ACE ver 1.29.3270.1441 will not open properly. Like case below , it appears for 30-60 seconds, but does not open. My lab PC DOES NOT have internet connection. Can I get a version that can be installed and run offline ??? https://ez.analog.com/ace-evaluat
Product Number: ACE
Software Version: 1.29.3270.1441
13:32:30 Logging Started - 10/30/2023 1:32:30 PM
13:32:30 Analysis | Control | Evaluation 1.29.3270.1441
13:32:30 Using .NET Framework 4.8.3928.0
13:32:30 Loading from path C:\Program Files (x86)\Analog Devices\ACE\ACE.exe
13:32:30 Checking command line for DEBUGFROM option...
13:32:30 - Debugging path is
13:33:01 Assembly AnalogDevices.Csa.UI.Rad.dll cannot be authenticated.
PartialChain: A certificate chain could not be built to a trusted root authority.
13:33:01 Assembly AnalogDevices.Csa.App.DataInstallers.dll cannot be authenticated.
13:33:01 Assembly AnalogDevices.Csa.App.DeviceApiInstallers.dll cannot be authenticated.
13:33:01 Assembly AnalogDevices.Csa.App.Installers.dll cannot be authenticated.
13:33:01 Assembly AnalogDevices.Csa.VectorGenerator.UI.dll cannot be authenticated.
13:33:01 AceCore is setting environment variables
13:33:01 AceCore is setting required default culture
13:33:01 AceCore is initializing the IOC container
13:33:01 AceCore is adding facilities
13:33:01 AceCore is registering components
13:33:01 Error registering ACE core components:
Castle.MicroKernel.Resolvers.DependencyResolverException: Missing dependency.
Component AnalogDevices.Csa.CastleSupport.Plugins.Extensions.WindsorExtensionPointManager has a dependency on AnalogDevices.Csa.Interfaces.IXElementInfo, which could not be resolved.
Make sure the dependency is correctly registered in the container as a service, or provided as inline argument.
at Castle.MicroKernel.Resolvers.DefaultDependencyResolver.ResolveFromKernelByType(CreationContext context, ComponentModel model, DependencyModel dependency)
at Castle.MicroKernel.Resolvers.DefaultDependencyResolver.ResolveFromKernel(CreationContext context, ComponentModel model, DependencyModel dependency)
at Castle.MicroKernel.Resolvers.DefaultDependencyResolver.TryResolveCore(CreationContext context, ISubDependencyResolver contextHandlerResolver, ComponentModel model, DependencyModel dependency, Object& value)
at Castle.MicroKernel.Resolvers.DefaultDependencyResolver.Resolve(CreationContext context, ISubDependencyResolver contextHandlerResolver, ComponentModel model, DependencyModel dependency)
at Castle.MicroKernel.ComponentActivator.DefaultComponentActivator.CreateConstructorArguments(ConstructorCandidate constructor, CreationContext context)
at Castle.MicroKernel.ComponentActivator.DefaultComponentActivator.Instantiate(CreationContext context)
at Castle.MicroKernel.ComponentActivator.DefaultComponentActivator.InternalCreate(CreationContext context)
at Castle.MicroKernel.ComponentActivator.AbstractComponentActivator.Create(CreationContext context, Burden burden)
at Castle.MicroKernel.Lifestyle.AbstractLifestyleManager.CreateInstance(CreationContext context, Boolean trackedExternally)
at Castle.MicroKernel.Lifestyle.SingletonLifestyleManager.Resolve(CreationContext context, IReleasePolicy releasePolicy)
at Castle.MicroKernel.Handlers.DefaultHandler.ResolveCore(CreationContext context, Boolean requiresDecommission, Boolean instanceRequired, Burden& burden)
at Castle.MicroKernel.Handlers.DefaultHandler.Resolve(CreationContext context, Boolean instanceRequired)
at Castle.MicroKernel.Handlers.AbstractHandler.Resolve(CreationContext context)
at Castle.Facilities.Startable.StartFlag.Start(IHandler handler)
at Castle.Facilities.Startable.StartFlag.StartAll()
at Castle.Facilities.Startable.StartableFacility.DeferredStartFlag.Signal()
at Castle.Facilities.Startable.StartableFacility.DeferredStartFlag.<Init>b__1_0(Object <p0>, EventArgs <p1>)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at Castle.MicroKernel.DefaultKernel.RaiseRegistrationCompleted()
at Castle.MicroKernel.DefaultKernel.OptimizeDependencyResolutionDisposable.Dispose()
at Castle.Windsor.WindsorContainer.Install(IWindsorInstaller[] installers)
at AnalogDevices.Csa.App.Installers.Ace.AceCore.RegisterComponents(IEnumerable`1 installers)
13:33:01 System.InvalidOperationException: Error registering ACE core components: Missing dependency.
