   at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
   at System.Windows.Application.RunDispatcher(Object ignore)
   at System.Windows.Application.RunInternal(Window window)
   at AnalogDevices.Csa.App.Wpf.Program.Main()
14:26:27 Logging Stopped - 11/16/2023 2:26:27 PM
14:26:27 Application RunDuration = 0:00:00:08.3772324
14:26:27 Application PeakPhysicalMemory = 325,705,728
14:26:27 Application PeakVirtualMemory = 5,628,645,376
