Can I reduce data capture of ADC to just one channel?
Product Number: EVAL-AD9083
Software Version: ACE
We are using the ADS8-V3EBZ together with the EVAL-AD9083 to acquire large data sets. Is it possible to just save the data of one ADC channel to the .bin ore .csv file with "AsyncRawCaptureToFile" or "PullAllCaptureDataToFile"?
    The AsyncRawCaptureToFile and PullAllCaptureDataToFile work with the current data in the DataStore in your analysis node. So firstly, does the plug-in allow you to specify which channels are enabled in the GUI in some way?
    If you turn off the channels being captured in the plug-in then these transactions should only capture/pull the data from those channels it finds in the current channel sequence. if you are not seeing this behaviour but the plug-in is configured as such it may be an issue in the plug-in or default channel sequence potentially.
  • Hi
    I can choose between 8 and 16 channel in the GUI. Probably channel wise is not possible since JESD204  just capture the 8 or 16 of them. I will try to configure the memory map directly if possible.
    Regards
    Daniel