Make sure the dependency is correctly registered in the container as a service, or provided as inline argument. ---> Castle.MicroKernel.Resolvers.DependencyResolverException: Missing dependency.
--- End of inner exception stack trace ---
at AnalogDevices.Csa.App.Installers.Ace.AceCore.RegisterComponents()
at AnalogDevices.Csa.App.Installers.Ace.AceCore.Initialize()
13:33:01 Unhandled application exception:
at AnalogDevices.Csa.App.Installers.Ace.AceCore.Resolve[T](String componentId)
at AnalogDevices.Csa.App.Wpf.CsaApplication.OnStartup(StartupEventArgs args)
at System.Windows.Application.<.ctor>b__1_0(Object unused)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
at System.Windows.Application.RunDispatcher(Object ignore)
at System.Windows.Application.RunInternal(Window window)
at System.Windows.Application.Run(Window window)
at AnalogDevices.Csa.App.Wpf.Program.Main()
13:33:01 Logging Stopped - 10/30/2023 1:33:01 PM
13:33:01 Application RunDuration = 0:00:00:31.8420804
13:33:01 Application PeakPhysicalMemory = 94,535,680
13:33:01 Application PeakVirtualMemory = 490,741,760
13:33:01 UsageLogger cannot log because IUsageLoggingProvider isn't defined
    We have prepare an article on the wiki for the issue you appear to be having: https://wiki.analog.com/resources/tools-software/ace/knownissues#ace_offline_installation_application_won_t_start
    Can you follow the steps on that page to try and address the issue? It is likely not specific to the 1.29 release version, this happens when the certs on the offline machine are out of date. Usually the standard solution for this would be to update the OS on the windows machine to include their updated root certs etc. The solution outlined in this article worked when reproduced on a local lab machine with no internet access but it was tricky to track down. It's been successful for other users as well, but it's possible the list of certs checked was not exhaustive and a machine could have a unique issue.
    Try this first to see if we can address the specific issue here:
    "PartialChain: A certificate chain could not be built to a trusted root authority."
  •  I ran the latest cert , and now ACE opens. BUT it needs the specific ADF4372 plug in, and that is not being installed. Are the other steps relevant for this ?? Attached is the appData log file.
    AppTrace_Nov1.log
    I have not tried the steps belwow - not sure I can !!
    Glad to hear that got you back up and running with ACE. There are only a select few plug-ins installed in the initial installer pack. To install any new plug-ins offline you will need to get the product ACEZIP file. I had a look at the product you mentioned above, under the software section of the EVAL board page you will see a link to the ACEZIP file for the plug-in: EVAL-ADF4372 Evaluation Board | Analog Devices assuming that this is the correct version you are looking for. Can you try installing the plug-in using the ACEZIP? If you were looking for details on how to install ACEZIP files you can use this wiki article: https://wiki.analog.com/resources/tools-software/ace/userguide/quickstart?s[]=acezip#installing_a_plug-in
